RB501V-40
RB501V-40
    ZHIDE(志得)
    SOD-323
    肖特基二极管 SOD323 40V 100mA
RB501V-40 数据手册
RB501V-40 表面安装肖特基二极管 Surface Mounted Schottky Barrier Rectifiers 反向电压 40 V 正向电流 0.1 A Reverse Voltage 40 V Forward Current 0.1 A 特征 Features SOD-323 ● 反向漏电流低 Low reverse leakage ● 正向浪涌承受能力强 High forward surge capability ● 高信赖性 High reliability ● 高温焊接保证 High temperature soldering guaranteed: 260℃/10 秒 260℃/10seconds ● 引线和管体皆符合RoHS标准 Lead and body according with RoHS standard ● 型号后缀“-F”标记无卤素产品 Green compound with suffix "-F" on Marking 机械数据 Mechanical Data ● 封装外形:SOD-323塑封 Case:SOD-323 Molded plastic Unit: inch (mm) ● 环氧树脂:UL易燃等级:94V-0 Epoxy: UL 94V-0 rate flame retardant ● 引脚:镀锡,无铅 Lead: Pure tin plated, lead free 最大值和特性 TA = 25℃ 除非另有规定。 Maximum Ratings & Characteristics 参数 Parameter Ratings at 25℃ ambient temperature unless otherwise specified. 符号 Symbols RB501V-40 单位 Unit / 4 / VRRM 40 V VRMS 28 V VDC 40 V IF(AV) 0.1 A IFSM 1 A VF 0.550 V Marking 印字 最大可重复峰值反向电压 Maximum repetitive peak reverse voltage 最大均方根电压 Maximum RMS voltage 最大直流阻断电压 Maximum DC blocking voltage 最大正向平均整流电流 Maximum average forward rectified current 正向不重复浪涌电流 8.3 ms单一正弦半波 Non-repetitive peak forward surge current 8.3 ms singlehalf sine-wave 最大正向电压 @IF=0.1A Maximum forward voltage 最大反向电流 @VDC Maximum reverse current TA= 25℃ IR TA= 100℃ 典型热阻 Typical thermal resistance (Note 1) uA 400 RθJL 150 CJ 6 pF TJ -55 --- +150 ℃ TSTG -55 --- +150 ℃ Type junction capacitance 工作结温 Operating junction Storage temperature rang 10000 RθJA 典型结电容 VR=4.0V,f=1MHz 存储温度 30.0 ℃/W 备注 Note: 1) 安装在PCB板上,从PN结到周围环境的热阻。 1) Thermal resistance from junction to ambient , PCB mounted. REV.1.1,2020-06 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com RB501V-40 特性曲线 Characteristic Curves 正向特性曲线(典型值) 正向电流降额曲线 IF(AV) (A) 1 0.1 0.01 0.1 0.5 0.9 1.3 正向电压 VF(V) VF Instantaneous Forward Voltage (V) 1.7 IF(A) Average Forward Rectified Current (A) FORWARD CURRENT DERATING CURVE 平均正向电流 IF Instantaneous Forward Current (A) 正向电流 IF(A) TYPICAL FORWARD CHARACTERISTIC 0.1 0.08 0.06 0.04 0.02 0 0 25 50 75 100 管芯温度 TJ(°C) 125 150 175 TJ, Junction temperature (°C) 浪涌特性曲线(最大值) 反向特性曲线 MAXIMUM NON REPETITIVE Typical Reverse Characteristics 100 0.6 0.4 Reverse Current(uA) 0.8 反向电流IR(uA) IFSM Peak Forward Surge Current (A) 峰值正向浪涌电流 IFSM(A) PEAK FORWARD SURGE CURRENT 1 10 1 0.2 0 0.1 1 10 100 0% 20% 40% 60% 80% 通过电流的周期 额定峰值反向电压% Number of Cycles at 60 Hz. Percent Of Rated Peak Reverse voltage % REV.1.1,2020-06 Changzhou zhide Electronics CO.,LTD 100% www.cz-zhide.com RB501V-40 REV.1.1,2020-06 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com
RB501V-40 价格&库存
很抱歉,暂时无法提供与“RB501V-40”相匹配的价格&库存,您可以联系我们找货
RB501V-40
  • 20+0.22356
  • 200+0.18566
  • 600+0.16460
  • 3000+0.14818
  • 9000+0.13716
  • 21000+0.13122
库存:2763
