Data Sheet
PR015xxVBHC
Page 1/5
P/N
310171xx
xx=number of poles
2015/05/19
Illustration
see enlarged drawing at the end of the document
Product specification
• pin header, THR solderable
• centerline 5.00 mm, direction of connection vertical 0°
• fittable without loss of poles
• color black
• Tape & Reel packaging
• Connection data
V / A 300 / 15
SEV Reg 130002 10 A / 250 V / 4 kV / 3 / IEC 61984
Page 2/5
P/N
310171xx
xx=number of poles
2015/05/19
Data Sheet
PR015xxVBHC
Technical Data
General Data
Solder pin length
min. number of poles
max. number of poles
Insulating material class
clearance/creepage dist.
protection category
Overvoltage category
Pollution degree
Rated voltage
Rated test voltage
3.4 mm
2
24
CTI 400
3.7 mm
IP 00
III
3
250 V
4.0 kV
III
2
500 V
4 kV
Connection data
V/A
SEV Reg 130002
300 / 15
Material
insulating material
flammability class
contact pin material
contact pin surface
PA66/6T
V0
CuZn
Ni + Ag
Climatic properties
upper limit temperature
lower limit temperature
105 °C
-40 °C
General
solderability
Tolerance
Acc. to IPC/JEDEC J-STD-020D-MSL 1
ISO 2768 -mH
II
2
500 V
4.0 kV
Page 3/5
P/N
310171xx
xx=number of poles
2015/05/19
Data Sheet
PR015xxVBHC
Matching Part to
P/N
310071
310261
310771
311071
ASP025
ASP145XX22-131 (on request)
ASP155XX22-131 (on request)
Product name
RP025xxIBWC Typ 007
FT085xxVBFC Type 026
RP025xxIBWU Typ 077
RP025xxHBWC Typ 107
SP025xxHDNC ASP025
SP145xxHBPC0001
SP155xxHBPC0001
Data Sheet
PR015xxVBHC
Illustration
Drawing
L=(pole size - 1) x centerline + 4.8 [0.189]
Page 4/5
P/N
310171xx
xx=number of poles
2015/05/19
Data Sheet
PR015xxVBHC
PCB Layout
Powered by TCPDF (www.tcpdf.org)
Page 5/5
P/N
310171xx
xx=number of poles
2015/05/19
很抱歉,暂时无法提供与“31017103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.792651+0.88134
- 10+5.0438410+0.65444
- 25+4.3916625+0.56982
- 50+3.9576550+0.51351
- 100+3.57846100+0.46431
- 250+3.16467250+0.41062
- 500+2.91406500+0.37810
- 1000+2.711071000+0.35176
- 5000+2.385915000+0.30957
