Preliminary Datasheet
LP6221A
High Efficiency 10A Boost DC/DC Convertor
General Description
Features
The LP6221A is a current mode boost DC-DC
Up to 94% efficiency
converter. Its PWM circuitry with built-in 10A current
Output completely off at Shutdown Mode
power MOSFET makes this converter highly power
Output voltage Up to 20V
efficiently. The LP6221A implements a constant
Over Current Protection
frequency
Over Temperature Protection
LP6221A can drive up to 20V output voltage
500KHz fixed frequency switching
The LP6221A includes under-voltage lockout, current
High switch on current: 10A
limiting, and thermal overload protection to prevent
Available in ESOP-8 Package
500KHz
PWM
control
scheme.
The
damage in the event of an output overload. The
LP6221A is available in ESOP-8 package.
Order Information
LP6221A
Applications
Battery products
Host Products
Panel
F: Pb-Free
Package Type
SP: ESOP-8
Marking Information
Device
Marking
Package
Shipping
LP6221ASPF
LPS
ESOP-8
4K/REEL
LP6221A
YWX
Marking indication:
Y:Production year W:Production week
LP6221A
Feb.-2019
Email: marketing@lowpowersemi.com
X: Series Number
www.lowpowersemi.com
Page 1 of 7
LP6221A
Functional Pin Description
Package Type
Pin Configurations
ESOP-8
FB
1
OD
2
LX
LX
8
EN
7
VIN
3
6
OC
4
5
GND
9(PAD)
GND
ESOP-8
(Top View)
Pin Description
Pin No.
Name
1
FB
Regulation Feedback Input. The feedback voltage is 1.16V.
2
OD
Output Disconnect Control Pin.
3/4
LX
Switching Pin.
5/9
GND
6
OC
Over Current Protection Program Pin. Connect a resistance to GND.
7
VIN
Power Supply Pin.
8
EN
Chip Enable Pin. Active high
LP6221A
Description
Ground Pin.
Feb.-2019
Page 2 of 7
LP6221A
Typical Application Circuit
VIN
4.7uH
CIN
470uF
PMOS
CIN
10uF
COUT
470uF
VOUT
COUT
10uF
RUP
3,4
LX
7
VIN
FB
VFB=1.155V
CIN
10uF
OD
EN
8
10KΩ
LP6221A
Feb.-2019
RDN
1
EN
OC
GND
5,9(PAD)
40KΩ
20KΩ
2
6
ROC
Page 3 of 7
LP6221A
Absolute Maximum Ratings Note 1
VIN to GND ----------------------------------------------------------------------------------------------------------- -0.3V to 16V
SW to GND ----------------------------------------------------------------------------------------------------------- -0.3V to 24V
OC/FB to GND --------------------------------------------------------------------------------------------------------- -0.3V to 6V
Other Pin to GND ---------------------------------------------------------------------------------------------------- -0.3V to 15V
Maximum Junction Temperature ----------------------------------------------------------------------------------------- 150°C
Operating Junction Temperature Range (TJ) -------------------------------------------------------------- -40℃ to 85°C
Maximum Soldering Temperature (at leads, 10 sec) --------------------------------------------------------------- 260°C
Note 1.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the
specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Thermal Information
Maximum Power Dissipation (PD, TA=25℃) ---------------------------------------------------------------------------- 2.0W
Thermal Resistance (θJA) ------------------------------------------------------------------------------------------------- 46℃/W
ESD Susceptibility
HBM(Human Body Mode) ---------------------------------------------------------------------------------------------------- 2KV
MM(Machine Mode) ---------------------------------------------------------------------------------------------------------- 200V
LP6221A
Feb.-2019
Page 4 of 7
LP6221A
Electrical Characteristics
(The specifications which apply over the full operating temperature range, otherwise specifications are at
TA=25℃, VIN = 5V, unless otherwise noted.)
Parameter
Symbol
Condition
Min
Typ.
2.6
Supply Voltage
Output Voltage Range
Supply Current
ICC
VFB=1.5V
Shutdown Current
ISD
VEN=0V
Feedback Voltage
VFB
Feedback Input Current
IFB
Switching Frequency
fOSC
Maximum Duty Cycle
DMAX
EN Input Low Voltage
VEN_L
EN Input High Voltage
VEN_H
Switch Current Limit
ILIMIT
Max
Units
15
V
V
0.15
mA
1
uA
1.155
VFB=1.5V
V
0.1
500
85
90
1.4
uA
KHz
95
0.4
V
V
VOUT=12V ROC=NC
6
A
VOUT=12V ROC=10KΩ
10
A
VOUT=12V ROC=12KΩ
8
A
VOUT=12V ROC=20KΩ
4
A
VOUT=12V ROC=30KΩ
2
A
MOSFET On Resistance
RDS(ON)
15
mΩ
Thermal shutdown
TOTP
150
OTP hysteresis
TOTP_HYS
LP6221A
Feb.-2019
Page 5 of 7
LP6221A
Application Information
The LP6221A uses a fixed frequency, peak current
mode boost regulator architecture to regulate voltage
at the feedback pin. At the start of each oscillator
cycle the MOSFET is turned on through the control
circuitry. To prevent sub-harmonic oscillations at
duty cycles greater than 50 percent, a stabilizing
ramp is added to the output of the current sense
amplifier and the result is fed into the negative input
of the PWM comparator. When this voltage equals
the output voltage of the error amplifier the power
Current Limitation
The internal power-MOS switch current is monitored
cycle-by-cycle and is limited to the value not exceed
10A(Typ.). When the switch current reaches the
limited value, the internal power-MOS is turned off
immediately until the next cycle. Keep traces at this
pin as short as possible. Do not put capacitance at
this pin.
Current limit program
MOSFET is turned off. The voltage at the output of
A resistor between OC and GND pin programs peak
the error amplifier is an amplified version of the
switch current. When the ROC value is between 10K
difference between the 1.155V bandgap reference
and 30K, the current limit will be set from 10A to 2A.
voltage and the feedback voltage. In this way the
If the OC pin is left floating, the default current limit is
peak current level keeps the output in regulation. If
6A. Keep traces at this pin as short as possible. Do
the feedback voltage starts to drop, the output of the
not put capacitance at this pin.
error amplifier increases. These results in more
current to flow through the power MOSFET, thus
increasing the power delivered to the output. The
LP6221A has internal soft start to limit the amount of
input current at startup and to also limit the amount of
overshoot on the output.
choice for low forward drop voltage and fast
switching time. The output diode rating should be
able to handle the maximum output voltage, average
current.
Set the output voltage by selecting the resistive
voltage divider ratio. The voltage divider drops the
output voltage to the 1.155V feedback voltage. Use a
20K resistor for RDN of the voltage divider. Determine
the high-side resistor RUP by the equation:
R UP
VOUT = (
+ 1) × VFB
R DN
Feb.-2019
To achieve high efficiency, Schottky diode is good
power dissipation and the pulsating diode peak
Setting the Output Voltage
LP6221A
Diode Selection
Output Disconnect Control Function
The LP6221A can control the external MOS switch
through the OD pin. When EN is low, the OD pin is in
a high-impedance state. When EN is high, the OD
pin is pulled down to GND. This allows the
asynchronous boost to cut off the output in shutdown
mode.
Page 6 of 7
LP6221A
Packaging Information
ESOP-8
LP6221A
Feb.-2019
Page 7 of 7
很抱歉,暂时无法提供与“LP6221ASPF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.02400
- 100+1.61700
- 1000+1.44100
- 2000+1.36400
- 4000+1.29800
- 国内价格
- 1+2.86200
- 10+2.25720
- 30+1.99800
- 100+1.68480
- 500+1.54440
- 1000+1.45800
