RS124XP
RS124XP
    RUNIC(润石)
    SOIC14
    RS124XP
RS124XP 数据手册
RS121S, RS122S RS121, RS122, RS124 150kHz, Rail-to-Rail I/O CMOS Operational Amplifier FEATURES DESCRIPTION • GAIN BANDWIDTH:150kHz • RAIL-TO-RAIL INPUT AND OUTPUT 0.8mV Typical Vos • • INPUT VOLTAGE RANGE: -0.1V to +5.6V with Vs = 5.5V SUPPLY RANGE: +2.5V to +5.5V • SHUTDOWN: RS121S/RS122S • SPECIFIED UP TO +125°C • MicroSIZE The RS121, RS122, RS124, RS121S, RS122S families of products offer low voltage operation and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (150kHz) and slew rate of 0.05V/us. The op-amps are unity gain stable and feature an ultra-low input bias current. The devices are ideal for sensor interfaces, active filters and portable applications. The RS121S, RS122S include a shutdown mode. Under logic control, the amplifiers can be switched from normal operation to a standby current that is less than 1uA.The RS121, RS122, RS124, RS121S, RS122S families of operational amplifiers are specified at the full temperature range of −40°C to +125°C under single or dual power supplies of 2.5V to 5.5V. PACKAGES: SOT23-5, SOT23-6 APPLICATIONS • • SENSORS PHOTODIODE AMPLIFICATION • ACTIVE FILTERS • TEST EQUIPMENT • DRIVING A/D CONVERTERS PIN CONFIGURATIONS + - 4 -IN +IN 6 1 5 2 3 + - 4 NC V+ -IN EN +IN -IN V- 8 1 2 3 7 6 5 4 NC V+ OUT 1 -IN A 2 +IN A 3 V- 4 En A 5 NC SOT23-6 SOT23-5 OUT A - 10 V+ 9 OUT B - 8 -IN B + V- 2 3 OUT 7 +IN B 6 En B 14 OUT D 13 -IN D A + +IN V+ + V- 5 1 RS121 - OUT RS122S RS121S RS121 B SOIC-8(SOP8),MSOP-8 MSOP-10 RS121B NC 1 -IN 2 OUT +IN 3 V- 4 V+ + V- 2 - IN 3 4 8 EN 7 V+ + 5 1 - + IN RS122 RS121S 6 OUT 5 NC RS124 OUT A 1 8 V+ OUT A 1 -IN A 2 7 OUTB -IN A 2 +IN A 3 6 -IN B +IN A 3 12 +IN D V- 4 5 +IN B V+ 4 11 V- +IN B 5 10 +IN C 9 -IN C 8 OUT C SOT23-5 + A B+ SOIC-8(SOP8) SOIC-8(SOP8),MSOP-8 Note: NC indicates no internal connection -IN B 6 OUT B 7 A - + - + B D + - + C SOIC-14(SOP14),TSSOP-14 REV B.3 1 www.run-ic.com RS121S, RS122S RS121, RS122, RS124 ABSOLUTE MAXIMUM RATINGS (1) Supply Voltage, V+ to V-...............................................7.0V Input Terminals, Voltage (2) …………... – 0.5 to (V+) + 0.5V Current (2)…………………....…..... ±10mA Storage Temperature ……….…………… −65°C to +150°C Operating Temperature ……….………… −40°C to +125°C Junction Temperature................................................150°C Package Thermal Resistance @ TA = +25°C SOT23-5, SOT23-6………………….………………200°C/W MSOP-10, SOIC-8 …………………….…………... 150°C/W SOIC-14, TSSOP-14………….……….……………100°C/W Lead Temperature (Soldering, 10s) ……………........260°C ESD Susceptibility HBM …......................................................................5000V MM ……………………….........………………...……….400V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be current-limited to 10mA or less. PACKAGE/ORDERING INFORMATION 2 www.run-ic.com RS121S, RS122S RS121, RS122, RS124 ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=5V, RL = 500kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER CONDITIONS TJ RS121S, RS122S, RS121, RS122, RS124 MIN TYP MAX UNIT 5.5 V POWER SUPPLY Vs Operating Voltage Range 25C IQ Quiescent Current/Amplifier 25C PSRR Power-Supply Rejection Ratio Vs=2.5V to 5.5V, Vcm=(V-)+0.5V 25C 2.5 68 7 uA 95 dB INPUT Vos Input Offset Voltage 25C 0.8 5 mV IB Input Bias Current 25C 1 10 pA Ios Input Offset Current 25C 1 10 pA 5.6 V Vcm CMRR Common-Mode Voltage Range Vs= 5.5V 25C -0.1 Vs= 5.5V, Vcm =-0.1V to 4V 25C 72 95 Common-Mode Rejection Ratio dB Vs= 5.5V, Vcm =-0.1V to 5.6V 25C 62 90 RL=500KΩ, Vo= 0.015V to 4.985V 25C 92 110 RL=100KΩ, Vo= 0.1V to 4.9V 25C 90 110 RL=2KΩ 25C 3 mV 25C 25 mA Slew Rate 25C 0.05 V/us Gain-Bandwidth Product 25C 0.15 MHz f = 1KHz 25C 77 nV/√Hz f = 10KHz 25C 39 nV/√Hz 25C
RS124XP 价格&库存
很抱歉,暂时无法提供与“RS124XP”相匹配的价格&库存,您可以联系我们找货
RS124XP
  • 1+1.77120
库存:35
