PSI CONNECTOR
4.0mm pitch/Disconnectable Crimp style connectors
Wire-to-wire type
Side entry type
• Secure locking structure
• Mis-mating prevention mechanism by keying
(2 to 4 circuits/3 kinds of keying)
• Finger-friendly design
• Large electric current was realized.
Specifications –––––––––––––––––––
Single type
Double type
• Current rating: 12 A AC, DC (Refer to the following table.)
• Voltage rating: 300 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,500 VAC/minute
• Applicable wire: AWG #26 to #16
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Note: The current rating differs depending on the number of circuits and the wire
size used in each connector. The table below lists the current rating as a
function of the number of circuits and the wire size.
Current unit: A
Top entry type
Circuits
2
3
4, 5, 6, 8
10, 12
14
This PSI connector is designed for wire-toboard and wire-to-wire 4.0 mm pitch
connector. Low insertion force type contact
is adopted and it provides excellent
operability. This connector has the secure
locking device that has the mechanism for
preventing the inverse insertion.
By adopting key shape and multi colors of
housing, prevention function of mis-mating
is considered.
1
# 16
# 18
12
11
10
9
9
10
9
8
7
7
Wire size (AWG)
# 20
# 22
8
7
6
6
6
5
5
5
5
4.5
# 24
# 26
4
4
4
4
4
3
3
3
3
3
Note: Do not branch in parallel current which exceeds the rated current (e.g. more than
12 A in the case of 2 circuits with AWG #12). If branched in parallel, current
imbalance or other problems may develop. If it is absolutely necessary to branch
such a large current in parallel, design the circuits without causing any imbalance
and provide an extra margin for each circuit.
Standards ––––––––––––––––––––––
Recognized E 60389
1 Certified LR 20812
2 R50259465
PSI CONNECTOR
PC board layout and Assembly layout
Top entry type
● Single type
● Double type
10
1.65
4.5
±0.05
+0.1
φ1.3
17.8
4
+0.1
φ1.3
±0.05
±0.05
±0.05
±0.05
+0.1
φ1.65
15.95
+0.1
φ1.65
1.65 ±0.05
A ±0.05
4 ±0.05
A ±0.05
Side entry type
Wire-to-wire type
22.1
9.35
10.25
10
F ±0.05
4 ±0.05
+0.1
+0.1
±0.05
H
8.7
+0.1
3
3 ±0.05
9 ±0.05
φ1.7
φ1.65
0.8
4 ±0.05
±0.05
+0.1
±0.05
A±0.05
A ±0.05
φ1.65
+0.1
±0.05
G
7.2
19.6
+0.1
φ1.7
+0.1
φ1.7
+0.1
Keying: A, B types
φ1.7
+0.1
F
Circuits
Keying: C type
0.8 t 1.2 1.2 t 2.0
2
3
Note: 1. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ±0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method.
The dimensions above should serve as a guideline. Contact JST for details.
13
17
13.3
17.3
G
H
Applicable panel
thickness (mm)
9
13
6.8
8.4
0.8∼2.0
Socket contact
Applicable wire
mm2
AWG#
Model No.
SPSI-001T-M1.1
SPSI-41T-M1.1
0.13∼0.33
26∼22
1.3∼2.4
2,600
0.5 ∼1.25
20∼16
1.7∼3.2
2,600
11.3
6.5
2.2
Insulation O.D. (mm) Q'ty/reel
Material and Finish
4
2.8
Copper alloy, tin-plated
RoHS compliance
Contact
Crimping
machine Crimp applicator
MKS-L
SPSI-001T-M1.1
AP-K2N
SPSI-41T-M1.1
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SPSI/M-001-11 APLMK SPSI/M001-11
MK/SPSI/M-41-11 APLMK SPSI/M41-11
2
PSI CONNECTOR
Socket housing
Top entry type
B
A
B
10
15.95
14.9
14.9
A
RoHS compliance
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
PSIP-02V-LE-A
LE...light blue Y...yellow R...red
Header
Top entry type
9.1
12.35
B
φ1.1
4
1.65
3.7
□1.14
4.5
A
15.05
12.35
B
RoHS compliance This product displays (LF)(SN) on a label.
Note: Other kinds of post-omitted products are available. Contact JST for details.
φ1.1
4
1.65
A
3.7
□1.14
4.5
5.95
ex.
3
B02B-PSILE-A1
PSI CONNECTOR
Header
Side entry type
S02B-PSILE-A1
S02B-PSIY-B1
S02B-PSIR-C2
S03B-PSILE-A1
S03B-PSIY-B1
S03B-PSIR-C2
S04B-PSILE-A1
S04B-PSIY-B1
S04B-PSIR-C2
16.65
3.7
9.35
B
3
□1.14
9
4
A
ex.
S02B-PSILE-A1
Pin contact
Applicable wire
mm2
AWG#
Model No.
SPSM-001T-M1.1
SPSM-41T-M1.1
26∼22
1.3∼2.4
2,600
0.5 ∼1.25
20∼16
1.7∼3.2
2,600
Material and Finish
18
2.2
0.13∼0.33
6.6
4
2.8
RoHS compliance
Contact
Crimping
MKS-L
SPSM-001T-M1.1
AP-K2N
SPSM-41T-M1.1
Applicator
Dies
MKS-L
Receptacle housing
Circuits Keying
A
2
3
C
A
B
A
B
Model No.
PSIR-02V-LE-A
PSIR-02V-Y-B
PSIR-03V-LE-A
PSIR-03V-Y-B
Dimensions (mm)
A
B
C
Q’ty/
bag
4.0
16.1
12.5
200
4.0
16.1
12.5
200
8.0
20.1
16.5
150
8.0
20.1
16.5
150
Material
9.1
Glass-filled PBT, UL94V-0
15.85
RoHS compliance
25.45
ex.
B
PSIR-03V-LE-A
8.45
4
PSI CONNECTOR
Contact position location numbers
Socket housing
5
4
3
2
14 13 12 11 10
9
8
7
2
1
Header
Header
● Top entry
● Side entry
14 13 12 11 10
1
6
5
4
3
5
4
3
2
9
8
2
1
1
1
7
6
5
4
3
2
Receptacle housing
3
3
4
2
1
Single
Double
Single
Double
Single
Single
Pin-omitted Header
1) When setting two times of pitch in single type header with omitting every other one pin
However, pins shall be inserted in No.1-circuit and No. N-circuit.
B *1 (8.0)B-PSI
; With circuit (pin)
e.g.)
*1; No. of circuits (No. of pins)
Circuit No.
3
; Without circuit (pin)
2
1
Circuit (pin)
Model No.
5
Circuit No.
4
e.g.)
Circuit No.
Model No.
B3(8.0)B-PSILE-1
6
5
4
3
2
1
Circuit (pin)
*2; Circuit No. of used original
header
*3; Circuit number without pin
(Circuit number
in which pin was removed)
Circuit No.
Circuit (pin)
Model No.
B4(6-2, 5)B-PSILE-1
3) When setting three times of pitch in double type header with omitting every other two pins
However, pins shall be inserted in the both ends of circuit.
B *1 (*2-*3)B-PSI
e.g.)
Circuit No.
14
13
12
11
10
9
8
7
6
5
4
3
2
1
Circuit (pin)
Circuit No.
Circuit (pin)
Model No.
B6(14-2, 3, 5, 6, 9, 10, 12, 13)B-PSILE-1
4) When omitting a pin of No.3 circuit in single type herder
B *1 (*2-*3)B-PSI
e.g.)
Circuit No.
5
4
3
2
Circuit (post)
Model No.
B4(5-3)B-PSILE-1
Note) As for pin-omitted product, there is a setting that cannot be used. Contact JST for details.
5
2
Circuit (pin)
B2(8.0)B-PSILE-A1
2) When setting two times of pitch in double type header with omitting every other one pin
B *1 (*2-*3)B-PSI
3
1
1
PSI CONNECTOR
Keying
Socket housing
Shape
A type
B type
C type
A type
B type
C type
A type
B type
C type
2 circuits
3 circuits
4 circuits
Header
Top entry type
Shape
2 circuits
3 circuits
4 circuits
Side entry type
Shape
2 circuits
3 circuits
4 circuits
Receptacle housing
Shape
A type
B type
2 circuits
3 circuits
6
很抱歉,暂时无法提供与“SPSI-41T-M1.1”相匹配的价格&库存,您可以联系我们找货
