1V5KE400CA
1V5KE400CA
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO201AD
    1V5KE400CA
1V5KE400CA 数据手册
1V5KE6V8(C)A – 1V5KE440(C)A Taiwan Semiconductor 1500W Transient Voltage Suppressors FEATURES ● ● ● ● ● ● ● ● ● Glass passivated junction 1500W peak pulse power capability at 1.0ms Excellent clamping capability Low incremental surge resistance Fast response time: Typically < 1.0ps from 0 V to BV for uni-directional, 5.0 ns for bidirectional Typical IR: 1.0μA above 10V UL certified: UL #E258596 Bi-directional types use CA suffix Electrical characteristics apply in both directions DO-201AE COLOR BAND DENOTES CATHODE ON UNIDIRECTIONAL DEVICES ONLY. NO COLOR BAND ON BIDIRECTIONAL DEVICES. ABSOLUTE MAXIMUM RATINGS Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Values are at TA = 25°C unless otherwise noted. PARAMETER Peak pulse power dissipation tp=1ms Peak pulse current Non-Repetitive Peak Forward Surge Current (1) Superimposed on Rated Load (JEDEC Method) Junction temperature Storage temperature Note: SYMBOL PPPM IPPM VALUE 1500 see table UNIT W A IFSM 200 A TJ -55 to +175 °C TSTG -55 to +175 °C SYMBOL VALUE UNIT PD 5.0 W 1. Measured on 8.3ms single half-sine wave; duty cycle = 4 pulses per minute maximum. THERMAL CHARACTERISTICS PARAMETER Power dissipation .375 inch lead length at TA=75°C 1 Version: B1910 1V5KE6V8(C)A – 1V5KE440(C)A Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Uni-directional Bi-directional (C) Device Reverse Stand-Off Voltage VRWM (V) Breakdown Voltage VBR (V) Min. Max. Test Current IT (mA) Clamping Voltage at IPPM VC(V) Peak Pulse Current IPPM (A) Reverse Leakage Current at VRWM (2) IR (μA) 1V5KE6V8(C)A 5.80 6.45 7.14 10 10.5 143 1000 1V5KE7V5(C)A 6.40 7.13 7.88 10 11.3 133 500 1V5KE8V2(C)A 7.02 7.79 8.61 10 12.1 124 200 1V5KE9V1(C)A 7.78 8.65 9.55 1 13.4 112 50 1V5KE10(C)A 8.55 9.5 10.5 1 14.5 103 10 1V5KE11(C)A 9.40 10.5 11.6 1 15.6 96.2 5 1V5KE12(C)A 10.2 11.4 12.6 1 16.7 90.0 5 1V5KE13(C)A 11.1 12.4 13.7 1 18.2 82.0 5 1V5KE15(C)A 12.8 14.3 15.8 1 21.2 71.0 5 1V5KE16(C)A 13.6 15.2 16.8 1 22.5 67.0 5 1V5KE18(C)A 15.3 17.1 18.9 1 26.2 59.5 5 1V5KE20(C)A 17.1 19.0 21.0 1 27.7 54.2 5 1V5KE22(C)A 18.8 20.9 23.1 1 30.6 49.0 5 1V5KE24(C)A 20.5 22.8 25.2 1 33.2 45.2 5 1V5KE27(C)A 23.1 25.7 28.4 1 37.5 40.0 5 1V5KE30(C)A 25.6 28.5 31.5 1 41.4 36.2 5 1V5KE33(C)A 28.2 31.4 34.7 1 45.7 33.0 5 1V5KE36(C)A 30.8 34.2 37.8 1 49.9 30.1 5 1V5KE39(C)A 33.3 37.1 41 1 53.9 28.0 5 1V5KE43(C)A 36.8 40.9 45.2 1 59.3 25.3 5 1V5KE47(C)A 40.2 44.7 49.4 1 64.8 23.2 5 1V5KE51(C)A 43.6 48.5 53.6 1 70.1 21.4 5 1V5KE56(C)A 47.8 53.2 58.8 1 77.0 19.5 5 1VKE62(C)A 53.0 58.9 65.1 1 85.0 17.7 5 1V5KE68(C)A 58.1 64.6 71.4 1 92.0 16.3 5 1V5KE75(C)A 64.1 71.3 78.8 1 104 14.6 5 1V5KE82(C)A 70.1 77.9 86.1 1 113 13.3 5 1V5KE91(C)A 77.8 86.5 95.5 1 125 12.0 5 1V5KE100(C)A 85.5 95 105 1 137 11.0 5 1V5KE110(C)A 94.0 106 116 1 152 9.9 5 1V5KE120(C)A 102 114 126 1 165 9.1 5 1V5KE130(C)A 111 124 137 1 179 8.4 5 1V5KE150(C)A 128 143 158 1 207 7.2 5 1V5KE160(C)A 136 152 168 1 219 6.8 5 2 Version: B1910 1V5KE6V8(C)A – 1V5KE440(C)A Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Uni-directional Bi-directional (C) Device Reverse Stand-Off Voltage VRWM (V) Breakdown Voltage VBR (V) Min. Max. Test Current IT (mA) Clamping Voltage at IPPM VC(V) Peak Pulse Current IPPM (A) Reverse Leakage Current at VRWM (2) IR (μA) 1V5KE170(C)A 145 162 179 1 234 6.4 5 1V5KE180(C)A 154 171 189 1 246 6.1 5 1V5KE200(C)A 171 190 210 1 274 5.5 5 1V5KE220(C)A 185 209 231 1 328 4.6 5 1V5KE250(C)A 214 237 263 1 344 4.5 5 1V5KE300(C)A 256 285 315 1 414 3.8 5 1V5KE350(C)A 300 333 368 1 482 3.2 5 1V5KE400(C)A 342 380 420 1 548 2.8 5 1V5KE440(C)A 376 418 462 1 602 2.6 5 Note: 2. .For bi-directional parts with VRWM < 10 V, the IR maximum limit is doubled. 3 Version: B1910 1V5KE6V8(C)A – 1V5KE440(C)A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig1. Peak Pulse Power Rating Curve Fig2. Pulse Derating Curve 100 125 10 PULSE POWER (%) PULSE POWER (KW) 100 1 0.1 0.0001 75 50 25 0 0.001 0.01 0.1 1 10 0 PULSE WIDTH (ms) Unidirectional TOTAL CAPCAITANCE (pF) IPPM, PEAK PULSE CURRENT (%) Peak value IPPM 80 100 125 150 175 200 10000 Rise time tr=10μs to 100% 100 75 Fig4. Total Capacitance Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM 120 50 AMBIENT TEMPERATURE (°C) Fig3. Pulse Waveform 140 25 Half value-IPPM/2 60 40 10/1000μs, waveform 20 Measured at Zero Bias 1000 Bidirectional 100 Measured at Stand-Off Voltage (V) td 0 f=1.0MHz Vsig=50mVp-p 10 0 0.5 1 1.5 2 2.5 3 5 PERCENT OF RATEDt,PEAK REVERSE VOLTAGE (%) TIME (ms) 50 500 REVERSE VOLTAGE (V) 4 Version: B1910 1V5KE6V8(C)A – 1V5KE440(C)A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig5. Steady State Power Derating Curve Fig6. Non-Repetitive Surge Current 6 PEAK FORWARD SURGE CURRENT(A) 200 POWER DISSIPATION (W) 5 4 3 2 1 0 0 25 50 75 100 125 150 175 200 Unidirectional only 8.3ms single half sine-wave JEDEC method 20 1 LEAD TEMPERATURE (°C) 10 100 NUMBER OF CYCLES at 60hZ 5 Version: B1910 1V5KE6V8(C)A – 1V5KE440(C)A Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AE Unit (mm) DIM. Min Max A 4.80 5.60 B 0.94 1.07 C 25.40 - D 7.20 9.50 E 25.40 - NOTES: UNLESS OTHERWISE SPECIFIED A) PACKAGE STANDARD REFERENCE: JEDEC DO-201 VARIATION AE. B) PLASTIC PACKAGE BODY. C) ALL DIMENSIONS ARE IN MILLMETERS. 6 Version: B1910 1V5KE6V8(C)A – 1V5KE440(C)A Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: B1910
1V5KE400CA 价格&库存
很抱歉,暂时无法提供与“1V5KE400CA”相匹配的价格&库存,您可以联系我们找货
