SD103AW
SD103AW
    JSMICRO(杰盛微)
    SOD523
    SD103AW
SD103AW 数据手册
SD103AW SD103BW SD103CW Features  Low reverse current and low forward voltage   High reliability Small surface mounting type Typical Applications  For general purpose applications  Case: SOD-123  Molding compound, UL flammability classification rating 94V-0  Terminals: Tin plated leads, solderable per MIL-STD-202, Method 208 to r Mechanical Data uc SOD-123 SD103AW SOD-123 SD103BW SOD-123 SD103CW SOD-123 Shipping Marking Code 3000/Tape Reel S4 3000/Tape Reel S5 3000/Tape Reel S6 co Package mi Part Number nd Ordering Information Se Maximum Ratings (@TA=25℃ unless otherwise specified) Symbol SD103AW SD103BW SD103CW Units VRRM 40 30 20 V RMS Reverse voltage VRMS 28 21 14 V Maximum average forward output current IF(AV) 350 mA Peak forward surge current,8.3ms single half-sine-wave IFSM 2 A Characteristic JS MI CR O Peak repetitive reverse voltage Thermal Characteristics Characteristic Symbol Value Units PD 400 mW Thermal Resistance Junction-to-Air R ΘJA* 250 °C/W Thermal Resistance Junction-to-Case R ΘJC* 138 °C/W Operating junction temperature range TJ 125 °C TSTG -55 to +150 °C Power dissipation Storage temperature range Part mounted on FR-4 board with recommended pad layout www.jsmsemi.com 第1/3页 SD103AW SD103BW SD103CW Electrical Characteristics (@TA=25℃ unless otherwise specified) Characteristic Symbol Forward Voltage VF * Test conditions Min. Typ. Max. Units IF=20mA - - 0.37 IF=200mA - - 0.60 - - 5 uA - 22 50 pF V VR= 30V (SD103AW) Maximum Peak Reverse Current IR** VR= 20V (SD103BW) Capacitance between terminals CT Reverse Recovery Time trr VR=0V,f=1MHz IF=IR=200mA, - Irr=0.1×IR,RL=100Ω Pulse width ≤380 uS, Duty cycle < 2% 10 - ns uc pulse test ,tp≤5ms to r VR= 10V (SD103CW) JS MI CR O Se mi co nd Ratings and Characteristic Curves (TA=25℃ unless otherwise noted) www.jsmsemi.com 第2/3页 SD103AW SD103BW SD103CW Package Outline Dimensions (unit:mm) SOD-123 SOD-123 K C A D H Dim Min Max A 1.45 1.75 B 2.55 2.85 C 1.00 1.30 D 0.50 0.60 0.25 0.45 0.02 0.10 0.05 0.15 3.55 3.85 E E H J uc J to r B co nd K Mounting Pad Layout(unit:mm) mi SOD-123 Se 0.91 CR O 1.22 2.36 JS MI 4.19 IMPORTANT NOTICE Jsmicro Semiconductor ( JSM ) reserves the right to make changes without further notice to any product herein to make corrections, modifications , improvements , or other changes. JSM does not assume any liability arising out of the application or use of any product described herein; neither does it convey any license under its patent rights ,nor the rights of others . www.jsmsemi.com 第3/3页
SD103AW 价格&库存
很抱歉,暂时无法提供与“SD103AW”相匹配的价格&库存,您可以联系我们找货
