RMCF0603JT360R
RMCF0603JT360R
    SEI
    贴片电阻 0603
RMCF0603JT360R 数据手册
RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Features: • • • • • • RMCF – standard power ratings RMCP – high power ratings Nickel barrier terminations standard Power derating from 100% at 70ºC to zero at +155ºC AEC-Q200 compliant (except RMCP0201) RoHS compliant and halogen free Electrical Specifications - RMCF Type/Code Power Rating (W) @ 70ºC Max. Working Voltage (V) (1) Max. Overload Voltage (V) Max. Jumper Current (A) RMCF01005 0.03 15 30 0.5 RMCF0201 0.05 25 50 0.5 RMCF0402 0.063 50 100 1 RMCF0603 0.1 75 150 1 RMCF0805 0.125 150 300 2 RMCF1206 0.25 200 400 2 RMCF1210 0.5 200 400 3 RMCF2010 0.75 200 400 3 RMCF2512 1 200 400 3 TCR (ppm/ºC) Ohmic Range (Ω) and Tolerance (2) 1% ± 300 ± 200 ± 400 ± 200 ± 200 ± 100 ± 200 ± 500 ± 400 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 400 ± 100 ± 200 ± 400 ± 200 ± 100 ± 200 ± 400 ± 200 ± 100 5% 10 - 97.6 100 - 1M 1 - 9.76 10 - 10M 1 - 9.76 (3) 10 - 1M 1.02M - 10M 1.1M - 20M 0.1 - 0.499 0.5 - 0.976 1 - 9.76 1 - 20M 10 - 1M 1.02M - 10M 0.1 - 9.76 0.1 - 20M 10 - 1M 1.02M - 10M 0.1 - 9.76 0.1 - 20M 10 - 1M 1.02M - 10M 0.1 - 0.976 1 - 9.76 10 - 10M 0.1 - 0.976 1 - 9.76 10 - 10M 10 - 10M 0.1 - 0.976 1 - 9.76 10 - 10M 10 - 10M - Notes: (1) Lesser of √ P*R or maximum working voltage (2) Contact Stackpole for extended ohmic values (3) Contact Stackpole for lower ohmic values Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Electrical Specifications - RMCP Type/Code Power Rating (W) @ 70ºC Max. Working (1) Voltage (V) Max. Overload Voltage (V) Max. Jumper Current (A) RMCP0201 0.063 25 50 1 RMCP0402 0.125 50 100 1.5 RMCP0603 0.25 75 150 2 RMCP0805 0.33 150 300 2.5 RMCP1206 0.5 200 400 3.5 RMCP1210 0.66 200 400 5 RMCP2010 1 200 400 6 RMCP2512 2 250 500 7 TCR (ppm/ºC) Ohmic Range (Ω) and Tolerance (2) 1%, 5% 1 - 9.76 10 - 10M 1 - 9.76 10 - 10M 1 - 9.76 10 - 10M 1 - 9.76 10 - 10M 1 - 9.76 10 - 10M 1 - 9.76 10 - 10M 1 - 9.76 10 - 10M 1 - 9.76 10 - 10M -200 / +400 ± 200 ± 200 ± 100 ± 200 ± 100 ± 200 ± 100 ± 400 ± 100 ± 400 ± 100 ± 200 ± 100 ± 200 ± 100 Notes: (1) Lesser of √ P*R or maximum working voltage (2) Contact Stackpole for extended ohmic values Electrical Specifications - Jumper Type/Code RMCF01005 RMCF0201 RMCF0402 RMCF0603 RMCF0805 RMCF1206 RMCF1210 RMCF2010 RMCF2512 Jumper Rated Current (A) 0.5 0.5 1 1 2 2 3 3 3 Max Overload Current (A)* 1 1 3 5 5 10 12 12 15 Jumper Resistance Value (Ω) 0.05 max. * < 1 second and 1 time Mechanical Specifications Type/Code Average Unit Weight (mg) RMCF01005 0.07 RMCF0201 RMCP0201 RMCF0402 RMCP0402 RMCF0603 RMCP0603 RMCF0805 RMCP0805 0.16 0.57 0.62 1.88 2.04 5.00 4.37 L Body Length 0.016 ± 0.0008 0.40 ± 0.02 0.024 ± 0.0012 0.60 ± 0.03 0.039 ± 0.004 1.00 ± 0.10 0.061 ± 0.006 1.55 ± 0.15 0.079 ± 0.008 2.00 ± 0.20 W Body Width 0.008 ± 0.0008 0.20 ± 0.02 0.012 ± 0.0012 0.30 ± 0.03 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.006 0.80 ± 0.15 0.049 ± 0.004 1.25 ± 0.10 Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 H Body Height 0.005 ± 0.0008 0.13 ± 0.02 0.009 ± 0.0012 0.23 ± 0.03 0.012 ± 0.004 0.30 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.006 0.50 ± 0.15 a Top Termination 0.004 ± 0.0012 0.10 ± 0.03 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 b Bottom Termination 0.004 ± 0.0012 0.10 ± 0.03 0.006 ± 0.002 0.15 ± 0.05 0.010 ± 0.006 0.25 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 Unit inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Mechanical Specifications (cont.) Type/Code RMCF1206 RMCP1206 RMCF1210 RMCP1210 RMCF2010 RMCP2010 RMCF2512 RMCP2512 L Body Length 0.126 ± 0.010 3.20 ± 0.25 0.126 ± 0.010 3.20 ± 0.25 0.197 ± 0.008 5.00 ± 0.20 0.248 ± 0.008 6.30 ± 0.20 Average Unit Weight (mg) 8.86 8.95 15.55 15.96 23.56 24.24 40.02 39.45 W Body Width 0.063 ± 0.006 1.60 ± 0.15 0.098 ± 0.010 2.50 ± 0.25 0.098 ± 0.008 2.50 ± 0.20 0.126 ± 0.010 3.20 ± 0.25 H Body Height 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.008 0.55 ± 0.20 a Top Termination 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 b Bottom Termination 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.024 ± 0.014 0.60 ± 0.35 0.024 ± 0.014 0.60 ± 0.35 Unit inches mm inches mm inches mm inches mm Performance Characteristics Test Short Time Overload Test Specifications Test Conditions (JIS-C 5202) ± (2% + 0.1Ω) 2.5 X rated voltage for 5 seconds 0201 = 1A 0402 / 0603 / 0805 = 2.5A 1206 / 1210 / 2010 / 2512 = 5A 100 VAC, 1 minute 260ºC ± 5ºC, for 10 seconds ± 0.5 seconds (Solder Bath) 235ºC ± 5ºC, for 2 seconds ± 0.5 seconds (Colophonium flux) -65ºC: 30 minutes 25ºC: 2 to 3 minutes 155ºC: 30 minutes 25ºC: 2 to 3 minutes (5 Cycles) Jumper: Max 0.05Ω after test Dielectric Withstanding Voltage Resistance to Soldering Heat Solderability No flashover or breakdown ± 1% 95% coverage, minimum Temperature Cycle ± (1% + 0.05Ω) Jumper (< 0.05Ω) Load Life (Endurance) 1% and below: ± (1% + 0.05Ω) 2% and 5%: ± (3% + 0.1Ω) Value < 1Ω: ± (3% + 0.1Ω) Jumper: Max 0.1Ω after test. Voltage Coefficient ± 100 (ppm/V) 70ºC ± 2°C, RCWV or max. working voltage whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" 1/10 rated voltage for 3 seconds max. then rated voltage for 3 seconds max. Bend of 3 mm for 5 ± 1 seconds The tested resistor should be immersed into isopropyl alcohol of 20ºC ~ 25°C for 60 seconds. Then the resitor is left in the room for 48 hours. Robustness of Termination ± (1% + 0.05Ω) 1%: ± (0.5% + 0.05Ω) Resistance to Solvent 5%: ± (0.5% + 0.05Ω) Jumper: Max. 0.05Ω after test 1%: ± (1% + 0.05Ω) 40ºC ± 2°C, 90%~95% R.H. RCWV or max. working voltage 5%: ± (2% + 0.05Ω) Damp Heat with Load whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hours Values < 1Ω: ± (3% + 0.1Ω) "OFF" Jumper: Max. 0.1Ω after test Operating temperature range is -55°C to +155°C for all sizes except for 01005 size Operating temperature range for 01005 is -55°C to +125°C Power Derating Curve: 100 -55ºC 70ºC Power Load (%) 80 60 01005 size All other sizes 40 20 0 -60 125ºC 0 20 40 60 80 100 120 140 155ºC 160 180 Ambient Temperature (ºC) Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Repetitive Pulse Information (This information is for reference only and is not guaranteed performance.) If repetitive pulses are applied to resistors, pulse wave form must be less than “Pulse limiting voltage”, “Pulse limiting current” or “Pulse limiting wattage” calculated by the formula below. Vp = K√P x R x T/t lp = K√P/R x T/t Pp = K2 x P x T/t Where: Vp: lp: Pp: P: R: T: t: K: [Vr: Pulse limiting voltage (V) Pulse limiting current (A) Pulse limiting wattage (W) Power rating (W) Nominal resistance (ohm) Repetitive period (sec) Pulse duration (sec) Coefficient by resistors type (refer to below matrix) Rated Voltage (V), Ir: Rated Current (A)] Note 1: If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000 Note 2: If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied Note 3: If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp) Note 4: Pulse limiting voltage (current, wattage) is applied at less than rated ambient temperature. If ambient temperature is more than the rated temperature (70°C), please decrease power rating according to “Power Derating Curve” Note 5: Please assure sufficient margin for use period and conditions for “Pulse limiting voltage” Note 6: If the pulse waveform is not square wave, please judge after transform the waveform into square wave according to the “Waveform Transformation to Square Wave”. RMCF Coefficient (K) Matrix Ohmic Value K R < 10Ω 10Ω ≤ R < 100Ω 100Ω ≤ R < 1KΩ 1KΩ ≤ R < 10KΩ 10KΩ ≤ R 0.50 0.45 0.35 0.25 0.20 Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Waveform Transformation to Square Wave 1. Discharge curve wave with time constant “t” → Square wave 2. Damping oscillation wave with time constant of envelope “t” → Square wave 3. Half-wave rectification wave → Square wave 4. Triangular wave → Square wave 5. Special wave → Square wave Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Recommended Pad Layout Type/Code RMCF01005 RMCF0201 RMCP0201 RMCF0402 RMCP0402 RMCF0603 RMCP0603 RMCF0805 RMCP0805 RMCF1206 RMCP1206 RMCF1210 RMCP1210 RMCF2010 RMCP2010 RMCF2512 RMCP2512 A B C Unit 0.008 0.20 0.012 0.30 0.020 0.50 0.031 0.80 0.047 1.20 0.087 2.20 0.087 2.20 0.138 3.50 0.193 4.90 0.020 0.50 0.039 1.00 0.059 1.50 0.083 2.10 0.118 3.00 0.165 4.20 0.165 4.20 0.240 6.10 0.315 8.00 0.008 0.20 0.016 0.40 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 0.110 2.80 0.110 2.80 0.138 3.50 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 6 Minimum 60 seconds 100°C 240°C * N/A www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile Packaging (EIA Standard RS-481) Packaging Specifications Reel Type 7" reel for 8 mm tape 10" reel for 8 mm tape Wa 0.354 9.00 0.394 10.00 ± ± ± ± M 0.020 0.50 0.020 0.50 7.008 178.00 10.000 254.00 ± ± ± ± A 0.079 2.00 0.079 2.00 Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 0.079 2.00 0.079 2.00 ± ± ± ± B 0.020 0.50 0.020 0.50 7 0.531 13.50 0.531 13.50 ± ± ± ± C 0.020 0.50 0.020 0.50 0.827 21.00 0.827 21.00 ± ± ± ± D 0.020 0.50 0.020 0.50 2.362 60.00 3.937 100.00 ± ± ± ± Unit 0.039 1.00 0.039 1.00 inches mm inches mm www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Taping Specifications - 01005, 0201, 0402 Type/Code RMCF01005 RMCF0201 RMCP0201 RMCF0402 RMCP0402 7" Reel Typical Full Tape A B Quantity Reel Weight (g) Width 0.315 0.018 ± 0.001 0.010 ± 10000 127.3 ± 12.0 8.00 0.45 ± 0.02 0.25 ± 0.315 0.028 ± 0.006 0.016 ± 10000 97.2 ± 9.0 8.00 0.70 ± 0.15 0.40 ± 0.315 0.047 ± 0.006 0.028 ± 10000 94.5 ± 9.0 8.00 1.20 ± 0.15 0.70 ± Type/Code RMCF01005 RMCF0201 RMCP0201 RMCF0402 RMCP0402 T1 0.012 0.31 0.015 0.38 0.016 0.40 ± ± ± ± ± ± T2 P 0.001 0.007 ± 0.001 0.079 ± 0.03 0.17 ± 0.03 2.00 ± 0.006 0.011 ± 0.001 0.079 ± 0.15 0.28 ± 0.02 2.00 ± 0.008 0.016 ± 0.002 0.079 ± 0.20 0.40 ± 0.05 2.00 ± W E 0.001 0.315 ± 0.012 0.069 ± 0.02 8.00 ± 0.30 1.75 ± 0.006 0.315 ± 0.008 0.069 ± 0.15 8.00 ± 0.20 1.75 ± 0.006 0.315 ± 0.008 0.069 ± 0.15 8.00 ± 0.20 1.75 ± P0 P1 0.002 0.157 ± 0.002 0.079 ± 0.05 4.00 ± 0.05 2.00 ± 0.004 0.157 ± 0.004 0.079 ± 0.10 4.00 ± 0.10 2.00 ± 0.004 0.157 ± 0.004 0.079 ± 0.10 4.00 ± 0.10 2.00 ± F Unit 0.004 0.138 ± 0.002 inches 0.10 3.50 ± 0.05 mm 0.004 0.138 ± 0.002 inches 0.10 3.50 ± 0.05 mm 0.004 0.138 ± 0.002 inches 0.10 3.50 ± 0.05 mm Unit 0.002 inches 0.05 mm 0.002 inches 0.05 mm 0.002 inches 0.05 mm Taping Specifications - 0603, 0805, 1206, 1210 Type/Code RMCF0603 RMCP0603 RMCF0805 RMCP0805 RMCF1206 RMCP1206 RMCF1210 RMCP1210 7" Reel Quantity (1) Typical Full Reel Tape Width Weight (g) 5000 118.3 ± 11.0 5000 139.2 ± 13.0 5000 151.4 ± 15.0 4000 175.7 ± 17.0 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. A 0.071 1.80 0.093 2.35 0.140 3.55 0.138 3.50 8 ± ± ± ± ± ± ± ± B 0.008 0.20 0.010 0.25 0.010 0.25 0.008 0.20 0.041 1.05 0.063 1.60 0.077 1.95 0.110 2.80 ± ± ± ± ± ± ± ± W 0.008 0.20 0.010 0.25 0.010 0.25 0.010 0.25 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± ± ± ± ± ± ± ± E 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Taping Specifications - 0603, 0805, 1206, 1210 (cont.) Type/Code F RMCF0603 RMCP0603 RMCF0805 RMCP0805 RMCF1206 RMCP1206 RMCF1210 RMCP1210 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± T1 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.024 0.60 0.030 0.75 0.030 0.75 0.030 0.75 ± ± ± ± ± ± ± ± T2 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.024 0.60 0.030 0.75 0.030 0.75 0.030 0.75 ± ± ± ± ± ± ± ± P 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± P0 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± P1 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm Taping Specifications - 2010, 2512 Type/Code RMCF2010 RMCP2010 RMCF2512 RMCP2512 Type/Code 7" Reel Typical Full Reel Tape A B W E F Unit Quantity Weight (g) Width 0.472 0.217 ± 0.012 0.110 ± 0.008 0.472 ± 0.008 0.069 ± 0.004 0.217 ± 0.002 inches 4000 183.1 ± 18.0 12.00 5.50 ± 0.30 2.80 ± 0.20 12.00 ± 0.20 1.75 ± 0.10 5.50 ± 0.05 mm 0.472 0.264 ± 0.008 0.134 ± 0.008 0.472 ± 0.008 0.069 ± 0.004 0.217 ± 0.002 inches 4000 255.3 ± 25.0 12.00 6.70 ± 0.20 3.40 ± 0.20 12.00 ± 0.20 1.75 ± 0.10 5.50 ± 0.05 mm T1 T2 RMCF2010 0.041 ± 0.008 0.009 ± 0.006 0.157 RMCP2010 1.05 ± 0.20 0.23 ± 0.15 4.00 RMCF2512 0.041 ± 0.008 0.009 ± 0.006 0.157 RMCP2512 1.05 ± 0.20 0.23 ± 0.15 4.00 Note: Plastic carrier tape used for 2010 and 2512 sizes. Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. P ± ± ± ± P0 0.004 0.10 0.004 0.10 9 0.157 4.00 0.157 4.00 ± ± ± ± P1 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 ± ± ± ± Unit 0.002 0.05 0.002 0.05 inches mm inches mm www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Single Pulse Power The data provided are for reference only. They are typical performance for this product but are not guaranteed. The actual pulse handling of each individual resistor may vary depending on a variety of factors including resistance tolerance and resistance value. Stackpole Electronics, Inc. assumes no liability for the use of this information. Customers should validate the performance of these products in their applications. Contact Stackpole marketing to discuss specific pulse application requirements. Temperature Measurement of Resistor Surface Description: The resistor surface generated temperature variation after applied rated voltage. Products and power: Size R-V Rated Power (W) Max Rated Voltage (V) 0201 15K 1/20 25 0402 40.2K 1/16 50 0603 57.6K 1/10 75 0805 180K 1/8 150 1206 182K 1/4 200 1210 100K 1/2 200 2010 100K 3.4 200 2512 75K 1 200 Test method: Measure component surface temperature directly after the temperature stabilizes. Test result: As per table below: Hot Spot Temperature - RMCF Size 0201 0402 0603 0805 1206 1210 2010 2512 Surface Temp. (°C) 36 37 46.2 50.4 70.6 110.6 141 150.4 Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 10 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions The thermal resistance of the RMCP will be similar to the RMCF. For example, the RMCF2512 and the RMCP2512 will have similar surface temperatures at 1W; the RMCP is designed to withstand higher temperatures associated with high power levels. Part Marking Specifications 5% Marking The nominal resistance is marked on the surface of the overcoating with the use of 3 digit markings. 0201 and 0402 are not marked. 1% Marking The nominal resistance is marked on the surface of the overcoating with the use of 4 digit markings. 0201 and 0402 are not marked. For shared E24/E96 values, 1% tolerance product may be marked with three digit marking instead of the standard four digit marking for all other E96 values. All E24 values available in 1% tolerance are also marked with three digit marking. Mark Instructions for 0603 1% Chip Resistors (per EIA-J) A two-digit number is assigned to each standard R-Value (E96) as shown in the chart below. This is followed by one alpha character which is used as a multiplier. Each letter “Y” – “F” represents a specific multiplier as follows: Y = 0.1 C = 1000 X=1 D(d) = 10000 A = 10 E = 100000 B = 100 F = 1000000 EXAMPLE: Chip Marking 01B 25C 93D Explanation 01 means 10.0 and B = 100 25 means 17.8 and C = 1,000 93 means 90.9 and D = 10,000 Value 10.0 x 100 = 1 K ohm 17.8 x 1,000 = 17.8 K ohm 90.9 x 10,000 = 909 K ohm E96 1% 10.0 10.2 10.5 10.7 11.0 11.3 11.5 11.8 12.1 12.4 12.7 13.0 13.3 13.7 14.0 14.3 # 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 1% 14.7 15.0 15.4 15.8 16.2 16.5 16.9 17.4 17.8 18.2 18.7 19.1 19.6 20.0 20.5 21.0 # 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1% 21.5 22.1 22.6 23.2 23.7 24.3 24.9 25.5 26.1 26.7 27.4 28.0 28.7 29.4 30.1 30.9 Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. # 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 11 1% 31.6 32.4 33.2 34.0 34.8 35.7 36.5 37.4 38.3 39.2 40.2 41.2 42.2 43.2 44.2 45.3 # 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 1% 46.4 47.5 48.7 49.9 51.1 52.3 53.6 54.9 56.2 57.6 59.0 60.4 61.9 63.4 64.9 66.5 # 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 1% 68.1 69.8 71.5 73.2 75.0 76.8 78.7 80.6 82.5 84.5 86.6 88.7 90.9 93.1 95.3 97.6 # 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type General Purpose Thick Film SMD Surface Mount Chip Resistor General Purpose High Power RMCP SMD Thick Film Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. RMCF Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) YES(1) 100% Matte Sn over Ni Jan-04 (Japan) Jan-05 (Taiwan, China) Lead-Free Effective Date Code (YY/WW) 04/01 05/01 YES(1) 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 12 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions How to Order - RMCF 1 2 3 4 5 6 7 8 9 10 11 12 13 14 R M C F 0 6 0 3 J T 4 K 7 0 Product Series Code Description Thick Film RMCF Chip Size Size W 01005 0.03 0201 0.05 0402 0.063 0603 0.1 0805 0.125 1206 0.25 1210 0.5 2010 0.75 2512 1 Code F J Z Tolerance Tol Value 1% E96, E24 5% E24 Jumper Code T G Packaging Size Quantity 01005 10000 7" Reel - Paper 0201, 0402 10000 Tape 0603, 0805, 1206 5000 1210 4000 7" Reel 2010, 2512 4000 Plastic Tape 10" Reel 0603, 0805, 1206 10000 Paper Tape Description Resistance Value Four characters with the multiplier used as the decimal holder. 0.1 ohm = R100 4.70 ohm = 4R70 10.0 Kohm = 10K0 1 Mohm = 1M00 Zero ohm jumper = 0R00 How to Order - RMCP 1 2 3 4 5 6 7 8 9 10 11 12 13 14 R M C P 0 6 0 3 J T 4 K 7 0 Product Series Code Description RMCP High Power Size Size W 0201 0.063 0402 0.125 0603 0.25 0805 0.33 1206 0.5 1210 0.66 2010 1 2512 2 Code F J Z Tolerance Tol Value 1% E96, E24 5% E24 Jumper Rev Date: 3/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Code T G 13 Packaging Description Size 0201, 0402 7" Reel 0603, 0805 Paper Tape 1206, 1210 2010, 2512 0603, 0805 10" Reel 1206, 1210 Paper Tape 2010 Quantity 10000 5000 4000 10000 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 10 Kohm = 10K0 1 Mohm = 1M00 8000 www.seielect.com marketing@seielect.com
RMCF0603JT360R
物料型号:RMCF系列和RMCP系列,分别代表标准功率和高功率的厚膜芯片电阻器。
器件简介:这些电阻器具备镍屏障端接标准,从70°C的100%功率降额到+155°C的零功率降额,符合AEC-Q200标准(RMCP0201除外),并且符合RoHS标准,无卤素。
引脚分配:文档中没有提供具体的引脚分配图,但提供了不同型号的电阻器的电气规格和机械规格。
参数特性: - 电气规格包括功率等级、最大工作电压、最大过载电压、最大跳线电流、温度系数(TCR)、欧姆范围和公差。 - 机械规格包括平均单位重量、体长、体宽、体高、顶部端接和底部端接尺寸。
功能详解:文档提供了详细的电阻器性能特性测试条件和测试规格,例如短时间过载、耐电压、焊接热抗性、温度循环、负载寿命(耐久性)、电压系数、端接的稳健性、耐溶剂性和带负载的湿热测试。
应用信息:文档中没有明确提供应用信息,但从电气和机械规格可以推断,这些电阻器适用于需要高功率和可靠性的应用场景。
封装信息:提供了不同型号的电阻器的封装尺寸和重量,以及推荐的焊盘布局和焊接参数。
RMCF0603JT360R 价格&库存
很抱歉,暂时无法提供与“RMCF0603JT360R”相匹配的价格&库存,您可以联系我们找货
RMCF0603JT360R
  • 1+0.885961+0.11364
  • 10+0.1761310+0.02259
  • 25+0.1272425+0.01632
  • 50+0.1005550+0.01290
  • 100+0.08038100+0.01031
  • 250+0.06110250+0.00784
  • 500+0.05032500+0.00646
  • 1000+0.041931000+0.00538
库存:14953
RMCF0603JT360R
  • 5000+0.028895000+0.00371
  • 10000+0.0251410000+0.00323
  • 15000+0.0233315000+0.00300
  • 25000+0.0213725000+0.00274
  • 35000+0.0202535000+0.00260
  • 50000+0.0192050000+0.00247
库存:14953
