POLYTRONICS TECHNOLOGY CORP.
24-1,Industry E.4th Rd. Science Park, Hsinchu,
Taiwan, R.O.C.
TEL: +886-3-5643931 FAX: +886-3-5644624
EVERFUSE
Product: SHV2920P500/30-AA
Revision: C
Date: 25 October,2016
Page: 1 of 1
TM
Polymeric PTC Fuse
Device Specification(preliminary)
Electrical Rating
Pol
ytr
o
Voltage: 30V
Current: 30A
Marking :
Figure
Recommended Pad Layout (mm)
P(Polytronics / Polystar Logo)
6.70
Max Min
8.60
Electrical Characteristics
Part Number
SHV2920P500/30-AA
Note: Ihold
5.00
5.3
cn
D
m.
C
E
Max
Min
Max Min
Max
Min
Max
5.70
2.00
3.20
2.30
4.90
5.30
Ihold
(A)
Itrip
(A)
Vmax
(V)
Imax
(A)
Pd typ
(W)
5.0
12.5
30
30
3.5
1.00
Maximum
Time-to-Trip
(A)
(Sec)
25.0
10.0
= Hold current: maximum current device will pass without tripping in 25℃ still air.
ee
Min
sC
o nf
ide
B
m@
at
SHV2920P500/30-AA
A
ee
Part Number
ni c
2.0
2.0
at
Physical Dimensions (mm)
4.6
Marking
Marking
nti
Itrip
= Trip Current: minimum current at which the device will trip in 25℃ still air.
Vmax
= Maximum voltage device can withstand without damage at rated current (Imax)
Imax
= Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pd
= Power dissipated from device when in the tripped state at 25℃ still air.
Rmin
= Minimum resistance of device in initial (un-soldered) state.
Resistance (Ω )
Rmin
0.003
al
R1max = Maximum resistance of device reflow soldering of 260°C for 20 sec.
*Value specified were determined using the PWB with 0.150”*1.5oz copper traces.
Caution
:Operation beyond the specified rating may result in damage and possible arcing and flame.
◎ Specifications are subject to change without notice.
R1max
0.020
Taiwan, R.O.C.
EVERFUSE
TM
Polymeric PTC Fuse
Revision: C
Page: 1 of 1
Preheat
-Temperature Min (Tsmin)
-Temperature Max (Tsmax)
-Time (Tsmin to Tsmax)
Time maintained above:
-Temperature (TL)
-Time (tL)
Peak Temperature (TP)
Time within 5ºC of actual Peak
Temperature (tP)
Ramp-Down Rate
Time 25ºC to Peak Temperature
Storage Condition
m.
Pb-Free Assembly
m@
at
Profile Feature
Average Ramp-Up Rate (Tsmax to TP)
ee
sC
o nf
ide
3ºC/second max.
150ºC
200ºC
60-180 seconds
217ºC
60-150 seconds
260ºC
20-40 seconds
6 ºC /second max.
8 minutes max.
0ºC ~35ºC, ≦70%RH
ee
ni c
at
Pol
ytr
o
cn
Soldering Parameters
nti
al
Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free
Recommended maximum paste thickness is 0.25mm (0.010 inch)
Devices can be cleaned using standard industry methods and solvents.
Note 1: All temperature refer to topside of the package, measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance
requirements.
很抱歉,暂时无法提供与“SHV2920P500-30-AA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.28360
- 10+7.11720
- 30+6.48000
- 100+5.75640
- 500+4.74120
- 1000+4.60080
