L7805CV
L7805CV
    UMW(友台)
    TO-220-3
    线性稳压器/LDO 固定 输入35V 输出:5V 1.2A
L7805CV 数据手册
UMW R UMW L78XX Three-terminal positive voltage regulator OUTPUT CURRENT TO 1.2A OUTPUT VOLTAGES OF 5;6;8;9;12V THERMAL OVERLOAD PROTECTION SHORT CIRCUIT PROTECTION OUTPUT TRANSITION SOA PROTECTION 1、 Absolute Maximum Ratings Tc=25℃ Symbol Parameter Input Voltage VI Value UNIT 35 V 1 2 3 TOPR Operating Temperature Range 0 ~ +125 ℃ TO - 263-3 TSTG Storage Temperature Range -65 ~+150 ℃ 1 Input 2 Gnd 3 Out 2、Electrical Characteristics (Tc=25℃)Of 7805 (refer to the test circuits, TJ = -55 to 150℃ VI = 10V,IO = 500 mA,CI = 0.33 μ F, CO = 0.1 μ F unless otherwise specified)。 Parameter Output Voltage Line Regulation (Note1) Load Regulation (Note1) Quiescent Current Quiescent Current Change Quiescent Current Change Short Circuit Current www.umw-ic.com Symbol VO Δ VO Δ VO IQ Δ IQ Δ Vo/Δ T ISC Test Condition MIN TYP MAX TJ = +25℃ 4.8 5 5.2 IO = 5mA to 1A, PO ≤ 15W VI = 8V to 20V 4.75 5 5.25 UNIT V VI = 7V to 25V 100 VI = 8V to 12V 50 TJ = +25℃ mV TJ = +25℃ IO = 5mA to 1.2A 100 TJ = +25℃ IO = 250mA to 750mA 50 TJ = +25℃ 6 mV IO = 5mA to 1A 0.5 VI = 8V to 25V 0.8 mA mA IO = 5mA 0.6 TJ = +25°C, VI = 35V 0.75 1 mV/℃ 1.2 A 友台半导体有限公司 UMW R UMW L78XX 3、Electrical Characteristics TJ = -55 (Tc=25℃)Of 7806(refer to the test circuits, to 150℃ VI = 11V , IO = 500 mA ,CI = 0.33 μ F , CO = 0.1 μ F unless otherwise specified)。 Parameter Output Voltage Line Regulation (Note1) Load Regulation (Note1) Quiescent Current Quiescent Current Change Quiescent Current Change Short Circuit Current www.umw-ic.com Symbol VO Δ VO Δ VO IQ Δ IQ Δ Vo/Δ T ISC Test Condition MIN TYP MAX TJ = +25℃ 5.75 6 6.25 IO = 5mA to 1A, PO ≤ 15W VI = 9V to 21V 5.7 6 6.3 UNIT V VI = 8V to 25V 100 VI = 9V to 13V 50 mV TJ = +25℃ TJ = +25℃ IO = 5mA to 1.2A 100 TJ = +25℃ IO = 250mA to 750mA 50 TJ = +25℃ 6 mV IO = 5mA to 1A 0.5 VI = 9V to 25V 0.8 mA mA IO = 5mA 0.7 TJ = +25°C, VI = 35V 0.75 2 mV/℃ 1.2 A 友台半导体有限公司 UMW R UMW L78XX 4、Electrical Characteristics (Tc=25℃)Of 7808(refer to the test circuits,TJ = -55 to 150℃ VI = 14V,IO = 500 mA,CI = 0.33 μ F, CO = 0.1 μ F unless otherwise specified)。 Parameter Output Voltage Line Regulation (Note1) Load Regulation (Note1) Quiescent Current Quiescent Current Change Quiescent Current Change Short Circuit Current www.umw-ic.com Symbol VO Δ VO Δ VO IQ Δ IQ Δ Vo/Δ T ISC Test Condition MIN TYP MAX TJ = +25℃ 7.7 8 8.3 IO = 5mA to 1A, PO ≤ 15W VI = 11.5V to 23V 7.6 8 8.4 UNIT V VI = 10.5V to 25V 100 VI = 11V to 17V 50 TJ = +25℃ mV TJ = +25℃ IO = 5mA to 1.2A 100 TJ = +25℃ IO = 250mA to 750mA 50 TJ = +25℃ 6 mV IO = 5mA to 1A mA 0.5 mA VI = 11.5V to 25V IO = 5mA 1 1 TJ = +25°C, VI = 35V 3 0.75 mV/℃ 1.2 A 友台半导体有限公司 UMW R UMW L78XX 5、Electrical Characteristics (Tc=25℃)Of 7809(refer to the test circuits,TJ = -55 to 150℃ VI = 15V,IO = 500 mA,CI = 0.33 μ F, CO = 0.1 μ F unless otherwise specified)。 Parameter Output Voltage Line Regulation (Note1) Load Regulation (Note1) Quiescent Current Quiescent Current Change Quiescent Current Change Short Circuit Current www.umw-ic.com Symbol VO Δ VO Δ VO IQ Δ IQ Δ Vo/Δ T ISC Test Condition MIN TYP MAX TJ = +25℃ 8.64 9 9.36 IO = 5mA to 1A, PO ≤ 15W VI = 11.5V to 26V 8.55 9 9.45 UNIT V VI = 11.5V to 26V 100 VI = 12V to 18V 50 TJ = +25℃ mV TJ = +25℃ IO = 5mA to 1.2A 100 TJ = +25℃ IO = 250mA to 750mA 50 TJ = +25℃ 6 mV IO = 5mA to 1A mA 0.5 mA VI = 11.5V to 26V IO = 5mA TJ = +25°C, VI = 35V 4 1 1 0.75 mV/℃ 1.2 A 友台半导体有限公司 UMW R UMW L78XX 6、Electrical Characteristics (Tc=25℃)Of 7812 (refer to the test circuits,TJ = -55 to 150℃ VI = 19V,IO = 500 mA,CI = 0.33 μ F, CO = 0.1 μ F unless otherwise specified)。 Parameter Output Voltage Line Regulation (Note1) Load Regulation (Note1) Quiescent Current Quiescent Current Change Quiescent Current Change Short Circuit Current www.umw-ic.com Symbol VO Δ VO Δ VO IQ Δ IQ Δ Vo/Δ T ISC Test Condition MIN TYP MAX TJ = +25℃ 11.5 12 12.5 IO = 5mA to 1A, PO ≤ 15W VI =15.5V to 27V 11.4 12 12.6 UNIT V VI = 14.5V to 30V 100 VI = 16V to 22V 50 TJ = +25℃ mV TJ = +25℃ IO = 5mA to 1.2A 100 TJ = +25℃ IO = 250mA to 750mA 50 TJ = +25℃ 6 mV IO = 5mA to 1A 0.5 VI = 15V to 30V 1 mA mA IO = 5mA 1.5 TJ = +25°C, VI = 35V 0.75 5 mV/℃ 1.2 A 友台半导体有限公司 UMW R UMW L78XX 7、Typical Characteristics Figure 1: Dropout Voltage vs Junction Temperature Figure 2: Peak Output Current vs Input/output Differential Voltage Figure3: Supply Voltage Rejection vs Frequency Figure 4: Quiescent Current vs Junction Temperature www.umw-ic.com 6 友台半导体有限公司 UMW R UMW L78XX Figure 5: Output Voltage vs Junction Temperature Figure 6: Load Transient Response Figure 7: Output Impedance vs Frequency Figure 8: Line Transient Response Figure 9: Quiescent Current vs Input Voltage www.umw-ic.com 7 友台半导体有限公司 UMW R UMW L78XX 8、Package Demensions TO-263-3 www.umw-ic.com 8 友台半导体有限公司 UMW R UMW L78XX 9、Package Demensions TO-220 DIM. mm. MIN. TYP inch MAX. MIN. A 4.40 4.60 0.173 TYP. MAX. 0.181 b 0.61 0.88 0.024 0.034 b1 1.15 1.70 0.045 0.067 c 0.49 0.70 0.019 0.027 D 15.25 15.75 0.600 0.620 E 10.0 10.40 0.393 0.409 e 2.4 2.7 0.094 0.106 e1 4.95 5.15 0.194 0.203 F 1.23 1.32 0.048 0.051 H1 6.2 6.6 0.244 0.260 J1 2.40 2.72 0.094 0.107 L 13.0 14.0 0.511 0.551 L1 3.5 3.93 0.137 0.154 L20 16.4 L30 0.645 28.9 1.138 φP 3.75 3.85 0.147 0.151 Q 2.65 2.95 0.104 0.116 0015988/N www.umw-ic.com 9 友台半导体有限公司
L7805CV 价格&库存
很抱歉,暂时无法提供与“L7805CV”相匹配的价格&库存,您可以联系我们找货
L7805CV
    • 1+0.60310
    • 50+0.55670
    库存:2
    L7805CV
      • 1+0.91270
      • 10+0.87570
      • 100+0.83080
      • 500+0.79030
      • 1000+0.76240
      库存:127
      L7805CV
      • 1+1.02714
      • 10+1.01173
      • 50+0.72981
      • 250+0.61142
      库存:5879
      L7805CV
      • 1+0.83820
      • 50+0.55770
      • 1000+0.50490
      库存:1
      L7805CV
      • 1+1.18090
      • 10+1.03140
      • 100+0.88190
      • 1000+0.74740
      库存:5879
      UMW L7805CV
      • 5+0.98670
      • 20+0.92100
      • 100+0.85520
      • 500+0.78940
      • 1000+0.72360
      • 2000+0.65780
      库存:2
      L7805CV
      • 1+6.446941+0.83114
      • 10+4.5544810+0.58716
      • 50+3.8098950+0.49117
      • 100+3.57944100+0.46146
      • 250+3.33563250+0.43003
      • 500+3.18855500+0.41107
      • 1000+3.067441000+0.39546
      • 2500+2.939632500+0.37898
      • 5000+2.862585000+0.36905
      库存:1477
      L7805CV
        库存:127
        UMW L7805CV
        • 100+0.48775
        • 500+0.47943
        库存:351
