Rev 1.0
DIO5661
37V Step-Up LED Driver with PWM to Constant Current
Dimming Mode
Features
Descriptions
Drive up to 10 serial LEDs
DIO5661 is a serial white LED driver, featuring an
PWM to Constant Current dimming mode
architecture of 86% high-efficiency current mode
Integrated 40V high current switch
boost converter, driving up to 10 serial LEDs or a
(1.3A limit)
3x13(3LEDs in rows) LED matrix. And it adopts
Wide VIN Input Range: 2.7V~5.5V
PWM to Constant Current dimming control mode,
Dimming scheme up to 100:1 range
with wide frequency range from 200Hz to 200kHz
Up to 86% PWM converter Efficiency
(The
Low 200mV feedback voltage
recommended). The serial configuration assures
LED open-circuit (OVP) protection: 37V
the very most brightness consistency of the
High switching frequency: 1.1MHz
whole LED array.
For Compact Solution Size
Integrated Soft start
DIO5661 works on 1.1MHz switching frequency,
< 1µA shutdown current
which can maximize current output of 1.3A limit
Compact SOT23-6, TSOT23-6, DFN-6 Package
and achieve high current conversion efficiency
Green compliant
and result in external compact component size.
-40 to +85 ˚C Temperature range
Additionally,
dimming
frequency
the
total
above
external
10kHz
is
component
number is minimized due to the integrated
Applications
low-side power MOSFET.
LED backlighting
Mobile Phones
DIO5661 integrates multiple protection features,
Handheld Devices
such as LED open-circuit protection, thermal
Digital Photo Frames
shutdown protection and cycle-by-cycle input
Automotive Navigation
current limit protection. And the built-in soft start
circuit limits inrush current when the circuit
starts.
Ordering Information
Order Part Number
Top Marking
TA
Package
DIO5661ST6
61YW
Green
-40 to +85°C
SOT23-6
Tape & Reel, 3000
DIO5661TST6
61YW
Green
-40 to +85°C
TSOT23-6
Tape & Reel, 3000
DIO5661CD6
D61
Green
-40 to +85°C
DFN2*2-6
Tape & Reel, 3000
www.dioo.com
© 2016 DIOO MICROCIRCUITS CO., LTD
DIO5661• Rev. 1.0
DIO5661
TSOT23-6/SOT23-6
DFN2*2-6
LX
1
6
VIN
GND
2
5
NC
FB
3
4
EN
FB
1
NC
2
GND
3
GND
8
VIN
5
EN
4
LX
Figure 1 Top View
Pin Descriptions
Name
LX
GND
www.dioo.com
Description
Converter switching node
Converter/IC ground
FB
Output feedback pin regulated at 0.2V
EN
IC enable and PWM dimming control pin
NC
No connected
VIN
IC supply voltage
DIO5661• Rev.1.0
37V Step-Up LED Driver with PWM to Constant Current Dimming Mode
Pin Assignment
DIO5661
Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress
ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections
of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability.
Parameter
Rating
Unit
Supply Voltage / VIN
-0.3 to 6.0
V
High Voltage Nodes / LX
-0.3 to 40
V
-0.3 to VIN + 0.3
V
Operating Temperature Range / TJ
-40 to 150
°C
Storage Temperature Range / TS
-65 to 150
°C
Lead Temperature Range / TLEAD
300
°C
Other pins / FB, EN
SOT23-6/TSOT23-6
190
DFN2*2-6
140
Thermal Resistance / θJA
°C/W
Maximum Power Dissipation at TA
