SK52C THRU SK520C
Reverse Voltage - 20 to 200 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
Built-in strain relief,ideal for automated placement
0.280(7.11)
0.260(6.60)
High forward surge current capability
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.103(2.62)
0.079(2.06)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Case: JEDEC DO-214AB/SMC molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.0077 ounce, 0.22 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
SYMBOLS
VRRM
VRMS
VDC
MDD
SK52C
MDD
MDD
SK53C SK54C
30
21
30
40
28
40
MDD
SK55C
MDD
SK56C
MDD
SK58C
MDD
SK510C
MDD
SK5150C
MDD
SK520C
UNITS
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
V
V
V
I(AV)
5.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
Maximum instantaneous forward voltage at 3.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
175
0.55
TJ
0.85
V
mA
pF
400
600
35.0
RJA
TSTG
A
1.0
50
IR
CJ
0.70
150
-55 to +125
℃/W
-55 to +150
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
DN:T21617A1
http://www.microdiode.com
Rev:2021A1
Page :1
SK52C THRU SK520C
AVERAGE FORWARD RECTIFIED CURRENT, AMPERES
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
FIG. 1- FORWARD CURRENT DERATING CURVE
Instaneous Reverse Current ( μA)
5.0
4.0
Single
Half Wave
Phase
Resistive
60Hz
inductive
or
Load
3.0
2.0
SK52C-SK56C
1.0
SK58C-SK5200C
50
75
100
125
150
10
4
10
3
10
2
TJ=100°C
101
TJ=25°C
175
Fig.3 Typical Forward Characteristic
40
60
80
100
Fig.4 Typical Junction Capacitance
TJ=25°C
10
Junction Capacitance (pF)
500
1
SK52C/SK54C
SK56C
SK58C/SK520C
0.1
1.0
1.5
100
SK52C/SK54C
SK56C/SK520C
2.0
0.1
10
100
Fig.6- Typical Transient Thermal Impedance
W) °C /
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
200
SK52C~SK56C
175
1
Reverse Voltage (V)
Instaneous Forward Voltage (V)
SK58C~SK520C
100
150
125
100
75
50
25
00
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(
Peak Forward Surage Current (A)
Percent of Rated Peak Reverse Voltage(%)
AMBIENT TEMPERATURE, C
Instaneous Forward Current (A)
TJ=75°C
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2021A1
Page :2
SK52C THRU SK520C
Packing information
unit:mm
P0
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
P1
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
BOX
(pcs)
6000
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
CARTON
SIZE
(mm)
CARTON
(pcs)
365*365*340
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Unit (inch)
Symbol
Unit (mm)
A
4.3
0.170
B
0.160
C
4.1
7.9
0.311
D
3.8
0.150
E
12
0.472
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2021A1
Page :3
很抱歉,暂时无法提供与“SK54C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52661
- 50+0.41256
- 150+0.35554
- 500+0.31277
- 2500+0.27854
- 5000+0.26136
