SCT63140FMAR
SCT63140FMAR
    SCT(芯洲科技)
    FCQFN15_3X3MM
    SCT63140是一款高度集成的电源管理IC,可实现符合WPC规范的无线充电发射系统的高性能、高效率和高性价比,支持最高15W的功率传输,可与无线专用控制器或基于通用MCU的发射控制器配合使用。该器件...
SCT63140FMAR 数据手册
SCT63140 SILICONCONTENT TECHNOLOGY 15W High-Integration, High-Efficiency PMIC for Wireless Power Transmitter FEATURES DESCRIPTION • • • • The SCT63140 is a highly integrated Power Management IC allows achieving high performance, high efficiency and cost effectiveness of wireless power transmitter system compliant with WPC specification to support up to 15W power transfer, working with a wireless application specific controller or a general MCU based transmitter controller. • • • • • • • • • VIN Input Voltage Range: 4.2V-20V PVIN Input Voltage Range: 1V-15V Up to 15W Power Transfer Integrated Full-Bridge Power Stage with 16-mΩ Rdson of Power MOSFETs Integrated 5V-100mA LDO Optimized for EMI Reduction Build-in 3.3V-100mA LDO Integrated Lossless Input Current Sensor with ±2% accuracy for FOD and current Demodulation 3.3V and 5V PWM Signal Logic Compatible Input Under-Voltage Lockout Over Current Protection Over Temperature Protection 3mm*3mm QFN-15L Package APPLICATIONS • • • WPC Compliant Wireless Chargers of 5W to 15W Systems for Mobiles, Tablets and Wearable Devices General Wireless Power Transmitters for Consumer, Industrial and Medical Equipment Proprietary Wireless Chargers and Transmitters This device integrates a 4-MOSFETs full bridge power stage,gate drivers, a 5V LDO, a 3.3V LDO and input current sensor for both system efficiency and easy-to-use. The proprietary gate driving scheme optimizes the performance of EMI reduction to save the system cost and design. The proprietary lossless current sensing circuitry with ±2% accuracy monitors input current of full bridge to support Foreign Object Detection FOD and current demodulation. The buildin 5V and 3.3V low dropout regulator LDO can provide power supplies to transmitter controller and external circuitries. The SCT63140 features input Under-Voltage Lockout UVLO, over current, short circuit protection, and over temperature protection. The SCT63140 is available in a compact 3mm*3mm QFN package. TYPICAL APPLICATION PVIN Power Transfer Efficiency with 10W RX @ Vout=9V PVIN1 C1 PGND C2 PVIN2 90.00 BST1 SW1 C8 80.00 70.00 VIN C3 VIN GND SW2 BST2 C9 5V VDD C10 EN PWM1 3.3V V3P3 C11 PWM2 ISNS Efficiency(%) SCT63140 60.00 50.00 40.00 30.00 20.00 10.00 Vout=9V 0.00 0 2 4 6 8 10 Output Power(W) For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved SCT63140 DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING (1) SCT63140FMA (1) For Tape & Reel, Add Suffix R (e.g. SCT63140FMAR) PACKAGE DISCRIPTION 3140 QFN-15L ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (1) Over operating free-air temperature unless otherwise noted DESCRIPTION MIN MAX UNIT VIN -0.3 24 V PVIN1, PVIN2 -0.3 17 V SW1,SW2 -1 17 V BST1,BST2 -0.3 23 V BST1-SW1,BST2-SW2 VDD, V3P3, ISNS, EN PWM1, PWM2 (2) Operating junction temperature TJ -0.3 6 V -0.3 6 V -40 125 °C PWM1 PWM2 15 Storage temperature TSTG -65 150 PGND PVIN2 EN 13 12 1 11 BST1 10 SW1 9 SW2 8 BST2 2 3 °C CONFIDEN TIAL P relimi nary D atashe et (1) PVIN1 14 ISNS 4 5 6 7 VIN GND V3V VDD Figure 1. Top view 15-Lead QFN 3mm*3mm Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime. (2) PIN FUNCTIONS NAME NO. PVIN1 1 PGND 2 PVIN2 3 VIN 4 GND V3P3 5 6 PIN FUNCTION Input supply voltage of half-bridge FETs Q1 and Q2. Connected to the drain of high side FET Q1. a local bypass capacitor from PVIN1 pin to PGND pin should be added. Path from PVIN1 pin to high frequency bypass capacitor and PGND must be as short as possible. PGND is the common power ground of the full bridge, connected to the source terminal of low side FETs Q2 and Q4 internally. Input supply voltage of half-bridge FETs Q3 and Q4. Connected to the drain of high side FET Q1. Local bypass capacitor from PVIN1 pin to PGND pin should be added. Path from PVIN1 pin to high frequency bypass capacitor and PGND must be as short as possible. Input supply voltage of the 5V LDO. Add a local bypass capacitor from VIN pin to GND pin. Path from VIN pin to high frequency bypass capacitor and GND must be as short as possible. Ground. 3.3V LDO output. Connect 2.2uF capacitor to ground. 2 For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved SCT63140 VDD 7 BST2 8 SW2 9 SW1 10 BST1 11 EN 12 ISNS 13 PWM2 14 PWM1 15 Output voltage of the 5V LDO. Connect 2.2uF capacitor from this pin to GND pin. VDD is also the input power supply for gate driver of power stage and the 3.3V LDO. Power supply bias for the high-side power MOSFET gate driver of Q3 as shown in the block diagram. Connect a 0.1uF capacitor from BST2 pin to SW2 pin. Switching node of the half-bridge FETs Q3 and Q4. Switching node of the half-bridge FETs Q1 and Q2. Power supply bias for the high-side power MOSFET gate driver of Q1 as shown in the block diagram. Connect a 0.1uF capacitor from BST1 pin to SW1 pin. Enable pin. Pull the pin high or keep it floating to enable the IC. When the device is enabled, 5V LDO will start to work if VIN higher than UVLO threshold. After VDD is established, power stage responds to PWM input logic then. Current detection output. The voltage of the pin is proportional to the input current. PWM logic input to the FET Q3 and Q4 as shown in the Block Diagram. Logic HIGH turns off the low-side FET Q4, and turns on the high-side FET Q3. Logic LOW turns off the high-side FET Q3 and turns on the low-side FET Q4. When PWM input is in the tristate mode, both Q3 and Q4 are turned off. PWM logic input to the FET Q1 and Q2 as shown in the Block Diagram. Logic HIGH turns off the low-side FET Q2, and turns on the high-side FET Q1. Logic LOW turns off the high-side FET Q1 and turns on the low-side FET Q2. When PWM input is in the tristate mode, both Q1 and Q2 are turned off. RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER VIN DEFINITION CONFIDEN TIAL P relimi anry D atashe et Input voltage range Input voltage range Operating junction temperature PVIN TJ MIN MAX UNIT 4.2 1 -40 20 15 125 V V °C MIN MAX UNIT -2 +2 kV -1 +1 kV ESD RATINGS PARAMETER VESD DEFINITION Human Body Model(HBM), per ANSI-JEDEC-JS-001-2014 (1) specification, all pins Charged Device Model(CDM), per ANSI-JEDEC-JS-002(2) 2014specification, all pins (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. THERMAL INFORMATION PARAMETER THERMAL METRIC RθJA Junction to ambient thermal resistance RθJC Junction to case thermal resistance (1) (1) DFN-19L 48 45 UNIT °C/W (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT63140 is mounted, thermal pad size, and external environmental factors. The PCB board is a heat sink that is soldered to the leads of the SCT63140. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved 3 SCT63140 ELECTRICAL CHARACTERISTICS VPVIN1=VPIN2=12V, VDD=5V, typical value is tested under 25°C. SYMBOL PARAMETER TEST CONDITION Input supplies and UVLO VIN Operating input voltage PVIN ISHDN ISHDN_PVIN Shutdown current from PVIN1,PVIN2 IVINQ Quiescent current from VIN pin IPVINQ Quiescent current from PVIN1, PVIN2 VIN_UVLO VDD_UVLO TYP 4.2 Operating input voltage VIN UVLO Threshold Hysteresis VDD UVLO Threshold Hysteresis Shutdown current from VIN pin MIN 1 VIN rising VDD rising EN=0V, VIN=12V EN=0V, PVIN=12V EN floating, VDD=5V, no loading on LDO EN floating, VDD=5V, no loading on LDO MAX UNIT 20 V 15 V 3.6 400 3.8 440 1 3 V mV V mV μA 1 3 uA 300 uA 50 uA ENABLE INPUTS and PWM logic VEN_H Enable high threshold 1.18 V VEN_L Enable low threshold 1.1 V VIH PWM1, PWM2 Logic level high V3P3=3.3V, VDD=5V VIL PWM1, PWM2 Logic level low V3P3=3.3V, VDD=5V VTS PWM1, PWM2 Tri-state voltage 2.65 V 1.2 0.55 V 2 V CONFIDEN TIAL P relimi nary D atashe et Power Stage VBST1-VSW1=5V, VBST2VSW2=5V VDD=5V RDSON_Q1 Q3 High-side MOSFET Q1 Q3 on-resistance RDSON_Q2 Q4 Low-side MOSFET Q2 Q4 on-resistance ILIM How-side current limit threshold 5V LDO VDD Output voltage IDD Output current Capability 3.3V LDO V3P3 Output voltage Cout=1uF, VDD=5V I3P3 Output current Capability VDD=5V ISC Short current 16 mΩ 16 mΩ 12.5 Cout=10uF 4.95 5 A 5.05 100 3.267 3.3 V mA 3.333 V 100 mA 50 mA Current Sense VISNS0 Voltage with no input current RISNS Input current to output voltage gain IPGND=0A ,Tj=25℃ PWM1=PWM2=0V VISNS=VISNS0+IPGND*RISNS VISNS1 Voltage with 0.6A input current VISNS2 0.585 0.6 0.615 V 0.98 1 1.02 V/A IPVIN=0.6A, Tj=25℃ 1.176 1.2 1.224 V Voltage with 1A input current IPVIN=1A, Tj=25℃ 1.568 1.6 1.632 V Thermal shutdown threshold Hysteresis TJ rising Protection TSD 4 For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. 155 35 All Rights Reserved °C °C SCT63140 90.00 90.00 80.00 80.00 70.00 70.00 60.00 60.00 Efficiency(%) Efficiency(%) TYPICAL CHARACTERISTICS 50.00 40.00 30.00 50.00 40.00 30.00 20.00 20.00 10.00 10.00 Vout=5V Vout=9V 0.00 0.00 0 1 2 3 4 0 5 2 4 Figure 2. Transfer Efficiency with 5W RX@ Vout=5V 10 6 80.00 5 70.00 4 60.00 Vout(V) Efficiency(%) 8 Figure 3. Transfer Efficiency with 10W RX@ Vout=9V 90.00 50.00 CONFIDEN TIAL P relimi anry D atashe et 40.00 3 2 30.00 20.00 1 10.00 Vout=12V 0 0.00 0 3 6 9 12 0 15 0.02 0.04 0.06 0.08 0.1 0.12 0.1 Iout(A) Output Power(W) Figure 5. 5V LDO Iout vs Vout Figure 4. Transfer Efficiency with 15W RX@ Vout=12V 3.5 3 3 2.7 2.4 Vsense(V) 2.5 Vout(V) 6 Output Power(W) Output Power(W) 2 1.5 1 2.1 1.8 1.5 1.2 0.5 0.9 0.6 0 0 0.05 0.1 0.15 0.2 Iout(A) Figure 6. 3.3V LDO Iout vs Vout 0.25 0.3 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 2.2 Iin(A) Figure 7. Current Sense Output Voltage vs Iin For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved 5 SCT63140 FUNCTIONAL BLOCK DIAGRAM VIN VDD 5V LDO Enable BIAS EN logic VIN UVLO Reference EN GND V3P3 VDD UVLO 3.3V LDO 3-stage logic PWM1 3-stage logic PWM2 CONFIDEN TIAL P relimi nary D atashe et PVN2 PVN1 Over Current Detection Over Current Detection BST2 BST1 Q1 Q3 SW1 VDD PWM1 Control PWM2 Control Q2 SW2 VD D Current sense I/V ISNS PGND Figure 8. Functional Block Diagram 6 For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Q4 SCT63140 OPERATION Overview The SCT63140 is a highly integrated power management unit optimized for wireless power transmitter applications. This device integrates the power functions required to a wireless power transmitter including 5V output LDO as power supply for external transmitter controller, full bridge power stage to convert DC input power to AC output for driving LC resonant circuit, lossless current sensing with ±2% accuracy, 3.3V output LDO for powering MCU. The SCT63140 has three power input pins. VIN is connected to the power FETs of 5V LDO. PVIN1 and PVIN2 are connected to the power FETs of the full bridge and conducts high currents for power transfer. VIN and PVIN1, PVIN2 can be powered separately for more flexibility of system power design. The operating voltage range for VIN is from 4.2V to 20V. An Under-voltage Lockout(UVLO) circuit monitors the voltage of VIN pin and disable the IC operation when VIN voltage falls below the UVLO threshold of 3.2V typically. The maximum operating voltage for PVIN is up to 15V while the minimum voltage accepted can be down to 1V. Another UVLO circuit also supervise the VDD voltage which is the power supply for gate drivers of full bridge MOSFETs. Full bridge will work when VDD UVLO release. Two independent PWM signals control two separate half bridge MOSFETs with internal adaptive non-overlap circuitry to prevent the shoot-through of MOSFETs in each bridge. PWM logics are compatible for both 3.3V and 5V IOs so the SCT63140 can accept PWM signal from the controller with using either 3.3V or 5V power supply. The full bridge of power MOSFETs includes proprietary designed gate driver scheme to resist switching node ringing without sacrificing MOSFET turn-on and turn-off time, which further erases high frequency radiation EMI noise caused by the MOSFETs hard switching. This allows the user to reduce the system cost and design effort for EMI reduction. CONFIDEN TIAL P relimi anry D atashe et The SCT63140 full protection features include VIN and VDD under-voltage lockout, over current protection with cycle-by-cycle current limit and hiccup mode, output hard short protection for 4-MOSFETs full bridge, current limit and current fold back at hard short for two LDOs and whole chip thermal shutdown protection. Enable and Start up Sequence When the VIN pin voltage rises above 3.6V and the EN pin voltage exceeds the enable threshold of 1.18V, the 5V output LDO enables at once. And the device disables when the VIN pin voltage falls below 3.2V or when the EN pin voltage is below 1.1V. VDD ramp up after 5V LDO works, and also the V3V. Once VDD rise up to 3.8V and V3V is higher than 3V, 4-MOSFETs full bridge allows PWM signal to control for switching. PWM input cannot control full bridge of MOSFETs if VDD drop to 3.36V or V3V drop to 2.7V. An internal 1.5uA pull up current source to EN pin allows the device enable when EN pin is floating to simply the system design. If an application requires a higher system under voltage lockout threshold, two external resistors divider(R1 and R2) in Figure 9 can be used to achieve an expected system UVLO. The UVLO rising and falling threshold can be calculated by Equation 1 and Equation 2 respectively. VIN Vrise = 1.18 ∗ �1 + Vfall R1 � − 1.5uA ∗ R R2 R1 = 1.1 ∗ �1 + � − 5.5uA ∗ R1 R2 1.5uA (1) EN (2) 4uA R1 R2 20K + 1.21V Figure 9. System UVLO by enable divider For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved 7 SCT63140 5V LDO The SCT63140 has an integrated low-dropout voltage regulator which powered from VIN and supply regulated 5V voltage on VDD pin. The output current capability is 100mA. This LDO can be used to bias the supply voltage of external transmitter controller directly. It is recommended to connect a decoupling ceramic capacitor of 1uF to 10uF to the VDD pin. Capacitor values outside of the range may cause instability of the internal linear regulator. Full bridge and PWM Control The SCT63140 integrate full bridge power stage with only 16mohm on-resistance for each power MOSFET optimized for wireless power transmitter driving the LC resonant circuit. This full bridge is able to operate in a wide switching frequency range from 20KHz to 400KHz for different applications which is completely compatible with WPC's frequency requirement from 100KHz to 205KHz. PWM1 input controls the half bridge comprised of high side MOSFET Q1 and low side MOSFET Q2, and PWM2 input controls the half bridge comprised of high side MOSFET Q3 and low side MOSFET Q4 as shown in block diagram. The PWM1 and PWM2 independently control the SW1 and SW2 duty cycle and frequency. Logic HIGH will turn off low side FET and turn on high side FET, and logic LOW will turn off high side FET and turn on low side FET. PWM1 and PWM2 also support tri-state input. When PWM input logic first enters tri-state either from logic HIGH or logic LOW, the states of its controlled FETs stay the same. If the PWM input stays in the tri-state for more than 60ns, its controlled FETs are all turned off, and the corresponding SW output becomes high impedance. The FETs stay off until the PWM logic reaches logic HIGH or logic LOW threshold. An external 100nF ceramic bootstrap capacitor between BST1 and SW1 pin powers floating high-side power MOSFET Q1's gate driver, and the other 100nF bootstrap capacitor between BST2 and SW2 pin powers for the Q2's. When low side FET is on which means SW is low, the bootstrap capacitor is charged through internal path by VDD power supply rail. CONFIDEN TIAL P relimi nary D atashe et PWM cannot been kept as high level for more than 2ms since the voltage of bootstrap capacitor will be discharged by internal leakage current if high side FET keeps on. Full Bridge Over Current Protection The SCT63140 integrates cycle-by-cycle current limit and hiccup mode for over-current protection. The current of the high side FET Q1 和 Q3 is sensed and compared to the current limit threshold during each switching cycle. If the current exceeds the threshold, 12.5A typical, the high side FET turns off immediately in present cycle to avoid current increasing even PWM signal is still kept in high level. The over current counter is incremented. If one high side FET occurs over current in 5 consecutive cycles, then all 4 internal FETs are turned off regardless of the PWM inputs. The full bridge enters hiccup mode and will attempt to restart after a time-out period of 24ms typically. Current Sense The SCT63140 has a proprietary lossless average current sensing circuit that measures the average input current of full bridge with ±2% accuracy and reports a proportional voltage directly to the ISNS pin. This voltage information on ISNS pin can be send to specialized controller or general MCU for Foreign Object Detection FOD and current demodulation. When the full bridge of MOSFETs does not work, no current flows to PGND. The DC bias voltage on ISNS pin is 600mV.This DC bias helps set up a suitable voltage bias for the following analog to digital converter in MCU or amplifier for current demodulation. The average input current to voltage conversion gain on ISNS is 1V/A. The equation 3 represent the corresponding relation for the output voltage on ISNS pin and average current to PGND from full bridge. VISNS = 600mV + IPGND ∗ 1V/A (3) 8 For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved SCT63140 3.3V LDO The SCT63140 has an integrated low-dropout voltage regulator which powered from VDD and supply regulated 3.3V voltage on V3V pin. The output current capability is 100mA. This LDO can be used to bias the supply voltage of MCU directly. It is recommended to connect a decoupling ceramic capacitor of 1uF to 10uF to the V3V pin. Capacitor values outside of the range may cause instability of the internal linear regulator. Thermal Shutdown The SCT63140 protects the device from the damage during excessive heat and power dissipation condition. Once the junction temperature exceeds 155C, the thermal sensing circuit stops two LDOs and full bridge of 4MOSFETs' working. When the junction temperature falls below 120C, then the device restarts. CONFIDEN TIAL P relimi anry D atashe et For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved 9 SCT63140 APPLICATION INFORMATION Typical Application VIN=4.2V~15V 4 C6 10uF C5 0.1uF 5 VIN PVIN1 GND PGND PVIN2 BST1 7 5V C7 2.2uF 6 3.3V C8 2.2uF SW1 VDD C2 22uF 3 C3 0.1uF C4 22uF 11 C10 0.1uF R4 C12 10 V3P3 SW2 9 8 R3 C11 EN 15 ISNS PWM1 14 R1 100K C1 0.1uF C9 0.1uF 12 PWM2 2 SCT63140 BST2 PWM1 1 13 PWM2 R2 100K CONFIDEN TIAL P relimi nary D atashe et Figure 10. Same Input to VIN and PVIN VIN=4.2V~20V 4 C6 10uF C5 0.1uF 5 PVIN1 VIN GND PGND PVIN2 BST1 7 5V C7 2.2uF 6 3.3V C8 2.2uF VDD SW1 15 PWM1 14 PWM2 R1 100K 2 C1 0.1uF C2 22uF 3 C3 0.1uF C4 22uF 11 C10 0.1uF R4 C12 10 SCT63140 V3P3 SW2 BST2 12 PVIN=1V~15V 1 9 8 C9 0.1uF R3 C11 EN PWM1 ISNS 13 PWM2 R2 100K Figure 11. Separate Input to VIN and PVIN 10 For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved SCT63140 Application Waveforms Figure 12. Power Up Figure 13. Power Up CONFIDEN TIAL P relimi anry D atashe et Figure 14. Power Down Figure 15. Power Down Figure 16. Full bridge @Vin=5V, RX=5W Figure 17. Full bridge @Vin=9V, RX=10W For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved 11 SCT63140 Layout Guideline Proper PCB layout is a critical for SCT63140’s stable and efficient operation. For better results, follow these guidelines as below: 1. 2. 3. 4. 5. Bypass capacitors from PVIN to PGND should put next to PVIN and PGND pin as close as possible especially for the two small capacitors. PGND connect to bottom layer by via between capacitors. Bypass capacitors from VIN to GND should put next to VIN and GND pin as close as possible especially for the small capacitor. Bypass capacitor for VDD place next to VDD pin. Bypass capacitor for V3V place next to V3V pin. EN PWM2 ISNS PWM1 BST1 PVIN1 SW1 PVIN PGND SW2 PVIN2 CONFIDEN TIAL P relimi nary D atashe et VDD V3V VIN GND BST2 VIN GND Figure 18. PCB Layout Example 12 For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved SCT63140 PACKAGE INFORMATION FCQFN-15L (3x3) Package Outline Dimensions Symbol TOTAL THICKNESS STAND OFF MOLD THICKNESS L/F THICKNESS LEAD WIDTH BODY SIZE X Y LEAD PITCH LEAD LENGTH PACKAGE EDGE TOLERANCE MOLD FLATNESS COPLANARITY LEAD OFFSET A A1 A2 A3 b b1 D E e e1 e2 L L1 L2 L3 aaa ccc eee bbb Min. 0.70 0 CONFIDEN TIAL P relimi anry D atashe et 0.20 0.25 0.30 0.225 1.65 0.90 Dimensions in Millimeters Nom. 0.75 0.02 0.55 0.203 REF 0.25 0.30 3.00 BSC 3.00 BSC 0.50 BSC 0.775 BSC 0.525 BSC 0.40 0.325 1.75 1.00 0.1 0.1 0.08 0.1 Max. 0.80 0.05 0.30 0.35 0.50 0.425 1.85 1.10 NOTE: 1. 2. 3. 4. 5. 6. Drawing proposed to be made a JEDEC package outline MO-220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved 13 SCT63140 TAPE AND REEL INFORMATION Orderable Device SCT63140FMAR Package Type QFN 3mmx3mm Pins 15 SPQ 5000 CONFIDEN TIAL P relimi nary D atashe et 14 For more information www.silicontent.com© 2019 Silicon Content Technology Co., Ltd. All Rights Reserved SCT63140 RELATED PARTS PN DESCRIPTION SCT63240 COMMENTS • • • • • 20W High-Integration, HighEfficiency PMIC for Wireless Power Transmitter Integrate a 5V-1A Step-down DC/DC converter compared with SC63140. • • • • • • • • VIN=4.2V~20V 4 C6 10uF 7 C8 22uF L1 5V C5 0.1uF 5 C7 0.1uF 6 10uH VIN Input Voltage Range: 4.2V-20V PVIN Input Voltage Range: 1V-17V Up to 20W Power Transfer Integrated High Efficiency Full-Bridge Power Stage Integrated High Efficiency 5V-1A Step-down DC/DC Converter Optimized for EMI Build in 3.3V-200mA LDO Provide 2.5V Voltage Reference Integrated Input Current sense with ±2% accuracy for FOD and modulation 3.3V and 5V PWM Signal compatible Input Under-Voltage Lockout Over current protection 3mm*4mm QFN-19L Package PVIN1 VIN GND PGND BST3 PVIN2 VDD=5V 8 VDD C9 1uF 9 3.3V 2 C1 0.1uF C2 22uF 3 C3 0.1uF C4 22uF SW3 BST1 SW1 PVIN=1V~17V 1 13 R2 0ohm 18 17 PWM2 R5 100K C14 12 V3P3 SW2 BST2 11 10 R1 0ohm PWM1 R4 SCT63240 C10 1uF 19 C12 0.1uF EN PWM1 PWM2 ISNS VREF AGND C11 0.1uF R3 C13 15 14 16 2.5V C15 1uF R6 100K Figure 19. SCT63240 Typical Application NOTICE: The information in this document is subject to change without notice. Users should warrant and guarantee the third party Intellectual Property rights are not infringed upon when integrating Silicon Content Technology (SCT) products into any application. SCT will not assume any legal responsibility for any said applications. 15 Silicon Content Technology Co., Ltd. #1 Floor 2 Building 15, Yard 33 Dijin Road, Haidian District, Beijing 100095 TEL:(8610) 64779806 FAX: (8610) 64779806 www.silicontent.com© Silicon Content Technology
SCT63140FMAR 价格&库存
很抱歉,暂时无法提供与“SCT63140FMAR”相匹配的价格&库存,您可以联系我们找货
