SODJ5.0CA
SODJ5.0CA
    CREATEKMICRO(达晶微)
    SODJ5.0CA
SODJ5.0CA 数据手册
SODJ Series CREATEK Microelectronics Power TVS in SOD123-FL Features ■ Glass passivated chip Bidirectional ■ 200W peak pulse power(10/1000us) ■ High accuracy, 5% tolerance 1 ■ Uni and Bidirectional unit 1 ■ Low clamping voltage ■ Low Leakage current 2 2 ■ Very fast response time Mechanical Data Unidirectional ■ Case:SOD123-FL (plastic package). RoHS compliant ■ Molding Compound Flammability Rating: UL 94 V-0 ■ Terminals: High temperature soldering guaranteed: 260 °C/10 sec. at terminals 1 1 2 2 Applications ■ Computers ■ Telecom system ■ Industrial equipments ■ Consumer electronic applications ■ Other VCC bus and I/O interfaces Absolute Maximum Ratings Ratings at 25 °C, ambient temperature unless otherwise specified Parameter Peak pulse power dissipation with a 10/1000us waveform (1) Maximum peak reverse pulse current a 10/1000us waveform Peak forward surge current 8.3ms single half sine-wave (1) (2 ) Operating junction and storage temperature range Symbol Value Unit PPP 200 W I PP See Next Table A I FSM 20 A TJ, TSTG -55 to +150 ℃ Notes: 1.Non-repetitive current pulse,per Fi g.5 and detated above TA=25°C per Fig.1 2.Measured on 8.3ms single half sine-wave,or equivalent square wave,duty cycle=4 pulses per minute maximum Rev. 1.0, 23-May-2012 www.crea-tek.com 1 SODJ Series CREATEK Microelectronics Electrical Characteristics (TA = 25 °C unless otherwise specified) Part Number Direction Maximum Working Voltage VRWM (V) Maximum Reverse Current@VRWM IR max(uA) VBR min(V) VBR max(V) IT(mA) Peak Surge Current IPP (A) Maximum Clamping Voltage@IPP VC (V) Breakdown Voltage@IT SODJ5.0A Uni-Dir 5.0 800 6.4 7.07 10 21.74 9.2 SODJ5.0CA Bi-Dir 5.0 1600 6.4 7.07 10 21.74 9.2 SODJ6.0A Uni-Dir 6.0 800 6.67 7.37 10 19.42 10.3 SODJ6.0CA Bi-Dir 6.0 1600 6.67 7.37 10 19.42 10.3 SODJ6.5A Uni-Dir 6.5 500 7.22 7.98 10 17.86 11.2 SODJ6.5CA Bi-Dir 6.5 1000 7.22 7.98 10 17.86 11.2 SODJ7.0A Uni-Dir 7.0 200 7.78 8.60 10 16.67 12.0 SODJ7.0CA Bi-Dir 7.0 400 7.78 8.60 1 16.67 12.0 SODJ7.5A Uni-Dir 7.5 100 8.33 9.21 1 15.51 12.9 SODJ7.5CA Bi-Dir 7.5 200 8.33 9.21 1 15.51 12.9 SODJ8.0A Uni-Dir 8.0 50 8.89 9.83 1 14.71 13.6 SODJ8.0CA Bi-Dir 8.0 100 8.89 9.83 1 14.71 13.6 SODJ8.5A Uni-Dir 8.5 10 9.44 10.40 1 13.89 14.4 SODJ8.5CA Bi-Dir 8.5 20 9.44 10.40 1 13.89 14.4 SODJ9.0A Uni-Dir 9.0 5 10.00 11.10 1 12.99 15.4 SODJ9.0CA Bi-Dir 9.0 10 10.00 11.10 1 12.99 15.4 SODJ10A Uni-Dir 10.0 5 11.10 12.30 1 11.77 17.0 SODJ10CA Bi-Dir 10.0 10 11.10 12.30 1 11.77 17.0 SODJ11A Uni-Dir 11.0 1 12.20 13.50 1 10.99 18.2 SODJ11CA Bi-Dir 11.0 1 12.20 13.50 1 10.99 18.2 SODJ12A Uni-Dir 12.0 1 13.30 14.70 1 10.05 19.9 SODJ12CA Bi-Dir 12.0 1 13.30 14.70 1 10.05 19.9 SODJ13A Uni-Dir 13.0 1 14.40 15.90 1 9.30 21.5 SODJ13CA Bi-Dir 13.0 1 14.40 15.90 1 9.30 21.5 SODJ14A Uni-Dir 14.0 1 15.60 17.20 1 8.62 23.2 SODJ14CA Bi-Dir 14.0 1 15.60 17.20 1 8.62 23.2 SODJ15A Uni-Dir 15.0 1 16.70 18.50 1 8.20 24.4 SODJ15CA Bi-Dir 15.0 1 16.70 18.50 1 8.20 24.4 SODJ16A Uni-Dir 16.0 1 17.80 19.70 1 7.69 26.0 SODJ16CA Bi-Dir 16.0 1 17.80 19.70 1 7.69 26.0 SODJ17A Uni-Dir 17.0 1 18.90 20.90 1 7.25 27.6 SODJ17CA Bi-Dir 17.0 1 18.90 20.90 1 7.25 27.6 SODJ18A Uni-Dir 18.0 1 20.00 22.10 1 6.85 29.2 SODJ18CA Bi-Dir 18.0 1 20.00 22.10 1 6.85 29.2 SODJ19A Uni-Dir 19.0 1 21.10 23.30 1 6.50 30.8 SODJ19CA Bi-Dir 19.0 1 21.10 23.30 1 6.50 30.8 SODJ20A Uni-Dir 20.0 1 22.20 24.50 1 6.18 32.4 SODJ20CA Bi-Dir 20.0 1 22.20 24.50 1 6.18 32.4 Rev. 1.0, 23-May-2012 www.crea-tek.com 2 SODJ Series CREATEK Microelectronics Part Number Direction Maximum Working Voltage VRWM (V) Maximum Reverse Current@VRWM IR max(uA) VBR min(V) VBR max(V) IT(mA) Peak Surge Current IPP (A) Maximum Clamping Voltage@IPP VC (V) Breakdown Voltage@IT SODJ22A Uni-Dir 22.0 1 24.40 26.90 1 5.64 35.5 SODJ22CA Bi-Dir 22.0 1 24.40 26.90 1 5.64 35.5 SODJ24A Uni-Dir 24.0 1 26.70 29.50 1 5.14 38.9 SODJ24CA Bi-Dir 24.0 1 26.70 29.50 1 5.14 38.9 SODJ26A Uni-Dir 26.0 1 28.90 31.90 1 4.75 42.1 SODJ26CA Bi-Dir 26.0 1 28.90 31.90 1 4.75 42.1 SODJ28A Uni-Dir 28.0 1 31.10 34.40 1 4.41 45.4 SODJ28CA Bi-Dir 28.0 1 31.10 34.40 1 4.41 45.4 SODJ30A Uni-Dir 30.0 1 33.30 36.80 1 4.13 48.4 SODJ30CA Bi-Dir 30.0 1 33.30 36.80 1 4.13 48.4 SODJ33A Uni-Dir 33.0 1 36.70 40.60 1 3.75 53.3 SODJ33CA Bi-Dir 33.0 1 36.70 40.60 1 3.75 53.3 SODJ36A Uni-Dir 36.0 1 40.00 44.20 1 3.44 58.1 SODJ36CA Bi-Dir 36.0 1 40.00 44.20 1 3.44 58.1 SODJ40A Uni-Dir 40.0 1 44.40 49.10 1 3.10 64.5 SODJ40CA Bi-Dir 40.0 1 44.40 49.10 1 3.10 64.5 SODJ43A Uni-Dir 43.0 1 47.80 52.80 1 2.88 69.4 SODJ43CA Bi-Dir 43.0 1 47.80 52.80 1 2.88 69.4 SODJ45A Uni-Dir 45.0 1 50.00 55.30 1 2.75 72.7 SODJ45CA Bi-Dir 45.0 1 50.00 55.30 1 2.75 72.7 SODJ48A Uni-Dir 48.0 1 53.30 58.90 1 2.59 77.4 SODJ48CA Bi-Dir 48.0 1 53.30 58.90 1 2.59 77.4 SODJ51A Uni-Dir 51.0 1 56.70 62.70 1 2.43 82.4 SODJ51CA Bi-Dir 51.0 1 56.70 62.70 1 2.43 82.4 SODJ54A Uni-Dir 54.0 1 60.00 66.30 1 2.30 87.1 SODJ54CA Bi-Dir 54.0 1 60.00 66.30 1 2.30 87.1 SODJ58A Uni-Dir 58.0 1 64.40 71.20 1 2.14 93.6 SODJ58CA Bi-Dir 58.0 1 64.40 71.20 1 2.14 93.6 SODJ60A Uni-Dir 60.0 1 66.70 73.70 1 2.07 96.8 SODJ60CA Bi-Dir 60.0 1 66.70 73.70 1 2.07 96.8 SODJ64A Uni-Dir 64.0 1 71.10 78.60 1 1.94 103.0 SODJ64CA Bi-Dir 64.0 1 71.10 78.60 1 1.94 103.0 SODJ70A Uni-Dir 70.0 1 77.80 86.00 1 1.77 113.0 SODJ70CA Bi-Dir 70.0 1 77.80 86.00 1 1.77 113.0 SODJ75A Uni-Dir 75.0 1 83.30 92.10 1 1.66 121.0 SODJ75CA Bi-Dir 75.0 1 83.30 92.10 1 1.66 121.0 SODJ78A Uni-Dir 78.0 1 86.70 95.80 1 1.59 126.0 SODJ78CA Bi-Dir 78.0 1 86.70 95.80 1 1.59 126.0 Rev. 1.0, 23-May-2012 www.crea-tek.com 3 SODJ Series CREATEK Microelectronics Part Number SODJ80A Direction Uni-Dir Maximum Working Voltage VRWM (V) Maximum Reverse Current@VRWM IR max(uA) VBR min(V) VBR max(V) 80.0 1 88.80 97.60 IT(mA) Peak Surge Current IPP (A) Maximum Clamping Voltage@IPP VC (V) 1 1.55 129.6 Breakdown Voltage@IT SODJ80CA Bi-Dir 80.0 1 88.80 97.60 1 1.55 129.6 SODJ85A Uni-Dir 85.0 1 94.40 104.00 1 1.46 137.0 SODJ85CA Bi-Dir 85.0 1 94.40 104.00 1 1.46 137.0 SODJ90A Uni-Dir 90.0 1 100.00 111.00 1 1.37 146.0 SODJ90CA Bi-Dir 90.0 1 100.00 111.00 1 1.37 146.0 SODJ100A Uni-Dir 100.0 1 111.00 123.00 1 1.24 162.0 SODJ100CA Bi-Dir 100.0 1 111.00 123.00 1 1.24 162.0 SODJ110A Uni-Dir 110.0 1 122.00 135.00 1 1.13 177.0 SODJ110CA Bi-Dir 110.0 1 122.00 135.00 1 1.13 177.0 SODJ120A Uni-Dir 120.0 1 133.00 147.00 1 1.04 193.0 SODJ120CA Bi-Dir 120.0 1 133.00 147.00 1 1.04 193.0 SODJ130A Uni-Dir 130.0 1 144.00 159.00 1 0.96 209.0 SODJ130CA Bi-Dir 130.0 1 144.00 159.00 1 0.96 209.0 SODJ140A Uni-Dir 140.0 1 155.00 171.00 1 0.88 226.8 SODJ140CA Bi-Dir 140.0 1 155.00 171.00 1 0.88 226.8 SODJ150A Uni-Dir 150.0 1 167.00 185.00 1 0.83 243.0 SODJ150CA Bi-Dir 150.0 1 167.00 185.00 1 0.83 243.0 SODJ160A Uni-Dir 160.0 1 178.00 197.00 1 0.77 259.0 SODJ160CA Bi-Dir 160.0 1 178.00 197.00 1 0.77 259.0 SODJ170A Uni-Dir 170.0 1 189.00 209.00 1 0.73 275.0 SODJ170CA Bi-Dir 170.0 1 189.00 209.00 1 0.73 275.0 Rev. 1.0, 23-May-2012 www.crea-tek.com 4 SODJ Series CREATEK Microelectronics Typical Characteristics (Tamb = 25 °C unless otherwise specified) Fig. 2-Maximum Non-Repetitive Peak Forward Surge Current Uniderictional Fig. 1-Pulse Derating Curve 100 50 0 0 100 TJ = TJ max 8.3ms Single Half Sine-wave (JEDEC Method) 10 1 Fig 3. –typical transient thermal impedance 100 10 1.0 0.1 0.01 10 1.0 0.1 0.1 1.0 10 t,Pulse duration,sec 0.1 1.0 10 100 1000 td,Pulse Width,μsec TA=25℃ Test Waveform tf=10μs td=1000μs Peak Value Ippm 10/1000μs Waveform as deffused by R.E.A 50 Cj, Capacitance,pF 10000 100 10000 Fig. 6-Typical Junction Capacitance Unidirectional 150 tf=10μs 100 Non-Repetive Pulse Waveform Shown in Fig.5 TA=25°C Fig. 5-Pulse Waveform IPPM, Peak Pulse Current % 10 Number of Cycles At 60 Hz Fig. 4-Peak Pulse Power Rating Curve PPPM, Peak Pulse Power,KW Transient thermal impedance(°C/W) 100 25 50 100 125 150 175 200 TA,Ambient Temperature,°C IFSM, Forward Surge Current,Amperes Peak Pulse Power(PPP) or current(IPP) Derating in percentage % 125 TJ = 25°C f = 1.0 MHz Vsig = 50mVp-p meansured at stand-off voltage VWM 1000 100 Uni-Directional Bi-Directional Half Value Ipp/2=td 10 0 0 1.0 2.0 t,Time,ms Rev. 1.0, 23-May-2012 3.0 1.0 10 100 V(WM),Reverse Stand-off Voltage,Voltage www.crea-tek.com 5 SODJ Series CREATEK Microelectronics Package Dimensions A E Dimensions in millimeters Symbol B D C Min Nom Max A 3.50 3.70 3.90 B 0.75 0.85 0.95 C 2.60 2.80 3.00 D 1.60 1.80 2.00 0.45Typ E J H K H 0.9 J 0.12 1.2 0.17 0.22 0.8Typ K K 1.05 Ordering information Order code Package Packaging option Base quantity Packaging specification SODJ Series SOD123-FL Tape and reel 3000pcs / reel EIA STD RS-481 Revision history Date Revision 23-May-2012 1.0 Rev. 1.0, 23-May-2012 Changes Initial release www.crea-tek.com 6 SODJ Series CREATEK Microelectronics CAUTION / WARNING Information in this document is believed to be accurate and reliable. However, CREATEK does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Users should independently evaluate the suitability of and test each product selected for their own applications, and CREATEK assumes no liability whatsoever relating to the choice, selection or use of the CREATEK products and services described herein. CREATEK reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. Information in this document supersedes and replaces all information previously supplied. Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an CREATEK product can reasonably be expected to result in personal injury, death or severe property or environmental damage. CREATEK accepts no liability for inclusion and/or use of CREATEK products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Resale of CREATEK products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by CREATEK for the CREATEK product or service described herein and shall not create or extend in any manner whatsoever, any liability of CREATEK. CREATEK expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. CREATEK only obligations are those in the CREATEK Standard Terms and Conditions of Sale and in no case will CREATEK be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2009,CREATEK Microelectronics t ® is a registered trademark of CREATEK Microelectronics All rights reserved Rev. 1.0, 23-May-2012 www.crea-tek.com 7
SODJ5.0CA 价格&库存
很抱歉,暂时无法提供与“SODJ5.0CA”相匹配的价格&库存,您可以联系我们找货
