HX2300A
20V N-Channel Enhancement Mode MOSFET
DESCRIPTION
SCHEMATIC DIAGRAM
The HX2300A uses advanced trench
technology to provide excellent RDS(ON), low gate
charge and high density cell Design for ultra low
on-resistance. This device is suitable for use as
a load switch or in PWM applications.
D
G
GENERAL FEATURES
S
VDS =20V,ID =2.5A
RDS(ON)(Typ.)=61mΩ
@VGS=2.5V
RDS(ON)(Typ.)=46mΩ
@VGS=4.5V
High power and current handing capability
Lead free product is acquired
Surface mount package
PIN ASSIGNMENT
SOT-23
(TOP VIEW)
D
3
APPLICATION
PWM applications
Load switch
A2SHB
PACKAGE
SOT-23
1
2
G
S
ORDERING INFORMATION
Part Number
Storage Temperature
Package
Marking
Devices Per Reel
-55°C to +150°C
SOT-23
A2SHB
3000
HX2300A
ABSOLUTE MAXIMUM RATINGS
(TA=25℃ unless otherwise noted)
parameter
symbol
limit
unit
Drain-source voltage
VDS
V
Gate-source voltage
VGS
±12
V
TA=25°C
Continuous drain current (TJ = 150 °C) a
TA=70°C
ID
2.5
2.0
Pulsed drain current b
IDM
10
Continuous source current (diode conduction) a
IS
0.6
TA=25°C
Power dissipation a
TA=70°C
Operating junction and storage temperature range
REV.1.0
~1~
PD
TJ, Tstg
0.71
0.46
-55—150
A
W
HX2300A
THERMAL CHARACTERISTICS
Parameter
Maximum junction-to-ambient a
Symbol
≤5s
Max
120
145
140
175
62
78
RθJA
Steady-State
Steady-State
Maximum junction-to-foot
Typ
RθJC
Unit
℃/W
Notes
a. Surface mounted on 1" x 1" FR4 board
b. Pulse width limited by maximum junction temperature
ELECTRICAL CHARACTERISTICS (TA=25℃
Parameter
Symbol
Condition
Min
Typ
Max
Unit
OFF Characteristics
Drain-source breakdown voltage
BVDSS
VGS=0V, ID=250µA
V
Zero gate voltage drain current
IDSS
VDS=20V, VGS=0V
1
µA
Gate-body leakage
IGSS
VDS=0V, VGS=±12V
±100
nA
VDS=VGS, ID=250µA
0.5
0.65
1.0
V
VGS=4.5V, ID=2.5A
46
60
61
85
5
180
38
7
30
7
3.5
0.6
0.45
0.76
1.16
ON Characteristics
Gate threshold voltage
VGS(th)
Drain-source on-state resistance a
RDS(ON)
Forward transconductance a
gfs
VGS=2.5V, ID=1A
VDS=5V, ID=2A
mΩ
S
Dynamic Characteristics b
Input capacitance
CISS
Output capacitance
COSS
Reverse transfer capacitance
CRSS
VDS=10V ,VGS=0V
f=1.0MHz
pF
Switching Characteristics
Turn-on delay time
Rise time
Turn-off delay time
Fall time
tD(ON)
tr
tD(OFF)
tf
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
VDD=10V
RL=3 ohm
VGEN=4.5V
RGEN=6ohm
VDS=10V
ID=2.5A
VGS=4.5V
ns
nC
DRAIN-SOURCE DIODE CHARACTERISTICS
Diode forward voltage
VSD
VGS=0V,Is=2.5A
Notes
a. Pulse test: Pulse width 300 μs, duty cycle 2 %
b. Guaranteed by design, not subject to production testing
REV.1.0
~2~
V
HX2300A
TYPICAL CHARACTERISTICS
REV.1.0
(25 °C, unless otherwise noted)
~3~
HX2300A
REV.1.0
~4~
HX2300A
PACKAGE INFORMATION
SOT-23
Symbol
Dimensions In Millimeters
Min.
Max.
Min.
Max.
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
0.950 TYP.
0.037 TYP.
e1
1.800
2.000
0.071
0.079
L
0.300
0.500
0.012
0.020
L1
θ
REV.1.0
Dimensions In Inches
0.550 REF.
o
0.022 REF.
8
~5~
o
o
8o
HX2300A
RECOMMENDED MINIMUM PADS FOR SOT-23
REV.1.0
~6~
很抱歉,暂时无法提供与“HX2300A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09170
- 500+0.07128
- 3000+0.05832
