SHP-02
SHP-02
    CHA(昭华)
    SMD4
    SHP-02
SHP-02 数据手册
·z ~,_,~ SHPSERIES HOW TO ORDER [[[8]f]------{工E一王子斗B------0 〉庄〈← OE L 叫e: 口 =Tube T/ R二Tape & Reel RoHs & Lead Free Solderable 口 = Regular U」一O ←〈← T=Top Tape Sealed 1. 27mm Half-Pitch DIP SW Full G。Id Ratings: 丁11 DU」一 ω OU P Positons· 02 03 04 05 06 08 10 山 U 』 山山 GR UA ~~~'~'~': zo←←2∞·工 ω2nL 且Q_11← ~ Mylar 附~ J 除这金边且达~飞~ D i 『nensions: 」〈← UE G。Id/Gold : 50M Q Max : 100M Q Max . 1QOM Q Max, Min at 100 VDC . 300VAC fo「 60 seconds : 5pF Max at 1MHZ . -30 。C to +85 。C . -40 。C to +85 。C Operation Fo「ce : 500gf Max Mechanical Life : 1000 cycles Operations Resistance to Solde「ing : 270 。C 土5℃ fo「 10 second Packing : All DIP Switches A「e Slipped In Standard IC Tubes Or Reel Package With All Poles In The “ OFF ” Package: 02,04,06,08,1O Tape&Reel :2000pcs Material plated G type P/N · 25mA at 24VDC · 1OOmA at 50VDC Mechanical & Processing E斗i CH U -H 山 AU U 叫||『 丁14」 。u←〈Z- 22」」一 1 1.76 土 0.40 Contact Rating Switching Non-Switching Contact Resistance Initial After life Insulation Resistance Dielectric Strength Switch Capacitance Operation Temperature Storage Temperature Unit m 阿1 Part Name Material Finished inch Base PPS UL94 VO Black E 。匠。- SHP-02GT SHP-03GT 4.12 0.16 Cover PPS UL94 VO Black 5.41 0.21 Actuator Nylon UL94 VO White SHP-04GT 6.66 0.26 Movable Beryllium Gold/Tin SHP-05GT SHP-06GT 7.95 9.20 0.31 0.36 Terminal Contact Brass Gold/Tin Terminal God I/Tin SHP-08GT SHP-10GT 11 .74 0.46 14.28 0.56 www.chau-hua.com 005 Brass www.cha-switch.com
SHP-02 价格&库存
很抱歉,暂时无法提供与“SHP-02”相匹配的价格&库存,您可以联系我们找货
