SS18
SS18
    HOTTECH(合科泰)
    SMA(DO-214AC)
    电压:80V 电流:1A
SS18 数据手册
SK12~SK110(SS12~SS110) SCHOTTKY BARRIER DIODE FEATURES  Small Surface Mount device  Low power loss, high efficiency  High forward surge current capability  For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications SMA MECHANICAL DATA     Case: SMA(DO-214AC) Case Material: Molded Plastic. UL flammability Classification Rating: 94V-0 Weight: 0.065 grams (approximate) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS(TA = 25°C unless otherwise noted) Symbol SK12 SK13 SK14 SK15 SK16 SK18 SK110 UNIT (SS12) (SS13) (SS14) (SS15) (SS16) (SS18) (SS110) Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 100 V Maximum RMS voltage VRMS 14 21 28 35 42 56 70 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 100 V Maximum average forward rectified current IF(AV) 1 A Peak forward surge current 8.3 ms single half sine-wave superimposed on rated load IFSM 30 A Maximum instantaneous forwad voltage at 1.0A VF Maximum DC reverse current at Rated DC blocking voltage TA = 25 ć TA = 100ć IR 0.55 0.70 0.85 V 0.5 mA 5 mA Voltage rate of change (rated VR) dv/dt 10000 V/µs Thermal resistance from junction to ambient R©JA 88 ć/ W TJ, TSTG – 65 to +150 ć Operating junction and storage temperature range ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 1/4 SK12~SK110(SS12~SS110) SCHOTTKY BARRIER DIODE Typical Characteristics ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 2/4 SK12~SK110(SS12~SS110) SCHOTTKY BARRIER DIODE SMA Package Outline Dimensions Symbol Dimensions In Millimeters Min. Max. A 2.20 B Dimensions In Inches Max. 2.80 Min. 0.086 1.30 1.70 0.051 0.067 C 4.70 5.30 0.185 0.209 D 1.70 2.55 0.067 0.100 E 0.90 1.50 0.035 0.059 F 0.90 1.50 0.035 0.059 0.110 SMA Suggested Pad Layout Note: 1.Controlling dimension: in millimeters 2.General tolerance: ±0.05mm 3.The pad layout is for reference purposes only ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 3/4 SK12~SK110(SS12~SS110) SCHOTTKY BARRIER DIODE SMA Tape and Reel SMA Embossed Carrier Tape DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P0 P P1 W SMA 2.89 5.35 2.68 Ø1.50 1.75 5.50 4.00 4.00 2.00 12.00 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 SMA Tape Leader and Trailer SMA Reel DIMENSIONS ARE IN MILLIMETER REEL OPTION 7’’ DIA TOLERANCE D D1 D2 G H I W1 W2 Ø178 54.40 13.00 R78 R25.60 R6.50 12.40 17.60 ±2 ±1 ±1 ±1 ±1 ±1 ±1 ±1 ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 4/4
很抱歉,暂时无法提供与“SS18”相匹配的价格&库存,您可以联系我们找货
