EGF107M1CD11RR
EGF107M1CD11RR
    MANYUE(万裕科技)
    AEC-D5X11MM_TM
    100UF ±20% 16V
EGF107M1CD11RR 数据手册
GF +105˚C, High Ripple Current (高紋波), Low Impendence (低阻抗品) Series FEATURES Low impedance for high frequency. Life time: 1,000~4,000 hours at 105˚C.   SPECIFICATIONS Item Performance Characteristics Operating Temperature Range -40 to +105˚C Rated Working Voltage Range 6.3 to 100V Nominal Capacitance Range 3.3 to 4700μF Capacitance Tolerance ±20% at 120Hz, +20˚C I ≤0.01CV or 3 (μA) Leakage Current whichever is greater measured after 2 minutes application of rated working voltage at +20˚C Working Voltage (V) tan δ (max.) tan δ (120Hz, +20˚C) 6.3 0.22 10 0.19 16 0.16 25 0.14 35 0.12 50 0.10 63 0.09 100 0.08 25 2 3 35 2 3 50 2 3 63 2 3 100 2 3 For capacitance value >1000μF, add 0.02 per another 1000μF Low Temperature Characteristics GF Impedance ratio max. at 120Hz Working Voltage (V) 6.3 Z-25˚C / Z+20˚C 4 Z-40˚C / Z+20˚C 8 16 2 4 : L ΦD L ≤7 D5~6.3 D8~10 Load life 1,000h 2,000h 3,000h Test time High Temperature Loading 10 3 6 Test temperature : +105˚C Test conditions : Rated DC working voltage D12.5 Post test requirements at +20˚C 4,000h Leakage current : ≤Initial specified value Cap. change : within ±25% of the initial measured value tan δ with rated ripple current : ≤150% of the initial specified value Miniature Aluminum Electrolytic Capacitors Shelf Life At +105˚C no voltage applied after 1,000 hours and then being stabilized at +20˚C the capacitors shall meet the following limits Leakage current : ≤Initial specified value Cap. change : within ±25% of the initial measured value tan δ : ≤150% of the initial specified value Industrial Standard JIS C - 5101-4 (IEC 60384-4) CASE SIZE TABLE ΦD 4 5 6.3 F 1.5 2.0 2.5 Φd 0.45 (L ≤7) 0.45 α β PART NUMBER SYSTEM (EXAMPLE : 6.3V 1000μF) 1 23 456 7 89 10 11 12 13 14 E GF 108 M 0J G 1B RR Type (Radial Bulk) Case Length (12.5mm) Diameter (10mm) Voltage (6.3V) Tolerance (±20%) Capacitance (1000μF) Series E-CAP 34 (L ≤7) 1 8 (L
EGF107M1CD11RR
物料型号:GF系列
器件简介:这些电容器设计用于在高达105°C的温度下工作,具有高纹波电流和低阻抗特性,适用于高频应用。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性: - 工作温度范围:-40至+105°C - 额定工作电压范围:6.3至100V - 标称电容范围:3.3至4700微法拉 - 电容公差:在120Hz和+20°C时为±20% - 漏电流:在+20°C下,额定工作电压应用2分钟后测量,取0.01CV或3μA中的较大值
功能详解:电容器具有低阻抗,适合高频应用,寿命在105°C下为1,000至4,000小时。
应用信息:适用于需要高纹波电流和低阻抗特性的高频应用。
封装信息:提供了详细的尺寸表和零件编号系统,包括安全阀设计、尺寸公差和不同电压和电容值的封装尺寸。
EGF107M1CD11RR 价格&库存
很抱歉,暂时无法提供与“EGF107M1CD11RR”相匹配的价格&库存,您可以联系我们找货
EGF107M1CD11RR
  • 10+0.27897
  • 100+0.22292
  • 300+0.19494
库存:608
