RA-5011
RA-5011
    JST
    P=2.54mm
    2X25P 2.54MM
RA-5011 数据手册
Crimp 2.54mm RA CONNECTOR Disconnectable Crimp style connectors pitch Features –––––––––––––––––––––––– • Secure locking mechanism (RA, RX headers) The locking levers are engaged by inserting the receptacle into the header. This ensures a firm connection that’s highly resistant to impact and vibration. • Housing lances The contact retention lances on the resilient housing allow visual confirmation of contact lock-in for easy and secure insertion. • Low insertion force contact The low insertion force contacts reduce surface finish wear and reduce the effects of stress relaxation. • Anti-misinsertion feature The guide devices of both housing and header prevent reverse connector insertion. Crimp style receptacles that are designed to mate with headers conforming to MIL-C83503. The low insertion force contacts reduce surface finish wear and resist stress relaxation very well. Specifications ––––––––––––––––––– • Current rating: 1.0A AC, DC (AWG #22) • Voltage rating: 300V AC, DC • Temperature range: -55˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/15m Ω max. After environmental testing/30m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,000V AC/minute • Applicable wire: AWG #26 to #22 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 RA CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Applicable wire mm2 AWG # Insulation O.D. (mm) Q'ty / reel 0.13 to 0.33 26 to 22 1.3 to 1.7 8,000 Model No. RA-SC1290 11.5 3.4 1.5 4.45 Material and Finish 1.0 1.8 Phosphor bronze, tin-plated (reflow treatment) 1.55 RoHS compliance Note: Contact JST for gold-plated contacts. Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits 8.0 3.65 14.1 5 3 1 R JST 2.54 A B 6.2 2.54 C Model No. Dimensions (mm) A B Q'ty / box C 10 RA-1011 10.16 17.50 8.75 500 16 RA-1611 17.78 25.12 12.56 500 20 RA-2011 22.86 30.20 15.10 500 26 RA-2611 30.48 37.82 18.91 250 30 RA-3011 35.56 42.90 21.45 200 34 RA-3411 40.64 47.98 23.99 250 40 RA-4011 48.26 55.60 27.80 200 50 RA-5011 60.96 68.30 34.15 200 60 RA-6011 73.66 81.00 40.50 250 Material Glass-filled PBT, UL94V-0, black RoHS compliance Header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– The following headers are applicable to the above Housing. RX header RA header RK header Circuits Top entry type Side entry type Top entry type Side entry type Top entry type Side entry type 10 RA-H101TD-1190 RA-H101SD-1190 – – – – 16 RA-H161TD-1190 RA-H161SD-1190 – – – – 20 RA-H201TD-1190 RA-H201SD-1190 RX-H201TD-1190 RX-H201SD-1190 – – 26 RA-H261TD-1190 RA-H261SD-1190 – – – – 30 RA-H301TD-1190 – – – – – 34 RA-H341TD-1190 RA-H341SD-1190 RX-H341TD-1190 RX-H341SD-1190 RK-H341TD-0190 RK-H341SD-0190 40 RA-H401TD-1190 RA-H401SD-1190 RX-H401TD-1190 RX-H401SD-1190 RK-H401TD-0190 RK-H401SD-0190 50 RA-H501TD-1190 RA-H501SD-1190 RX-H501TD-1190 RX-H501SD-1190 – – 60 RA-H601TD-1190 RA-H601SD-1190 RX-H601TD-1190 RX-H601SD-1190 – – RoHS compliance This product displays (LF)(SN) on a label. Note: Contact JST for gold-plated headers. Crimping machine, Applicator––––––––––––––––––––––––––––––––––––––––––––––– Contact Crimping machine RA-SC1290 AP-K2N Crimp applicator Dies Crimp applicator with dies MKS-L MK/RA-SC12 APLMK RA-SC12 *MKS-SC *SC/RA-SC12 APLSC RA-SC12 Note: *Strip-crimp applicator 2
RA-5011 价格&库存
很抱歉,暂时无法提供与“RA-5011”相匹配的价格&库存,您可以联系我们找货
RA-5011
    • 1+5.109971+0.66235
    • 50+4.1492750+0.53783
    • 100+3.64407100+0.47234
    • 300+3.30451300+0.42833
    • 500+3.22997500+0.41867
    • 1000+3.180281000+0.41223
    • 4000+3.147154000+0.40793
    库存:100
    RA-5011
    库存:317
