LP3102QVF
LP3102QVF
    LPSEMI(微源)
    TDFN10
    LP3102QVF
LP3102QVF 数据手册
Preliminary Datasheet LP3102 Dual Channel Charge Pump Power Solution For TFT LCD Panel General Description Features The LP3102 DC/DC converter integrates two low  Ultra-Low-Noise for RF Application noise, high efficiency charge pumps for dual outputs,  2.5V to 4.8V Input Supply Voltage Range which consist of one inverting output and a step-up  Adaptive 1.5x / 2x mode switchover for positive voltage and -1x mode for negative voltage  VP output range (VOUT ≦ 2x VIN): output. The device operates from 2.5V to 4.8V input, and provides a step-up output voltage (VP) of 2x the input voltage. The negative inverting output (VN) is -1x inverted from the positive output VP. The LP3102 is available in a small TDFN-10 pin package that features a bottom side exposed thermal pad to provide optimal heat dissipation. The small package size and low external parts count make the 5.5V to 5.9V (LP3102QVF) VN output range (VOUT ≦ 2x VIN):  -5.5V to -5.9V (LP3102QVF)  High current output: Vin=3.3V, IOUT=±120mA;  Built in Power On Sequence  TDFN-10 (3.0mm × 3.0mm) Package device ideally suitable for TFT LCD applications of mobile products. The device is rated to operate from -40℃ to +85℃ ambient temperature range. Typical Application Circuit LP3102 VIN C1 LP3102 □ □ □ □ VP C1P C2P C4 2.2uF 10uF Order Information VIN Positive Output C5 2.2uF C1N C2N EN VN Negative Output ON F: Pb-Free OFF R0 100K C3P Package Type QV: TDFN-10 C2 10uF C6 2.2uF C3 10uF C3N GND Output Type Default: 5.5V ~ 5.9V Marking Information Device Marking Package Shipping LP3102QVF LPS TDFN-10 4K/REEL LP3102QVF Applications    Mobile Device, Smart Phone Portable Media Players/MP3 players Cellular and Smart mobile phone  LCD Bias Power LP3102-02 Jun. 2018 YWX Marking indication: Y:Production year W:Production week X:Production batch Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 1 of 7 Preliminary Datasheet LP3102 Functional Pin Description Package Type Pin Configurations TDFN-10 C3P 1 10 C3N VN 2 9 VP C1P 3 C1N 4 GND 11 EN 5 8 C2P 7 C2N 6 VIN Pin Description Pin Name 1 C3P Flying Capacitor 1 Positive Terminal (C6). 2 VN Negative Output pin. 3 C1P Flying Capacitor 1 Positive Terminal (C4). 4 C1N Flying Capacitor 1 Negative Terminal (C4). 5 EN Device Enable pin. 6 VIN Input Supply Voltage. Bypass VIN with a low ESR ceramic capacitor to GND. 7 C2N Flying Capacitor 1 Negative Terminal (C5). 8 C2P Flying Capacitor 1 Positive Terminal (C5). 9 VP 10 C3N Flying Capacitor 1 Negative Terminal (C6). 11(Pad) GND Ground pin. LP3102-02 Jun. 2018 Description Positive Output pin. Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 2 of 7 Preliminary Datasheet LP3102 Function Diagram C1P C1N Charge Pump VIN VP C2P EN Band Gap C2N Logic Control OSC Charge Pump C3P GND VN C3N Absolute Maximum Ratings  Input / Output Voltage to GND --------------------------------------------------------------------------------- -0.3V to 6V  EN to GND -------------------------------------------------------------------------------------------------------- -0.3V to VIN  Maximum Junction Temperature ------------------------------------------------------------------------------------ 150℃  Maximum Soldering Temperature (at leads, 10sec) ----------------------------------------------------------- 260℃  Storage Temperature Range ---------------------------------------------------------------------------- −65℃ to 165℃  Operation Ambient Temperature Range --------------------------------------------------------------- -40℃ to 85℃  Maximum Power Dissipation (PD, TA
LP3102QVF 价格&库存
很抱歉,暂时无法提供与“LP3102QVF”相匹配的价格&库存,您可以联系我们找货
