TP5552-SR
TP5552-SR
    3PEAK(思瑞浦)
    SOIC-8
    超低噪声、3.5MHZ、零漂移、轨到轨输入输出运算放大器
TP5552-SR 数据手册
3PEAK TP5551/TP5552 / TP5554 Ultra Low Noise, 3.5MHz, Zero Drift, RRIO Op-amps Description Features  Low Offset Voltage: 5μV(max)  Zero Drift: 0.05 µV/°C(max)  No 1/f Noise Corner Down to 0.1Hz - Input Noise Voltage . . . . . . . .. .15 nV/√Hz @ 1kHz -0.1Hz to 10Hz Noise Voltage . . . . . . . . . . 350nVP-P  Slew Rate: 2.5 V/μs  Bandwidth: 3.5MHz  Low Supply Current: 500A per Amplifier  Low Input Bias Current: 50pA Typical  Rail-to-Rail Output Voltage Range  High gain, CMRR, PSRR: 130 dB  7K HBM ESD Rating  –40°C to 125°C Operation Range The family of amplifier are single/dual/quad chopper stabilized zero-drift operational amplifier optimize for single or dual supply operation from 1.8V to 5.5V and ±0.9V to ±2.75V. TP555X features very low input offset voltage and low noise with no 1/f noise corner down to 0.1Hz. The TP555X is designed to have ultra low offset voltage and offset temperature drift, wide gain bandwidth and rail-to-rail input/output swing while minimizing power consumption. This family amp TP555X can provide very low offset voltage(max 5μV) and near-zero drift over time and temperature with excellent CMRR and PSRR. The TP5551(single version) is available in SOT23-5, SC70-5 and SO-8 packages. The TP5552(dual version) is offered in MOSP-8, SO-8 package. The TP5554(quad version) is available in TSSOP-14,SO-14 package. All versions are specified for operation from -40°C to 125°C. 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. Applications  Medical Instrumentation  Temperature Measurements  Precision current sensing  Precision Low Drift, Low Frequency ADC Drivers  Process Control Systems  Precision Voltage Reference Buffers Related Zero-Drift RRO Op-amps eN @1kHz ( nV/√Hz ) GBW Single Vos(Max) Supply Current TP555X 5μV 560 μA 12 3.5 MHz TP553X 10μV 34 μA 55 350kHz Pin Configuration (Top View) TP5551 SOT23-5/SC70-5 (-T and -C Suffixes) 4 -IN TP5551U SOT23-5/SC70-5 (-T and -C Suffixes) 2.5 2 2.25 1.5 OUT 1.75 4 1 0 1.25 3 5 0 -IN 10 -1 2 V+ 15 -1.5 V- 5 20 -1.25 1 A +IN 25 -2 3 30 -1.75 +IN V+ -2.5 2 5 A -2.25 V- 35 Population Of Amplifiers 1 OUT Offset Voltage Distribution Offset Voltage(μV) Pin Configuration (Top View) www.3peakic.com.cn REV B 1 TP5551 / TP5552/TP5554 Ultra Low Noise, 3.5MHz, Zero Drift, RRIO Op-amps NC TP5551 TP5552 TP5554 8-Pin SOIC (-S Suffix) 8-Pin SOIC/MSOP (-S and -V Suffixes) 14-Pin SOIC/TSSOP (-S and -T Suffixes) 1 8 1 Out A NC ﹣In 2 7 ﹢Vs ﹣In A 2 ﹢In 3 6 Out ﹢In A 3 ﹣Vs 4 5 A Out A 1 14 Out D 7 Out B ﹣In A 2 13 ﹣In D 6 ﹣In B ﹢In A 3 12 ﹢In D ﹢In B ﹢Vs 4 11 ﹣Vs ﹢In B 5 10 ﹢In C ﹣In B 6 9 ﹣In C Out B 7 8 Out C B 4 ﹣Vs NC ﹢Vs 8 5 A D B C Order Information Model Name TP5551 TP5551U TP5552 TP5554 Order Number Package MSL Transport Media, Quantity Marking Information TP5551-TR SOT23-5 3 Tape and Reel, 3000 E51T TP5551L1-TR SOT23-5 1 Tape and Reel, 3000 E51T TP5551-CR SC70-5 3 Tape and Reel, 3000 51C TP5551-SR SO-8 3 Tape and Reel, 4000 TP5551 TP5551U-TR SOT23-5 3 Tape and Reel, 3000 E51U TP5551U-CR SC70-5 3 51V TP5552-SR SO-8 3 Tape and Reel, 3000 Tape and Reel, 4000 TP5552 TP5552L1-SR SO-8 1 Tape and Reel, 4000 TP5552 TP5552-VR MSOP-8 3 Tape and Reel, 3000 TP5552 TP5554-SR SO-14 3 Tape and Reel, 2500 TP5554 TP5554-TR TSSOP-14 3 Tape and Reel, 3000 TP5554 Absolute Maximum Ratings Note 1 Supply Voltage: .....................................................7V – Current at Supply Pins……………............... ±50mA Input Voltage: ....................... ……V – 0.3 to V + 0.3 Operating Temperature Range.......–40°C to 125°C Input Current: +IN, –IN Note 2........................... ±20mA Maximum Junction Temperature................... 150°C Output Current: OUT...................................... ±60mA Storage Temperature Range.......... –65°C to 150°C …....... Indefinite Lead Temperature (Soldering, 10 sec) ......... 260°C Output Short-Circuit Duration Note 3 + Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power supply, the input current should be limited to less than 10mA. Note 3: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection 2 Symbol Parameter Condition HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001 7 kV CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002 2 kV REV B Minimum Level Unit www.3peakic.com.cn TP5551 / TP5552/TP5554 Ultra Low Noise, 3.5MHz, Zero Drift, RRIO Op-amps Electrical Characteristics At TA = 27°C, VDD=5V, RL=10K, Vcm=VDD/2, unless otherwise noted. VDD=5V, PARAMETER SYMBOL VDD CONDITIONS MAX UNITS 5.5 V 1400 μA TP5551, TA = -40°C to 85°C 1600 μA TP5551, TA = -40°C to 125°C 1750 μA 950 μA TP5552/4, TA = -40°C to 85°C 1150 μA TP5552/4, TA = -40°C to 125°C 1300 μA ±5 μV ±10 μV 0.05 μV/°C Supply Voltage Range MIN 1.8 TP5551 IQ Quiescent current per amplifier TYP 1200 TP5552/4 550 ±1 VOS input Offset Voltage TA = -40°C to 125°C dVos/dT vs temperature PSRR vs power supply 0.008 Vs=+1.8V to +5.5V 95 Vs=+1.8V to +5.5V, TA = -40°C to 125°C 85 dB input voltage noise, f=0.01Hz to 1Hz 0.1 μVpp input voltage noise, f=0.1Hz to 10Hz 0.35 μVpp Input voltage noise density, f=1kHz 15 nV/√Hz 3 2 ±50 ±200 ±100 pF pF pA pA pA V dB dB VN (p-p) VN IOS VCM CMRR Input capacitor Differential Input capacitor Common-Mode Input Current Over temperature Input offset current Common-mode voltage range Common-mode rejection ratio CMRR Common-mode rejection ratio VO Output Voltage Swing from rail ISC GBW SR tor ts Short-circuit current Unity Gain Bandwidth Slew rate Overload recovery time Settling time to 0.01% CIN IB AVO θJA Open-Loop Voltage Gain Thermal Resistance Junction to Ambient www.3peakic.com.cn VS=5V, VCM = 0.5V to 4.5V VS=5V, VCM = 0V to 5V VS=5V, VCM = 0V to 5V, TA = -40°C to 125°C RL=10kΩ RL=10kΩ, TA = -40°C to 125°C CL=100pF G=+1, CL=100pF G=-10 CL=100pF (V-)+100mV
TP5552-SR 价格&库存
很抱歉,暂时无法提供与“TP5552-SR”相匹配的价格&库存,您可以联系我们找货
TP5552-SR
    • 1+6.22080
    • 100+4.98960
    • 1000+4.44960
    • 2000+4.19040
    • 4000+3.99600
    库存:1252
    TP5552-SR
    • 1+13.82400
    • 10+11.34000
    • 30+9.93600
    • 100+8.53200
    • 500+7.88400
    • 1000+7.34400
    库存:4765
    TP5552-SR
    • 1+2.81750
    • 100+2.25400
    库存:1388
    TP5552-SR
    • 1+20.295431+2.63745
    • 10+15.0006910+1.94938
    • 25+13.6877925+1.77877
    • 100+12.24075100+1.59072
    • 250+11.55102250+1.50109
    • 500+11.13560500+1.44710
    • 1000+10.793401000+1.40263
    库存:1455
    TP5552-SR
    • 1+11.27000
    • 10+8.90820
    • 30+7.72240
    • 100+6.54640
    库存:397
    TP5552-SR
    • 4000+11.278904000+1.46573
    库存:1455
