SG-221M1CBK-0807
SG-221M1CBK-0807
    LELON(立隆电子)
    插件,D8xL7mm
    直插铝电解电容 AEC_D8X7MM_TM
SG-221M1CBK-0807 数据手册
Aluminum Electrolytic Capacitors SG Features ‧ 105℃, 1,000 hours assured ‧ High temperature Category range, with 7mm height ‧ RoHS Compliance Sleeve & Marking Color: Green & Black SPECIFICATIONS Items Category Temperature Range Capacitance Tolerance Performance -40℃ ~ +105℃ ±20% I = 0.01CV or 3 (µA) whichever is greater (after 2 minutes) Where, C = rated capacitance in µF V = rated DC working voltage in V Leakage Current (at 20℃) Dissipation Factor (Tanδat 120Hz, 20℃) Rated Voltage Tanδ(max) 4 0.35 6.3 0.23 10 0.20 16 0.17 (at 120Hz, 20℃) 25 0.15 35 0.12 50 0.10 63 0.10 Impedance ratio shall not exceed the values given in the table below. Rated Voltage 4 6.3 10 16 25 35 50 Impedance Z(-25℃)/Z(+20℃) 6 4 3 3 2 2 2 Z(-40℃)/Z(+20℃) Ratio 12 10 8 6 4 4 4 Low Temperature Characteristics (at 120Hz) 63 2 4 Test Time 1,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied with rated ripple current for 1,000 hours at 105℃. Test time: 500 hours; other items are the same as those for the Endurance. Endurance Shelf Life Test Freq.(Hz) Cap.(μ F) Ripple Current & Frequency Multipliers 60 (50) 120 500 1k 10k up 0.75 0.88 1.00 1.00 1.20 1.10 1.30 1.15 1.45 1.20 Under 47 100 to 330 DIAGRAM OF DIMENSIONS φD+βmax 15 min Sleeve LEAD SPACING AND DIAMETER Unit: mm φD P φd α β P±0.5 φd L+α max 4 min V. DC Contents 0.1 0.22 0.33 0.47 1 2.2 3.3 4.7 10 0R1 R22 R33 R47 010 2R2 3R3 4R7 100 22 33 47 100 220 330 220 330 470 101 221 331 4V (0G) φD×L 4×7 4×7 5×7 6.3×7 8×7 mA 32 38 61 90 156 6.3V (0J) φD×L 4×7 4×7 4×7 6.3×7* 6.3×7 8×7 mA 31 32 38 75 99 156 10V (1A) φD×L 4×7 4×7 5×7* 6.3×7 8×7 Note: Case size in mark of “*” is available to product down size. 2011 Version mA 32 35 47 80 140 5 2.0 6.3 2.5 0.5 8 3.5 1.0 0.5 Dimension: φD × L(mm) Ripple Current: mA/rms at 120 Hz, 105°C DIMENSION & PERMISSIBLE RIPPLE CURRENT µF 4 1.5 0.45 16V (1C) φD×L mA 25V (1E) φD×L mA 4×7 25 4×7 26 5×7* 5×7 6.3×7* 6.3×7 8×7 39 43 59 90 146 5×7* 6.3×7 6.3×7 8×7 41 53 65 125 35V (1V) φD×L 50V (1H) 63V (1J) mA φD×L mA φD×L mA 4×7 5×7* 22 30 4×7 4×7 4×7 4×7 4×7 4×7 4×7 5×7* 6.3×7* 2 3 4 5 10 15 18 23 34 4×7 4×7 4×7 4×7 4×7 4×7 4×7 5×7 6.3×7 2 3 4.4 7.9 11 17 21 26 40 6.3×7 8×7* 8×7 47 71 83 6.3×7 8×7 8×7 53 76 85 8×7 70
SG-221M1CBK-0807 价格&库存
很抱歉,暂时无法提供与“SG-221M1CBK-0807”相匹配的价格&库存,您可以联系我们找货
SG-221M1CBK-0807
  • 10+0.35446
  • 100+0.27929
  • 300+0.24171
  • 1000+0.21179
库存:1233
