Application Note: AN_SY6288
Low Loss Power Distribution Switch
Features
Ordering Information
SY6288□(□□)□
Sil
tia
l-P
re
p
fid
YES
YES
YES
YES
YES
TUV
certified
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
en
UL
certified
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
YES
.C
on
Package
Type
SOT23-5
MSOP8
SO8
SOT23-5
SOT23-5
MSOP8
SO8
SOT23-5
SOT23-5
SOT23-5
SO8
MSOP8
MSOP8
MSOP8
MSOP8
MSOP8
MSOP8
SOT23-5
SOT23-5
SOT23-5
MSOP8
MSOP8
MSOP8
MSOP8
SO8
SO8
Co
rp
er
gy
Ordering
Number
SY6288AAAC
SY6288ACAC
SY6288AFAC
SY6288A1AAC
SY6288BAAC
SY6288BCAC
SY6288BFAC
SY6288CAAC
SY6288C3AAC
SY6288C30AAC
SY6288CFAC
SY6288CCAC
SY6288C1CAC
SY6288C2CAC
SY6288C4CAC
SY6288C5CAC
SY6288C30CAC
SY6288DAAC
SY6288D1AAC
SY6288D30AAC
SY6288DCAC
SY6288D1CAC
SY6288D2CAC
SY6288D5CAC
SY6288DFAC
SY6288D1FAC
YES
YES
YES
YES
YES
YES
ar
ed
Temperature Code
Package Code
Optional Spec Code
Distribution voltages: 2.5V to 5.5V
Over temperature shutdown and automatic retry
Reverse blocking (no body diode)
At shutdown, OUT can be forced higher than IN
Fault flag (OCB) output if over current, thermal
shut down, reverse blocking happens.
Automatic output discharge at shutdown
o
SY6288A1: No output discharge function
o
Others: Auto output discharge function
Built-in softstart
0.4ms rise time
RoHS Compliant and Halogen Free
Two Enable polarities and three current levels
o SY6288A: Active High/0.6A
o SY6288A1: Active High/0.6A
o SY6288B: Active Low/0.6A
o SY6288C: Active High/2A
o SY6288C1: Active High/1.5A
o SY6288C2: Active High/1.5A
o SY6288C3: Active High/1.5A
o SY6288C30: Active High/2A
o SY6288C4: Active High/2A
o SY6288C5: Active High/2.5A
o SY6288D: Active Low/2A
o SY6288D1: Active Low/1.5A
o SY6288D2: Active Low/1.5A
o SY6288D5: Active Low/2.5A
o SY6288D30:Active Low/2A
Compact packages minimize board space:
SOT23-5, SO8, MSOP8
UL certification NO. E333762
TUV certification NO. R 50188769
rP
ST
SY6288 is an ultra-low RDS(ON) switch with current limiting
function to protect the power source from over current and
short circuit conditions.
fo
General Description
YES
YES
YES
YES
YES
YES
YES
Typical Application Circuit
YES
YES
Note: A low-ESR 150uF aluminum electrolytic or
tantalum between VOUT and GND is strongly
recommended.
AN_SY6288 Rev. 1.0B
Silergy Corp. Confidential-prepared for Customer Use Only
1
AN_SY6288
Pin Configurations (Top View)
MSOP8
SO8
Top Mark
CWxyz
ABTxyz
AAJxyz
Fdxyz
DBxyz
ABDxyz
AALxyz
DFxyz
FPxyz
Brxyz
ABUxyz
ADKxyz
ADLxyz
AEXxyz
AZDxyz
ARWxyz
AAMxyz
Buxyz
DSxyz
Bqxyz
ABExyz
ACKxyz
AEHxyz
AZExyz
AANxyz
ACJxyz
rP
ST
①
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
Part Number
Package type
SY6288AAAC
SOT23-5
SY6288ACAC
MSOP8
SY6288AFAC
SO8
SY6288A1AAC
SOT23-5
SY6288BAAC
SOT23-5
SY6288BCAC
MSOP8
SY6288BFAC
SO8
SY6288CAAC
SOT23-5
SY6288C3AAC
SOT23-5
SY6288C30AAC
SOT23-5
SY6288CCAC
MSOP8
SY6288C1CAC
MSOP8
SY6288C2CAC
MSOP8
SY6288C4CAC
MSOP8
SY6288C5CAC
MSOP8
SY6288C30CAC
MSOP8
SY6288CFAC
SO8
SY6288DAAC
SOT23-5
SY6288D1AAC
SOT23-5
SY6288D30AAC
SOT23-5
SY6288DCAC
MSOP8
SY6288D1CAC
MSOP8
SY6288D2CAC
MSOP8
SY6288D5CAC
MSOP8
SY6288DFAC
SO8
SY6288D1FAC
SO8
Note① : x=year code, y=week code, z= lot number code.
fo
SOT23-5
Sil
Functional Pin Description
Pin Name
IN
GND
OUT
ENSY6288A/A1/C/C1/C2/C3/C30/C4/C5
ENB- SY6288B/D/D1/D2/D5/D30
OCB
AN_SY6288 Rev.1.0B
Pin Number
(SO8, MSOP8)
2,3
1
6,7,8
Pin number
(SOT23-5)
5
2
1
4
4
ON/OFF control. Don’t float. EN:
high enable. ENB: low enable.
5
3
Open Drain Fault Flag
Pin Description
Input pin
Ground pin
Output pin
2
AN_SY6288
Absolute Maximum Ratings (Note 1)
All pins-------------------------- -------------------------------------------------------------------------------- 6V
Power Dissipation, PD @ TA = 25°C SOT23-5/MSOP8/SO8--------------------------------------------- 0.4/0.5/0.65W
Package Thermal Resistance (Note 2)
SOT23-5/MSOP8/SO8, θ JA ------------------------------------------------------------------------ 100/150/90°C/W
SOT23-5/MSOP8/SO8, θ JC ------------------------------------------------------------------------ 30/ 65/ 45°C/W
Junction Temperature Range ---------------------------------------------------------------------------------- 150°C
Lead Temperature (Soldering, 10 sec.) -----------------------------------------------------------------------260°C
Storage Temperature Range ----------------------------------------------------------------------------------- -65°C to 150°C
rP
ST
Recommended Operating Conditions (Note 3)
Sil
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
fo
IN----------------------------------------------------------------------------------------------------------------- 2.5V to 5.5V
EN/ENB--------------------------------------------------------------------------------------------------------- -0.3V to VIN+0.3V
All other pins --------------------------------------------------------------------------------------------------- 0-5.5V
Junction Temperature Range -------------------------------------------------------------------------------- -40°C to 125°C
Ambient Temperature Range -------------------------------------------------------------------------------- -40°C to 85°C
AN_SY6288 Rev.1.0B
3
AN_SY6288
Electrical Characteristics
(VIN = 5V, CL=1uF, per channel, TA = 25°C unless otherwise specified)
Parameter
Input Voltage Range
Symbol
VIN
Shutdown Input Current
ISHDN
Quiescent Supply Current
IQ
RDS(ON)
Current Limit
ILIM
Short Circuit Output Current
IOS
Logic-Low
Voltage
Logic-High
Voltage
IN UVLO Threshold
IN UVLO Hysteresis
Turn-ON Time
OCB Low Resistance
OCB Delay Time
OUT Shutdown Discharge
Resistance
Thermal
Shutdown
Temperature
Thermal Shutdown Hysteresis
VIL
Min
2.5
Open load, switch off
Output grounded, switch off
Open load, switch on
SOT23-5 (SY6288A/A1/B/C/D/D1)
SOT23-5(SY6288C3/C30/D30)
MSOP8 (SY6288A/B/C/C1/C4)
MSOP8(SY6288C2/C5/D1/D2/D5)
MSOP8 (SY6288C30/D)
SO8( SY6288A/B/C/D/D1)
SY6288A/A1/B
SY6288C/C30/D/D30
SY6288C1
SY6288C2/C3/D2
SY6288D1
SY6288C4
SY6288C5/D5
MSOP8 (SY6288D), OUT
connected to GND device enabled.
SOT23-5(SY6288C3)
Typ
100
90
100
90
83
105
1.6
3.7
3.2
2
3.7
3.7
4.4
Unit
V
µA
µA
µA
mΩ
mΩ
mΩ
mΩ
mΩ
mΩ
A
A
A
A
A
A
A
1.8
2.4
A
1.05
1.4
0.8
A
V
60
50
60
50
57
65
0.8
2.1
1.6
1.5
1.6
2.5
2.7
0.1
0.1
32
80
70
80
70
70
85
1.2
2.9
2.4
1.75
2.5
2.9
3.55
1.2
0.7
fid
VIN,UVLO
VIN,HYS
TON
Co
rp
en
VIH
RL=5 Ω, CL=1uF
ROCB
TOCB_Delay
.C
on
EN/ EN
Threshold
tia
l-P
re
p
ar
ed
fo
rP
ST
FET RON
Test Conditions
RDIS
Except for SY6288A1
TSD
Max
5.5
1
1
2
V
0.1
400
10
10
2.4
V
V
µs
Ω
ms
10
Ω
150
°C
°C
Sil
er
gy
Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are
stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for
extended periods may affect device reliability.
Note 2: θ JA is measured in the natural convection at TA = 25°C on a low effective single layer thermal conductivity
test board of JEDEC 51-3 thermal measurement standard.
Note 3: The device is not guaranteed to function outside its operating conditions.
AN_SY6288 Rev.1.0B
4
AN_SY6288
Typical Operating Characteristics
Sil
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
fo
rP
ST
(SY6288DFAC)
AN_SY6288 Rev.1.0B
5
AN_SY6288
Output Fall Time vs. VIN
rP
ST
( RL=2.5Ω )
2400
2100
Rise Time (us)
1800
fo
1500
1200
COUT=1uF
ar
ed
900
COUT=100uF
COUT=470uF
600
3
3.5
4
4.5
5
5.5
6
VIN (V)
Sil
er
gy
Co
rp
.C
on
fid
en
Current Limit (A)
tia
l-P
re
p
300
AN_SY6288 Rev.1.0B
6
AN_SY6288
Sil
er
gy
Co
rp
.C
on
fid
en
tia
l-P
re
p
ar
ed
fo
rP
ST
Block diagram
AN_SY6288 Rev.1.0B
7
AN_SY6288
Operation
Supply Filter Capacitor
rP
ST
In order to prevent the input voltage drooping during
hot-plug events, a 10uF ceramic capacitor form VIN to
GND is strongly recommended. However, higher
capacitor values could reduce the voltage droop on the
input further. Furthermore, an output short will cause
ringing on the input without the input capacitor. It
could destroy the internal circuitry when the input
transient exceeds 6V which is the absolute maximum
supply voltage even for a short duration.
fo
Output Filter Capacitor
Between VOUT and GND, a low-ESR 150uF
aluminum electrolytic or tantalum capacitor is strongly
recommended to meet the 330mV maximum droop
requirement. Standard bypass methods should be used
to minimize inductance and resistance between the
bypass capacitor and the down steam connector. This
will reduce EMI and improve the transient performance.
If long cables are connected to the output terminals, an
anti-parallel schottky diode such as BAT54 is
suggested to be placed in parallel with the output
terminals to absorb the negative ringing due to the
cable inductance.
.C
on
PCB Layout Guide
fid
en
tia
l-P
re
p
Fault Flag (OCB)
The OCB output is asserted (active low) when an over
temperature shutdown condition is encountered. The
OCB will also be pulled if over current or reverse
blocking happens and persists for 10ms. The output
remains asserted until the fault status is removed.
Connecting a heavy capacitive load to an enabled
device can cause a momentary over current condition;
however, no false reporting on OCB occurs due to the
10-ms deglitch circuit. OCB is not deglitched when the
switch is turned OFF due to an over temperature
shutdown.
ar
ed
The SY6288 is a current limited P-channel MOSFET
power switch designed for high-side load-switching
applications. There is no parasitic body diode between
drain and source of the MOSFET, so the SY6288
prevents current flow from out to input when out being
externally forced to a higher voltage than VIN when
chip is disabled.
Over-current protection
When the over-current condition is sensed, the gate
of the pass switch is modulated to achieve constant
output current. Under output short circuit conditions,
the normal current limit folded back 50%. If the over
current condition persists for a long enough time, the
junction temperature may exceed 150°C, and overtemperature protection will shut down the part. Once
the chip temperature drops to 130°C, the part will
restart.
For best performance of the SY6288, the following
guidelines must be strictly followed:
Locate the ceramic bypass capacitors as close as
possible to the VIN pins and VOUT pins of
SY6288.
Co
rp
Keep all VBUS traces as short and wide as possible
and use at least 2 ounce copper for all VBUS traces.
er
gy
Place a ground plane under all circuitry to lower
both resistance and inductance and improve DC
and transient performance.
Sil
tantalum capacitor between VOUT and GND is
Locate the output capacitor as close to the
connectors as possible to lower impedance
(mainly inductance) between the port and the
capacitor and improve transient performance.
Input and output capacitors should be placed
closed to the IC and connected to ground plane to
reduce noise coupling.
AN_SY6288 Rev.1.0B
PCB Layout Guide (SO8)
8
rP
ST
AN_SY6288
PCB Bottom Layer (SO8)
.C
on
fid
en
tia
l-P
re
p
ar
ed
fo
PCB Top Over Layer (SO8)
Sil
er
gy
Co
rp
PCB Top Layer (SO8)
AN_SY6288 Rev. 1.0B
9
AN_SY6288
SOT23-5 Package outline &
PCB layout design
0.55
.C
on
Co
rp
1.0 - 1.3
0.95 TYP
1.90 TYP
Notes: All dimensions are in millimeters.
All dimensions don’t include mold
flash & metal burr.
Sil
er
gy
0.01 - 0.1
fid
en
0.1 - 0.15
0.25 REF
Recommended Pad Layout
0.30 - 0.50
tia
l-P
re
p
0.95 TYP
0.3 - 0.6
1.50 - 1.70
rP
ST
ar
ed
0.80
fo
2.70 - 3.00
2.40
2.80 - 3.10
AN_SY6288 Rev. 1.0B
10
AN_SY6288
rP
ST
tia
l-P
re
p
ar
ed
fo
5.40
3.80 - 4.00
1.27 TYP
5.80 - 6.20
6.10
1.55
SO8 Package outline & PCB
layout design
er
gy
Sil
AN_SY6288 Rev. 1.0B
0.60 - 0.85
4.80 - 5.00
1.40 - 1.60
0.25 base
0.18 - 0.25
fid
.C
on
-8
Co
rp
45°
0.25 - 0.50
en
0.30 – 0.50
0.08 - 0.25
0.60
1.27 (TYP)
flash & metal burr.
11
AN_SY6288
MSOP8 Package outline & PCB
layout design
4.70-5.10
fo
0.75-0.95
2.85-3.10
0.65 (TYP)
flash & metal burr.
Sil
er
gy
Co
rp
0.10-0.25
0.40-0.80
0.25 base
.C
on
fid
en
0.45
0.05-0.15
tia
l-P
re
p
ar
ed
5.30
2.85-3.10
rP
ST
1.35
0.65
AN_SY6288 Rev. 1.0B
12
AN_SY6288
Taping & Reel Specification
1. Taping orientation
SOT23-5
3.9/4.1
tia
l-P
re
p
SOP8
ar
ed
Feeding direction
fo
rP
ST
7.7/8.3
1.45/1.55
3.9/4.1
.C
on
fid
en
11.7/12.3
1.45/1.55
MSOP8
Co
rp
Feeding direction
1.45/1.55
11.7/12.3
Sil
er
gy
3.9/4.1
Feeding direction
AN_SY6288 Rev. 1.0B
13
AN_SY6288
Tape width
(mm)
Pocket
pitch(mm)
Reel size
(Inch)
SOT23-5
8
4
7"
SOP8
12
8
MSOP8
12
8
Reel
width(mm)
Trailer
length(mm)
Leader length
(mm)
Qty per
reel
8.4
280
160
3000
13"
12.4
400
400
2500
13"
12.4
400
400
3000
en
tia
l-P
re
p
Package
types
ar
ed
fo
rP
ST
2. Carrier Tape & Reel specification for packages
Sil
er
gy
Co
rp
.C
on
fid
3. Others: NA
AN_SY6288 Rev. 1.0B
14
很抱歉,暂时无法提供与“SY6288C3AAC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.42398
- 50+1.11813
- 150+0.98712
- 500+0.82350
- 3000+0.75071
- 6000+0.70697
