G3236864062060A
G3236864062060A
    JGHC(晶光华)
    SMD3225_4P
    无源晶振 36.864MHz ±20ppm 6pF 60Ω -40℃~+85℃
G3236864062060A 数据手册
承 认 SPECIFICATION FOR 书 APPROVAL 客户名称:Customer 货 SMD 3225 GLASS 石英晶体谐振器 名:Description 客户料号: Part No 物料编号: Code No G3236864062060A 频 率:Frequency 36.864MHz 日 期:Date 2020-09-22 备 注: RoHS 豁免条款 7(a) 制作(Prepare by) 检查(Check by) 批准(Approve by) 郭静 甘瑛 张刚 客户批准 Approve by customer 批准日期 Approval date Add:广东省深圳市华发北路桑达工业区桑达雅苑 7P 7 P Sangda Yayuan Huafa North Road, Futian District, Shenzhen, Guangdong Tel: 86-755-83048260 86-755-83048290 Fax: 86-755-83048280 www.jghcorp.com ShenZhen JingGuangHua Electronics Co.,Ltd. 1、 Specifications 1 规格型号 Holder Type 2 标称频率 Nominal Frequency 36.864MHz 3 振动模式 Mode of Oscillation Fundamental 4 调整频差 Frequency Tolerance at 25℃ ±20ppm 5 温度频差 Temperature Frequency Stability ±30ppm 6 工作温度 Operating Temperature Range -40~85℃ 7 贮存温度 Storage Temperature Range -40~90℃ 8 负载电容 Load Capacitance 9 静电容 Shunt capacitance ≤7 pF 10 等效电阻 Equivalent Series Resistance 60Ω Max 11 激励功率 Drive Level 12 绝缘阻抗 Insulation Resistance 13 年老化率 Aging 14 测试仪器 Test machine SMD GLASS 3225 6 pF 10 uW 500MΩ/100V±15VDC ±3ppm/First year 250B 2.Frequency stability over temperature range (AT cut) Temperature Range Frequency Stability ±30PPM ±50PPM ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ -40℃~+85℃ ☆ ☆ ☆ -40℃~+125℃ ☆ ☆ ☆ 0℃~+50℃ ±3PPM ±5PPM ±7.5PPM ±10PPM ☆ ☆ ☆ ☆ ☆ -10℃~+60℃ -20℃~+70℃ -30℃~+70℃ www.jghcorp.com ±20PPM ±70PPM ShenZhen JingGuangHua Electronics Co.,Ltd. 3. Dimensions (unit:mm) 4.Recommended Reflow profile 5、Reliability specifications Item www.jghcorp.com Condition Standard ShenZhen JingGuangHua Electronics Co.,Ltd. 1. 2.. 3. 4. 5. 6. 7. 8. Drop characteristics Shake characteristics Free drop from 75cm height on a hard Frequency change: wooden board for 3 times. (Board is thickness ≤5ppm more than 30 mm.) Rr as specification Shake frequency 10~55Hz, cyc1~2 minutes, Frequency change: swing 1.5mm, direction x/y/z, all 30 minutes, ≤5ppm test after 1 hours. Rr as specification Put crystal into the pressure cabin with Airproof characteristics alcohol, keep pressure 0.4~0.5mpa 10 IR≥500MΩ minutes, then take out and blow for 5 minutes Weld 260±5℃, 3 seconds characteristics 90% exhibit tin ok Frequency change: Humidity +40±2℃ & 90%~95% R.H. 250 hours characteristics ≤5ppm Rr as specification Low temperature -30±2℃, 250 hours, put in room temperature, characteristics test after 1 hours. High temperature +85±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. Temperature -30±3℃/30±3 min~+85±2℃/30±3min, 5 cycling cycles Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification 6、Packaging standard www.jghcorp.com ShenZhen JingGuangHua Electronics Co.,Ltd. 1.5 310 .5 08 06 04 02 0180 .0 + 0/-0 06 0.0 01 3.0 08 06 04 Ps H o le 02 + 1/-0 ±0 .2 ±0 .4 3 -2 .0 ±0 .5 H o le 0 1 3 .0 ±0 .5 La b el 17 .0 ±0.3 * 1 1 9 .4 ±1 *2 G J T E H B C D * 1 -5 0 32 , -4 0 2 5 : 1 3.0 ±0 .3, -3 2 2 5 :9 .0 ±0 .3 * 2 -5 0 3 2 ,-4 0 2 5 :1 5 .4 ± 1 .0 , -3 2 2 5 :11 .4 ±1 .0 *3 -S e ries : 3 3 0 # 2#3 A Q F K D irec tio n  Standard quantity of ST -3225 : 3,000 pcs/reel  Standard quantity of SN –Series : 4,000 pcs/reel  Standard quantity of others : 1,000 pcs/reel  Carrier tape : Antistatic material (PS)  Each reel can be recycled SJ-7050 SJ-6032 SN-7050 SN-6032 SJ-5032 SJ -5032 SJ-4025 SJ-3225 A ±01 5.4 3.9±0.1 3.5±0.1 3.5±0.1 2.9±0.1 2.9±0.1 B 7.4±0.1 6.4±0.1 5.4±0.1 5.4±0.1 4.4±0.1 3.6±0.1 C 16.0±0.2 16.0±0.2 12.0±0.2 12.0±0.2 10.0±0.2 8.0±0.2 D 7.5±0.1 7.5±0.1 5.5±0.1 5.5±0.1 5.5±0.1 5.5±0.1 E 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 F 8.0±0.1 8.0±0.1 8.0±0.1 8.0±0.1 4.0±0.1 4.0±0.1 G 2.0±0.1 2.0±0.1 2.0±0.1 2.0±0.1 2.0±0.1 2.0±0.1 H 4.0±0.1 4.0±0.1 4.0±0.1 4.0±0.1 4.0±0.1 4.0±0.1 J 1.55±0.05 1.55±0.05 1.5+0.1/0 1.5+0.1/0 1.5±0.1/0 1.5±0.1/0 K 1.4±0.1 1.5±0.1 1.0±0.1 1.5±0.1 0.9±0.1 0.9±0.1 Q 1.6+0.1/0 1.55±0.05 1.6±0.1 1.6±0.1 1.5±0.1/0 1.5±0.1/0 T 0.3±0.05 0.3±0.05 0.25±0.05 0.25±0.05 0.25±0.05s 0.25±0.05s Item www.jghcorp.com Empty Space ShenZhen JingGuangHua Electronics Co.,Ltd. Cover Tape Min.500mm Empty Pockets Min.20 pockets Cover Tape Min.0mm Empty Pockets Min.40mm Tapa Leader Tape Trailer 7.Inner carton A n tistatic bag S ea l R eel L able L able R eel OUTET CARTON L able 7-1.MARKING www.jghcorp.com ShenZhen JingGuangHua Electronics Co.,Ltd. (1)Marking Labels are affixed to reel, inner carton and outer carton. (2) Each label contains the following information. (a) Manufacture’s name or symbol (b) Parts name or type (c) Frequency (d) Quantity (e) Reel number (f) Manufacturer’s code (EIAJ code) 7-2. QUANTITY 3000pcs/reel (max.5reels in outer carton) 7-3. STORAGE ENVIRONMENT      Storage the reel at normal temperature and humidity Open the packing just before using Do not expose the sun Do not storage with some erosive chemicals Nothing is allowed to put on the reel or carton to prevent mechanical damage 7-4. HANDLING  Handle with care to prevent the damage of tape, reel and products. www.jghcorp.com ShenZhen JingGuangHua Electronics Co.,Ltd.
G3236864062060A
物料型号:SMD GLASS 3225
器件简介:该文档描述的是一款SMD 3225封装的石英晶体谐振器,具有36.864MHz的标称频率。
引脚分配:文档中没有提供具体的引脚分配图,但通常SMD 3225封装的石英晶体谐振器会有2个引脚,分别为GND(接地)和输出。
参数特性: - 标称频率:36.864MHz - 振动模式:基础模式(Fundamental) - 频率容差:±20ppm(25°C时) - 温度频率稳定性:±30ppm - 工作温度范围:-40~85°C - 存储温度范围:-40~90°C - 负载电容:6pF - 静电容:不超过7pF - 等效电阻:最大60欧姆 - 激励功率:10微瓦 - 绝缘阻抗:500MΩ/100V(15V峰峰值) - 年老化率:第一年±3ppm
功能详解:文档没有提供详细的功能介绍,但石英晶体谐振器通常用于为电子设备提供稳定的时钟信号。
应用信息:该器件适用于需要精确时钟信号的各种电子设备,如通信设备、计算机、家用电器等。
封装信息:SMD GLASS 3225封装,尺寸和建议布局在文档中有详细说明,建议回流焊温度曲线也包括在内。
G3236864062060A 价格&库存
很抱歉,暂时无法提供与“G3236864062060A”相匹配的价格&库存,您可以联系我们找货
