31224102
31224102
    METZCONNECT
    插件,P=3.5mm
    排针 间距:3.5mm 1x2P 插件
31224102 数据手册
Data Sheet PR033xxVBHC Page 1/5 P/N 312241xx xx=number of poles 2013/12/05 Illustration see enlarged drawing at the end of the document Product specification • pin header, THR solderable • centerline 3.50 mm, direction of connection vertical 0° • fittable without loss of poles • color black • Tape & Reel packaging • Connection data V / A 300 / 15 6 A / 200 V / 2.5 kV / 3 / IEC 61984 Page 2/5 P/N 312241xx xx=number of poles 2013/12/05 Data Sheet PR033xxVBHC Technical Data General Data Solder pin length min. number of poles max. number of poles Insulating material class clearance/creepage dist. protection category Overvoltage category Pollution degree Rated voltage Rated test voltage 3.6 mm 2 24 CTI 600 2.5 mm IP 00 III 3 200 V 2.5 kV III 2 500 V 2.5 kV II 2 500 V 2.5 kV Connection data V/A 300 / 15 6 A / 200 V / 2.5 kV / 3 / IEC 61984 Material insulating material flammability class contact pin material contact pin surface PA46 V0 CuZn Ni + Ag Climatic properties upper limit temperature lower limit temperature 105 °C -40 °C General solderability Tolerance For THR products acc. to IPC/JEDEC J-STD-020D-MSL 1 | For THT products max. 260 °C / 10 s ISO 2768 -mH Page 3/5 P/N 312241xx xx=number of poles 2013/12/05 Data Sheet PR033xxVBHC Matching Part to P/N 311661 Product name RP023xxHBWC Typ 166 Data Sheet PR033xxVBHC Illustration Drawing L=(pole size - 1) x centerline + 2.7 [0.106] Page 4/5 P/N 312241xx xx=number of poles 2013/12/05 Data Sheet PR033xxVBHC PCB Layout Powered by TCPDF (www.tcpdf.org) Page 5/5 P/N 312241xx xx=number of poles 2013/12/05
31224102 价格&库存
很抱歉,暂时无法提供与“31224102”相匹配的价格&库存,您可以联系我们找货
