SFHG96AA402
SFHG96AA402
    WISOL(威盛)
    2595MHz TD LTE Band41N Rx 声表面波滤波器,5引脚布局,1.1x0.9x0.5mm 封装,适用于TD LTE Band41N 接收端。
SFHG96AA402 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. WISOL PART No. SFHG96AA402 DOC. No. SMS-51-L-SFT-FX-102 DATE Feb. 20, 2017 REVISION 000 WISOL Kim, Woo hyun Byun, Kyung-Su Hong, Sang-Dea ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 531-7, Gajang-ro, Osan-si, Gyeonggi-do, KOREA, 18103 http://www.wisol.co.kr Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 ▶ A TABLE OF CONTENTS 1. REVISION HISTORY ..................................................................................................................................... 3 2. DEFINITION .................................................................................................................................................. 4 3. PRECAUTIONS ............................................................................................................................................. 4 4. OUTLINE DRAWING & DIMENSIONS.......................................................................................................... 5 5. MARKING ...................................................................................................................................................... 6 6. PERFORMANCE ........................................................................................................................................... 7 6-1. MAXIMUM RATINGS .......................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ................................................................................................... 8 7. RELIABILITY ............................................................................................................................................... 10 7-1. ENGINEERING SAMPLE FLOW CHART ......................................................................................... 10 7-2. TEST ITEM & CONDITION ................................................................................................................ 11 8. REFLOW CONDITION ................................................................................................................................ 12 9. RECOMMENDED PCB DIMENSIONS ....................................................................................................... 12 10. CAUTION ................................................................................................................................................... 13 11. PACKING ................................................................................................................................................... 14 11-1. DIMENSIONS.................................................................................................................................. 14 11-2. REELING QUANTITY ..................................................................................................................... 15 11-3. TAPING STRUCTURE .................................................................................................................... 15 11-4. INNER BOX(Reel Packing) STRUCTURE ...................................................................................... 16 11-5. OUTER BOX STRUCTURE ............................................................................................................ 17 12. TAPE SPECIFICATIONS .......................................................................................................................... 18 13. RoHS DATA ............................................................................................................................................... 19 SMS-51-L-SFT-FX-102 Page 2/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 1. REVISION HISTORY 000 Feb. 20, 2017 SMS-51-L-SFT-FX-102 All Page Make specification Page 3/25 Feb. 20, 2017 Surface Acoustic Wave Filter SFHG96AA402 TD LTE Band41N Rx 2595MHz 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 2. DEFINITION 2-1. PART No. SFHG96AA402 ① ② ③ No. ④ ⑤ ⑥ EXPLANATION ① SAW Filter ② Design Type ③ Center Frequency : 2595MHz(2535 ~ 2655) ④ Input:50ohm,Output:50ohm ⑤ Package size: 1.1×0.9mm² ⑥ Design Revision (02 : Molding Type) 2-2. APPLICATION : Band-Pass Filter for TD LTE B41N Rx etc. 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT-FX-102 Page 4/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] Yt X O X SMS-51-L-SFT-FX-102 Page 5/25 No. Function Others Ground 1 Unbalanced Input 4 Unbalanced Output Feb. 20, 2017 Surface Acoustic Wave Filter SFHG96AA402 TD LTE Band41N Rx 2595MHz 3 1.1×0.9×0.5mm Version : 000 5pin lay-out 5. MARKING Yt O X X 5-1. Y t X X st nd - The 1 2 character 'Yt' indicates the model name of SAW Filter SFHG96AA402. rd - The 3 character 'X' indicates the year and the month of manufacture. Year Month 1 2 3 4 5 6 7 8 9 10 11 12 2017 1 2 3 4 5 6 7 8 9 A B C 2018 D E F G H I J K L M N O 2019 P Q R S T U V W X Y Z a 2020 1 2 3 4 5 6 7 8 9 A B C ※ This rotates by the 3 years. - The th 4 character 'X' indicates Lot No. 5-2. ○ - This symbol indicates input pin 1. - This indicates the producing center ○ : China 5-3. Marking : Laser Marking SMS-51-L-SFT-FX-102 Page 6/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 15 dBm Operating Temperature Range -30 ~ +85 ℃ Storage Temperature Range -40 ~ +85 ℃ SMS-51-L-SFT-FX-102 Page 7/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -30 ~ +85℃ SPECIFICATION Item FREQUENCY RANGE [MHz] UNIT Insertion Loss 2535 ~ 2655 Inband Ripple Min. Typ. (25℃) Max. dB - 1.7 2.9 2535 ~ 2655 dB - 0.7 1.8 Input VSWR 2535 ~ 2655 - - 1.3 2.0 Output VSWR 2535 ~ 2655 - - 1.4 2.0 DC ~ 1225 dB 37 42 - 1225 ~ 1560 dB 30 35 - 1560 ~ 1610 dB 29 34 - 1610 ~ 2170 dB 27 32 - 2170 ~ 2400 dB 30 35 - 2400 ~ 2473 dB 36 41 - 2456 ~ 2483 dB 36 41 - 2750 ~ 4900 dB 23 28 - 4900 ~ 6000 dB 27 32 - 5070 ~ 5310 dB 28 33 - . Absolute Attenuation Input: Unbalanced 50 Ohm // 3.8nH Output: Unbanced 50 Ohm // 3.8nH Termination Impedance 6-2-2. TEST FIXTURE [X—Ray Top View] SMS-51-L-SFT-FX-102 Page 8/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm Version : 000 5pin lay-out 6-2-3. GRAPH HG96AA4_Nearband 0 0 -20 -1 -40 -2 -60 -3 -80 2.2 2.4 2.6 Frequency (GHz) 2.8 -4 3 HG96AA4_Fullband 0 -20 -40 -60 -80 0.01 2.01 4.01 6 Frequency (GHz) SMS-51-L-SFT-FX-102 Page 9/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (MSL 2a) (JESD22-A113) (n=191) HTS (n=23) ESD(HBM) (n=9) Board Level Drop (n=11) LTS (n=23) ESD(HBM) LIMIT (n=3) Bending (n=11) uHAST (n=23) ESD(MM) (n=9) Solder Heat (n=11) THS (n=23) ESD(CDM) (n=6) Solderability (n=11) Temp. Drift (n=5) TC (n=23) Final Electrical Data (n=115) SMS-51-L-SFT-FX-102 Final Electrical Data (n=27) Page 10/25 Final Electrical Data (n=49) Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning TEST CONDITION REMARK Bake + Soak(MSL or above) + 3X Reflow duration ( Soak 60℃ 60% 120HR) JESD22-A113 TEST ITEM REMARK TEST CONDITION Duration HTS (High Temperature Storage) JESD22-A103 condition A 125(-0/+10)℃ 1000hr LTS (Low Temperature Storage) JESD22-A119 A -40(-10/+0)℃ 1000hr uHAST (Unbiased HAST) JESD22-A118 130℃ /85% /33.3psi 96hr JESD22-A101 85℃ /85% RH 1000hr TC (Temperature Cycle) JESD22-A104 Condition G (-40℃ /125℃) 1000cycle ESD(HBM) JESD22-A114 250V or above - ESD(HBM) LIMIT - 300V or above - ESD(MM) JESD22-A115 No spec butneed data - ESD(CDM) JESD22-C101 500V or above - Board Level Drop Test JESD22-B111 1500G Duration 0.5ms 150cycle THS (Temperature Humidity Storage) Bending Test 0.5㎜/sec 3times (1mm distance) Solder Heat Resistance 260℃ 10sec Solderability 235℃ 3sec Temp Drift SMS-51-L-SFT-FX-102 -40℃ Page 11/25 → +25℃ → +125℃ Per conditions 2HR Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [unit : mm] [SAW, X-ray Top view] SMS-51-L-SFT-FX-102 [PCB, X-ray Top view] Page 12/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT-FX-102 Page 13/25 Feb. 20, 2017 Surface Acoustic Wave Filter SFHG96AA402 TD LTE Band41N Rx 2595MHz 3 1.1×0.9×0.5mm Version : 000 5pin lay-out 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.08 +0.05 -0.05 1.23 +0.05 -0.05 Ø 1.50 +0.10 -0.00 Ø 0.50 +0.01 1.75 +0.10 -0.10 3.50 +0.05 -0.05 4.00 +0.05 -0.05 4.00 +0.05 -0.05 2.00 +0.05 -0.05 0.23 +0.05 -0.05 0.70 +0.05 -0.05 8.00 +0.30 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø 258.0 +1.0 -0.5 Ø 81.0 +1.0 -1.0 Ø 13.0 +0.5 -0.5 50.0 +0.8 -0.8 2.2 +0.3 -0.3 7.0 +0.5 -0.5 30.0 +0.8 -0.8 35.0 +1.0 -1.0 1.8 +0.5 -0.5 1.5 +0.5 -0.5 9.0 +1.0 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT-FX-102 Page 14/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-2. REELING QUANTITY 10 inch reel : 10,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. Y t X O X Y t X O X 11-3-2. BARCODE LABEL ① MODEL NAME BARCODE ② Model Name ③ Reel number ④ Quantity / Marking SMS-51-L-SFT-FX-102 Page 15/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material : Polyethylene + Aluminium Size : 310×370mm Material Size: 2 : Paper (D)260×(W)37×(H)265mm SMS-51-L-SFT-FX-102 3 Page 16/25 Feb. 20, 2017 EA . . Surface Acoustic Wave Filter SFHG96AA402 TD LTE Band41N Rx 2595MHz 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-5. OUTER BOX STRUCTURE Material : Paper TYPE A SIZE(mm) a b c Inner Box # 270 240 275 6 boxes SIDE ① SIDE ② MODEL Q'TY EA USER DATE . . - SIDE is the same as front side. SMS-51-L-SFT-FX-102 Page 17/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT-FX-102 Page 18/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 13. RoHS DATA SMS-51-L-SFT-FX-102 Page 19/25 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SMS-51-L-SFT-FX-102 SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Page 20/25 Version : 000 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SMS-51-L-SFT-FX-102 SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Page 21/25 Version : 000 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SMS-51-L-SFT-FX-102 SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Page 22/25 Version : 000 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SMS-51-L-SFT-FX-102 SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Page 23/25 Version : 000 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SMS-51-L-SFT-FX-102 SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Page 24/25 Version : 000 Feb. 20, 2017 Surface Acoustic Wave Filter TD LTE Band41N Rx 2595MHz SMS-51-L-SFT-FX-102 SFHG96AA402 3 1.1×0.9×0.5mm 5pin lay-out Page 25/25 Version : 000 Feb. 20, 2017
SFHG96AA402 价格&库存
很抱歉,暂时无法提供与“SFHG96AA402”相匹配的价格&库存,您可以联系我们找货
