11P-SAN
11P-SAN
    JST
    P=2mm
    1X11P 2MM
11P-SAN 数据手册
SAN CONNECTOR 2.0mm pitch/Board-in Crimp style connectors Specifications ––––––––––––––––––– Measuring 2.0mm in pitch, 6.0mm in mounting height, and 3.25mm in thickness, this board-in connector meets the needs for high-density mounting on printed circuit boards efficiently and economically. The connector is ideal for VCRs, car stereo systems, audio products and many other consumer oriented electronic products. • Compact • Housing lances • Easy mounting onto printed circuit boards • Two types of contacts * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 1.6 min 9.2 6 2 min 2 ± 0.05 • Current rating: 2A AC, DC (AWG #24) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #30 to #24 • Applicable PC board thickness: Type A contact: 1.2mm, 1.6mm Type B contact: 1.6mm 1.85 Note: 1. The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ±0.05mm for all centers. *Type A 0.8 +0.1 -0.05 dia. *Type B 2 to 7 circuits: 0.75 ±0.05 dia. 8 to 15 circuits: 0.85 ±0.05 dia. 3. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 3.25 1 SAN CONNECTOR Contact Type A 0.9 2 1.6 Model No. Type SAN-002T-0.8A SAN-002T-0.8K A Applicable wire AWG # mm2 0.05∼0.22 B Insulation O.D.(mm) Q’ty / reel 30∼24 0.9∼1.3 14,000 Material and Finish 9 3.1 Brass, tin-plated (reflow treatment) RoHS compliance Note: Contact JST if you require shielded wires, thin wires or other special wires. Type B 1.8 0.9 Contact Crimping machine Crimp applicator SAN-002T-0.8A AP-K2N SAN-002T-0.8K Applicator Dies Crimp applicator with dies MKS-L MK/SAN-002-08 APLMK SAN002-08 *MKS-SC SC/SAN-002-08 APLSC SAN002-08 Note: *Strip-crimp applicator 9 3.1 Housing Circuits Model No. 2 2P-SAN 3P-SAN 4P-SAN 5P-SAN 6P-SAN 7P-SAN 8P-SAN 9P-SAN 10P-SAN 11P-SAN 12P-SAN 13P-SAN 14P-SAN 15P-SAN 3 4 5 1 6 13 14 15 8 5.65 JST 7 9 10 11 12 2 3.25 A B 13 14 15 Dimensions (mm) A B 2.0 5.2 1,000 4.0 7.2 1,000 6.0 9.2 1,000 8.0 11.2 1,000 10.0 13.2 1,000 12.0 15.2 1,000 14.0 17.2 1,000 16.0 19.2 1,000 18.0 21.2 1,000 20.0 23.2 1,000 22.0 25.2 1,000 24.0 27.2 1,000 26.0 29.2 1,000 28.0 31.2 1,000 Material PA 66, UL94V-0, yellow RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 2 Q'ty / bag 2P-SAN-o(blank)…yellow K…black W…white R…red
11P-SAN 价格&库存
很抱歉,暂时无法提供与“11P-SAN”相匹配的价格&库存,您可以联系我们找货
11P-SAN
    • 1000+0.37680
    库存:3909
    11P-SAN
      • 5+0.71060
      • 50+0.55320
      • 150+0.47440
      • 1000+0.41550
      • 2000+0.36820
      • 5000+0.34460
      库存:68045
      11P-SAN
        • 1000+0.45100
        库存:291
        11P-SAN
          • 1+1.025721+0.13334
          • 10+0.6693310+0.08701
          • 50+0.5911050+0.07684
          • 100+0.53894100+0.07006
          • 500+0.51286500+0.06667
          • 1000+0.504171000+0.06554
          • 2000+0.495482000+0.06441
          库存:268
          11P-SAN
            • 1000+0.37950
            库存:28000
