Cautions and Warnings
Please be noted that this spec is only for reference if you have projects
designed with the product number listed in. If you are looking for new
project design-in, please find BBHV Series specification/datasheet on
Chilisin website. Or you may find our sales contact for more information on
old part number at your convenience. Appreciated your attention and
understanding.
Note: Please be sure to request approval specifications that provide further details of the products.
Kindly note that the content of these specifications are subject to change or may be discontinued
without prior notice. This product may not be designed/used in medical or high risk applications
without Chilisin approval. Please contact our sales department before ordering.
SMD Multilayer Ferrite Chip Beads
Chilisin offers a wide range of multi-layered ferrite chip beads with various
sizes, frequency characteristics, and impedance values for EMI solutions.
These ferrite formulas are used to compose seven types of EMI
suppression chip beads: SB, GB, PB, UPB, NB, HF, and VPB series.
Product Identification
Product symbol: SB, GB, PB, UPB, NB, HF, VPB
Packaging: T:Tape and Reel;B:Bulk
Tolerance: Y = ± 25%; M = ± 20%; T:±30%
Note: RoHS Compliant
Shape and Dimensions
Recommended Pattern
Dimensions in mm
Dimensions in mm
TYPE
A
B
C
D
TYPE
A
B
C
060303
0.60.03
0.300.03
0.30.03
0.150.05
060303
0.2 ~ 0.3
0.75 ~ 1.05
0.3
100505
1.00.10
0.500.10
0.50.10
0.250.10
100505
0.4
1.2 ~ 1.4
0.5
160805
1.60.15
0.800.15
0.50.15
0.30.2
160805
0.7 ~ 0.8
1.8 ~ 2.0
0.6 ~ 0.8
160808
1.60.15
0.800.15
0.80.15
0.30.2
160808
0.7 ~ 0.8
1.8 ~ 2.0
0.6 ~ 0.8
201209
2.00.20
1.250.20
0.90.20
0.50.3
201209
1.0 ~ 1.2
2.6 ~ 4.0
1.0 ~ 1.2
321611
3.20.20
1.600.20
1.10.20
0.50.3
321611
2.0
4.2 ~ 5.2
1.2
:SBY / SBJ / NB / PB
:UPB
:SBY / SBJ / NB / PB / UPB / HF
:SBK / SBJ / GB / PB / NB / UPB / VPB
:SBK / GB / PB / UPB
:SBY / SBK / PBY / UPB
Dimension Conversion
Code
Dimension in mm
(AxBxC)
EIA
060303
0.6X0.3X0.3
0201
100505
1.0X0.5X0.5
0402
160805
1.6x0.8x0.5
0603
160808
1.6x0.8x0.8
0603
201209
2.0x1.2x0.9
0805
321611
3.2x1.6x.1.1
1206
Don’t apply narrower pattern than listed above to PBY and UPB.
Narrow pattern might cause excessive heat or open circuit.
SMD Multilayer Ferrite Chip Power Beads – VPB Series
Electrical Characteristics
Impedance
Test Frequency
RDC
Rated current
(Ω±25%)
(MHz)
(Ω) Max
(mA) Max
VPB160808T-100Y-N
10
100
0.010
6000
VPB160808T-300Y-N
30
100
0.015
4000
VPB160808T-600Y-N
60
100
0.030
3000
VPB160808T-121Y-N
120
100
0.040
3000
VPB160808T-201Y-N
200
100
0.050
2500
VPB160808T-221Y-N
220
100
0.080
2000
VPB160808T-301Y-N
300
100
0.080
2000
VPB160808T-331Y-N
330
100
0.080
2000
VPB160808T-471Y-N
470
100
0.100
2000
VPB160808T-601Y-N
600
100
0.100
2000
Part Number
Note: When ordering, please specify tolerance code. Tolerance : Y=±25%
Operating temperature range-55℃~125℃(Including self - temperature rise)
Rate Current:Applied the current to coils, the temperature rise shall not be more than 30℃
Measure Equipment:
Z:HP4291A
RDC:HP4338B or CHEN HWA 502
Test Instruments:Agilent E4991A Impedance / Material Analyzer
VPB160808T-300Y-N
16
35
14
Z
12
10
8
X
6
4
R
2
30
Z
25
X
10
R
5
10
100
40
X
100
1000
250
300
100
80
X
Z
150
100
X
50
R
IMPEDANCE(Ω)
180
160
IMPEDANCE(Ω)
350
Z
10
100
150
100
10
100
1000
1
VPB160808T-301Y-N
400
600
200
150
X
R
50
IMPEDANCE(Ω)
350
IMPEDANCE(Ω)
700
Z
350
Z
300
250
200
150
X
100
R
50
1
10
100
FREQUENCY(MHz)
RDC
很抱歉,暂时无法提供与“VPB160808T-600Y-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.04623
- 500+0.03551
- 1500+0.02955
- 4000+0.02601
- 24000+0.02290
- 48000+0.02117
