ST150(ZD)
ST150(ZD)
    CHAULIGHT(洲光源)
    DIP-4
    ST150(ZD)
ST150(ZD) 数据手册
CHAU LIGHT Technical Data Sheet ST150(ZD) Transmissive Optical Sensor with Transistor Output Descriptions The ST150(ZD) is a photointerrupter high-performance standard type,combines high-output GaAlAs IRED with high sensitive phototransistor. Features      Wide gap 5mm Slit 1.0mm PWB mounting type package Pb free This product itself will Applications      Printers FAX Copiers Scanners Amusement machines GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 1 页 共 6 页 CHAU LIGHT Technical Data Sheet Package Dimension Notes: 1.All dimensions are in millimeters 2.Tolerances unless dimensions ±0.3mm 3.Lead spacing is measured where the lead emerge from the package GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 2 页 共 6 页 CHAU LIGHT Technical Data Sheet Absolute Maximum Ratings Parameter(Ta=25℃) Symbo Ratings Unit Power Dissipation at(or Below)25 Free Air Temperature Pd 75 mW Reverse Voltage VR 5 V Forward Current IF 50 mA Peak Forward Current(Pulse width≤100μs,Duty cycle=1%) IFP 1 A Collector Power Dissipation PC 75 mW Collector Current IC 20 mA Collector-Emitter Voltage VCEO 30 V Emitter-Collector Voltage VECO 5 V Operating Temperature TOPR -25~+85 ℃ Storage Temperature TSTG -40~+100 ℃ Lead Soldering Temperature (2mm from body for 5 seconds) TSOL 260 ℃ Input (Emitter) Output (Detector) Electro-Optical Characteristics Parameter(Ta=25℃) Input (Emitter) Output (Detector) Transfer Characteristics Symbo Min. Typ. Max. Unit Conditions Forward Voltage VF -- 1.2 1.6 V IF=20mA Reverse Current IR -- -- 10 μA VR=5V P -- 940 -- nm IF=20mA ICEO -- -- 100 nA VCE=20V,Ee=0mW/cm2 C-E Saturation Voltage VCE(sat) -- -- 0.4 V IC=2mA,Ee=1mW/cm2 Collect Current IC(ON) 0.5 -- -- mA VCE=5V,IF=20mA Rise time tr -- 15 -- μS VCE=5V,IC=1mA,RL=1KΩ Fall time tf -- 15 -- μS VCE=5V,IC=1mA,RL=1KΩ Peak Wavelength Dark Current GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 3 页 共 6 页 CHAU LIGHT Technical Data Sheet Typical Electrical/Optical/Characteristics Curves GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 4 页 共 6 页 CHAU LIGHT Technical Data Sheet GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 5 页 共 6 页 CHAU LIGHT Technical Data Sheet Packing Quantity Specification 1.150PCS//1Bag 2.4Bag/1box 2. 10bos/1Carton Notes 1.Above specification may be changed without notice. CHAU LIGHT will reserve authority on material change for above specification. 2.When using this product, please observe the absolute maximum ratings and the instruction for using outlined in these specification sheets. CHAU LIGHT assumes no responsibility for any damage resulting from use of the product which does not comply with the absolute maximum ratings and the instructions included in these specification sheets. 3.These specification sheets include materials protected under copyright of CHAU LIGHT corporation.Please don’t reproduce or cause anyone to reproduce them without CHAU LIGHT ’s consent. GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 6 页 共 6 页
ST150(ZD) 价格&库存
很抱歉,暂时无法提供与“ST150(ZD)”相匹配的价格&库存,您可以联系我们找货
ST150(ZD)
  • 5+0.66140
  • 50+0.52143
  • 150+0.45144
  • 500+0.40425
  • 2500+0.36224
  • 5000+0.34118
库存:13351
