SLR-03VF
SLR-03VF
    JST
    P=3.96mm
    1X3P 3.96MM
SLR-03VF 数据手册
SL CONNECTOR 3.96mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 7A AC, DC max. • Voltage rating: 300V AC, DC max. • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/7m Ω max. After environmental testing/10m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #26 to #18 0.13 to 0.75mm2 * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Inner-housing lock Housing lance Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Free spring Current unit: A Wire size (AWG) Circuits #18 #20 #22 #24 #26 1 7 5 4 3 2 2 7 5 4 3 2 3 6 4 4 3 2 4 6 4 4 3 2 6 6 4 4 3 2 Standards –––––––––––––––––––––– 0 • Low insertion force contact • Housing lance • Inner-housing lock Recognized E60389 1 Certified LR20812 2 R9351104 Assembly layout 1 to 4 circuits : 9.3 6 circuits : 14.3 31.4 Both side lock product 1 5.9 6.1A (31.4) 31.4 SL CONNECTOR Contact Applicable wire Model No. 1.4 Pin contact mm2 Insulation O.D. (mm) AWG # Pin contact Socket contact SSM-01T-P1.4 SSF-01T-P1.4 0.13∼0.5 26∼20 1.3∼2.5 SSM-21T-P1.4 SSF-21T-P1.4 0.3 ∼0.75 22∼18 1.5∼2.5 Q´ty / reel 6,000 Material and Finish 17.6 4.3 Phosphor bronze, tin-plated (reflow treatment) 0.5 RoHS compliance Note: Contact JST for special products. Socket contact Contact Crimping machine Crimp applicator SSM-01T-P1.4 SSF-01T-P1.4 12.6 4.3 MKS-L Applicator Dies − AP-K2N Crimp applicator with dies MK/SSF/M-01-14 APLMK SSF/M01-14 − − SSM-21T-P1.4 MKS-L SSF-21T-P1.4 − MK/SSF/M-21-14 APLMK SSF/M21-14 − − Contact position location numbers Contact position numbers are stamped Receptacle housing Plug housing 1 L 3 JST 1 2 L 3 6 5 JST L 4 3 3 1 2 2 4 1 3 5 JST L 6 2 1 3 2 1 2 1 4 3 2 1 Both side lock product 3 6 2 5 1 4 3 1 Both side lock product 6 3 5 2 4 1 2 1 3 2 1 1 2 JST 2 JST 2 JST 3 L L L 3 4 3 2 1 1 4 4 1 JST 1 JST 3 2 1 1 L 2 1 2 L L 1 2 JST Plug housing 1 JST Receptacle housing 3 2 1 2 SL CONNECTOR Housing Material: PA 66, UL94V-0, white Current rating Receptacle housing(for pin contact) Plug housing(for socket contact) 300V 7A 1 JST L 5.2 Q´ty / bag 5.9 1 SLP-01V 6.1 2.4 Q´ty / bag 2.4 SLR-01VF 1 JST L 1,000 24.2 1.0 Circuits Voltage rating 7.2 1,000 5.2 19.0 7A 2 L 1 JST 1 L 500 9.16 7.2 24.2 19.0 SLR-03VF Q´ty / bag 5.9 6A 2 JST 1 500 1 7.2 13.12 24.2 SLP-04V 6A 1 17.08 19.0 6A 3 6 L 2 1 5 JST 4 2 L 500 SLP-06V Q´ty / bag 1 500 4 L 13.12 4 3 JST 17.08 2.4 2.4 Q´ty / bag 11.1 300V 7.2 24.2 SLR-06VF 6 1 500 1.0 2 JST 10.9 3 L 1.0 4 Q´ty / bag 5.9 2.3 Q´ty / bag 6.1 300V 500 13.12 19.0 SLR-04VF 4 3 2 JST L 1.0 L 2.4 3 500 SLP-03V 2.3 300V 2 JST 9.16 2.4 Q´ty / bag 6.1 3 Q´ty / bag 1.0 300V 6.1 2 SLP-02V 5.9 2.3 Q´ty / bag 2.4 SLR-02VF 7.2 24.2 2 3 5 JST 6 500 13.12 19.0 Both side lock product *SLR-03VF-MD 6A 3 2 1 1 21.62 12.3 (11.9) 24.2 RoHS compliance Note: 1. *Marked products are not CSA/TU¨V approved. 2. Contact JST for special products. 3 Q´ty / bag 5.9 300V Both side lock product *SLP-03V-MD 6.1 3 Q´ty / bag 500 11.8 (7.2) 19 2 21.52 3 500
SLR-03VF 价格&库存
很抱歉,暂时无法提供与“SLR-03VF”相匹配的价格&库存,您可以联系我们找货
SLR-03VF
    • 500+0.47520
    库存:2000
    SLR-03VF
      • 1+0.737101+0.09555
      • 300+0.62115300+0.08052
      • 500+0.55490500+0.07193
      • 1000+0.505201000+0.06549
      • 4000+0.463794000+0.06012
      • 5000+0.463795000+0.06012
      • 10000+0.4555110000+0.05905
      库存:72
      SLR-03VF
        • 1+711.85866
        • 2+694.06142
        • 4+683.38723
        库存:500
        SLR-03VF
          库存:6000
