MB6S(0.8A)
MB6S(0.8A)
    UMW(友台)
    MBS1
    MB6S(0.8A)
MB6S(0.8A) 数据手册
UMW R UMW MB05S-MB10S Features • • • • 0.8Amp Single Phase Glass Passivated Bridge Rectifier 50 to 1000 Volts Surface Mount Package Glass Passivated Diode Construction Moisture Resistant Epoxy Case High Surge Current Capability Maximum Ratings • • MBS -1 Operating Temperature: -55°C to +150°C Storage Temperature: -55°C to +150°C ∼ MCC Catalog Number Device Marking MB05S MB1S MB2S MB4S MB6S MB8S MB10S MB05S MB1S MB2S MB4S MB6S MB8S MB10S Maximum Rccurrent Peak Reverse Voltage 50V 100V 200V 400V 600V 800V 1000V Maximum RMS Voltage 35V 70V 140V 280V 420V 560V 700V Maximum DC Blocking Voltage 50V 100V 200V 400V 600V 800V 1000V Electrical Characteristics @ 25°C Unless Otherwise Specified Average Forward IF(AV) 0.8A Note T A = 30°C Current Peak Forward Surge I 8.3ms, half sine 30A FSM Current Maximum 1.0V IFM = 0.5A; Instantaneous VF Forward Voltage TA = 25°C Maximum DC Reverse Current At IR TA = 25°C 10 µA Rated DC Blocking Voltage Typical Junction CJ 25pF Measured at Capacitance 1.0MHz, VR=4.0V Note1. Measured at 1.0 MHz and applied reverse voltage of 4.0 Volts Note2. On alum: substrate P.C.B with an rea of 0.8 x 0.8 x 0.25” ( 20 x 20 x 6.4mm ) mounte on 0.05 x 0.05 “( 13 x 13 mm ) solder pad. *Pulse Test: Pulse Width 300µsec, Duty Cycle 1% www.umw-ic.com 1 D B E ∼ + F C A Notch in case K M J G H N L          M         .252    .017 .090 .004 .021 .055 ---- .040 .008   .272    .029 .106 .008 .023 .065 .200  .050 .014   6.40    0.45 2.30 0.10 0.53 1.40 ---- 1.02 0.15  6.91    0.75 2.70 0.20 0.58 1.65 5.08  1.27 0.35    友台半导体有限公司 UMW R UMW MB05S-MB10S Figure 1 Typical Forward Characteristics Figure 2 Typical Reverse Characteristics 20 100 60 10 40 6 20 4 10 2 6 25°C Amps 1 4 .6 2 .4 µAmps 1 .6 .2 .4 .1 .2 .06 TA=25°C .1 .04 .06 .04 .02 .01 .02 .4 .6 .8 1.0 1.2 1.4 .01 20 Volts 40 60 Instantaneous Forward Current - Amperesversus Instantaneous Forward Voltage - Volts 80 100 120 140 Volts Instantaneous Reverse Leakage Current - MicroAmperesversus Percent Of Rated Peak Reverse Voltage - Volts Figure 3 Forward Derating Curve 1.2 Figure 4 Peak Forward Surge Current 1.0 60 50 .8 40 .6 30 Amps Amps .4 10 5 0 .2 Single Phase, Half Wave 60Hz Resistive or Inductive Load 0 0 40 50 75 100 125 20 150 175 1 2 4 6 8 10 20 40 60 80 100 Cycles °C Peak Forward Surge Current - Amperesversus Number Of Cycles At 60Hz - Cycles Average Forward Rectified Current - Amperesversus Ambient Temperature - °C www.umw-ic.com 2 友台半导体有限公司
MB6S(0.8A)
物料型号为UMW MB05S-MB10S,这是一款表面安装封装的玻璃钝化二极管,具有防潮环氧树脂封装。
器件简介包括高浪涌电流能力,工作温度范围为-55°C至+150°C,存储温度范围也为-55°C至+150°C。
引脚分配如下: - A:阳极 - C:阴极 - D:阳极 - E:阴极 - K:缺口用于识别极性
参数特性包括: - 平均正向电流(IF(AV)):0.8A - 峰值正向浪涌电流(FSM):30A(8.3ms半正弦波) - 最大瞬时正向电压(VF):1.0V(IFM=0.5A; TA=25°C) - 最大直流反向电流(IR):10μA(TA=25°C) - 典型结电容(CJ):25pF(1.0MHz, VR=4.0V)
功能详解包括器件的正向特性曲线、反向特性曲线、正向降额曲线、峰值正向浪涌电流曲线。
应用信息为单相半波整流,适用于电阻性或电感性负载。
封装信息包括尺寸参数,如A(6.40mm至6.91mm)、B(2.41mm至2.67mm)、C(3.68mm至3.94mm)等,以及缺口K用于识别极性。
以上信息摘自PDF文档,由友台半导体有限公司提供。
www.umw-ic.com是友台半导体有限公司的网址。
MB6S(0.8A) 价格&库存
很抱歉,暂时无法提供与“MB6S(0.8A)”相匹配的价格&库存,您可以联系我们找货
MB6S(0.8A)
  • 1+0.46240
  • 200+0.15368
  • 1500+0.09643
  • 3000+0.07657
库存:3531
MB6S(0.8A)
  • 50+0.14224
  • 500+0.11016
  • 3000+0.08705
  • 6000+0.07636
  • 24000+0.06718
  • 51000+0.06210
库存:2746
