AW32905FCR
AW32905FCR
    AWINIC(艾为)
    FCQFN12_1.3x1.8
    AW32905FCR
AW32905FCR 数据手册
AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 Over-Voltage Protection Load Switch with Surge Protection FEATURES GENERAL DESCRIPTION  The AW329xx family OVP load switch features surge protection, an internal clamp circuit protects the device from surge voltages up to 120V.           Highly reliable 1.3mm × 1.8mm FCQFN-12 package Surge protection  IEC 61000-4-5: > 120V The AW329xx features an ultra-low 27m (typ.) Rdson nFET load switch. When input voltage exceeds the OVP threshold, the switch is turned off very fast to prevent damage to the protected downstream devices. The IN pin is capable of withstanding fault voltages up to 29VDC. Integrated low Rdson nFET switch: typical 27m 5A continuous current capability Default Over-Voltage Protection (OVP) threshold  AW32901: 5.95V  AW32902: 6.2V  AW32905: 6.8V  AW32909: 9.98V  AW32910: 10.5V  AW32912: 14V OVP threshold adjustable range: 4V to 20V Input system ESD protection  IEC 61000-4-2 Contact discharge: ±8kV  IEC 61000-4-2 Air gap discharge: ±15kV Input maximum voltage rating: 29VDC Fast turn-off response: typical 50ns Over-Temperature Protection (OTP) Under-Voltage Lockout (UVLO) The default OVP threshold is 5.95V (AW32901), 6.2V (AW32902), 6.8V (AW32905), 9.98V (AW32909), 10.5V (AW32910) and 14V (AW32912), the OVP threshold can be adjusted from 4V to 20V through external OVLO pin. The device features an open-drain output ACOK, when VIN_UVLO < VIN < VIN_OVLO and the switch is on, ACOK will be driven low to indicate a good power input, otherwise it is high impedance. This device features over-temperature protection that prevents itself from thermal damaging. APPLICATIONS    The AW329xx is available in a RoHS compliant 1.3mm × 1.8mm FCQFN-12 package. Smartphones Tablets Charging Ports TYPICAL APPLICATION CIRCUIT USB Port TVS CIN 0.1µF 50V R1 R2 Optional Optional Charger OUT IN AW32901 AW32902 OVLO AW32905 AW32909 ACOK AW32910 AW32912 EN VIO COUT 1µF Battery PMIC 10kΩ Controller GND Figure 1 AW329XX typical application circuit R1 and R2 are used for OVP threshold adjustment, to use default OVP threshold, connect OVLO to ground. All the trademarks mentioned in the document are the property of their owners. www.awinic.com.cn 1 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 DEVICE COMPARISON TABLE VIN_OVLO (V) Condition Min. Typ. Max. VIN_OVLO hysteresis (mV) AW32901 VIN rising 5.83 5.95 6.07 130 AW32902 VIN rising 6.08 6.20 6.32 130 AW32905 VIN rising 6.66 6.80 6.94 140 AW32909 VIN rising 9.78 9.98 10.18 210 AW32910 VIN rising 10.29 10.50 10.71 210 AW32912 VIN rising 13.7 14.0 14.3 280 Device PIN CONFIGURATION AND TOP MARK Marking Pin Configuration (TOP VIEW) 1 2 3 4 A EN OUT OUT GND A B ACOK OUT IN GND B C OVLO IN IN GND C 1 2 3 4 XXX YYY XXX – Marking YYY – Production tracking code Figure 2 Pin Configuration and Top Mark PIN DEFINITION Pin Name A1 EN B1 ACOK Power good flag, active-low, open-drain C1 OVLO OVP threshold adjustment pin C2, C3, B3 IN A2, A3, B2 OUT Switch output A4, B4, C4 GND Device ground www.awinic.com.cn Description Enable pin, active low Switch input and device power supply 2 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 FUNCTIONAL BLOCK DIAGRAM OUT IN Clamp Detect OVLO Gate Driver & Charge pump VIN Divider Selection OV comp Logic Control ACOK UV&OT comp Oscillator Bandgap & Ibias EN GND Figure 3 Functional Block Diagram www.awinic.com.cn 3 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 TYPICAL APPLICATION CIRCUITS USB Port CIN 0.1µF 50V TVS AW32901 AW32902 OVLO AW32905 AW32909 ACOK AW32910 AW32912 EN Optional Charger OUT IN VIO COUT 1µF Battery PMIC 10kΩ Controller GND Figure 4 AW329XX typical application circuit(using default OVP threshold) USB Port TVS CIN 0.1µF 50V R1 R2 Optional Optional Charger OUT IN AW32901 AW32902 OVLO AW32905 AW32909 ACOK AW32910 AW32912 EN VIO COUT 1µF Battery PMIC 10kΩ Controller GND Figure 5 AW329XX typical application circuit(using external resistors set OVP threshold) Notice for Typical Application Circuits: 1. If VBUS is required to pass surge voltage greater than 120V, external TVS is needed, the maximum clamping voltage of the TVS should be below 34V. 2. When the default OVP threshold is used, connect OVLO pin to GND directly or through a 0Ω resistor. OVLO pin cannot be left floating. 3. If R1 and R2 are used to adjust the OVP threshold, it is better to use 1% precision resistors to improve the OVP threshold precision. 4. If ACOK is not used, it can be left floating, or short to GND. 5. CIN = 0.1μF is recommended for typical application, larger CIN is also acceptable. The rated voltage of CIN should be larger than the TVS maximum clamping voltage, if no TVS is applied and only AW329XX is used, the rated voltage of CIN should be 50V. 6. COUT = 1μF is recommended for typical application, larger COUT is also acceptable. The rated voltage of COUT should be larger than the OVP threshold. For example, if the OVP threshold is 6.8V, the rated voltage of COUT should be 10V or higher. www.awinic.com.cn 4 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 ORDERING INFORMATION Part Number AW32901FCR AW32902FCR AW32905FCR AW32909FCR AW32910FCR AW32912FCR Temperature Package Marking -40°C – 85°C 1.3mm × 1.8mm × 0.55mm FCQFN-12 -40°C – 85°C 1.3mm × 1.8mm × 0.55mm FCQFN-12 OWM -40°C – 85°C 1.3mm × 1.8mm × 0.55mm FCQFN-12 RZR -40°C – 85°C 1.3mm × 1.8mm × 0.55mm FCQFN-12 -40°C – 85°C 1.3mm × 1.8mm × 0.55mm FCQFN-12 N9V -40°C – 85°C 1.3mm × 1.8mm × 0.55mm FCQFN-12 PBN NV9 V5B Moisture Sensitivity Level Environmental Information Delivery Form ROHS+HF Tape and Reel 3000pcs/Reel MSL1 ROHS+HF Tape and Reel 3000pcs/Reel MSL1 ROHS+HF Tape and Reel 3000pcs/Reel ROHS+HF Tape and Reel 3000pcs/Reel MSL1 ROHS+HF Tape and Reel 3000pcs/Reel MSL1 ROHS+HF Tape and Reel 3000pcs/Reel MSL1 MSL1 AW329xx Shipping R: Tape & Reel Package Type FC: FCQFN www.awinic.com.cn 5 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 ABSOLUTE MAXIMUM RATINGS (NOTE 1) Symbol VIN Parameter Condition Input voltage Min. Max. Unit -0.3 29 V V VOUT Output voltage -0.3 See(NOTE 2) VOVLO OVLO voltage -0.3 6 V VACOK ACOK voltage -0.3 6 V VEN EN voltage -0.3 6 V ISW Continuous current of switch IN-OUT(NOTE 3) Continuous current on IN and OUT pin 5 A IPEAK Peak current Peak input and output current on IN and OUT pin(10ms) 8 A IDIODE Continuous diode current Continuous forward current through the nFET body diode 1.5 A TA Ambient temperature -40 85 °C TJ Junction temperature -40 150 °C TSTG Storage temperature -65 150 °C TLEAD Soldering temperature At leads, 10 seconds 260 °C Surge Input surge protection IEC61000-4-5 test with 2 equivalent series resistance 120 V NOTE1: Conditions out of those ranges listed in “absolute maximum ratings” may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in “recommended operating conditions”. Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: 29V or VIN+0.3V, whichever is smaller. NOTE3: Limited by thermal design. THERMAL INFORMATION Symbol RJA Parameter Condition Value Unit Thermal resistance from junction to ambient (NOTE 1) In free air 65 °C/W NOTE1: Thermal resistance from junction to ambient is highly dependent on PCB layout. www.awinic.com.cn 6 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 ESD AND LATCH-UP RATINGS Symbol VESD ILatch-up Parameter Condition Value Unit IEC61000-4-2 system ESD on IN pin Contact discharge ±8 kV Air gap discharge ±15 kV Human Body Model All pins, per MIL-STD-883J Method 3015.9 ±2 kV Charged Device Model All pins, per ESDA/JEDEC JS-002-2014 ±1 kV Machine Model All pins, per JESD22-A115C ±200 V Latch-up All pins, per JESD78D, I Trigger ±800 mA RECOMMENDED OPERATING CONDITIONS Symbol Parameter VIN Input DC voltage CIN Input capacitance COUT Min. 3 Output load capacitance www.awinic.com.cn Typ. 7 Max. Unit 28 V 0.1 μF 1 μF Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 ELECTRICAL CHARACTERISTICS TA = -40°C to 85°C unless otherwise noted. Typical values are guaranteed for VIN = 5V, CIN = 0.1μF, IIN≤ 5A and TA = 25℃. Symbol Description Test Conditions VIN_CLAMP Input clamp voltage IIN = 10mA Rdson Switch on resistance VIN = 5V, IOUT = 1A, TA = 25°C 27 37 m Input quiescent current VIN = 5V, VOVLO=0V,IOUT = 0A 65 130 μA IIN_OVLO Input current at overvoltage condition VIN = 5V, VOVLO=3V,VOUT = 0V 60 120 μA VOVLO_TH OVLO set threshold 1.20 1.24 V 20 V 0.33 V IQ VOVLO_RNG OVP threshold adjustable range VOVLO_SEL External OVLO select threshold IOVLO OVLO pin leakage current Min. Typ. Max. 30.8 1.16 4 OVLO rising 0.19 Hysteresis 0.26 V 0.06 VOVLO=VOVLO_TH -0.2 Units V 0.2 μA Protection VIN rising 5.83 5.95 6.07 AW32901 Hysteresis VIN rising 0.13 6.08 6.20 6.32 AW32902 Hysteresis VIN rising 0.13 6.66 6.80 6.94 AW32905 Hysteresis VIN_OVLO 0.14 OVP trip level V VIN rising 9.78 9.98 10.18 AW32909 Hysteresis VIN rising 0.21 10.29 10.50 10.71 AW32910 Hysteresis VIN rising 0.21 13.7 14.0 14.3 AW32912 Hysteresis www.awinic.com.cn 8 0.28 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 ELECTRICAL CHARACTERISTICS (CONTINUED) TA = -40°C to 85°C unless otherwise noted. Typical values are guaranteed for VIN = 5V, CIN = 0.1μF, IIN≤ 5A and TA = 25℃. Symbol Description Test Conditions Min. Typ. Max. VIN rising 2.9 3.0 Hysteresis 0.1 Units Protection(continued) VIN_UVLO UVLO trip level V TSDN Shutdown temperature 150 °C TSDN_HYS Shutdown temperature hysteresis 20 °C 50  RDCHG Output discharge resistance VOUT=7V,VOVLO=3V Digital Logical Interface VOL ILEAK_ACOK ACOK output low voltage ISINK=1mA ACOK leakage current VIO=5V, ACOK de-asserted VIH EN input high voltage VIL EN input low voltage ILEAK_EN EN leakage current -0.5 0.4 V 0.5 μA 1.2 VEN = 5V V 0 0.5 V 2 μA Timing Characteristics (Figure 6) Debounce time From VIN > VIN_UVLO to 10% VOUT 15 ms Start-up time From VIN > VIN_UVLO to ACOK low 30 ms tON Switch turn-on time RL = 100, CL = 22μF, VOUT from 10% VIN to 90% VIN 2 ms tOFF Switch turn-off time CL = 0μF, RL = 100, VIN > VIN_OVLO to VOUT stop rising, VIN rise at 10V/μs 50 ns tDEB tSTART www.awinic.com.cn 9 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 TIMING DIAGRAM OVP trip level VIN tDEB tDEB VOUT tON tON tOFF VEN VACOK tSTART tSTART Figure 6 Timing diagram www.awinic.com.cn 10 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 TYPICAL CHARACTERISTICS Table 1 Table of Figures INDEX Figure No Rdson vs. Output Current FIGURE 7 Rdson vs. Temp. (IOUT = 1A) FIGURE 8 Rdson vs. Input Voltage (IOUT = 1A) FIGURE 9 Input Supply Current vs. Supply Voltage FIGURE 10 Normalized Internal OVP Threshold vs. Temp. FIGURE 11 OVLO set threshold vs. Temp. FIGURE 12 Power-up (COUT = 1μF, 100mA load) FIGURE 13 Power-up (COUT = 100μF, 100mA load) FIGURE 14 OVP Response (AW32905) FIGURE 15 130V Surge Response(AW32905) FIGURE 16 VIN = 5V, VEN = 0V, VOVLO = 0V, CIN = 0.1μF, COUT = 1μF, and TA = 25°C unless otherwise specified. 40.0 35.0 35.0 Rdson(mΩ) Rdson(mΩ) 33.0 31.0 29.0 27.0 30.0 25.0 20.0 25.0 0 1 2 3 4 5 -40 Output Current(A) Figure 7 Rdson vs. Output Current www.awinic.com.cn -15 10 35 60 85 Temperature(℃) Figure 8 Rdson vs. Temp. (IOUT = 1A) 11 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 TYPICAL CHARACTERISTICS (CONTINUED) VIN = 5V, VEN = 0V, VOVLO = 0V, CIN = 0.1μF, COUT = 1μF, and TA = 25°C unless otherwise specified. 35.0 Input Supply Current (A) 300 Rdson(mΩ) 33.0 31.0 29.0 27.0 25.0 –40° C 250 25° C 200 85° C 150 100 50 0 0 4 8 12 16 20 0 5 10 Input Voltage(V) Figure 9 Rdson vs. Input Voltage (IOUT = 1A) 20 25 30 35 Figure 10 Input Supply Current vs. Supply Voltage 1.10 1.210 External OVP Threshold Voltage Normalized Threshold Voltage 15 Input Voltage (V) Normalized to TA = 25° C 1.206 1.05 1.202 1.00 1.198 0.95 1.194 0.90 1.190 -40 -15 10 35 Temperature (°C) 60 85 -40 Figure 11 Normalized Internal OVP Threshold vs. Temp. -15 10 35 Temperature (°C) VIN 5V / div C1 C1 VOUT 5V / div 20ms / div IOUT 500mA / div C4 20ms / div Figure 13 Power-up (COUT = 1μF, 100mA load). www.awinic.com.cn ACOK 2V / div C3 IOUT 100mA / div C4 VOUT 5V / div C2 ACOK 2V / div C3 85 Figure 12 OVLO set threshold vs. Temp. VIN 5V / div C2 60 Figure 14 Power-up (COUT = 100μF, 100mA load) 12 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 TYPICAL CHARACTERISTICS (CONTINUED) VIN = 5V, VEN = 0V, VOVLO = 0V, CIN = 0.1μF, COUT = 1μF, and TA = 25°C unless otherwise specified. VIN 5V / div VIN 10V / div C1 C2 VOUT 5V / div C3 ACOK 2V / div C1 IIN 20A / div C2 VOUT 5V / div C3 1ms / div 10us / div Figure 15 OVP Response (AW32905) www.awinic.com.cn Figure 16 130V Surge Response (AW32905) 13 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 FUNCTIONAL DESCRIPTION Device Operation If the AW329xx is enabled and the input voltage is between UVLO and OVP threshold, the internal charge pump begins to work after debounce time, the gate of the nFET switch will be slowly charged high till the switch is fully on. ACOK will be driven low about 30ms after VIN valid, indicating the switch is on with a good power input. If the input voltage exceeds the OVP trip level, the switch will be turned off in about 50ns. If EN is pulled high, or input voltage falls below UVLO threshold, or over-temperature happens, the switch will also be turned off. Surge Protection The AW329xx integrates a clamp circuit to suppress input surge voltage. For surge voltages between VIN_OVLO and VIN_CLAMP, the switch will be turned off but the clamp circuit will not work. For surge voltages greater than VIN_CLAMP, the internal clamp circuit will detect surge voltage level and discharge the surge energy to ground. The device can suppress surge voltages up to 120V. Over-Voltage Protection If the input voltage exceeds the OVP rising trip level, the switch will be turned off in about 50ns. The switch will remain off until VIN falls below the OVP falling trip level. OVP Threshold Adjustment If the default OVP threshold is used, OVLO pin must be grounded. If OVLO pin is not grounded, and by connecting external resistor divider to OVLO pin as shown in the typical application circuit, between IN and GND, the OVP threshold can be adjusted as following: VIN_OVLO = R1+R2 VOVLO_TH R2 For example, if we select R1 = 1MΩ and R2 = 100kΩ, then the new OVP threshold calculated from the above formula is 13.2V. The OVP threshold adjustment range is from 4V to 20V. When the OVLO pin voltage VOVLO exceeds VOVLO_SEL (0.26V typical), VOVLO is compared with the reference voltage VOVLO_TH (1.2V typical) to judge whether input supply is over-voltage. ACOK Output The device features an open-drain output ACOK, it should be connected to the system I/O rail through a pullup resistor. If the device is enabled and VIN_UVLO < VIN < VIN_OVLO, ACOK will be driven low indicating the switch is on with a good power input. If OVP, UVLO, or OT occurs, or EN is pulled high, the switch will be turned off and ACOK will be pulled high. USB On-The-Go (OTG) Operation If VIN = 0V and OUT is supplied by OTG voltage, the body diode of the load switch conducts current from OUT to IN and the voltage drop from OUT to IN is approximately 0.7V. When VIN > VIN_UVLO, internal charge pump begins to open the load switch after debounce time (about 15ms). After switch is fully on, current is supplied through switch channel and the voltage drop from OUT to IN is minimum. www.awinic.com.cn 14 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 PCB LAYOUT CONSIDERATION To make fully use of the performance of AW329XX, the guidelines below should be followed. 1. All the peripherals should be placed as close to the device as possible. Place the input capacitor CIN on the top layer (same layer as the AW329XX) and close to IN pin, and place the output capacitor COUT on the top layer (same layer as the AW329XX) and close to OUT pin. 2. If external TVS is used, IN pin routing passes through the external TVS firstly, and then connect AW329XX. 3. Red bold paths on figure 4 and 5 are power lines that will flow large current, please route them on PCB as straight, wide and short as possible. 4. If R1 and R2 are used, route OVLO line on PCB as short as possible to reduce parasitic capacitance. 5. The power trace from USB connector to AW329XX may suffer from ESD event, keep other traces away from it to minimize possible EMI and ESD coupling. 6. Use rounded corners on the power trace from USB connector to AW329XX to decrease EMI coupling. www.awinic.com.cn 15 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 TAPE AND REEL INFORMATION CARRIER TAPE Pin 1 User Direction of Feed NOTE: 1. Unit: mm; 2. Material: 3000(carbon filled polycarbonate); 3. A permissible difference of the accumulation pitch of the sending hole is assumed to be ±0.2 up to 10 pitches; 4. Surface resistance: 105 to 1011 ohms/sq. www.awinic.com.cn 16 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 REEL NOTE: 1. Units: mm; 2. Material: polystyrene; 3. Planeness: max 3mm; 4. Surface resistance: 105 to 1011 ohms/sq; 5. All outstanding tolerance: ±0.25mm. www.awinic.com.cn 17 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 PACKAGE DESCRIPTION BOTTOM VIEW TOP VIEW E e2 e3 L2 L1 PIN 1 PIN 1 I.D. A L2 L1 B ØL e1 e3 D C L3 4 SIDE VIEW A1 A3 A 3 SYMBOL A A1 A3 MIN 0.50 0.00 D E e1 e2 e3 1.20 1.70 L L1 L2 L3 2 1 NOM 0.55 0.02 MAX 0.60 0.05 0.15REF. 1.30 1.80 0 REF. 0.200REF. 0.400REF. 0.18 0.25 0.16REF. 1.40 1.90 0.30 0.25REF. 0.175REF. Unit: mm NOTE: All dimensions do not include mold flash or protrusions. www.awinic.com.cn 18 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 SOLDER MASK DETAILS 0.05 MIN 0.05 MIN METAL UNDER SOLDER MASK METAL UNDER SOLDER MASK 0.16 TYP 0.25 TYP Ø(0.25) SOLDER MASK OPENING SOLDER MASK OPENING 0.16 TYP Pad Type: Solder Mask Defined 1.200 0.200 0.400 0.800 0.400 0.05 0.13 0.23 0.13 Ø0.230 Copper Pad Diameter Ø0.330 Solder Mask Opening PAD Type: Non-Solder Mask Defined NOTE: 1. Not to scale 2. Unit: mm. www.awinic.com.cn 19 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 REFLOW Figure 17 Package Reflow Oven Thermal Profile Table 2 Package Reflow Standard Reflow Note Spec Average ramp-up rate (217°C to Peak) Max. 3°C /sec Time of Preheat temp.(from 150°C to 200°C) 60-120 sec Time to be maintained above 217°C 60-150 sec Peak Temperature 250-260°C Time within 5°C of actual peak temp 20-40 sec Ramp-down rate Max. 6°C /sec Time from 25°C to peak temp Max. 8min NOTE: 1. All data are compared with the package-top temperature, measured on the package surface; 2. AW329XX adopted the Pb-Free assembly. www.awinic.com.cn 20 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 REVISION HISTORY Vision Date Change Record V0.9 February 2018 Datasheet V0.9 released 1. Added Typical Characteristics. 2. Added Tape and Reel Information. V1.0 April 2018 3. Added Solder Mask Details. 4. Added Reflow Information. V1.1 www.awinic.com.cn September, 2018 21 Storage Temperature Modified Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW32901/AW32902/AW32905/ AW32909/AW32910/AW32912 Sep. 2018 V1.1 DISCLAIMER Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 22 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW32905FCR 价格&库存
很抱歉,暂时无法提供与“AW32905FCR”相匹配的价格&库存,您可以联系我们找货
