JSM4728A-JSM4764A
1 Watts Sueface Mount Zener Diodes
Features
Complete voltage range 3.3 to 100 volts
High peak reverse power dissipation
High reliability
Low leakage current
Standard zener voltage tolerance is ± 5%.
B
SMA
Dim
A
C
Case : SMA (DO-214AC) Molded plastic
Epoxy : UL94V-O rate flame retardant
D
MI
Lead : Lead formed for Surface mount
J
Polarity : Color band denotes cathode end
Mounting position : Any
Weight : 0.064 gram
CR
JS
Mechanical Data
G
E
H
Mi
Max
A
2.29
2.92
B
4.00
4.60
C
1.27
1.63
D
0.15
0.31
E
4.80
5.59
G
0.10
0.20
H
0.76
1.52
J
2.01
2.62
All Dimensions in mm
O
@ TA = 25C unless otherwise specified
mi
Se
Maximum Ratings
Rating
DC Power Dissipation at TL = 75 °C (Note1)
Symbol
Value
Unit
PD
1.0
W
co
VF
1.2
V
Junction Temperature Range
TJ
- 55 to + 150
°C
Storage Temperature Range
Ts
1.25
r
to
Fig. 1 MAXIMUM CONTINUOUS POWER DERATING
PD, MAXIMUM DISSIPATION
(WATTS)
°C
- 55 to + 150
uc
Note :
(1) P.C.B. Mounted on 0.31x0.31x0.08" (8x8x2mm) copper areas pads.
nd
Maximum Forward Voltage at IF = 200 mA
1.00
0.75
0.50
P.C.B. Mounted on
copper areas pads
0.25
50
75
100
125
150
TL, LEAD TEMPERATURE (°C)
www.jsmsemi.com
175
第1/2页
JSM4728A-JSM4764A
ELECTRICAL CHARACTERISTICS
Rating at 25 C ambient temperature unless otherwise specified
Nominal Zener
Voltage
Maximum Reverse Maximum DC
Leakage Current Zener Current
Maximum
Surge Current
IZK
(mA)
IR @ VR
(V)
(A)
IZM
(mA)
IRM(2)
(mApk)
400
1.0
100
1.0
276
1380
400
1.0
100
1.0
252
1260
9.0
400
1.0
50
1.0
234
1190
58.0
9.0
400
1.0
10
1.0
217
1070
JS
Type
Maximum Zener
Impedance
JSM4732A
4.7
53.0
8.0
500
1.0
10
1.0
193
970
JSM4733A
5.1
49.0
7.0
550
1.0
10
1.0
178
890
JSM4734A
5.6
45.0
5.0
600
1.0
10
2.0
162
810
JSM4735A
6.2
41.0
2.0
700
1.0
10
3.0
146
730
JSM4736A
6.8
37.0
3.5
700
1.0
50
4.0
133
660
JSM4737A
7.5
34.0
4.0
700
0.5
50
5.0
121
605
8.2
31.0
4.5
700
0.5
50
6.0
110
550
9.1
28.0
5.0
700
0.5
50
7.0
100
500
10
25.0
7.0
700
0.25
50
7.6
91
454
23.0
8.0
700
0.25
50
8.4
83
414
9.0
700
0.25
5.0
9.1
76
380
VZ @ IZT
(V)
IZT
(mA)
JSM4728A
3.3
76.0
10
JSM4729A
3.6
69.0
10
JSM4730A
3.9
64.0
JSM4731A
4.3
JSM4739A
JSM4742A
12
21.0
JSM4743A
13
19.0
10
700
0.25
5.0
9.9
69
344
JSM4744A
15
17.0
14
700
0.25
5.0
11.4
61
305
JSM4745A
16
15.5
16
700
0.25
5.0
12.2
57
285
JSM4746A
18
14.0
0.25
5.0
13.7
50
250
JSM4747A
22
750
0.25
5.0
15.2
45
225
JSM4748A
22
11.5
23
750
0.25
5.0
16.7
41
205
JSM4749A
24
10.5
25
750
0.25
5.0
18.2
38
190
JSM4750A
27
9.5
35
750
0.25
5.0
20.6
34
170
JSM4751A
30
8.5
40
1000
0.25
5.0
22.8
30
150
JSM4752A
33
7.5
45
1000
0.25
5.0
25.1
27
135
JSM4753A
36
7.0
50
1000
0.25
5.0
27.4
25
125
JSM4754A
39
6.5
60
1000
0.25
5.0
29.7
115
JSM4755A
43
6.0
70
1500
0.25
5.0
32.7
22
110
JSM4756A
47
5.5
80
1500
0.25
uc
23
5.0
35.8
19
95
JSM4757A
51
5.0
95
1500
0.25
5.0
38.8
18
90
JSM4758A
56
4.5
110
2000
0.25
5.0
42.6
16
80
JSM4759A
62
4.0
125
2000
0.25
5.0
47.1
14
70
JSM4760A
68
3.7
150
2000
0.25
5.0
51.7
13
65
JSM4761A
75
3.3
175
2000
0.25
5.0
56.0
12
60
JSM4762A
82
3.0
200
3000
0.25
5.0
62.2
11
55
JSM4763A
91
2.8
250
3000
0.25
5.0
69.2
10
50
JSM4764A
100
2.5
350
3000
0.25
5.0
76.0
9.0
45
mi
co
r
to
11
Se
JSM4741A
nd
O
JSM4740A
CR
MI
JSM4738A
ZZT @ IZT ZZK @ IZK
Notes :
(1) The type number listed have a standard tolerance on the nominal zener voltage of 5%.
(2) The revese surge current is a non-repetitive, 8.3ms pulse width square wave or equivalent sine-wave superimposed
on IZT per JEDEC Method
www.jsmsemi.com
第2/2页
很抱歉,暂时无法提供与“JSM4734A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.24244
- 200+0.19319
- 600+0.16858
- 4000+0.15010
- 8000+0.14087
- 20000+0.13338
