XT25F08BSOIGU-S
XT25F08BSOIGU-S
    XTX(芯天下)
    SOP-8
    XT25F08BSOIGU-S
XT25F08BSOIGU-S 数据手册
3.3V QUAD IO Serial Flash XT25F08B-S Technology Limited XT25F08B-S Quad IO Serial NOR Flash Datasheet 深圳市芯天下技术有限公司 XTX Technology Limited Tel: (86 755) 28229862 Fax: (86 755) 28229847 Web Site: http://www.xtxtech.com/ Technical Contact: fae@xtxtech.com * Information furnished is believed to be accurate and reliable. However, XTX Technology Limited assumes no responsibility for the consequences of use of such information or for any infringement of patents of other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent rights of XTX Technology Limited. Specifications mentioned in this publication are subject to change without notice. This publication supersedes and replaces all information previously supplied. XTX Technology Limited products are not authorized for use as critical components in life support devices or systems without express written approval of XTX Technology Limited. The XTX logo is a registered trademark of XTX Technology Limited. All other names are the property of their respective own. Rev 0.2 April 1, 2020 Page 0 3.3V QUAD IO Serial Flash XT25F08B-S Serial NOR Flash Memory 3.3V Multi I/O with 4KB, 32KB & 64KB Sector/Block Erase  1024K-byte  15uA typical standby current  256 bytes per programmable page  0.06uA typical deep power down current Support SFDP & Unique ID  Standard, Dual, Quad SPI   Low Power Consumption     8M -bit Serial Flash  Single Power Supply Voltage: Full voltage range:  2.7~3.6V  Standard SPI: SCLK, CS#, SI, SO, WP#, HOLD#  Minimum 100,000 Program/Erase Cycle  Dual SPI: SCLK, CS#, IO0, IO1, WP#, HOLD#  High Speed Clock Frequency  Quad SPI: SCLK, CS#, IO0, IO1, IO2, IO3  108MHz for fast read with 30PF load Flexible Architecture  Dual I/O Data transfer up to 216Mbits/s  Sector of 4K-byte  Quad I/O Data transfer up to 432Mbits/s  Block of 32/64k-byte  Program/Erase Speed Advanced security Features  Page Program time: 0.4ms typical   Sector Erase time: 70ms typical Software/Hardware Write Protection  Block Erase time: 0.15/0.25s typical  Write protect all/portion of memory via software  Chip Erase time: 2.5s typical  Enable/Disable protection with WP# Pin  Top or Bottom, Sector or Block selection  4*256-Byte Security Registers With OTP Lock Package Options  See 1.1 Available Ordering OPN  All Pb-free packages are compliant RoHS, Halogen-Free and REACH.  Known Good Die “KGD”version  Temperature Range & Moisture Sensitivity Level  Rev 0.2 Industrial Level Temperature. (-40℃ to +85℃), MSL3 April 1, 2020 Page 1 3.3V QUAD IO Serial Flash XT25F08B-S CONTENTS 1. GENERAL DESCRIPTION ............................................................................................................3 1.1. Available Ordering OPN ................................................................................................................................... 3 1.2. Connection Diagram ........................................................................................................................................ 3 1.3. Pin Description ................................................................................................................................................ 4 1.4. Block Diagram ................................................................................................................................................. 5 2. MEMORY ORGANIZATION ........................................................................................................6 3. DEVICE OPERATION ..................................................................................................................7 4. DATA PROTECTION ...................................................................................................................8 5. STATUS REGISTER .....................................................................................................................9 6. COMMANDS DESCRIPTION.....................................................................................................11 6.1. Write Enable (WREN) (06H) ........................................................................................................................... 14 6.2. Write Enable for Volatile Status Register (50H) .............................................................................................. 14 6.3. Write Disable (WRDI) (04H) ........................................................................................................................... 14 6.4. Read Status Register (RDSR) (05H or 35H) ...................................................................................................... 15 6.5. Write Status Register (WRSR) (01H) ............................................................................................................... 15 6.6. Read Data Bytes (READ) (03H) ....................................................................................................................... 16 6.7. Read Data Bytes At Higher Speed (Fast Read) (0BH) ....................................................................................... 16 6.8. Dual Output Fast Read (3BH) ......................................................................................................................... 17 6.9. Quad Output Fast Read (6BH) ........................................................................................................................ 18 6.10. Dual I/O Fast Read (BBH) ............................................................................................................................... 18 6.11. Quad I/O Fast Read (EBH) .............................................................................................................................. 20 6.12. Quad I/O Word Fast Read (E7H) ..................................................................................................................... 21 6.13. Page Program (PP) (02H)................................................................................................................................ 22 6.14. Quad Page Program (QPP) (32H) .................................................................................................................... 22 6.15. 4 x I/O Page Program (4PP) ............................................................................................................................ 23 6.16. Sector Erase (SE) (20H) .................................................................................................................................. 24 6.17. 32KB Block Erase (BE) (52H) ........................................................................................................................... 24 6.18. 64KB Block Erase (BE) (D8H) .......................................................................................................................... 25 6.19. Chip Erase (CE) (60/C7H)................................................................................................................................ 26 6.20. Deep Power-Down (DP) (B9H)........................................................................................................................ 26 6.21. Release from Deep Power-Down and Read Device ID (RDI) (ABH)................................................................... 27 6.22. Read Manufacture ID/ Device ID (REMS) (90H)............................................................................................... 28 6.23. Continuous Read Mode Reset (CRMR) (FFH) .................................................................................................. 28 6.24. Read Manufacture ID/ Device ID Dual I/O (92H) ............................................................................................. 29 6.25. Read Manufacture ID/ Device ID Quad I/O (94H)............................................................................................ 30 6.26. Read Identification (RDID) (9FH) .................................................................................................................... 30 6.27. Erase Security Registers (44H)........................................................................................................................ 31 6.28. Program Security Registers (42H) ................................................................................................................... 31 Rev 0.2 April 1, 2020 Page 1 3.3V QUAD IO Serial Flash XT25F08B-S 6.29. Read Security Registers (48H) ........................................................................................................................ 32 6.30. Enable Reset (66H) and Reset (99H) ............................................................................................................... 33 6.31. Read Serial Flash Discoverable Parameter (5AH) ............................................................................................ 34 6.32. Read Unique ID (RUID)................................................................................................................................... 35 7. ELECTRICAL CHARACTERISTICS ...............................................................................................40 7.1. Power-on Timing............................................................................................................................................ 40 7.2. Initial Delivery State....................................................................................................................................... 40 7.3. Data Retention and Endurance ...................................................................................................................... 40 7.4. Latch up Characteristics ................................................................................................................................. 40 7.5. Absolute Maximum Ratings ........................................................................................................................... 41 7.6. Capacitance Measurement Condition ............................................................................................................ 41 7.7. DC Characteristics.......................................................................................................................................... 42 7.8. AC Characteristics .......................................................................................................................................... 43 8. ORDERING INFORMATION .....................................................................................................45 9. PACKAGE INFORMATION ........................................................................................................46 9.1. Package SOP8 150MIL.................................................................................................................................... 46 9.2. Package SOP8 208MIL.................................................................................................................................... 47 9.3. Package DFN8 (2x3x0.55) mm ........................................................................................................................ 48 10. REVISION HISTORY..................................................................................................................49 Rev 0.2 April 1, 2020 Page 2 XT25F08B-S 3.3V QUAD IO Serial Flash 1. GENERAL DESCRIPTION The XT25F08B-S (8M-bit) Serial flash supports the standard Serial Peripheral Interface (SPI), and supports the Dual/Quad SPI: Serial Clock, Chip Select, Serial Data I/O0 (SI), I/O1 (SO), I/O2 (WP#), and I/O3 (HOLD#). The Dual I/O data is transferred with speed of 216Mbits/s and the Quad I/O & Quad output data is transferred wit speed of 432Mbits/s. 1.1. 1.2. Available Ordering OPN OPN Package Type Package Carrier XT25F08BSOIGU-S SOP8 150mil Tube XT25F08BSOIGU-S SOP8 150mil Tube XT25F08BSSIGU-S SOP8 208mil Tube XT25F08BSSIGT-S SOP8 208mil Tape & Reel XT25F08BDFIGT-S DFN8 2x3x0.55 mm Tape & Reel Connection Diagram CS# 1 SO(IO1) 2 8 VCC 7 HOLD#(IO3) Top View WP#(IO2) 3 6 SCLK VSS 4 5 SI(IO0) 8 – LEAD SOP CS# 1 8 VCC 7 HOLD#(IO3) SO(IO1) 2 Top View 6 SCLK WP#(IO2) 3 5 SI(IO0) VSS 4 DFN8 Rev 0.2 April 1, 2020 Page 3 3.3V QUAD IO Serial Flash 1.3. Pin Description Pin Name I/O CS# I SO (IO1) I/O Data Output (Data Input Output 1) WP# (IO2) I/O Write Protect Input (Data Input Output 2) SI (IO0) I/O SCLK I HOLD# (IO3) I/O VCC Description Chip Select Input Ground VSS Rev 0.2 XT25F08B-S Data Input (Data Input Output 0) Serial Clock Input Hold Input (Data Input Output 3) Power Supply April 1, 2020 Page 4 XT25F08B-S 3.3V QUAD IO Serial Flash Block Diagram WP#(IO2) Write Control Logic Status Register HOLD#(IO3) SCLK CS# SPI Command & Control Logic High Voltage Generators Page Address Latch/Counter Flash Memory Column Decode And 256-Byte Page Buffer SI(IO0) SO(IO1) Rev 0.2 Write Protect Logic And Row Decode 1.4. Byte Address Latch/Counter April 1, 2020 Page 5 XT25F08B-S 3.3V QUAD IO Serial Flash 2. MEMORY ORGANIZATION XT25F08B-S Each Device has Each block has Each sector has Each page has 1M 64K/32K 4K 256 bytes 4K 256/128 16 - pages 256 16/8 - - sectors 16/32 - - - blocks UNIFORM BLOCK SECTOR ARCHITECTURE XT25F08B-S 64K Bytes Block Sector Architecture Block Sector Address range 255 15 14 0FF000H …… …… …… 0F0000H 0F0FFFH 239 0EF000H 0EFFFFH …… …… 0E0000H 1 0 Rev 0.2 …… 0E0FFFH …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 2 …… 240 224 …… 0FFFFFH 02F000H 02FFFFH …… …… …… 32 020000H 020FFFH 31 01F000H 01FFFFH …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… 0 000000H April 1, 2020 …… …… 000FFFH Page 6 3.3V QUAD IO Serial Flash XT25F08B-S 3. DEVICE OPERATION Standard SPI The XT25F08B-S features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. Note: “WP#” & “HOLD#” pin require external pull-up. Dual SPI The XT25F08B-S supports Dual SPI operation when using the “Dual Output Fast Read” and “Dual I/O Fast Read” (3BH and BBH) commands. These commands allow data to be transferred to or from the device at two times the rate of the standard SPI. When using the Dual SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. Note: “WP#” & “HOLD#” pin require external pull-up. Quad SPI The XT25F08B-S supports Quad SPI operation when using the “Quad Output Fast Read”, “Quad I/O Fast Read”, “Quad I/O Word Fast Read” (6BH, EBH, E7H) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1, and WP# and HOLD# pins become IO2 and IO3. Quad SPI commands require the non-volatile Quad Enable bit (QE) in Status Register to be set. Hold The HOLD# signal goes low to stop any serial communications with the device, but doesn’t stop the operation of write status register, programming, or erasing in progress. The operation of HOLD, need CS# keep low, and starts on falling edge of the HOLD# signal, with SCLK signal being low (if SCLK is not being low, HOLD operation will not start until SCLK being low). The HOLD condition ends on rising edge of HOLD# signal with SCLK being low (If SCLK is not being low, HOLD operation will not end until SCLK being low). The SO is high impedance, both SI and SCLK don’t care during the HOLD operation, if CS# drives high during HOLD operation, it will reset the internal logic of the device. To re-start communication with chip, the HOLD# must be at high and then CS# must be at low. Figure1. Hold Condition CS# SCLK HOLD# HOLD Rev 0.2 HOLD April 1, 2020 Page 7 XT25F08B-S 3.3V QUAD IO Serial Flash 4. DATA PROTECTION The XT25F08B-S provide the following data protection methods:  Write Enable (WREN) command: The WREN command is set the Write Enable Latch bit (WEL). The WEL bit will return to reset by the following situation:  Power-Up  Write Disable (WRDI)  Write Status Register (WRSR)  Page Program (PP)  Sector Erase (SE) / Block Erase (BE) / Chip Erase (CE)  Software Protection Mode: The Block Protect (BP3, BP2, BP1, BP0) bits define the section of the memory array that can be read but not change.  Hardware Protection Mode: WP# going low to protected the BP0~BP3 bits and SRP bit.  Deep Power-Down Mode: In Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down Mode command. Table1.0 XT25F08B-S Protected area size (CMP=0) Status Register Content Memory Content BP3 BP2 BP1 BP0 Blocks Addresses Density Portion 0 0 0 0 NONE NONE NONE NONE 0 0 0 1 Block 15 0F0000H – 100000H 64KB Upper 1/16 0 0 1 0 Block 14 – 15 0E0000H – 100000H 128K Upper 1/8 0 0 1 1 Block 12 – 15 0C0000H – 100000H 256K Upper 1/4 0 1 0 0 Block 8 – 15 080000H – 100000H 512K Upper 1/2 0 1 0 1 Protected all 000000H – 100000H 1M All 0 1 1 0 Protected all 000000H – 100000H 1M All 0 1 1 1 Protected all 000000H – 100000H 1M All 1 X X X Protected all 000000H – 100000H 1M All Table1.1 XT25F08B-S Protected area size (CMP=1) Status Register Content Rev 0.2 Memory Content BP3 BP2 BP1 BP0 Blocks Addresses Density Portion 0 0 0 0 NONE NONE NONE NONE 0 0 0 1 Block 0 000000H – 010000H 64KB Lower 1/16 0 0 1 0 Block 0 – 1 000000H – 020000H 128K Lower 1/8 0 0 1 1 Block 0 – 3 000000H – 040000H 256K Lower 1/4 0 1 0 0 Block 0 – 7 000000H – 080000H 512K Lower 1/2 0 1 0 1 Protected all 000000H – 100000H 1M All 0 1 1 0 Protected all 000000H – 100000H 1M All 0 1 1 1 Protected all 000000H – 100000H 1M All 1 X X X Protected all 000000H – 100000H 1M All April 1, 2020 Page 8 XT25F08B-S 3.3V QUAD IO Serial Flash 5. STATUS REGISTER S15 S14 S13 S12 S11 S10 S9 S8 Reserved CMP Reserved Reserved Reserved LB QE Reserved S7 S6 S5 S4 S3 S2 S1 S0 SRP Reserved BP3 BP2 BP1 BP0 WEL WIP The status and control bits of the Status Register are as follows: WIP bit. The Write In Progress (WIP) bit indicates whether the memory is busy in program/erase/write status register progress. When WIP bit sets to 1, means the device is busy in program/erase/write status register progress, when WIP bit sets 0, means the device is not in program/erase/write status register progress. WEL bit. The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write Status Register, Program or Erase command is accepted. BP3, BP2, BP1, BP0 bits. The Block Protect (BP3, BP2, BP1, BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase commands. These bits are written with the Write Status Register (WRSR) command. When the Block Protect (BP3, BP2, BP1, BP0) bits are set to 1, the relevant memory area (as defined in Table1.0 & 1.1) becomes protected against Page Program (PP), Sector Erase (SE) and Block Erase (BE) commands. The Block Protect (BP3, BP2, BP1, BP0) bits can be written provided that the Hardware Protected mode has not been set. The Chip Erase (CE) command is executed, if the Block Protect (BP3, BP2, BP1, BP0) bits are all 0. SRP bit. The Status Register Protect (SRP) bit is non-volatile Read/Write bits in the status register. The SRP bit controls the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable protection. SRP WP# Status Register Description 0 X Software Protected 1 0 Hardware Protected 1 1 Hardware Unprotected The Status Register can be written to after a Write Enable command, WEL=1.(Default) WP#=0, the Status Register locked and cannot be written until the next power-up. WP#=1, the Status Register is unlocked and can be written after a Write Enable command, WEL=1. QE bit. The Quad Enable (QE) bit is a non-volatile Read/Write bit in the Status Register that allows Quad operation. When the QE bit is set to 0 (Default) the WP# pin and HOLD# pin are enable. When the QE bit is set to 1, the Quad IO2 and IO3 pins are enabled. (The QE bit should never be set to 1 during standard SPI or Dual SPI operation if the WP# or HOLD# pins are tied directly to the power supply or ground). Rev 0.2 April 1, 2020 Page 9 3.3V QUAD IO Serial Flash XT25F08B-S LB bit. The LB bit is a non-volatile One Time Program (OTP) bit in Status Register (S10) that provide the write protect control and status to the Security Registers. The default state of LB is 0, the security registers are unlocked. LB can be set to 1 using the Write Register instruction. LB is One Time Programmable, once it’s set to 1, the Security Registers will become read-only permanently. CMP bit. The CMP bit is a non-volatile Read/Write bit in the Status Register (S14). It is used in conjunction with the BP3-BP0 bits to provide more flexibility for the array protection. Please see the Status registers Memory Protection table for details. The default setting is CMP=0. Rev 0.2 April 1, 2020 Page 10 XT25F08B-S 3.3V QUAD IO Serial Flash 6. COMMANDS DESCRIPTION All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-byte command code must be shifted in to the device, most significant bit first on SI, each bit being latched on the rising edges of SCLK. See Table2, every command sequence starts with a one-byte command code. Depending on the command, this might be followed by address bytes, or by data bytes, or by both or none. CS# must be driven high after the last bit of the command sequence has been shifted in. For the command of Read, Fast Read, Read Status Register or Release from Deep Power-Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. CS# can be driven high after any bit of the data-out sequence is being shifted out. For the command of Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Write Enable, Write Disable or Deep Power-Down command, CS# must be driven high exactly at a byte boundary, otherwise the command is rejected, and is not executed. That is CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if at any time the input byte is not a full byte, nothing will happen and WEL will not be reset. Table 2. Commands Command Name Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 n-Bytes Write Enable 06H Write Enable for Volatile Status Register 50H Write Disable 04H Read Status Register 05H (S7-S0) (continuous) Read Status Register-1 35H (S15-S8) (continuous) Write Status Register 01H (S7-S0) (S15-S8) Read Data 03H A23-A16 A15-A8 A7-A0 (D7-D0) Fast Read 0BH A23-A16 A15-A8 A7-A0 dummy Dual Output Fast Read 3BH A23-A16 A15-A8 A7-A0 dummy Dual I/O Fast Read BBH A23-A8(2) A7-A0 M7-M0(2) (D7-D0)(1) Quad Output Fast Read 6BH A23-A16 A15-A8 A7-A0 Quad I/O Fast Read EBH A23-A0 M7-M0(4) Dummy(5) (D7-D0)(3) (continuous) Quad I/O Word Fast Read E7H A23-A0 M7-M0(4) Dummy(6) (D7-D0)(3) (continuous) Continuous Read Reset FFH Page Program 02H A23-A16 A15-A8 A7-A0 (D7-D0) Quad Page Program 32H A15-A8 A7-A0 (D7-D0)(3) Quad I/O PP 38H Sector Erase 20H A23-A16 A23-A0 D7-D0 A23-A16 A15-A8 A7-A0 Block Erase(32KB) 52H A23-A16 A15-A8 A7-A0 Block Erase(64KB) D8H A23-A16 A15-A8 A7-A0 Chip Erase Deep Power-Down Rev 0.2 398 (continuous) (Next byte) (continuous) (D7-D0) (continuous) (D7-D0)(1) (continuous) (continuous) dummy (D7-D0)(3) (continuous) (Next byte) (Next byte) (Next byte) C7/60H B9H April 1, 2020 Page 11 XT25F08B-S 3.3V QUAD IO Serial Flash Release From Deep Power-Down, And Read Device ID ABH Release From Deep Power-Down ABH Manufacturer/Device ID dummy dummy dummy (DID7-DID0) (continuous) 90H dummy dummy 00H (MID7MID0) Manufacturer/Device ID by Dual I/O 92H A23-A8 A7-A0, M[7:0] (M7-M0) (ID7-ID0) Manufacturer/Device ID by Quad I/O 94H A23-A0, M[7:0] dummy (M7-M0) (ID7-ID0) Read Serial Flash Discoverable Parameters 5AH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (continuous) Read Unique ID 5AH 00h 01h 94h dummy (D7-D0) (continuous) Read Identification 9FH (MID7MID0) (JDID15-J DID8) (JDID7-JDI D0) Erase Security Register(8) 44H A23-A16 A15-A8 A7-A0 Program Security Register(8) 42H A23-A16 A15-A8 A7-A0 (D7-D0) (Next byte) Read Security Register(8) 48H A23-A16 A15-A8 A7-A0 dummy (D7-D0) Enable Reset 66H Reset 99H (DID7-DID0) (continuous) (continuous) (continuous) NOTE: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8,A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9,A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3, …..) 4. Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 Rev 0.2 April 1, 2020 Page 12 XT25F08B-S 3.3V QUAD IO Serial Flash 5. Quad I/O Fast Read Data IO0 = (x, x, x, x, D4, D0,…) IO1 = (x, x, x, x, D5, D1,…) IO2 = (x, x, x, x, D6, D2,…) IO3 = (x, x, x, x, D7, D3,…) 6. Quad I/O Word Fast Read Data IO0 = (x, x, D4, D0,…) IO1 = (x, x, D5, D1,…) IO2 = (x, x, D6, D2,…) IO3 = (x, x, D7, D3,…) 7. Quad I/O Word Fast Read Data: the lowest address bit must be 0. 8. Security Registers Address: Security Register1: A23-A16=00H, A15-A8=01H, A7-A0= Byte Address; Security Register2: A23-A16=00H, A15-A8=02H, A7-A0= Byte Address; Security Register3: A23-A16=00H, A15-A8=03H, A7-A0= Byte Address. Table of ID Definitions: XT25F08B-S Operation Code M7-M0 ID15-ID8 9FH 0B 40 90H 0B 14 13 ABH Rev 0.2 ID7-ID0 13 April 1, 2020 Page 13 3.3V QUAD IO Serial Flash 6.1. XT25F08B-S Write Enable (WREN) (06H) The Write Enable (WREN) command is for setting the Write Enable Latch (WEL) bit. The Write Enable Latch (WEL) bit must be set prior to every Page Program (PP), Sector Erase (SE), Block Erase (BE), Chip Erase (CE) and Write Status Register (WRSR) command. The Write Enable (WREN) command sequence: CS# goes low, sending the Write Enable command, CS# goes high. Figure2. Write Enable Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI SO 6.2. 06H High-Z Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical nonvolatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Write Enable for Volatile Status Register command must be issued prior to a Write Status Register command and any other commands can't be inserted between them. Otherwise, Write Enable for Volatile Status Register will be cleared. The Write Enable for Volatile Status Register command will not set the Write Enable Latch bit, it is only valid for the Write Status Register command to change the volatile Status Register bit values. Figure3. Write Enable for Volatile Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI SO 6.3. 50H High-Z Write Disable (WRDI) (04H) The Write Disable command is for resetting the Write Enable Latch (WEL) bit. The Write Disable command sequence: CS# goes low, sending the Write Disable command, CS# goes high. The WEL bit is reset by following condition: Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Block Erase and Chip Erase commands. Rev 0.2 April 1, 2020 Page 14 XT25F08B-S 3.3V QUAD IO Serial Flash Figure 4. Write Disable Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 04H High-Z SO 6.4. Read Status Register (RDSR) (05H or 35H) The Read Status Register (RDSR) command is for reading the Status Register. The Status Register can be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”, the SO will output Status Register bits S7~S0. The command code “35H”, the SO will output Status Register bits S15~S8. Figure 5. Read Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI 05H or 35H S7~S0 or S15~S8 out SO High-Z 7 6 5 4 3 2 1 MSB 6.5. S7~S0 or S15~S8 out 0 7 6 5 4 3 2 1 0 7 MSB Write Status Register (WRSR) (01H) The Write Status Register (WRSR) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). The Write Status Register (WRSR) command has no effect on S15, S1 and S0 of the Status Register. CS# must be driven high after the eighth or sixteen bit of the data byte has been latched in. If not, the Write Status Register (WRSR) command is not executed. If CS# is driven high after eighth bit of the data byte, the CMP and QE bit will be cleared to 0. As soon as CS# is driven high, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register can still be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. The Write Status Register (WRSR) command allows the user to change the values of the Block Protect (BP3, BP2, BP1, BP0) bits, to define the size of the area that is to be treated as read-only, as defined in Table1. The Write Status Register (WRSR) command also allows the user to set or reset the Status Register Protect (SRP) bit in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP) bit and Write Protect (WP#) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register (WRSR) command is not executed once the Hardware Protected Mode is entered. Rev 0.2 April 1, 2020 Page 15 XT25F08B-S 3.3V QUAD IO Serial Flash Figure 6. Write Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI Status Register in 7 6 5 4 3 2 1 01H MSB 0 15 14 13 12 11 10 9 8 MSB High-Z SO 6.6. Read Data Bytes (READ) (03H) The Read Data Bytes (READ) command is followed by a 3-byte address (A23-A0), each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fR, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. The whole memory can, therefore, be read with a single Read Data Bytes (READ) command. Any Read Data Bytes (READ) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 7. Read Data Bytes Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 SCLK Command SI 03H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB SO 6.7. Data Out1 High-Z MSB 7 6 5 4 3 2 1 Data Out2 0 Read Data Bytes At Higher Speed (Fast Read) (0BH) The Read Data Bytes at Higher Speed (Fast Read) command is for fast reading data out. It is followed by a 3byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Rev 0.2 April 1, 2020 Page 16 XT25F08B-S 3.3V QUAD IO Serial Flash Figure 8. Read Data Bytes at Higher Speed Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 0BH 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO Data Out2 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB 6.8. Data Out3 Dual Output Fast Read (3BH) The Dual Output Fast Read command is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The command sequence is shown in Figure 9. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Figure 9. Dual Output Fast Read Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 3BH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 6 4 2 0 6 4 2 Data Out1 SO Rev 0.2 0 6 4 2 0 6 4 2 Data Out2 7 5 3 1 7 5 3 MSB MSB April 1, 2020 Data Out3 0 6 Data Out4 1 7 5 3 1 7 5 3 MSB MSB 1 7 Page 17 XT25F08B-S 3.3V QUAD IO Serial Flash 6.9. Quad Output Fast Read (6BH) The Quad Output Fast Read command is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO3, IO2, IO1 and IO0. The command sequence is shown in Figure 10. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Figure 10. Quad Output Fast Read Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI(IO0) 6BH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO(IO1) High-Z WP#(IO2) High-Z HOLD#(IO3) CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 Byte7 Byte8 6.10. Dual I/O Fast Read (BBH) The Dual I/O Fast Read command is similar to the Dual Output Fast Read command but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte 2-bit per clock by SI and SO, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The command sequence is shown in Figure 11. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Dual I/O Fast Read with “Continuous Read Mode” The Dual I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7- 0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) =(1, 0), then the next Dual I/O Fast Read command (after CS# is raised and then lowered) does not require the BBH command code. The command sequence is shown in figure 12. If the “Continuous Read Mode” bits (M5- 4) do not equal (1, 0), the next command requires the first BBH command code, thus returning to normal operaRev 0.2 April 1, 2020 Page 18 XT25F08B-S 3.3V QUAD IO Serial Flash tion. A “Continuous Read Mode” Reset command can be used to reset (M5- 4) before issuing normal command. Figure 11. Dual I/O Fast Read Sequence Diagram (M5-4≠(1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 BBH SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS# 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Byte5 Byte4 Byte3 Byte2 Byte6 Figure 12. Dual I/O Fast Read Sequence Diagram (M5-4= (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS# 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Rev 0.2 Byte2 April 1, 2020 Byte3 Byte4 Page 19 XT25F08B-S 3.3V QUAD IO Serial Flash 6.11. Quad I/O Fast Read (EBH) The Quad I/O Fast Read command is similar to the Dual I/O Fast Read command but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte and 4-dummy clock 4-bits per clock by IO0, IO1, IO3, IO4, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO0, IO1, IO2, IO3. The command sequence is shown in Figure 13. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Fast read command. Quad I/O Fast Read with “Continuous Read Mode” The Quad I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) =(1, 0), then the next Quad I/O Fast Read command (after CS# is raised and then lowered) does not require the EBH command code. The command sequence is shown in Figure 14. If the “Continuous Read Mode” (M5- 4) do not equal (1, 0), the next command requires the first EBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5- 4) before issuing normal command. Figure 13. Quad I/O Fast Read Sequence Diagram (M5-4≠(1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 EBH A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Figure 14. Quad I/O Fast Read Sequence Diagram (M5-4= (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Rev 0.2 April 1, 2020 Dummy Byte1 Byte2 Page 20 XT25F08B-S 3.3V QUAD IO Serial Flash 6.12. Quad I/O Word Fast Read (E7H) The Quad I/O Word Fast Read command is similar to the Quad I/O Fast Read command except that the lowest address bit (A0) must equal 0 and only 2-dummy clock. The command sequence is shown in followed Figure 15. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Word Fast read command. Quad I/O Word Fast Read with “Continuous Read Mode” The Quad I/O Word Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) =(1, 0), then the next Quad I/O Word Fast Read command (after CS# is raised and then lowered) does not require the E7H command code. The command sequence is shown in followed Figure 16. If the “Continuous Read Mode” bits (M5- 4) do not equal (1, 0), the next command requires the first E7H command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M7-0) before issuing normal command. Figure 15. Quad I/O Word Fast Read Sequence Diagram (M5-4≠(1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 E7H A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Byte3 Figure16. Quad I/O Word Fast Read Sequence Diagram (M5-4= (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte1 Byte2 Rev 0.2 April 1, 2020 Page 21 XT25F08B-S 3.3V QUAD IO Serial Flash 6.13. Page Program (PP) (02H) The Page Program (PP) command is for programming the memory. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Page Program (PP) command is entered by driving CS# Low, followed by the command code, three address bytes and at least one data byte on SI. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven low for the entire duration of the sequence. The Page Program command sequence: CS# goes low sending Page Program command 3-byte address on SI at least 1 byte data on SI CS# goes high. The command sequence is shown in Figure17. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven high after the eighth bit of the last data byte has been latched in; otherwise the Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Page Program (PP) command applied to a page which is protected by the Block Protect (BP3, BP2, BP1, BP0) is not executed. Figure 17. Page Program Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 02H 23 22 21 20 19 Data Byte1 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 2072 2073 2074 2075 2076 2077 2078 2079 CS# SCLK Data Byte2 SI Data Byte3 Data Byte4 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB MSB Data Byte256 7 6 5 4 3 2 1 0 MSB 6.14. Quad Page Program (QPP) (32H) The Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. To use Quad Page Program the Quad enable in status register Bit9 must be set (QE=1). A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Quad Page Program command is entered by driving CS# Low, followed by the command code (32H), three address bytes and at least one data byte on IO pins. The command sequence is shown in Figure 18. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven high after the eighth bit of the last data byte has been latched in; otherwise the Quad Page Program command is not executed. Rev 0.2 April 1, 2020 Page 22 XT25F08B-S 3.3V QUAD IO Serial Flash As soon as CS# is driven high, the self-timed Quad Page Program cycle (whose duration is tPP) is initiated. While the Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Quad Page Program command applied to a page which is protected by the Block Protect (BP3, BP2, BP1, BP0) will not be executed. Figure 18. Quad Page Program Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 32H 23 22 21 20 19 7 6 5 4 3 2 1 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 MSB Byte1 Byte2 Byte3 Byte4 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 536 537 538 539 540 541 542 543 CS# SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 Byte5 Byte6 Byte7 Byte8 Byte9 Byte10 Byte11 Byte12 Byte13 Byte14 Byte15 Byte16 Byte253 Byte254 Byte255 Byte256 6.15. 4 x I/O Page Program (4PP) The Quad Page Program (4PP) instruction is for programming the memory to be "0". A Write Enable (WREN) instruction must execute to set the Write Enable Latch (WEL) bit and Quad Enable (QE) bit must be set to "1" before sending the Quad Page Program (4PP). The Quad Page Programming takes four pins: SIO0, SIO1, SIO2, and SIO3 as address and data input, which can improve programmer performance and the effectiveness of application. The 4PP operation frequency supports as fast as f4PP. The other function descriptions are as same as standard page program. The sequence of issuing 4PP instruction is: CS# goes low  sending 4PP instruction code  3-byte address on SIO[3:0]  at least 1-byte on data on SIO[3:0]  CS# goes high. Rev 0.2 April 1, 2020 Page 23 XT25F08B-S 3.3V QUAD IO Serial Flash Figure 19. Quad I/O Page Program Sequence Diagram 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 536 537 538 539 540 541 542 543 CS SCLK Command SI 24-bit addr 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 38H Byte1 Byte2 Byte3 Byte4 Byte253 Byte254 Byte255 Byte256 6.16. Sector Erase (SE) (20H) The Sector Erase (SE) command is for erasing the all data of the chosen sector. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Sector Erase (SE) command is entered by driving CS# low, followed by the command code, and 3-address byte on SI. Any address inside the sector is a valid address for the Sector Erase (SE) command. CS# must be driven low for the entire duration of the sequence. The Sector Erase command sequence: CS# goes low sending Sector Erase command 3-byte address on SI, CS# goes high. The command sequence is shown in Figure 20. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the Sector Erase (SE) command is not executed. As soon as CS# is driven high, the self-timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Sector Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Sector Erase (SE) com-mand applied to a sector which is protected by the Block Protect (BP3, BP2, BP1, BP0) bit (see Table1.0&1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus recommend to perform a re-erase once power resume. Figure 20. Sector Erase Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 20H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.17. 32KB Block Erase (BE) (52H) The 32KB Block Erase (BE) command is for erasing the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 32KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and three address bytes on SI. Any address inside the block is a valid address for the 32KB Block Erase (BE) command. CS# must be driven low for the entire duration of the sequence. Rev 0.2 April 1, 2020 Page 24 XT25F08B-S 3.3V QUAD IO Serial Flash The 32KB Block Erase command sequence: CS# goes low sending 32KB Block Erase command 3-byte address on SI, CS# goes high. The command sequence is shown in Figure21. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 32KB Block Erase (BE) command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 32KB Block Erase (BE) command applied to a block which is protected by the Block Protect (BP3, BP2, BP1, BP0) bits (see Table1.0 & 1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus recommend to perform a re-erase once power resume. Figure 21. 32KB Block Erase Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 52H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.18. 64KB Block Erase (BE) (D8H) The 64KB Block Erase (BE) command is for erasing the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 64KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and three address bytes on SI. Any address inside the block is a valid address for the 64KB Block Erase (BE) command. CS# must be driven low for the entire duration of the sequence. The 64KB Block Erase command sequence: CS# goes low sending 64KB Block Erase command 3-byte address on SI, CS# goes high. The command sequence is shown in Figure 22. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 64KB Block Erase (BE) command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 64KB Block Erase (BE) command applied to a block which is protected by the Block Protect (BP3, BP2, BP1, BP0) bits (see Table1.0 & 1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus recommend to perform a re-erase once power resume. Figure 22. 64KB Block Erase Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI D8H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Rev 0.2 April 1, 2020 Page 25 3.3V QUAD IO Serial Flash XT25F08B-S 6.19. Chip Erase (CE) (60/C7H) The Chip Erase (CE) command is for erasing the all data of the chip. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit .The Chip Erase (CE) command is entered by driving CS# Low, followed by the command code on Serial Data Input (SI). CS# must be driven Low for the entire duration of the sequence. The Chip Erase command sequence: CS# goes low, sending Chip Erase command, CS# goes high. The command sequence is shown in Figure 23. CS# must be driven high after the eighth bit of the command code has been latch in, otherwise the Chip Erase command is not executed. As soon as CS# is driven high, the selftimed Chip Erase cycle (whose duration is tCE) is initiated. While the Chip Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Chip Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Chip Erase (CE) command is executed if the Block Protect (BP3,BP2, BP1, BP0) bits are all 0. The Chip Erase (CE) command is ignored if one or more sectors are protected. Note: Power disruption during erase operation will cause incomplete erase, thus recommend to perform a re-erase once power resume. Figure 23. Chip Erase Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 60H or C7H 6.20. Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (DP) command is the only way to put the device in the lowest consumption mode (the Deep Power-Down Mode). It can also be used as an extra software protection mechanism, while the device is not in active use, since in this mode, the device ignores all Write, Program and Erase commands. Driving CS# high deselects the device, and puts the device in the Standby Mode (if there is no internal cycle currently in progress). But this mode is not the Deep Power-Down Mode. The Deep Power-Down Mode can only be entered by executing the Deep Power-Down (DP) command. Once the device has entered the Deep PowerDown Mode, all commands are ignored except the Release from Deep Power-Down and Read Device ID (RDI) command. This releases the device from this mode. The Release from Deep Power-Down and Read Device ID (RDI) command also allows the Device ID of the device to be output on SO. The Deep Power-Down Mode automatically stops at Power-Down, and the device always Power-Up in the Standby Mode. The Deep Power-Down (DP) command is entered by driving CS# low, followed by the command code on SI. CS# must be driven low for the entire duration of the sequence. The Deep Power-Down command sequence: CS# goes low, sending Deep Power-Down command, CS# goes high. The command sequence is shown in Figure 24. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Deep Power-Down (DP) command is not executed. As soon as CS# is driven high, it requires a delay of tDP before the supply current is reduced to ICC2 and the Deep PowerDown Mode is entered. Any Deep Power-Down (DP) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Rev 0.2 April 1, 2020 Page 26 XT25F08B-S 3.3V QUAD IO Serial Flash Figure 24. Deep Power-Down Sequence Diagram CS# tDP 0 1 2 3 4 5 6 7 SCLK Command SI Stand-by mode Deep Power-down mode B9H 6.21. Release from Deep Power-Down and Read Device ID (RDI) (ABH) The Release from Power-Down and Read/Device ID command is a multi-purpose command. It can be used to release the device from the Power-Down state or obtain the devices electronic identification (ID) number. To release the device from the Power-Down state, the command is issued by driving the CS# pin low, shifting the instruction code “ABH” and driving CS# high as shown in Figure24. Release from Power-Down will take the time duration of tRES1 (See AC Characteristics) before the device will resume normal operation and other command are accepted. The CS# pin must remain high during the tRES1 time duration. When used only to obtain the Device ID while not in the Power-Down state, the command is initiated by driving the CS# pin low and shifting the instruction code “ABH” followed by 3-dummy byte. The Device ID bits are then shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in Figure25. The Device ID value for the XT25F08B-S is listed in Manufacturer and Device Identification table. The Device ID can be read continuously. The command is completed by driving CS# high. When used to release the device from the Power-Down state and obtain the Device ID, the command is the same as previously described, and shown in Figure 25, except that after CS# is driven high it must remain high for a time duration of tRES2 (See AC Characteristics). After this time duration the device will resume normal operation and other command will be accepted. If the Release from Power-Down/Device ID command is issued while an Erase, Program or Write cycle is in process (when WIP equal 1) the command is ignored and will not affects on the current cycle. Figure 25. Release Power-Down Sequence Diagram CS tRES1 0 1 2 3 4 5 6 7 SCLK Command SI ABH Deep Power-down mode Rev 0.2 April 1, 2020 Stand-by mode Page 27 XT25F08B-S 3.3V QUAD IO Serial Flash Figure 26. Release Power-Down/Read Device ID Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 SCLK Command SI ABH tRES2 3 Dummy Bytes 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Device ID High-Z SO MSB 7 6 5 4 3 2 1 0 Stand-by Mode 6.22. Read Manufacture ID/ Device ID (REMS) (90H) The Read Manufacturer/Device ID command is an alternative to the Release from Power-Down / Device ID command that provides both the JEDEC assigned Manufacturer ID and the specific Device ID. The command is initiated by driving the CS# pin low and shifting the command code “90H” followed by a 24-bit address (A23-A0) of 000000H. After which, the Manufacturer ID and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first is shown in Figure 27. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure 27. Read ID Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 90H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK SI Manufacturer ID SO Manufacturer ID Device ID 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB MSB 6.23. Continuous Read Mode Reset (CRMR) (FFH) The Dual/Quad I/O Fast Read operations, “Continuous Read Mode” bits (M7-0) are implemented to further reduce command overhead. By setting the (M7-0) to AXH, the next Dual/Quad I/O Fast Read operations do not require the BBH/EBH/E7H command code. Because the XT25F08B-S has no hardware reset pin, so if Continuous Read Mode bits are set to “AXH”, the XT25F08B-S will not recognize any standard SPI commands. So Continuous Read Mode Reset command will reRev 0.2 April 1, 2020 Page 28 XT25F08B-S 3.3V QUAD IO Serial Flash lease the Continuous Read Mode from the “AXH” state and allow standard SPI command to be recognized. The command sequence is shown in Figure 28. Figure 28. Continuous Read Mode Reset Sequence Diagram Mode Bit Reset for Quad/ Dual I/O CS# 0 1 2 3 4 5 6 7 SCLK SI(IO0) FFH SO(IO1) Don’t care WP#(IO2) Don’t care HOLD#(IO3) Don’t care 6.24. Read Manufacture ID/ Device ID Dual I/O (92H) The Read Manufacturer/Device ID Dual I/O command is an alternative to the Release from Power-Down / Device ID command that provides both the JEDEC assigned Manufacturer ID and the specific Device ID by dual I/O. The command is initiated by driving the CS# pin low and shifting the command code “92H” followed by a 24-bit address (A23-A0) of 000000H. After which, the Manufacturer ID and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in Figure 28.1 If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure 28.1. Read Manufacture ID/ Device ID Dual I/O Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 92H SO(IO1) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 MFR ID Rev 0.2 Device ID MFR ID (Repeat) April 1, 2020 Device ID (Repeat) MFR ID (Repeat) Device ID (Repeat) Page 29 XT25F08B-S 3.3V QUAD IO Serial Flash 6.25. Read Manufacture ID/ Device ID Quad I/O (94H) The Read Manufacturer/Device ID Quad I/O command is an alternative to the Release from Power-Down / Device ID command that provides both the JEDEC assigned Manufacturer ID and the specific Device ID by quad I/O. The command is initiated by driving the CS# pin low and shifting the command code “94H” followed by a 24-bit address (A23-A0) of 000000H. After which, the Manufacturer ID and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first is shown in Figure 29. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure 29. Read Manufacture ID/ Device ID Quad I/O Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 94H HOLD#(IO3) A23-16 A15-8 A7-0 M7-0 Dummy MID DID MID DID MID DID 6.26. Read Identification (RDID) (9FH) The Read Identification (RDID) command allows the 8-bit manufacturer identification to be read, followed by two bytes of device identification. The device identification indicates the memory type in the first byte, and the memory capacity of the device in the second byte. Any Read Identification (RDID) command while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The Read Identification (RDID) command should not be issued while the device is in Deep Power-Down Mode. The device is first selected by driving CS# to low. Then, the 8-bit command code for the command is shifted in. This is followed by the 24-bit device identification, stored in the memory, being shifted out on Serial Data Output, each bit being shifted out during the falling edge of Serial Clock. The command sequence is shown in Figure30. The Read Identification (RDID) command is terminated by driving CS# to high at any time during data output. When CS# is driven high, the device is put in the Standby Mode. Once in the Standby Mode, the device waits to be selected, so that it can receive, decode and execute commands. Figure 30. Read Identification ID Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK Command SI 9FH Manufacturer ID SO High-Z 7 6 5 4 3 2 1 Memory Type JDID15-JDID8 0 7 6 5 4 3 2 1 Capacity JDID7-JDID0 0 7 6 5 4 3 2 1 0 High-Z MSB Rev 0.2 April 1, 2020 Page 30 XT25F08B-S 3.3V QUAD IO Serial Flash 6.27. Erase Security Registers (44H) The XT25F08B-S provides four 256-byte Security Registers which only erased all at once but able to program individually. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. The Erase Security Registers command is similar to Sector/Block Erase command. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Erase Security Registers command sequence: CS# goes low, sending Erase Security Registers Command, CS# goes high. The command sequence is shown in Figure 33. CS# must be driven high after the eighth bit of the command code has been latched in, otherwise the Erase Security Registers command is not executed. As soon as CS# is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Erase Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Security Registers Lock Bit (LB) in the Status Register can be used to OTP protect the security registers. Once the LB bit is set to 1, the Security Registers will be permanently locked; the Erase Security Registers command will be ignored. Address A23-A16 A15-A10 A9-A0 Security Registers 00000000 000000 Don’t Care Figure 33. Erase Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 44H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.28. Program Security Registers (42H) The Program Security Registers command is similar to the Page Program command. It allows from 1 to 256 bytes Security Registers data to be programmed. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Program Security Registers command. The Program Security Registers command is entered by driving CS# Low, followed by the command code (42H), three address bytes and at least one data byte on SI. As soon as CS# is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. If the Security Registers Lock Bit (LB) is set to 1, the Security Registers will be permanently locked. Program Security Registers command will be ignored. Address Rev 0.2 A23-A16 A15-A8 Security Registers 0 00H 00H Byte Address Security Registers 1 00H 01H Byte Address Security Registers 2 00H 02H Byte Address Security Registers 3 00H 03H Byte Address April 1, 2020 A7-A0 Page 31 XT25F08B-S 3.3V QUAD IO Serial Flash Figure 34. Program Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 42H 23 22 21 20 19 Data Byte1 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 2072 2073 2074 2075 2076 2077 2078 2079 CS# SCLK Data Byte2 SI Data Byte3 Data Byte4 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB MSB Data Byte256 7 6 5 4 3 2 1 0 MSB 6.29. Read Security Registers (48H) The Read Security Registers command is similar to Fast Read command. The command is followed by a 3byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Once the A9-A0 address reaches the last byte of the register (Byte 3FFH), it will reset to 000H, the command is completed by driving CS# high. Address Security Registers Rev 0.2 A23-A16 A15-A10 A9-A0 00000000 000000 Address April 1, 2020 Page 32 XT25F08B-S 3.3V QUAD IO Serial Flash Figure 35. Read Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 48H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO 7 6 5 4 3 2 1 Data Out2 0 7 6 5 4 3 2 1 Data Out3 0 MSB MSB 6.30. Enable Reset (66H) and Reset (99H) If the Reset command is accepted, any on-going internal operation will be terminated and the device will return to its default power-on state and lose all the current volatile settings, such as Volatile Status Register bits, Write Enable Latch status (WEL), Read Parameter setting (P7-P0) and Wrap Bit Setting (W6-W4). The “Reset (99H)” command sequence as follow: CS# goes low Sending Enable Reset command CS# goes high CS# goes low Sending Reset command CS# goes high. Once the Reset command is accepted by the device, the device will take approximately tRSTR to reset. During this period, no command will be accepted. Data corruption may happen if there is an internal Erase or Program operation when Reset command sequence is accepted by the device. It is recommended to check the BUSY bit in Status Register before issuing the Reset command sequence. Figure 36. Enable Reset and Reset command Sequence Diagram CS# 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCLK Command SI Rev 0.2 High-Z 66H Command 99H April 1, 2020 Page 33 XT25F08B-S 3.3V QUAD IO Serial Flash 6.31. Read Serial Flash Discoverable Parameter (5AH) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be interrogated by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. SFDP is a standard of JEDEC Standard No.216. Figure 37. Read Serial Flash Discoverable Parameter command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 5AH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO Data Out3 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB Rev 0.2 Data Out2 April 1, 2020 Page 34 XT25F08B-S 3.3V QUAD IO Serial Flash 6.32. Read Unique ID (RUID) The Read Unique ID command accesses a factory-set read-only 128bit number that is unique to each XT25F08B-S device. The Unique ID can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID command sequence: CS# goes low → sending Read Unique ID command →00H →01H →94H → Dummy byte 128bit Unique ID Out → CS# goes high. The command sequence is show below. Figure 37.1. Read Unique ID (RUID) Sequence (Command 5AH) CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 5AH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 160 161 162 163 164 165 166 167 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 128 bit unique serial number SO 12 12 12 12 12 12 12 12 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB Rev 0.2 April 1, 2020 Page 35 XT25F08B-S 3.3V QUAD IO Serial Flash Table 3. Signature and Parameter Identification Data Values Description SFDP Signature Comment Fixed:50444653H Add(H) DW Add (Byte) (Bit) 00H Data Data 07:00 53H 53H 01H 15:08 46H 46H 02H 23:16 44H 44H 03H 31:24 50H 50H SFDP Minor Revision Number Start from 00H 04H 07:00 00H 00H SFDP Major Revision Number Start from 01H 05H 15:08 01H 01H Number of Parameters Headers Start from 00H 06H 23:16 01H 01H 07H 31:24 FFH FFH 08H 07:00 00H 00H Start from 0x00H 09H 15:08 00H 00H Start from 0x01H 0AH 23:16 01H 01H 0BH 31:24 09H 09H 0CH 07:00 30H 30H 0DH 15:08 00H 00H 0EH 23:16 00H 00H Unused ID number (JEDEC) Contains 0xFFH and can never be changed 00H: It indicates a JEDEC specified header Parameter Table Minor Revision Number Parameter Table Major Revision Number Parameter Table Length (in double word) How many DWORDs in the Parameter table First address of JEDEC Flash Parameter Table Pointer (PTP) Unused ID Number(XTX Manufacturer ID) Parameter Table Minor Revision Number Parameter Table Major Revision Number Parameter Table Length (in double word) Parameter table Contains 0xFFH and can never be 0FH 31:24 FFH FFH changed It is indicates XTX manufacturer ID 10H 07:00 0BH 0BH Start from 0x00H 11H 15:08 00H 00H Start from 0x01H 12H 23:16 01H 01H 13H 31:24 03H 03H 14H 07:00 60H 60H 15H 15:08 00H 00H 16H 23:16 00H 00H 17H 31:24 FFH FFH How many DWORDs in the Parameter table First address of XTX Flash Parameter Table Pointer (PTP) Parameter table Contains 0xFFH and can never be Unused Rev 0.2 changed April 1, 2020 Page 36 XT25F08B-S 3.3V QUAD IO Serial Flash Table 4. Parameter Table (0): JEDEC Flash Parameter Tables Description Comment Add(H) DW Add (Byte) (Bit) Data Data 00: Reserved; 01: 4KB erase; Block/Sector Erase Size 10: Reserved; 01:00 01b 02 1b 03 0b 11: not support 4KB erase Write Granularity 0: 1Byte, 1: 64Byte or larger Write Enable Instruction Re- 0: Nonvolatile status quested for Writing to Volatile bit 1: Volatile statusbit Status Registers (BP status register bit) 30H E5H 0: Use 50H Opcode, Write Enable Opcode Select for 1: Use 06H Opcode, Writing to Volatile Status Regis- Note:If target flash status register is 04 0b 07:05 111b 15:08 20H 16 1b 18:17 00b 19 0b 0=Not support, 1=Support 20 1b (1-4-4) Fast Read 0=Not support, 1=Support 21 1b (1-1-4) Fast Read 0=Not support, 1=Support 22 1b 23 1b 33H 31:24 FFH 37H:34H 31:00 ters Unused Nonvolatile, then bits 3 and 4 must be set to 00b. Contains 111b and can never be changed 31H 4KB Erase Opcode (1-1-2) Fast Read 0=Not support, 1=Support Address Bytes Number used in 00: 3Byte only, 01: 3 or 4Byte, addressing flash array Double Transfer Rate (DTR) 10: 4Byte only, 11: Reserved clocking (1-2-2) Fast Read 0=Not support, 1=Support 32H Unused Unused Flash Memory Density (1-4-4) Fast Read Number of 0 0000b: Wait states (Dummy Wait states (1-4-4) Fast Read Number of Clocks) not support Mode Bits (1-4-4) Fast Read Opcode 0 0000b: Wait states (Dummy Wait states (1-1-4) Fast Read Number of Clocks) not support Mode Bits (1-1-4) Fast Read Opcode Rev 0.2 3BH April 1, 2020 00100b 44H 07:05 010b 15:08 EBH 20:16 01000b 3AH 000b:Mode Bits not support FFH 007FFFFFH 38H 39H (1-1-4) Fast Read Number of F1H 04:00 000b:Mode Bits not support 20H EBH 08H 23:21 000b 31:24 6BH 6BH Page 37 XT25F08B-S 3.3V QUAD IO Serial Flash Description Comment (1-1-2) Fast Read Number of 0 0000b: Wait states (Dum- Wait states (1-1-2) Fast Read Number my Clocks) not support of Mode Bits (1-1-2) Fast Read Opcode Add(H) DW Add (Byte) (Bit) 04:00 3DH (1-2-2) Fast Read Number of Wait (2-2-2) Fast Read 3FH 0=not support 1=support Unused (4-4-4) Fast Read 08H 07:05 000b 15:08 3BH 20:16 00010b 3EH Bits (1-2-2) Fast Read Opcode 0=not support 1=support 40H Unused Data 01000b 3CH 000b: Mode Bits not support states (1-2-2) Fast Read Number of Mode Data 3BH 42H 23:21 010b 31:24 BBH 00 0b 03:01 111b 04 0b 07:05 111b BBH EEH Unused 43H:41H 31:08 0xFFH 0xFFH Unused 45H:44H 15:00 0xFFH 0xFFH 20:16 00000b (2-2-2) Fast Read Number of Wait 0 0000b: Wait states (Dummy states (2-2-2) Fast Read Number of Mode Clocks) not support Bits (2-2-2) Fast Read Opcode (4-4-4) Fast Read Number of Wait 0 0000b: Wait states (Dummy states (4-4-4) Fast Read Number of Mode Clocks) not support 0x00b: this sector type don’t exist Sector Type 1 erase Opcode Sector/block size=2^N bytes Sector Type 2 Size Sector/block size=2^N bytes Sector/block size=2^N bytes FFH FFH 49H:48H 15:00 0xFFH 0xFFH 20:16 00000b 4AH 00H 23:21 000b 4BH 31:24 FFH FFH 4CH 07:00 0CH 0CH 4DH 15:08 20H 20H 4EH 23:16 0FH 0FH 4FH 31:24 52H 52H 50H 07:00 10H 10H 51H 15:08 D8H D8H 52H 23:16 00H 00H 53H 31:24 FFH FFH 0x00b: this sector type don’t exist Sector Type 4 erase Opcode Rev 0.2 31:24 0x00b: this sector type don’t exist Sector Type 3 erase Opcode Sector Type 4 Size 47H 0x00b: this sector type don’t exist Sector Type 2 erase Opcode Sector Type 3 Size 000b 000b: Mode Bits not support Sector/block size=2^N bytes Sector Type 1 Size 00H 23:21 000b: Mode Bits not support Unused Bits (4-4-4) Fast Read Opcode 46H April 1, 2020 Page 38 XT25F08B-S 3.3V QUAD IO Serial Flash Table 5. Parameter Table (1): XTX Flash Parameter Tables Description Comment Add(H) DW Add (Byte) (Bit) 61H:60H 63H:62H Data Data 15:00 3600H 3600H 31:16 2700H 2700H 2000H=2.000V Vcc Supply Maximum Voltage 2700H=2.700V 3600H=3.600V 1650H=1.650V Vcc Supply Minimum Voltage 2250H=2.250V 2300H=2.300V 2700H=2.700V HW Reset# pin 0=not support 1=support 00 0b HW Hold# pin 0=not support 1=support 01 0b Deep Power Down Mode 0=not support 1=support 02 1b SW Reset 0=not support 1=support 03 0b 11:04 99H 12 0b 13 0b 14 1b 15 0b 66H 23:16 FFH FFH 67H 31:24 64H 64H 0=not support 1=support 00 0b 0=Volatile 1=Nonvolatile 01 0b 09:02 FFH 10 0b 0=not support 1=support 11 0b Read Lock 0=not support 1=support 12 0b Permanent Lock 0=not support 1=support 13 1b Unused 15:14 11b Unused 31:16 FFFFH SW Reset Opcode Should be issue Reset Program Suspend/Resume Enable(66H) before Reset cmd 0=not support 1=support Erase Suspend/Resume 0=not support 1=support 65H:64H Unused Wrap-Around Read mode 0=not support 1=support Wrap-Around Read mode Opcode 7994H 08H:support 8B wrap-around Wrap-Around Read data length read 16H:8B&16B 32H:8B&16B&32B 64H:8B&16B&32B&64B Individual block lock Individual block lock bit (Volatile/Nonvolatile) Individual block lock Opcode Individual block lock Volatile protect bit default protect status Secured OTP Rev 0.2 0=protect 1=unprotect 6BH:68H April 1, 2020 E3FCH FFFFH Page 39 XT25F08B-S 3.3V QUAD IO Serial Flash 7. ELECTRICAL CHARACTERISTICS 7.1. Power-on Timing Vcc(max) Chip Selection is not allowed Vcc(min) Reset State tVSL Device is fully accessible VWI tPUW Time Table3. Power-Up Timing and Write Inhibit Threshold Note: At power-down, need to ensure VCC drop to 0.5V before the next power-on in order for the device to have a proper power-on reset. Symbol Parameter Min Max Unit tVSL VCC(min) To CS# Low 10 us tPUW Time Delay Before Write Instruction 1 - ms VWI Write Inhibit Voltage 1.5 2.5 V 7.2. Initial Delivery State The device is delivered with the memory array erased: all bits are set to 1(each byte contains FFH).The Status Register contains 00H (all Status Register bits are 0). 7.3. Data Retention and Endurance Parameter Typical Unit Data Retention Time 20 Years Erase/Program Endurance 100K Cycles Parameter Min Max Input Voltage Respect To VSS On I/O Pins -1.0V VCC Current -100mA 7.4. Latch up Characteristics Rev 0.2 April 1, 2020 VCC+1.0V 100mA Page 40 XT25F08B-S 3.3V QUAD IO Serial Flash 7.5. Absolute Maximum Ratings Parameter Value Unit Ambient Operating Temperature -40 to 85 ℃ Storage Temperature -65 to 150 ℃ Output Short Circuit Current 200 mA Applied Input/Output Voltage -0.5 to 4.0 V -0.5 to 4.0 V VCC 7.6. Capacitance Measurement Condition Symbol Parameter Typ Min Max Unit Conditions CIN Input Capacitance 6 pF VIN=0V COUT Output Capacitance 8 pF VOUT=0V CL Load Capacitance 30 Input Rise And Fall time pF 5 ns Input Pulse Voltage 0.1VCC to 0.8VCC V Input Timing Reference Voltage 0.2VCC to .8 0.7VCC V Output Timing Reference Voltage VCC 0.5VCC V Figure36. Input Test Waveform and Measurement Level Maximum Negative Overshoot Waveform 20ns 20ns VSS VSS-2.0V 20ns Maximum Positive Overshoot Waveform 20ns VCC+2.0V VCC 20ns Rev 0.2 April 1, 2020 20ns Page 41 XT25F08B-S 3.3V QUAD IO Serial Flash 7.7. DC Characteristics (T=-40℃~85℃,VCC=2.7~3.6V) Symbol Max. Unit Input Leakage Current ±2 μA ILO(1) Output Leakage Current ±2 μA ICC1 Standby Current 15 40 μA ICC2 Deep Power-Down Current 0.06 2 μA 15 20 mA 13 18 mA 5 7 mA ILI (1) Parameter Test Condition Min. Typ CS#=VCC VIN=VCC or VSS CS#=VCC VIN=VCC or VSS CLK=0.1VCC/0.9VCC at 108MHz, Q=Open(*1 I/O) CLK=0.1VCC/0.9VCC at ICC3(2) Operating Current(Read) 80MHz, Q=Open(*1,*2,*4 I/O) CLK=0.1VCC/0.9VCC at 50MHZ,Q=Open(*1 I/O) ICC4 Operating Current(PP) CS#=VCC 30 mA ICC5 Operating Current(WRSR) CS#=VCC 30 mA ICC6 Operating Current(SE) CS#=VCC 30 mA ICC7 Operating Current(BE) CS#=VCC 30 mA VIL Input Low Voltage -0.5 0.2VCC V VIH Input High Voltage 0.7VCC VCC+0.4 V VOL Output Low Voltage IOL=1.6mA 0.4 V VOH Output High Voltage IOH=-100uA VCC-0.2 V Notes: 1. Tested on sample basis and specified through design and characterization data, T= 25° C. 2. Pattern 00 or FF. Typical values given for T=25°C. Value guaranteed by design and/or characterization, not 100% tested in production. Rev 0.2 April 1, 2020 Page 42 XT25F08B-S 3.3V QUAD IO Serial Flash 7.8. AC Characteristics (T=-40℃~85℃,VCC=2.7~3.6V,CL=30pF) Symbol fC Parameter Serial Clock Frequency For: Fast Read(0BH), Dual Output(3BH) fC1 Serial Clock Frequency For: Dual I/O(BBH), Quad I/O(EBH),Quad Output(6BH) fR Min. Typ. Max. Unit 108 MHz 108 MHz 80 MHz tCLH Serial Clock Frequency For: Read Data(03H), Read Identification ID(9FH), Read Manufacture ID (90H) Serial Clock High Time 45% PC ns tCLL Serial Clock Low Time 45% PC ns tCLCH Serial Clock Rise Time(Slew Rate) 0.2 V/ns tCHCL Serial Clock Fall Time(Slew Rate) 0.2 V/ns tSLCH CS# Active Setup Time 5 ns tCHSH CS# Active Hold Time 5 ns tSHCH CS# Not Active Setup Time 5 ns tCHSL CS# Not Active Hold Time 5 ns tSHSL CS# High Time (read/write) 20 ns tSHQZ Output Disable Time tCLQX Output Hold Time 1 ns tDVCH Data In Setup Time 2 ns tCHDX Data In Hold Time 2 ns tHLCH Hold# Low Setup Time(relative to Clock) 5 ns tHHCH Hold# High Setup Time(relative to Clock) 5 ns tCHHL Hold# High Hold Time(relative to Clock) 5 ns tCHHH Hold# Low Hold Time(relative to Clock) 5 ns tHLQZ Hold# Low To High-Z Output 6 ns tHHQX Hold# Low To Low-Z Output 6 ns tCLQV Clock Low To Output Valid 6.5 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns tDP 6 ns CS# High To Deep Power-Down Mode 0.1 us tRES1 CS# High To Standby Mode Without Electronic Signature Read 20 us tRES2 CS# High To Standby Mode With Electronic Signature Read 20 us tRST_R CS# High To Next Command After Reset (from read) 20 us tRST_P CS# High To Next Command After Reset (from program) 20 us tRST_E CS# High To Next Command After Reset (from erase) 12 ms 800 ms tW Rev 0.2 Write Status Register Cycle Time 70 April 1, 2020 Page 43 XT25F08B-S 3.3V QUAD IO Serial Flash tPP Page Programming Time 0.4 0.7 ms tSE Sector Erase Time 70 800 ms tBE Block Erase Time(32K Bytes/64K Bytes) 0.15/0.25 1.2/1.6 s tCE Chip Erase Time 2.5 5 s Note: 1. Clock high or Clock low must be more than or equal to 45%PC, PC=1/fC(Max). 2. Maximum Serial Clock Frequencies are measured results picked at the falling edge. 3. Typical values given for TA=25°C. Value guaranteed by design and/or characterization, not 100% tested in production. tSHSL Figure 37. Serial Input Timing CS# tCHSL tCHSH tSLCH tSHCH SCLK tDVCH SI tCHCL tCLCH tCHDX MSB LSB High-Z SO Figure 38. Output Timing CS# tCLH tSHQZ SCLK tCLQV tCLQX tCLL tCLQV tCLQX LSB SO SI Least significant address bit (LSB) in Figure 39. Hold Timing CS# tCHHL tHLCH tHHCH SCLK tHLQZ SO tCHHH tHHQX HOLD# SI do not care during HOLD operation Rev 0.2 April 1, 2020 Page 44 XT25F08B-S 3.3V QUAD IO Serial Flash 8. ORDERING INFORMATION The ordering part number is formed by a valid combination of the following XT 25F 08B SO I G U -S Company Prefix XT = XTX Product Family 25F = 2.7~3.6V Serial Flash Memory with 4KB Uniform-Sector Product Density 08B = 8M bit Product Package SO = 8-pin SOP8(150mil) SS = 8-pin SOP8(208mil) DF = 8-pad DFN8(2x3x0.55mm) Temperature & Moisture Sensitivity Level I = Industrial Level Temp. (-40℃ to +85℃), MSL3 Green Code G = Green/Reach Package Product Carrier U = Tube; T = Tape & Reel; A = Tray Internal Version “S” Rev 0.2 April 1, 2020 Page 45 XT25F08B-S 3.3V QUAD IO Serial Flash 9. PACKAGE INFORMATION 9.1. Package SOP8 150MIL e 8 5 12*(2 X) 1200 15*(2 X) Detail “A” Θ0.8 1 b “B” b 4 Base Metal A2 A c 0.813 L L1 Θ E1 E 10° h Detail “B” SEATING PLANE A1 “A” c D Symbol A A1 A2 b c D E1 e E h L L1 θ Min 1.350 0.100 1.300 0.330 0.190 4.700 3.800 ---5.800 0.2500 0.508 0.837 0° Dimensions in Millimeters Norm ---------------4.900 3.900 1.270 6.000 0.350 0.635 1.040 ---- Max 1.750 0.250 1.500 0.510 0.250 5.000 4.000 ---6.200 0.500 0.762 1.243 8° Note: 1. Coplanarity: 0.1mm 2. Max allowable mold flash is 0.15mm at the package ends. 0.25mm between leads. 3. All dimensions follow JEDEC MS-012 standard. Rev 0.2 April 1, 2020 Page 46 XT25F08B-S 3.3V QUAD IO Serial Flash E E1 9.2. Package SOP8 208MIL 0.8 0.8 C b Symbol A A1 A2 b c D E E1 e L θ Min 1.750 0.050 1.700 0.350 0.190 5.130 7.700 5.180 0.500 0° A L 0.25 e 0° GAGE PLANE SEATING PLANE A2 A1 D Dimensions in Millimeters Norm 1.950 0.150 1.800 0.420 0.20 5.230 7.900 5.280 1.270 BSC 0.650 ---- Max 2.160 0.250 1.910 0.480 0.250 5.330 8.100 5.380 0.800 8° Note: 1. JEDEC Outline : N/A 2. Coplanarity: 0.1mm 3. Max allowable mold flash is 0.15mm at the package ends. 0.25mm between leads. Rev 0.2 April 1, 2020 Page 47 XT25F08B-S 3.3V QUAD IO Serial Flash 9.3. Package DFN8 (2x3x0.55) mm b e L L1 D h Pin 1 Corner 1 2 Nd EXPOSED THERMAL PAD ZONE BOTTOM VIEW c A1 A TOP VIEV h E E2 D2 SIDE VIEW SYMBOL A A1 b c D D2 e Nd E E2 L L1 h Rev 0.2 MIN 0.50 0 0.18 0.10 1.90 1.50 2.90 0.10 0.30 0.05 0.05 MILLIMETER NOM 0.55 0.02 0.25 0.15 2.00 1.60 0.50BSC 1.50BSC 3.00 0.20 0.35 0.10 0.15 April 1, 2020 MAX 0.60 0.05 0.30 0.20 2.10 1.70 3.10 0.30 0.40 0.15 0.25 Page 48 3.3V QUAD IO Serial Flash XT25F08B-S 10. REVISION HISTORY Revision Rev 0.2 Description Date 0.0 Initial version based on datasheet XT25F08B Rev 1.6 Apr 9-2019 0.1 Corrected OPN typo. Updated description in 7.1 Power-on timing Aug 26-2019 0.2 Deleted package TSSOP8, changed operation current. Add note to AC /DC Characteristics. Change standby current typical from 12 uA to 15uA. Change standby current max from 20 uA to 40uA. Change DPD current max from 0.1uA to 2uA. Change 32K/64K tBE max to 1.2/1.6s. April 1-2020 April 1, 2020 Page 49
XT25F08BSOIGU-S 价格&库存
很抱歉,暂时无法提供与“XT25F08BSOIGU-S”相匹配的价格&库存,您可以联系我们找货
