S-1135 Series
www.sii-ic.com
HIGH RIPPLE-REJECTION LOW DROPOUT
MIDDLE OUTPUT CURRENT CMOS VOLTAGE REGULATOR
Rev.2.2_01
© SII Semiconductor Corporation, 2008-2015
The S-1135 Series, developed using the CMOS technology, is a positive voltage regulator IC which has the low dropout
voltage, the high-accuracy output voltage and the low current consumption (300 mA output current).
A 1.0 μF small ceramic capacitor can be used. It operates with low current consumption of 45 μA typ.
The overcurrent protection circuit prevents the load current from exceeding the current capacity of the output transistor. The
ON / OFF circuit ensures longer battery life.
Various capacitors, also small ceramic capacitors, can be used for this IC more than for the conventional regulator ICs which
have CMOS technology.
Furthermore, a small SOT-89-5, SOT-23-5, and HSNT-6A packages realize high-density mounting.
Features
• Output voltage:
• Input voltage:
• Output voltage accuracy:
• Dropout voltage:
• Current consumption:
• Output current:
• Input and output capacitors :
• Ripple rejection:
• Built-in overcurrent protection circuit:
• Built-in ON / OFF circuit:
• Discharge shunt function is selectable.
• Pull-up or pull-down resistor is selectable.
• Operation temperature range:
• Lead-free, Sn 100%, halogen-free*2
1.0 V to 3.5 V, selectable in 0.05 V step
1.5 V to 5.5 V
±1.0% (1.0 V to 1.45 V output product : ±15 mV)
160 mV typ. (2.6 V output product, IOUT = 300 mA)
During operation:
45 μA typ., 65 μA max.
During power-off:
0.1 μA typ., 1.0 μA max.
Possible to output 300 mA (VIN ≥ VOUT(S) + 1.0 V)*1
A ceramic capacitor of 1.0 μF or more can be used.
70 dB typ. (1.0 V output product, f = 1.0 kHz)
Limits overcurrent of output transistor.
Ensures long battery life.
Ta = −40°C to +85°C
*1. Attention should be paid to the power dissipation of the package when the output current is large.
*2. Refer to “ Product Name Structure” for details.
Applications
• Power supply for battery-powered device
• Power supply for cellular phone
• Power supply for portable equipment
Packages
• SOT-89-5
• SOT-23-5
• HSNT-6A
1
HIGH RIPPLE-REJECTION LOW DROPOUT MIDDLE OUTPUT CURRENT CMOS VOLTAGE REGULATOR
Rev.2.2_01
S-1135 Series
Block Diagrams
1.
S-1135 Series A type
*1
VIN
VOUT
Overcurrent
protection circuit
ON / OFF
ON / OFF
circuit
Function
ON / OFF logic
Discharge shunt
function
Pull-up resistor
Pull-down resistor
Status
Active “H”
Available
None
Available
Reference
voltage circuit
*1
VSS
*1. Parasitic diode
Figure 1
2.
S-1135 Series B type
*1
VIN
VOUT
Overcurrent
protection circuit
ON / OFF
ON / OFF
circuit
Reference
voltage circuit
*1
VSS
*1. Parasitic diode
Figure 2
2
Function
ON / OFF logic
Discharge shunt
function
Pull-up resistor
Pull-down resistor
Status
Active “H”
Available
None
None
Rev.2.2_01
S-1135 Series
3.
S-1135 Series C type
*1
VIN
VOUT
Overcurrent
protection circuit
ON / OFF
ON / OFF
circuit
Function
ON / OFF logic
Discharge shunt
function
Pull-up resistor
Pull-down resistor
Status
Active “H”
None
None
Available
Reference
voltage circuit
VSS
*1. Parasitic diode
Figure 3
4.
S-1135 Series D type
*1
VIN
VOUT
Overcurrent
protection circuit
ON / OFF
ON / OFF
circuit
Function
ON / OFF logic
Discharge shunt
function
Pull-up resistor
Pull-down resistor
Status
Active “H”
None
None
None
Reference
voltage circuit
VSS
*1. Parasitic diode
Figure 4
3
Rev.2.2_01
S-1135 Series
5.
S-1135 Series E type
*1
VIN
VOUT
Overcurrent
protection circuit
ON / OFF
ON / OFF
circuit
Function
ON / OFF logic
Discharge shunt
function
Pull-up resistor
Pull-down resistor
Status
Active “L”
Available
Available
None
Reference
voltage circuit
*1
VSS
*1. Parasitic diode
Figure 5
6.
S-1135 Series F type
*1
VIN
VOUT
Overcurrent
protection circuit
ON / OFF
ON / OFF
circuit
Reference
voltage circuit
*1
VSS
*1. Parasitic diode
Figure 6
4
Function
ON / OFF logic
Discharge shunt
function
Pull-up resistor
Pull-down resistor
Status
Active “L”
Available
None
None
Rev.2.2_01
S-1135 Series
7.
S-1135 Series G type
*1
VIN
VOUT
Overcurrent
protection circuit
ON / OFF
ON / OFF
circuit
Function
ON / OFF logic
Discharge shunt
function
Pull-up resistor
Pull-down resistor
Status
Active “L”
None
Available
None
Reference
voltage circuit
VSS
*1. Parasitic diode
Figure 7
8.
S-1135 Series H type
*1
VIN
VOUT
Overcurrent
protection circuit
ON / OFF
ON / OFF
circuit
Function
ON / OFF logic
Discharge shunt
function
Pull-up resistor
Pull-down resistor
Status
Active “L”
None
None
None
Reference
voltage circuit
VSS
*1. Parasitic diode
Figure 8
5
Rev.2.2_01
S-1135 Series
Users can select the product type, output voltage, and package type for the S-1135 Series. Refer to “1. Product
name” regarding the contents of product name, “2. Function list of product type” regarding the product type, “3.
Packages” regarding the package drawings.
1.
Product name
1. 1
SOT-89-5
S-1135
x
xx
U5T1
x
Environmental code
U: Lead-free (Sn 100%), halogen-free
G: Lead-free (for details, please contact our sales office)
Package abbreviation and IC packing specifications*1
U5T1: SOT-89-5, Tape
Output voltage*2
10 to 35
(e.g., when the output voltage is 1.0 V, it is expressed as 10.)
Product type*3
A to H
*1.
*2.
*3.
1. 2
Refer to the tape drawing.
If you request the product which has 0.05 V step, contact our sales office.
Refer to “2. Function list of product type”.
SOT-23-5
S-1135
x
xx
M5T1
x
Environmental code
S: Lead-free, halogen-free
M5T1: SOT-23-5, Tape
Output voltage*2
10 to 35
Product type*3
A to H
*1.
*2.
*3.
6
Rev.2.2_01
S-1135 Series
1. 3
HSNT-6A
S-1135
x
xx
A6T1
U
Environmental code
A6T1: HSNT-6A, Tape
Output voltage*2
10 to 35
Product type*3
A to H
*1.
*2.
*3.
2.
Table 1
Product Type
3.
ON / OFF Logic
Discharge Shunt Function
Pull-up Resistor
Pull-down Resistor
A
Active “H”
Available
None
Available
B
Active “H”
Available
None
None
C
Active “H”
None
None
Available
D
Active “H”
None
None
None
E
Active “L”
Available
Available
None
F
Active “L”
Available
None
None
G
Active “L”
None
Available
None
H
Active “L”
None
None
None
Packages
Package Name
SOT-89-5
SOT-23-5
HSNT-6A
Package
UP005-A-P-SD
MP005-A-P-SD
PJ006-A-P-SD
Tape
UP005-A-C-SD
MP005-A-C-SD
PJ006-A-C-SD
Drawing Code
Reel
UP005-A-R-SD
MP005-A-R-SD
PJ006-A-R-SD
Land
PJ006-A-LM-SD
Stencil Opening
PJ006-A-LM-SD
7
Rev.2.2_01
S-1135 Series
4.
Product name list
4. 1
ON / OFF logic:
Discharge shunt function:
Active “H”
Available
Pull-up resistor:
Pull-down resistor:
None
Available
Table 2
Output Voltage
SOT-89-5
SOT-23-5
HSNT-6A
1.0 V ±15 mV
S-1135A10-U5T1x
S-1135A10-M5T1y
S-1135A10-A6T1U
1.1 V ±15 mV
S-1135A11-U5T1x
S-1135A11-M5T1y
S-1135A11-A6T1U
1.2 V ±15 mV
S-1135A12-U5T1x
S-1135A12-M5T1y
S-1135A12-A6T1U
1.3 V ±15 mV
S-1135A13-U5T1x
S-1135A13-M5T1y
S-1135A13-A6T1U
1.4 V ±15 mV
S-1135A14-U5T1x
S-1135A14-M5T1y
S-1135A14-A6T1U
1.5 V ±1.0%
S-1135A15-U5T1x
S-1135A15-M5T1y
S-1135A15-A6T1U
1.6 V ±1.0%
S-1135A16-U5T1x
S-1135A16-M5T1y
S-1135A16-A6T1U
1.7 V ±1.0%
S-1135A17-U5T1x
S-1135A17-M5T1y
S-1135A17-A6T1U
1.8 V ±1.0%
S-1135A18-U5T1x
S-1135A18-M5T1y
S-1135A18-A6T1U
1.85 V ±1.0%
S-1135A1J-U5T1x
S-1135A1J-M5T1y
S-1135A1J-A6T1U
1.9 V ±1.0%
S-1135A19-U5T1x
S-1135A19-M5T1y
S-1135A19-A6T1U
2.0 V ±1.0%
S-1135A20-U5T1x
S-1135A20-M5T1y
S-1135A20-A6T1U
2.1 V ±1.0%
S-1135A21-U5T1x
S-1135A21-M5T1y
S-1135A21-A6T1U
2.2 V ±1.0%
S-1135A22-U5T1x
S-1135A22-M5T1y
S-1135A22-A6T1U
2.3 V ±1.0%
S-1135A23-U5T1x
S-1135A23-M5T1y
S-1135A23-A6T1U
2.4 V ±1.0%
S-1135A24-U5T1x
S-1135A24-M5T1y
S-1135A24-A6T1U
2.5 V ±1.0%
S-1135A25-U5T1x
S-1135A25-M5T1y
S-1135A25-A6T1U
2.6 V ±1.0%
S-1135A26-U5T1x
S-1135A26-M5T1y
S-1135A26-A6T1U
2.7 V ±1.0%
S-1135A27-U5T1x
S-1135A27-M5T1y
S-1135A27-A6T1U
2.8 V ±1.0%
S-1135A28-U5T1x
S-1135A28-M5T1y
S-1135A28-A6T1U
2.85 V ±1.0%
S-1135A2J-U5T1x
S-1135A2J-M5T1y
S-1135A2J-A6T1U
2.9 V ±1.0%
S-1135A29-U5T1x
S-1135A29-M5T1y
S-1135A29-A6T1U
3.0 V ±1.0%
S-1135A30-U5T1x
S-1135A30-M5T1y
S-1135A30-A6T1U
3.1 V ±1.0%
S-1135A31-U5T1x
S-1135A31-M5T1y
S-1135A31-A6T1U
3.2 V ±1.0%
S-1135A32-U5T1x
S-1135A32-M5T1y
S-1135A32-A6T1U
3.3 V ±1.0%
S-1135A33-U5T1x
S-1135A33-M5T1y
S-1135A33-A6T1U
3.4 V ±1.0%
S-1135A34-U5T1x
S-1135A34-M5T1y
S-1135A34-A6T1U
3.5 V ±1.0%
S-1135A35-U5T1x
S-1135A35-M5T1y
S-1135A35-A6T1U
Remark 1. Please contact our sales office for products with specifications other than the above.
2. x: G or U
y: S or U
3. Please select products of environmental code = U for Sn 100%, halogen-free products.
8
Rev.2.2_01
S-1135 Series
4. 2
ON / OFF logic:
Active “H”
Available
Pull-up resistor:
Pull-down resistor:
None
None
Table 3
Output Voltage
SOT-89-5
SOT-23-5
HSNT-6A
1.0 V ±15 mV
S-1135B10-U5T1x
S-1135B10-M5T1y
S-1135B10-A6T1U
1.1 V ±15 mV
S-1135B11-U5T1x
S-1135B11-M5T1y
S-1135B11-A6T1U
1.2 V ±15 mV
S-1135B12-U5T1x
S-1135B12-M5T1y
S-1135B12-A6T1U
1.3 V ±15 mV
S-1135B13-U5T1x
S-1135B13-M5T1y
S-1135B13-A6T1U
1.4 V ±15 mV
S-1135B14-U5T1x
S-1135B14-M5T1y
S-1135B14-A6T1U
1.5 V ±1.0%
S-1135B15-U5T1x
S-1135B15-M5T1y
S-1135B15-A6T1U
1.6 V ±1.0%
S-1135B16-U5T1x
S-1135B16-M5T1y
S-1135B16-A6T1U
1.7 V ±1.0%
S-1135B17-U5T1x
S-1135B17-M5T1y
S-1135B17-A6T1U
1.8 V ±1.0%
S-1135B18-U5T1x
S-1135B18-M5T1y
S-1135B18-A6T1U
1.85 V ±1.0%
S-1135B1J-U5T1x
S-1135B1J-M5T1y
S-1135B1J-A6T1U
1.9 V ±1.0%
S-1135B19-U5T1x
S-1135B19-M5T1y
S-1135B19-A6T1U
2.0 V ±1.0%
S-1135B20-U5T1x
S-1135B20-M5T1y
S-1135B20-A6T1U
2.1 V ±1.0%
S-1135B21-U5T1x
S-1135B21-M5T1y
S-1135B21-A6T1U
2.2 V ±1.0%
S-1135B22-U5T1x
S-1135B22-M5T1y
S-1135B22-A6T1U
2.3 V ±1.0%
S-1135B23-U5T1x
S-1135B23-M5T1y
S-1135B23-A6T1U
2.4 V ±1.0%
S-1135B24-U5T1x
S-1135B24-M5T1y
S-1135B24-A6T1U
2.5 V ±1.0%
S-1135B25-U5T1x
S-1135B25-M5T1y
S-1135B25-A6T1U
2.6 V ±1.0%
S-1135B26-U5T1x
S-1135B26-M5T1y
S-1135B26-A6T1U
2.7 V ±1.0%
S-1135B27-U5T1x
S-1135B27-M5T1y
S-1135B27-A6T1U
2.8 V ±1.0%
S-1135B28-U5T1x
S-1135B28-M5T1y
S-1135B28-A6T1U
2.85 V ±1.0%
S-1135B2J-U5T1x
S-1135B2J-M5T1y
S-1135B2J-A6T1U
2.9 V ±1.0%
S-1135B29-U5T1x
S-1135B29-M5T1y
S-1135B29-A6T1U
3.0 V ±1.0%
S-1135B30-U5T1x
S-1135B30-M5T1y
S-1135B30-A6T1U
3.1 V ±1.0%
S-1135B31-U5T1x
S-1135B31-M5T1y
S-1135B31-A6T1U
3.2 V ±1.0%
S-1135B32-U5T1x
S-1135B32-M5T1y
S-1135B32-A6T1U
3.3 V ±1.0%
S-1135B33-U5T1x
S-1135B33-M5T1y
S-1135B33-A6T1U
3.4 V ±1.0%
S-1135B34-U5T1x
S-1135B34-M5T1y
S-1135B34-A6T1U
3.5 V ±1.0%
S-1135B35-U5T1x
S-1135B35-M5T1y
S-1135B35-A6T1U
2. x: G or U
y: S or U
9
Rev.2.2_01
S-1135 Series
4. 3
ON / OFF logic:
Active “H”
None
Pull-up resistor:
Pull-down resistor:
None
Available
Table 4
Output Voltage
SOT-89-5
SOT-23-5
HSNT-6A
1.0 V ±15 mV
S-1135C10-U5T1x
S-1135C10-M5T1y
S-1135C10-A6T1U
1.1 V ±15 mV
S-1135C11-U5T1x
S-1135C11-M5T1y
S-1135C11-A6T1U
1.2 V ±15 mV
S-1135C12-U5T1x
S-1135C12-M5T1y
S-1135C12-A6T1U
1.3 V ±15 mV
S-1135C13-U5T1x
S-1135C13-M5T1y
S-1135C13-A6T1U
1.4 V ±15 mV
S-1135C14-U5T1x
S-1135C14-M5T1y
S-1135C14-A6T1U
1.5 V ±1.0%
S-1135C15-U5T1x
S-1135C15-M5T1y
S-1135C15-A6T1U
1.6 V ±1.0%
S-1135C16-U5T1x
S-1135C16-M5T1y
S-1135C16-A6T1U
1.7 V ±1.0%
S-1135C17-U5T1x
S-1135C17-M5T1y
S-1135C17-A6T1U
1.8 V ±1.0%
S-1135C18-U5T1x
S-1135C18-M5T1y
S-1135C18-A6T1U
1.85 V ±1.0%
S-1135C1J-U5T1x
S-1135C1J-M5T1y
S-1135C1J-A6T1U
1.9 V ±1.0%
S-1135C19-U5T1x
S-1135C19-M5T1y
S-1135C19-A6T1U
2.0 V ±1.0%
S-1135C20-U5T1x
S-1135C20-M5T1y
S-1135C20-A6T1U
2.1 V ±1.0%
S-1135C21-U5T1x
S-1135C21-M5T1y
S-1135C21-A6T1U
2.2 V ±1.0%
S-1135C22-U5T1x
S-1135C22-M5T1y
S-1135C22-A6T1U
2.3 V ±1.0%
S-1135C23-U5T1x
S-1135C23-M5T1y
S-1135C23-A6T1U
2.4 V ±1.0%
S-1135C24-U5T1x
S-1135C24-M5T1y
S-1135C24-A6T1U
2.5 V ±1.0%
S-1135C25-U5T1x
S-1135C25-M5T1y
S-1135C25-A6T1U
2.6 V ±1.0%
S-1135C26-U5T1x
S-1135C26-M5T1y
S-1135C26-A6T1U
2.7 V ±1.0%
S-1135C27-U5T1x
S-1135C27-M5T1y
S-1135C27-A6T1U
2.8 V ±1.0%
S-1135C28-U5T1x
S-1135C28-M5T1y
S-1135C28-A6T1U
2.85 V ±1.0%
S-1135C2J-U5T1x
S-1135C2J-M5T1y
S-1135C2J-A6T1U
2.9 V ±1.0%
S-1135C29-U5T1x
S-1135C29-M5T1y
S-1135C29-A6T1U
3.0 V ±1.0%
S-1135C30-U5T1x
S-1135C30-M5T1y
S-1135C30-A6T1U
3.1 V ±1.0%
S-1135C31-U5T1x
S-1135C31-M5T1y
S-1135C31-A6T1U
3.2 V ±1.0%
S-1135C32-U5T1x
S-1135C32-M5T1y
S-1135C32-A6T1U
3.3 V ±1.0%
S-1135C33-U5T1x
S-1135C33-M5T1y
S-1135C33-A6T1U
3.4 V ±1.0%
S-1135C34-U5T1x
S-1135C34-M5T1y
S-1135C34-A6T1U
3.5 V ±1.0%
S-1135C35-U5T1x
S-1135C35-M5T1y
S-1135C35-A6T1U
2. x: G or U
y: S or U
10
Rev.2.2_01
S-1135 Series
4. 4
ON / OFF logic:
Active “H”
None
Pull-up resistor:
Pull-down resistor:
None
None
Table 5
Output Voltage
SOT-89-5
SOT-23-5
HSNT-6A
1.0 V ±15 mV
S-1135D10-U5T1x
S-1135D10-M5T1y
S-1135D10-A6T1U
1.1 V ±15 mV
S-1135D11-U5T1x
S-1135D11-M5T1y
S-1135D11-A6T1U
1.2 V ±15 mV
S-1135D12-U5T1x
S-1135D12-M5T1y
S-1135D12-A6T1U
1.3 V ±15 mV
S-1135D13-U5T1x
S-1135D13-M5T1y
S-1135D13-A6T1U
1.4 V ±15 mV
S-1135D14-U5T1x
S-1135D14-M5T1y
S-1135D14-A6T1U
1.5 V ±1.0%
S-1135D15-U5T1x
S-1135D15-M5T1y
S-1135D15-A6T1U
1.6 V ±1.0%
S-1135D16-U5T1x
S-1135D16-M5T1y
S-1135D16-A6T1U
1.7 V ±1.0%
S-1135D17-U5T1x
S-1135D17-M5T1y
S-1135D17-A6T1U
1.8 V ±1.0%
S-1135D18-U5T1x
S-1135D18-M5T1y
S-1135D18-A6T1U
1.85 V ±1.0%
S-1135D1J-U5T1x
S-1135D1J-M5T1y
S-1135D1J-A6T1U
1.9 V ±1.0%
S-1135D19-U5T1x
S-1135D19-M5T1y
S-1135D19-A6T1U
2.0 V ±1.0%
S-1135D20-U5T1x
S-1135D20-M5T1y
S-1135D20-A6T1U
2.1 V ±1.0%
S-1135D21-U5T1x
S-1135D21-M5T1y
S-1135D21-A6T1U
2.2 V ±1.0%
S-1135D22-U5T1x
S-1135D22-M5T1y
S-1135D22-A6T1U
2.3 V ±1.0%
S-1135D23-U5T1x
S-1135D23-M5T1y
S-1135D23-A6T1U
2.4 V ±1.0%
S-1135D24-U5T1x
S-1135D24-M5T1y
S-1135D24-A6T1U
2.5 V ±1.0%
S-1135D25-U5T1x
S-1135D25-M5T1y
S-1135D25-A6T1U
2.6 V ±1.0%
S-1135D26-U5T1x
S-1135D26-M5T1y
S-1135D26-A6T1U
2.7 V ±1.0%
S-1135D27-U5T1x
S-1135D27-M5T1y
S-1135D27-A6T1U
2.8 V ±1.0%
S-1135D28-U5T1x
S-1135D28-M5T1y
S-1135D28-A6T1U
2.85 V ±1.0%
S-1135D2J-U5T1x
S-1135D2J-M5T1y
S-1135D2J-A6T1U
2.9 V ±1.0%
S-1135D29-U5T1x
S-1135D29-M5T1y
S-1135D29-A6T1U
3.0 V ±1.0%
S-1135D30-U5T1x
S-1135D30-M5T1y
S-1135D30-A6T1U
3.1 V ±1.0%
S-1135D31-U5T1x
S-1135D31-M5T1y
S-1135D31-A6T1U
3.2 V ±1.0%
S-1135D32-U5T1x
S-1135D32-M5T1y
S-1135D32-A6T1U
3.3 V ±1.0%
S-1135D33-U5T1x
S-1135D33-M5T1y
S-1135D33-A6T1U
3.4 V ±1.0%
S-1135D34-U5T1x
S-1135D34-M5T1y
S-1135D34-A6T1U
3.5 V ±1.0%
S-1135D35-U5T1x
S-1135D35-M5T1y
S-1135D35-A6T1U
2. x: G or U
y: S or U
11
Rev.2.2_01
S-1135 Series
Pin Configurations
SOT-89-5
Top view
5
4
*1.
1
2
Table 6
Pin No.
Symbol
Description
1
VOUT
Output voltage pin
2
VSS
GND pin
3
No connection
NC*1
4
ON / OFF
ON / OFF pin
5
VIN
Input voltage pin
The NC pin is electrically open.
The NC pin can be connected to VIN or VSS.
3
Figure 9
SOT-23-5
Top view
5
4
*1.
1
2
Table 7
Pin No.
Symbol
Description
1
VIN
Input voltage pin
2
VSS
GND pin
3
ON / OFF
ON / OFF pin
4
No connection
NC*1
5
VOUT
Output voltage pin
3
Figure 10
HSNT-6A
Top view
1
6
2
5
3
4
*1.
Bottom view
6
1
5
2
4
3
*1
*1. Connect the heat sink of backside
at shadowed area to the board,
and set electric potential open or
GND.
However, do not use it as the
function of electrode.
Figure 11
12
Table 8
Pin No.
Symbol
Description
1
VOUT
Output voltage pin
2
VSS
GND pin
3
No connection
NC*1
4
ON / OFF
ON / OFF pin
5
No connection
NC*1
6
VIN
Input voltage pin
Rev.2.2_01
S-1135 Series
Absolute Maximum Ratings
Table 9
Item
Symbol
VIN
VON / OFF
VOUT
Input voltage
Output voltage
SOT-89-5
PD
SOT-23-5
HSNT-6A
Operation ambient temperature
Topr
Storage temperature
Tstg
*1. When mounted on board
[Mounted board]
(1) Board size :
114.3 mm × 76.2 mm × t1.6 mm
(2) Name :
JEDEC STANDARD51-7
*2. When mounted on board
[Mounted board]
(1) Board size :
50 mm × 50 mm × t1.6 mm
(2) Wiring ratio : 50%
Power dissipation
VSS − 0.3 to VSS + 6.0
VSS − 0.3 to VIN + 0.3
1000*1
600*1
1000*2
−40 to +85
−40 to +125
V
V
V
mW
mW
mW
°C
°C
The absolute maximum ratings are rated values exceeding which the product could suffer physical
damage. These values must therefore not be exceeded under any conditions.
1200
Power Dissipation (PD) [mW]
Caution
(Ta = 25°C unless otherwise specified)
Unit
1000
SOT-89-5
HSNT-6A
800
600
400
SOT-23-5
200
100
50
Ambient Temperature (Ta) [°C]
Figure 12 Power Dissipation of Package
13
Rev.2.2_01
S-1135 Series
Electrical Characteristics
Table 10 (1 / 2)
Item
Output
voltage*1
Output current*2
Symbol
1.0 V ≤ VOUT(S) < 1.1 V
1.1 V ≤ VOUT(S) < 1.2 V
1.2 V ≤ VOUT(S) < 1.3 V
1.3 V ≤ VOUT(S) < 1.4 V
1.4 V ≤ VOUT(S) < 1.5 V
1.5 V ≤ VOUT(S) < 2.0 V
2.0 V ≤ VOUT(S) < 2.6 V
2.6 V ≤ VOUT(S) ≤ 3.5 V
VOUT(S)
− 0.015
VOUT(S)
× 0.99
300*5
0.50
0.05
0.2
%/V
1
1.1 V ≤ VOUT(S) ≤ 3.5 V
0.05
0.2
%/V
1
1.0 V ≤ VOUT(S) ≤ 2.0 V
2.0 V < VOUT(S) ≤ 3.5 V
1.0 V ≤ VOUT(S) ≤ 3.0 V
VIN = VOUT(S) + 1.0 V,
1.0 mA ≤ IOUT ≤ 300 mA
3.0 V < VOUT(S) ≤ 3.5 V
VIN = VOUT(S) + 1.0 V, IOUT = 100 mA,
−40°C ≤ Ta ≤ +85°C
15
15
30
30
40
45
mV
mV
mV
mV
1
1
1
1
±130
ppm/°C
1
ISS1
VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load
45
65
μA
2
VOUT(E)
IOUT
Dropout voltage*3
Vdrop
Line regulation
ΔVOUT1
ΔVIN• VOUT
Load regulation
Conditions
Test
Min.
Typ.
Max.
Unit
Circuit
ΔVOUT2
ΔVOUT
ΔTa • VOUT
IOUT = 100 mA
1.0 V ≤ VOUT(S) < 1.5 V
1.5 V ≤ VOUT(S) ≤ 3.5 V
IOUT = 300 mA
1.6 V ≤ VIN ≤ 5.5 V,
IOUT = 100 mA
VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V,
IOUT = 100 mA
1.0 mA ≤ IOUT ≤ 150 mA
0.61
0.49
0.38
0.31
0.27
0.25
0.21
0.16
VOUT(S)
+ 0.015
VOUT(S)
× 1.01
0.72
0.61
0.53
0.47
0.41
0.38
0.32
0.26
VOUT(S)
VOUT(S)
V
1
V
1
mA
V
V
V
V
V
V
V
V
3
1
1
1
1
1
1
1
1
Output voltage
temperature coefficient*4
Current consumption
during operation
Current consumption
during power-off
Input voltage
ON / OFF pin
input voltage “H”
ON / OFF pin
input voltage “L”
ON / OFF pin
input current “H”
ISS2
VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load
0.1
1.0
μA
2
VIN
1.5
5.5
V
1.0
V
4
0.3
V
4
ON / OFF pin
input current “L”
ISL
VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ
determined by VOUT output level
B / D / E / F / G / H type
VIN = 5.5 V,
VON / OFF = 5.5 V
A / C type
A / B / C / D / F / H type
VIN = 5.5 V,
VON / OFF = 0 V
E / G type
1.0 V ≤ VOUT(S) ≤ 1.2 V
f = 1.0 kHz,
ΔVrip = 0.5 Vrms,
1.2 V < VOUT(S) ≤ 3.5 V
IOUT = 50 mA
VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V
−0.1
1.0
−0.1
1.0
2.5
2.5
0.1
5.0
0.1
5.0
μA
μA
μA
μA
4
4
4
4
70
dB
5
65
dB
5
100
mA
3
Ripple rejection
Short-circuit current
14
VSH
VSL
ISH
RR
Ishort
Rev.2.2_01
S-1135 Series
Table 10 (2 / 2)
S-1135 Series A / B / E / F type (With discharge shunt function)
Item
“L” output Nch
ON resistance
Symbol
RLOW
Conditions
VOUT = 0.1 V, VIN = 5.5 V
Min.
Typ.
Max.
Unit
Test
Circuit
35
Ω
3
Min.
Typ.
Max.
Unit
Test
Circuit
S-1135 Series A / C / E / G type (With pull-up / pull-down resistor)
Item
Symbol
Conditions
Power-off pull-up /
RPD
1.0
2.2
5.0
MΩ
4
pull-down resistor
*1. VOUT(S): Set output voltage
VOUT(E): Actual output voltage
Output voltage when fixing IOUT(= 100 mA) and inputting VOUT(S) +1.0 V
*2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current.
*3. Vdrop = VIN1 − (VOUT3 × 0.98)
VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 300 mA.
VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input
voltage.
*4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation.
ΔVOUT
ΔVOUT
[mV/°C]*1 = VOUT(S)[V]*2 × ΔTa • VOUT [ppm/°C]*3 ÷ 1000
ΔTa
*1. Change in temperature of output voltage
*2. Set output voltage
*3. Output voltage temperature coefficient
*5. The output current can be at least this value.
Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the
This specification is guaranteed by design.
15
Rev.2.2_01
S-1135 Series
Test Circuits
1.
VOUT
VIN
ON / OFF
V
VSS
A
Set to ON
Figure 13
2.
A
VOUT
VIN
ON / OFF
VSS
Set to VIN or GND
Figure 14
3.
VOUT
VIN
ON / OFF
VSS
A
V
Set to VIN or GND
Figure 15
4.
VOUT
VIN
A
ON / OFF
VSS
V
RL
Figure 16
5.
VOUT
VIN
ON / OFF
VSS
Set to ON
Figure 17
16
V
RL
Rev.2.2_01
S-1135 Series
Standard Circuit
Input
Output
VOUT
VIN
CIN
*1
ON / OFF
VSS
Single GND
*1.
*2.
CL
*2
GND
CIN is a capacitor for stabilizing the input.
A ceramic capacitor of 1.0 μF or more can be used as CL.
Figure 18
Caution
The above connection diagram and constant will not guarantee successful operation. Perform
thorough evaluation using the actual application to set the constant.
Condition of Application
Input capacitor (CIN) :
Output capacitor (CL) :
1.0 μF or more
1.0 μF or more
Caution Generally a series regulator may cause oscillation, depending on the selection of external parts.
Confirm that no oscillation occurs in the application for which the above capacitors are used.
Selection of Input and Output Capacitors (CIN, CL)
The S-1135 Series requires an output capacitor between the VOUT and VSS pin for phase compensation. Operation is
stabilized by a ceramic capacitor with an output capacitance of 1.0 μF or more over the entire temperature range.
When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be
1.0 μF or more.
The value of the output overshoot or undershoot transient response varies depending on the value of the output
capacitor. The required capacitance of the input capacitor differs depending on the application.
The recommended capacitance for an application is CIN ≥ 1.0 μF, CL ≥ 1.0 μF; however, when selecting the output
capacitor, perform sufficient evaluation, including evaluation of temperature characteristics, on the actual device.
17
Rev.2.2_01
S-1135 Series
Explanation of Terms
1.
Low dropout voltage regulator
This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor.
2.
Output voltage (VOUT)
The accuracy of the output voltage is ensured at ±1.0% or ±15 mV*1 under the specified conditions of fixed input
voltage*2, fixed output current, and fixed temperature.
*1.
*2.
When VOUT < 1.5 V : ±15 mV, When 1.5 V ≤ VOUT : ±1.0%
Differs depending on the product.
Caution
3.
If the above conditions change, the output voltage value may vary and exceed the accuracy range
of the output voltage. Refer to “ Electrical Characteristics” and “ Characteristics (Typical
Data)” for details.
ΔVOUT1
ΔVIN • VOUT
Line regulation
Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output
voltage changes due to a change in the input voltage with the output current remaining unchanged.
4.
Load regulation (ΔVOUT2)
Indicates the dependency of the output voltage on the output current. That is, the values show how much the output
voltage changes due to a change in the output current with the input voltage remaining unchanged.
5.
Dropout voltage (Vdrop)
Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN)
gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN =
VOUT(S) + 1.0 V.
18
Rev.2.2_01
S-1135 Series
ΔVOUT
ΔTa • VOUT
6. Output voltage temperature coefficient
The shaded area in Figure 19 is the range where VOUT varies in the operation temperature range when the output
voltage temperature coefficient is ±130 ppm/°C.
Example of S-1135B30 typ. product
VOUT
[V]
+0.39 mV/°C
VOUT(E)
*1
−0.39 mV/°C
−40
*1.
+25
+85
Ta [°C]
VOUT(E) is the value of the output voltage measured at Ta = +25°C.
Figure 19
ΔVOUT
ΔVOUT
ΔTa
19
Rev.2.2_01
S-1135 Series
Operation
1.
Basic operation
Figure 20 shows the block diagram of the S-1135 Series.
The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage
resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant
output voltage which is not influenced by the input voltage and temperature change, to the output transistor.
VIN
*1
Current
supply
Error
amplifier
Vref
VOUT
Rf
Vfb
Reference voltage
circuit
Rs
VSS
*1.
Parasitic diode
Figure 20
2.
Output transistor
In the S-1135 Series, a low on-resistance P-channel MOS FET is used as the output transistor.
Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to reverse
current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher
than VIN.
Rev.2.2_01
S-1135 Series
3.
ON / OFF pin
This pin starts and stops the regulator.
When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS
FET output transistor between the VIN and VOUT pins is turned off, reducing current consumption significantly.
Since the S-1135 Series A / B / E / F type has a built-in discharge shunt circuit to discharge the output capacitance,
the VOUT pin is forcibly set to VSS level. In the S-1135 Series C / D / G / H type, the VOUT pin is set to VSS level
through several hundred kΩ internal divided resistors between the VOUT and VSS pins. Note that the current
consumption increases when a voltage of 0.3 V to 1.0 V (Ta = 25°C) is applied to the ON / OFF pin.
The ON / OFF pin is configured as shown in Figures 21 and 22. In the S-1135 Series A / C / E / G type, the
ON
/ OFF pin is internally pulled up to the VIN pin or pulled down to the VSS pin in the floating status, so the VOUT pin is
set to the VSS level. In the S-1135 Series B / D / F / H type, the ON / OFF pin is not internally pulled up or pulled
down, so do not use the ON / OFF pin in the floating status. When not using the ON / OFF pin, connect it to the VIN
pin in the product B / D type, and connect it to the VSS pin in the F / H type.
Table 11
Product Type
ON / OFF Pin
Internal Circuit
VOUT Pin Voltage
Current Consumption
A/B/C/D
“H”: ON
Operate
Set value
ISS1*1
A/B/C/D
“L”: OFF
Stop
VSS level
ISS2
E/F/G/H
“H”: OFF
Stop
VSS level
ISS2
E/F/G/H
“L”: ON
Operate
Set value
ISS1*1
*1. Note that the IC’s current consumption increases as much as current flows into the pull-up / pull-down
resistor when; the ON / OFF pin is connected to the VIN pin in the A / C type, the ON / OFF pin is
connected to the VSS pin in the E / G type (Refer to Figure 21).
(1) S-1135 Series A / C / E / G type
(2) S-1135 Series B / D / F / H type
VIN
VIN
E / G type
ON / OFF
ON / OFF
A / C type
VSS
Figure 21
VSS
Figure 22
21
Rev.2.2_01
S-1135 Series
4.
Discharge shunt function (S-1135 Series A / B / E / F type)
The S-1135 Series A / B / E / F type has a built-in discharge shunt circuit to discharge the output capacitance.
When the ON / OFF pin is set to OFF level, turns the output transistor off, and turns the discharge shunt circuit on so
that the output capacitor discharges. These types allow the VOUT pin to reach the VSS level faster than the S-1135
Series C / D / G / H type that does not have a discharge shunt circuit.
S-1135 Series
Output transistor : OFF
*1
VOUT
VIN
Discharge shunt circuit
: ON
*1
ON / OFF
ON / OFF circuit
Output
capacitor
(CL)
ON / OFF pin : OFF
Current flow
GND
VSS
*1. Parasitic diode
Figure 23
22
Rev.2.2_01
S-1135 Series
5.
Overcurrent protection circuit
The S-1135 Series has an overcurrent protection circuit having the characteristics shown in “1. Output Voltage vs.
Output Current (When Load Current Increases) (Ta = 25°C)” in “ Characteristics (Typical Data)”, in order to
protect the output transistor against an excessive output current and short circuiting between the VOUT and VSS
pins. The current when the output pin is short-circuited (Ishort) is internally set at approx. 100 mA (typ.), and the normal
value is restored for the output voltage, if releasing a short circuit once.
Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps
short circuiting inside, pay attention to the conditions of input voltage and load current so that,
under the usage conditions including short circuit, the loss of the IC will not exceed power
dissipation of the package.
6.
Pull-down / pull-up resistor (S-1135 Series A / C / E / G type)
In the S-1135 Series A / C / E / G type, the ON / OFF pin is internally pulled up to the VIN pin or pulled down to the
VSS pin in the floating status, so the VOUT pin is set to the VSS level.
Note that the IC’s current consumption increases as much as current flows into the pull-up / pull-down resistor of 2.2
MΩ (typ.) when; the ON / OFF pin is connected to the VIN pin in the A / C type, the ON / OFF pin is connected to the
VSS pin in the E / G type.
23
Rev.2.2_01
S-1135 Series
Precautions
• Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When
mounting an output capacitor between the VOUT and VSS pins (CL) and a capacitor for stabilizing the input between
the VIN and VSS pins (CIN), the distance from the capacitors to these pins should be as short as possible.
• Note that generally the output voltage may increase when a series regulator is used at low load current (1.0 mA or
less).
• Note that generally the output voltage may increase due to the leakage current from an output driver when a series
regulator is used at high temperature.
• Generally a series regulator may cause oscillation, depending on the selection of external parts. The following
conditions are recommended for the S-1135 Series. However, be sure to perform sufficient evaluation under the actual
usage conditions for selection, including evaluation of temperature characteristics. Refer to “5. Example of
Equivalent Series Resistance vs. Output Current Characteristics (Ta = 25°C)” in “ Reference Data” for the
equivalent series resistance (RESR) of the output capacitor.
1.0 μF or more
1.0 μF or more
• The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small
or an input capacitor is not connected.
• If the output capacitance is small, power supply’s fluctuation and the characteristics of load fluctuation become worse.
Sufficiently evaluate the output voltage’s fluctuation with the actual device.
• Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power
supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device.
• The application conditions for the input voltage, the output voltage, and the load current should not exceed the
package power dissipation.
• Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic
protection circuit.
• In determining the output current, attention should be paid to the output current value specified in Table 10 in “
Electrical Characteristics” and footnote *5 of the table.
• SII Semiconductor Corporation claims no responsibility for any disputes arising out of or in connection with any
infringement by products including this IC of patents owned by a third party.
24
Rev.2.2_01
S-1135 Series
Output Voltage vs. Output Current (When Load Current Increases) (Ta = 25°C)
VOUT = 2.5 V
3.0
1.0
2.5
0.8
VOUT [V]
VOUT = 1.0 V
1.2
VOUT [V]
1.
VIN = 1.3 V
1.5 V
2.0 V
3.0 V
5.5 V
0.6
0.4
0.2
1.5
1.0
0.5
200
300 400
IOUT [mA]
500
100
200
300 400
IOUT [mA]
VIN = 3.8 V
4.0 V
4.5 V
5.5 V
VOUT [V]
VOUT = 3.5 V
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Remark
500
100
200
300 400
IOUT [mA]
500
600
be paid to the following.
1. The minimum output current value and
footnote *5 in Table 10 in the “ Electrical
Characteristics”
2. The package power dissipation
600
Output Voltage vs. Input Voltage (Ta = 25°C)
VOUT = 1.0 V
1.2
1.0
IOUT = 1 mA
IOUT = 30 mA
IOUT = 50 mA
IOUT = 100 mA
0.9
0.8
0.7
0.6
0.6
VOUT = 3.5 V
3.7
3.6
3.5
3.4
3.3
3.2
3.1
3.0
3.0
1.0
1.4
1.8
VIN [V]
VOUT = 2.5 V
2.7
2.6
2.5
2.4
2.3
2.2
2.1
2.0
2.0
VOUT [V]
VOUT [V]
1.1
VOUT [V]
2.
VIN = 2.8 V
3.0 V
3.5 V
4.5 V
5.5 V
2.0
2.2
2.6
5.0
5.5
IOUT = 1 mA
IOUT = 30 mA
IOUT = 50 mA
IOUT = 100 mA
2.5
3.0
3.5
VIN [V]
4.0
4.5
IOUT = 1 mA
IOUT = 30 mA
IOUT = 50 mA
IOUT = 100 mA
3.5
4.0
4.5
VIN [V]
25
Rev.2.2_01
S-1135 Series
Dropout Voltage vs. Output Current
−40°C
Vdrop [V]
VOUT = 1.0 V
0.40
0.35
0.30
0.25
0.20
0.15
0.10
0.05
Vdrop [V]
VOUT = 3.5 V
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
0.35
0.30
0.25
0.20
0.15
0.10
0.05
IOUT [mA]
250
300
250
300
Ta = 85°C
25°C
−40°C
50
100
150 200
IOUT [mA]
IOUT = 300 mA
150 mA
100 mA
50 mA
1.0
26
100
Dropout Voltage vs. Set Output Voltage
Vdrop [V]
4.
Ta = 85°C
25°C
50
1.5
30 mA
2.0
2.5
VOUT(S) [V]
VOUT = 2.5 V
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
Vdrop [V]
3.
10 mA
3.0
1 mA
3.5
Ta = 85°C
25°C
−40°C
50
100
150 200
IOUT [mA]
250
300
Rev.2.2_01
S-1135 Series
5.
Output Voltage vs. Ambient Temperature
VOUT = 1.0 V
1.10
VOUT [V]
VOUT [V]
1.05
1.00
0.95
0.90
VOUT = 2.5 V
2.70
2.65
2.60
2.55
2.50
2.45
2.40
2.35
2.30
−40 −25
−40 −25
Ta [°C]
50
75 85
50
75 85
Ta [°C]
50
75 85
VOUT = 3.5 V
3.8
VOUT [V]
3.7
3.6
3.5
3.4
3.3
3.2
Ta [°C]
Current Consumption vs. Input Voltage
VOUT = 3.5 V
70
60
50
40
30
−40°C
1
2
3
VIN [V]
25°C
4
VOUT = 2.5 V
70
60
50
40
30
Ta = 85°C
ISS1 [μA]
Ta = 85°C
ISS1 [μA]
VOUT = 1.0 V
70
60
50
40
30
6
−40°C
1
2
3
VIN [V]
4
25°C
5
6
Ta = 85°C
ISS1 [μA]
6.
−40 −25
25°C
−40°C
1
2
3
VIN [V]
4
5
6
27
Rev.2.2_01
S-1135 Series
7.
Ripple Rejection (Ta = 25°C)
VOUT = 1.0 V
VOUT = 2.5 V
100
80
IOUT = 1 mA
60
40
IOUT = 30 mA
IOUT = 50 mA
IOUT = 100 mA
100
1k
10k
100k
Frequency [Hz]
1M
VOUT = 3.5 V
Ripple Rejection [dB]
VIN = 4.5 V, CL = 1.0 μF
100
IOUT = 1 mA
IOUT = 30 mA
IOUT = 50 mA
80
60
40
IOUT = 100 mA
28
100
1k
10k
100k
Frequency [Hz]
VIN = 3.5 V, CL = 1.0 μF
VIN = 2.0 V, CL = 1.0 μF
1M
100
IOUT = 1 mA
IOUT = 30 mA
IOUT = 50 mA
80
60
40
IOUT = 100 mA
100
1k
10k
100k
Frequency [Hz]
1M
Rev.2.2_01
S-1135 Series
Reference Data
6.0
5.5
5.0
4.5
4.0
3.5
3.0
2.5
2.0
Transient Response Characteristics of Load (Ta = 25°C)
1.05
1.00
IOUT
100
2.65
50
2.60
VOUT
−50
IOUT [mA]
VOUT [V]
1.15
1.10
VOUT = 2.5 V
VIN = 3.5 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA
150
2.70
2.55
2.50
50
VOUT
0.95
−100
2.45
0.90
−100 −50 0
−150
2.40
−100 −50 0
50 100 150 200 250 300 350
t [μs]
100
IOUT
−50
IOUT [mA]
VOUT = 1.0 V
VIN = 2.0 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA
150
1.20
VOUT [V]
2.
5.0
4.5
4.0
3.5
3.0
2.5
2.0
1.5
1.0
VIN [V]
VIN [V]
VOUT = 3.5 V
IOUT = 100 mA, tr = tf = 5.0 μs, CL = 1.0 μF
3.80
3.75
3.70
VIN
3.65
3.60
3.55
VOUT
3.50
3.45
3.40
−100 −50 0 50 100 150 200 250 300 350
t [μs]
VOUT = 2.5 V
2.80
2.75
2.70
VIN
2.65
2.60
2.55
VOUT
2.50
2.45
2.40
t [μs]
VOUT [V]
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
VOUT [V]
VOUT = 1.0 V
1.30
1.25
1.20
1.15
VIN
1.10
1.05
VOUT
1.00
0.95
0.90
t [μs]
VIN [V]
Transient Response Characteristics when Input (Ta = 25°C)
VOUT [V]
1.
−100
t [μs]
−150
VOUT = 3.5 V
VIN = 4.5 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA
150
3.70
3.60
3.55
3.50
100
IOUT
50
VOUT
−50
−100
3.45
3.40
−100 −50 0
IOUT [mA]
VOUT [V]
3.65
t [μs]
−150
29
Rev.2.2_01
S-1135 Series
Transient Response Characteristics of ON / OFF Pin (Ta = 25°C)
VOUT [V]
1
0.8
5
2
VON / OFF
1.6
−1
VOUT
VON / OFF [V]
2.0
VOUT = 2.5 V
VIN = 3.5 V, tr = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA
6
6
−2
1
−3
100
t [μs]
150
200
3
0.4
−50
4
VON / OFF
4
−2
VOUT
VON / OFF [V]
VOUT = 1.0 V
VIN = 2.0 V, tr = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA
3
2.4
VOUT [V]
3.
−4
−50
100
t [μs]
150
200
−6
VOUT = 3.5 V
VIN = 4.5 V, tr = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA
6
6
2
VOUT [V]
4
VOUT
3
2
−2
1
−4
4
VON / OFF
−50
100
t [μs]
150
200
VON / OFF [V]
5
−6
Output Capacitance vs. Characteristics of Discharge Time (Ta = 25°C)
S-1135 Series A / B type (with discharge shunt function)
VIN = VOUT + 1.0 V, IOUT = no load
VON / OFF = VOUT + 1.0 V → VSS, tf = 1 μs
1 μs
2.5
VON / OFF
VOUT(s) = 1.0 V
2.5 V
3.5 V
tDSC [ms]
2.0
1.5
VSS
1.0
tDSC
0.5
VOUT
4
6
CL [μF]
8
10
12
VOUT × 10%
VIN = VOUT + 1.0 V
Figure 24
Figure 25
30
Measurement Condition of Discharge Time
Rev.2.2_01
S-1135 Series
Example of Equivalent Series Resistance vs. Output Current Characteristics (Ta = 25°C)
CIN = CL = 1.0 μF
100
VIN
RESR [Ω]
5.
CIN
Stable
ON / OFF
S-1135 Series
VOUT
CL*1
VSS
300
RESR
IOUT [mA]
*1.
Figure 26
CL : TAIYO YUDEN TMK316BJ105KD (1.0 μF)
Figure 27
31
Rev.2.2_01
S-1135 Series
Marking Specifications
1.
SOT-89-5
Top view
1
(1) to (3)
(4) to (6)
: Product code (Refer to Product name vs. Product code)
: Lot number
(4) (5) (6)
4
(1) (2) (3)
5
2
3
(a) S-1135 Series A type
Product Name
(b) S-1135 Series B type
(1)
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
Product code
(2)
(3)
E
A
E
B
E
C
E
D
E
E
E
F
E
G
E
H
E
I
E
J
E
K
E
L
E
M
E
N
E
O
E
P
E
Q
E
R
E
S
E
T
E
U
E
V
E
W
E
X
E
Y
E
Z
E
2
E
3
Product Name
(1)
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
Product code
(2)
(3)
G
A
G
B
G
C
G
D
G
E
G
F
G
G
G
H
G
I
G
J
G
K
G
L
G
M
G
N
G
O
G
P
G
Q
G
R
G
S
G
T
G
U
G
V
G
W
G
X
G
Y
G
Z
G
2
G
3
S-1135A10-U5T1x
S-1135B10-U5T1x
S-1135A11-U5T1x
S-1135B11-U5T1x
S-1135A12-U5T1x
S-1135B12-U5T1x
S-1135A13-U5T1x
S-1135B13-U5T1x
S-1135A14-U5T1x
S-1135B14-U5T1x
S-1135A15-U5T1x
S-1135B15-U5T1x
S-1135A16-U5T1x
S-1135B16-U5T1x
S-1135A17-U5T1x
S-1135B17-U5T1x
S-1135A18-U5T1x
S-1135B18-U5T1x
S-1135A1J-U5T1x
S-1135B1J-U5T1x
S-1135A19-U5T1x
S-1135B19-U5T1x
S-1135A20-U5T1x
S-1135B20-U5T1x
S-1135A21-U5T1x
S-1135B21-U5T1x
S-1135A22-U5T1x
S-1135B22-U5T1x
S-1135A23-U5T1x
S-1135B23-U5T1x
S-1135A24-U5T1x
S-1135B24-U5T1x
S-1135A25-U5T1x
S-1135B25-U5T1x
S-1135A26-U5T1x
S-1135B26-U5T1x
S-1135A27-U5T1x
S-1135B27-U5T1x
S-1135A28-U5T1x
S-1135B28-U5T1x
S-1135A2J-U5T1x
S-1135B2J-U5T1x
S-1135A29-U5T1x
S-1135B29-U5T1x
S-1135A30-U5T1x
S-1135B30-U5T1x
S-1135A31-U5T1x
S-1135B31-U5T1x
S-1135A32-U5T1x
S-1135B32-U5T1x
S-1135A33-U5T1x
S-1135B33-U5T1x
S-1135A34-U5T1x
S-1135B34-U5T1x
S-1135A10-U5T1x
S-1135B35-U5T1x
Remark 1. x: G or U
2. Please select products of environmental code = U for Sn 100%, halogen-free products.
32
Rev.2.2_01
S-1135 Series
(c) S-1135 Series C type
Product Name
(d) S-1135 Series D type
(1)
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
Product code
(2)
(3)
A
A
A
B
A
C
A
D
A
E
A
F
A
G
A
H
A
I
A
J
A
K
A
L
A
M
A
N
A
O
A
P
A
Q
A
R
A
S
A
T
A
U
A
V
A
W
A
X
A
Y
A
Z
A
2
A
3
Product Name
(1)
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
Product code
(2)
(3)
B
A
B
B
B
C
B
D
B
E
B
F
B
G
B
H
B
I
B
J
B
K
B
L
B
M
B
N
B
O
B
P
B
Q
B
R
B
S
B
T
B
U
B
V
B
W
B
X
B
Y
B
Z
B
2
B
3
S-1135C10-U5T1x
S-1135D10-U5T1x
S-1135C11-U5T1x
S-1135D11-U5T1x
S-1135C12-U5T1x
S-1135D12-U5T1x
S-1135C13-U5T1x
S-1135D13-U5T1x
S-1135C14-U5T1x
S-1135D14-U5T1x
S-1135C15-U5T1x
S-1135D15-U5T1x
S-1135C16-U5T1x
S-1135D16-U5T1x
S-1135C17-U5T1x
S-1135D17-U5T1x
S-1135C18-U5T1x
S-1135D18-U5T1x
S-1135C1J-U5T1x
S-1135D1J-U5T1x
S-1135C19-U5T1x
S-1135D19-U5T1x
S-1135C20-U5T1x
S-1135D20-U5T1x
S-1135C21-U5T1x
S-1135D21-U5T1x
S-1135C22-U5T1x
S-1135D22-U5T1x
S-1135C23-U5T1x
S-1135D23-U5T1x
S-1135C24-U5T1x
S-1135D24-U5T1x
S-1135C25-U5T1x
S-1135D25-U5T1x
S-1135C26-U5T1x
S-1135D26-U5T1x
S-1135C27-U5T1x
S-1135D27-U5T1x
S-1135C28-U5T1x
S-1135D28-U5T1x
S-1135C2J-U5T1x
S-1135D2J-U5T1x
S-1135C29-U5T1x
S-1135D29-U5T1x
S-1135C30-U5T1x
S-1135D30-U5T1x
S-1135C31-U5T1x
S-1135D31-U5T1x
S-1135C32-U5T1x
S-1135D32-U5T1x
S-1135C33-U5T1x
S-1135D33-U5T1x
S-1135C34-U5T1x
S-1135D34-U5T1x
S-1135C35-U5T1x
S-1135D35-U5T1x
Remark 1. x: G or U
33
Rev.2.2_01
S-1135 Series
2.
SOT-23-5
Top view
5
(1) to (3)
(4)
4
: Lot number
(1) (2) (3) (4)
1
2
3
Product Name
(1)
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
Product code
(2)
(3)
E
A
E
B
E
C
E
D
E
E
E
F
E
G
E
H
E
I
E
J
E
K
E
L
E
M
E
N
E
O
E
P
E
Q
E
R
E
S
E
T
E
U
E
V
E
W
E
X
E
Y
E
Z
E
2
E
3
Product Name
(1)
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
Product code
(2)
(3)
G
A
G
B
G
C
G
D
G
E
G
F
G
G
G
H
G
I
G
J
G
K
G
L
G
M
G
N
G
O
G
P
G
Q
G
R
G
S
G
T
G
U
G
V
G
W
G
X
G
Y
G
Z
G
2
G
3
S-1135A10-M5T1y
S-1135B10-M5T1y
S-1135A11-M5T1y
S-1135B11-M5T1y
S-1135A12-M5T1y
S-1135B12-M5T1y
S-1135A13-M5T1y
S-1135B13-M5T1y
S-1135A14-M5T1y
S-1135B14-M5T1y
S-1135A15-M5T1y
S-1135B15-M5T1y
S-1135A16-M5T1y
S-1135B16-M5T1y
S-1135A17-M5T1y
S-1135B17-M5T1y
S-1135A18-M5T1y
S-1135B18-M5T1y
S-1135A1J-M5T1y
S-1135B1J-M5T1y
S-1135A19-M5T1y
S-1135B19-M5T1y
S-1135A20-M5T1y
S-1135B20-M5T1y
S-1135A21-M5T1y
S-1135B21-M5T1y
S-1135A22-M5T1y
S-1135B22-M5T1y
S-1135A23-M5T1y
S-1135B23-M5T1y
S-1135A24-M5T1y
S-1135B24-M5T1y
S-1135A25-M5T1y
S-1135B25-M5T1y
S-1135A26-M5T1y
S-1135B26-M5T1y
S-1135A27-M5T1y
S-1135B27-M5T1y
S-1135A28-M5T1y
S-1135B28-M5T1y
S-1135A2J-M5T1y
S-1135B2J-M5T1y
S-1135A29-M5T1y
S-1135B29-M5T1y
S-1135A30-M5T1y
S-1135B30-M5T1y
S-1135A31-M5T1y
S-1135B31-M5T1y
S-1135A32-M5T1y
S-1135B32-M5T1y
S-1135A33-M5T1y
S-1135B33-M5T1y
S-1135A34-M5T1y
S-1135B34-M5T1y
S-1135A35-M5T1y
S-1135B35-M5T1y
Remark 1. y: S or U
34
Rev.2.2_01
S-1135 Series
Product Name
(1)
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
Product code
(2)
(3)
A
A
A
B
A
C
A
D
A
E
A
F
A
G
A
H
A
I
A
J
A
K
A
L
A
M
A
N
A
O
A
P
A
Q
A
R
A
S
A
T
A
U
A
V
A
W
A
X
A
Y
A
Z
A
2
A
3
Product Name
(1)
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
Product code
(2)
(3)
B
A
B
B
B
C
B
D
B
E
B
F
B
G
B
H
B
I
B
J
B
K
B
L
B
M
B
N
B
O
B
P
B
Q
B
R
B
S
B
T
B
U
B
V
B
W
B
X
B
Y
B
Z
B
2
B
3
S-1135C10-M5T1y
S-1135D10-M5T1y
S-1135C11-M5T1y
S-1135D11-M5T1y
S-1135C12-M5T1y
S-1135D12-M5T1y
S-1135C13-M5T1y
S-1135D13-M5T1y
S-1135C14-M5T1y
S-1135D14-M5T1y
S-1135C15-M5T1y
S-1135D15-M5T1y
S-1135C16-M5T1y
S-1135D16-M5T1y
S-1135C17-M5T1y
S-1135D17-M5T1y
S-1135C18-M5T1y
S-1135D18-M5T1y
S-1135C1J-M5T1y
S-1135D1J-M5T1y
S-1135C19-M5T1y
S-1135D19-M5T1y
S-1135C20-M5T1y
S-1135D20-M5T1y
S-1135C21-M5T1y
S-1135D21-M5T1y
S-1135C22-M5T1y
S-1135D22-M5T1y
S-1135C23-M5T1y
S-1135D23-M5T1y
S-1135C24-M5T1y
S-1135D24-M5T1y
S-1135C25-M5T1y
S-1135D25-M5T1y
S-1135C26-M5T1y
S-1135D26-M5T1y
S-1135C27-M5T1y
S-1135D27-M5T1y
S-1135C28-M5T1y
S-1135D28-M5T1y
S-1135C2J-M5T1y
S-1135D2J-M5T1y
S-1135C29-M5T1y
S-1135D29-M5T1y
S-1135C30-M5T1y
S-1135D30-M5T1y
S-1135C31-M5T1y
S-1135D31-M5T1y
S-1135C32-M5T1y
S-1135D32-M5T1y
S-1135C33-M5T1y
S-1135D33-M5T1y
S-1135C34-M5T1y
S-1135D34-M5T1y
S-1135C35-M5T1y
S-1135D35-M5T1y
Remark 1. y: S or U
35
Rev.2.2_01
S-1135 Series
3.
HSNT-6A
Top view
6
5
4
(1) to (3)
(4)
(5) to (9)
(1) (2) (3)
: Blank
: Lot number
(4) (5) (6)
(7) (8) (9)
1
2
3
Product Name
S-1135A10-A6T1U
S-1135A11-A6T1U
S-1135A12-A6T1U
S-1135A13-A6T1U
S-1135A14-A6T1U
S-1135A15-A6T1U
S-1135A16-A6T1U
S-1135A17-A6T1U
S-1135A18-A6T1U
S-1135A1J-A6T1U
S-1135A19-A6T1U
S-1135A20-A6T1U
S-1135A21-A6T1U
S-1135A22-A6T1U
S-1135A23-A6T1U
S-1135A24-A6T1U
S-1135A25-A6T1U
S-1135A26-A6T1U
S-1135A27-A6T1U
S-1135A28-A6T1U
S-1135A2J-A6T1U
S-1135A29-A6T1U
S-1135A30-A6T1U
S-1135A31-A6T1U
S-1135A32-A6T1U
S-1135A33-A6T1U
S-1135A34-A6T1U
S-1135A35-A6T1U
36
(1)
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
Product code
(2)
(3)
E
A
E
B
E
C
E
D
E
E
E
F
E
G
E
H
E
I
E
J
E
K
E
L
E
M
E
N
E
O
E
P
E
Q
E
R
E
S
E
T
E
U
E
V
E
W
E
X
E
Y
E
Z
E
2
E
3
Product Name
S-1135B10-A6T1U
S-1135B11-A6T1U
S-1135B12-A6T1U
S-1135B13-A6T1U
S-1135B14-A6T1U
S-1135B15-A6T1U
S-1135B16-A6T1U
S-1135B17-A6T1U
S-1135B18-A6T1U
S-1135B1J-A6T1U
S-1135B19-A6T1U
S-1135B20-A6T1U
S-1135B21-A6T1U
S-1135B22-A6T1U
S-1135B23-A6T1U
S-1135B24-A6T1U
S-1135B25-A6T1U
S-1135B26-A6T1U
S-1135B27-A6T1U
S-1135B28-A6T1U
S-1135B2J-A6T1U
S-1135B29-A6T1U
S-1135B30-A6T1U
S-1135B31-A6T1U
S-1135B32-A6T1U
S-1135B33-A6T1U
S-1135B34-A6T1U
S-1135B35-A6T1U
(1)
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
S
Product code
(2)
(3)
G
A
G
B
G
C
G
D
G
E
G
F
G
G
G
H
G
I
G
J
G
K
G
L
G
M
G
N
G
O
G
P
G
Q
G
R
G
S
G
T
G
U
G
V
G
W
G
X
G
Y
G
Z
G
2
G
3
Rev.2.2_01
S-1135 Series
Product Name
S-1135C10-A6T1U
S-1135C11-A6T1U
S-1135C12-A6T1U
S-1135C13-A6T1U
S-1135C14-A6T1U
S-1135C15-A6T1U
S-1135C16-A6T1U
S-1135C17-A6T1U
S-1135C18-A6T1U
S-1135C1J-A6T1U
S-1135C19-A6T1U
S-1135C20-A6T1U
S-1135C21-A6T1U
S-1135C22-A6T1U
S-1135C23-A6T1U
S-1135C24-A6T1U
S-1135C25-A6T1U
S-1135C26-A6T1U
S-1135C27-A6T1U
S-1135C28-A6T1U
S-1135C2J-A6T1U
S-1135C29-A6T1U
S-1135C30-A6T1U
S-1135C31-A6T1U
S-1135C32-A6T1U
S-1135C33-A6T1U
S-1135C34-A6T1U
S-1135C35-A6T1U
(1)
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
Product code
(2)
(3)
A
A
A
B
A
C
A
D
A
E
A
F
A
G
A
H
A
I
A
J
A
K
A
L
A
M
A
N
A
O
A
P
A
Q
A
R
A
S
A
T
A
U
A
V
A
W
A
X
A
Y
A
Z
A
2
A
3
Product Name
S-1135D10-A6T1U
S-1135D11-A6T1U
S-1135D12-A6T1U
S-1135D13-A6T1U
S-1135D14-A6T1U
S-1135D15-A6T1U
S-1135D16-A6T1U
S-1135D17-A6T1U
S-1135D18-A6T1U
S-1135D1J-A6T1U
S-1135D19-A6T1U
S-1135D20-A6T1U
S-1135D21-A6T1U
S-1135D22-A6T1U
S-1135D23-A6T1U
S-1135D24-A6T1U
S-1135D25-A6T1U
S-1135D26-A6T1U
S-1135D27-A6T1U
S-1135D28-A6T1U
S-1135D2J-A6T1U
S-1135D29-A6T1U
S-1135D30-A6T1U
S-1135D31-A6T1U
S-1135D32-A6T1U
S-1135D33-A6T1U
S-1135D34-A6T1U
S-1135D35-A6T1U
(1)
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
Product code
(2)
(3)
B
A
B
B
B
C
B
D
B
E
B
F
B
G
B
H
B
I
B
J
B
K
B
L
B
M
B
N
B
O
B
P
B
Q
B
R
B
S
B
T
B
U
B
V
B
W
B
X
B
Y
B
Z
B
2
B
3
37
4.5±0.1
1.5±0.1
1.6±0.2
5
1
4
2
3
1.5±0.1 1.5±0.1
0.4±0.05
0.3
45°
0.4±0.1
0.4±0.1
0.45±0.1
No. UP005-A-P-SD-1.1
TITLE
SOT895-A-PKG Dimensions
No.
UP005-A-P-SD-1.1
SCALE
UNIT
mm
4.0±0.1(10 pitches : 40.0±0.2)
ø1.5 +0.1
-0
2.0±0.05
5° max.
ø1.5 +0.1
-0
0.3±0.05
8.0±0.1
2.0±0.1
4.75±0.1
3 2 1
4
5
Feed direction
No. UP005-A-C-SD-1.1
TITLE
No.
SOT895-A-Carrier Tape
UP005-A-C-SD-1.1
SCALE
UNIT
mm
16.5max.
13.0±0.3
Enlarged drawing in the central part
(60°)
(60°)
No. UP005-A-R-SD-1.1
TITLE
SOT895-A-Reel
No.
UP005-A-R-SD-1.1
SCALE
QTY.
UNIT
1,000
mm
2.9±0.2
1.9±0.2
4
5
1
2
+0.1
0.16 -0.06
3
0.95±0.1
0.4±0.1
No. MP005-A-P-SD-1.2
TITLE
No.
SOT235-A-PKG Dimensions
MP005-A-P-SD-1.2
SCALE
UNIT
mm
4.0±0.1(10 pitches:40.0±0.2)
+0.1
ø1.5 -0
2.0±0.05
+0.2
ø1.0 -0
0.25±0.1
4.0±0.1
1.4±0.2
3.2±0.2
3 2 1
4
5
Feed direction
No. MP005-A-C-SD-2.1
TITLE
SOT235-A-Carrier Tape
No.
MP005-A-C-SD-2.1
SCALE
UNIT
mm
12.5max.
9.0±0.3
ø13±0.2
(60°)
(60°)
No. MP005-A-R-SD-1.1
SOT235-A-Reel
TITLE
No.
MP005-A-R-SD-1.1
SCALE
QTY.
UNIT
3,000
mm
1.96±0.05
1.78±0.05
6
1
5
0.5
4
2
3
0.5
0.5
0.12±0.04
0.48±0.02
0.22±0.05
The heat sink of back side has different electric
potential depending on the product.
Confirm specifications of each product.
Do not use it as the function of electrode.
No. PJ006-A-P-SD-3.0
TITLE
HSNT-6A-A-PKG Dimensions
No.
PJ006-A-P-SD-3.0
SCALE
UNIT
mm
+0.1
5°
4.0±0.1
2.0±0.05
ø1.5 -0
ø0.5±0.1
2.25±0.05
0.25±0.05
0.65±0.05
4.0±0.1
3 21
0.5
0.5
0.5
0.5
0.5
0.5
4 5 6
Feed direction
No. PJ006-A-C-SD-1.0
TITLE
HSNT-6A-A-Carrier Tape
No.
PJ006-A-C-SD-1.0
SCALE
UNIT
mm
12.5max.
9.0±0.3
ø13±0.2
(60°)
(60°)
No. PJ006-A-R-SD-1.0
TITLE
HSNT-6A-A-Reel
No.
PJ006-A-R-SD-1.0
SCALE
UNIT
QTY.
5,000
mm
Land Recommendation
0.5
0.7
0.7
0.35
0.35
0.3
1.4
2.1
Caution It is recommended to solder the heat sink to a board
in order to ensure the heat radiation.
PKG
Stencil Opening
0.5
0.2
0.8
0.8
0.3
0.2
1.6
2.0
TITLE
HSNT-6A-A
-Land &Stencil Opening
PJ006-A-LM-SD-1.1
No.
SCALE
No. PJ006-A-LM-SD-1.1
UNIT
mm
Disclaimers (Handling Precautions)
1.
All the information described herein (product data, specifications, figures, tables, programs, algorithms and
application circuit examples, etc.) is current as of publishing date of this document and is subject to change without
notice.
2.
The circuit examples and the usages described herein are for reference only, and do not guarantee the success of
any specific mass-production design.
SII Semiconductor Corporation is not responsible for damages caused by the reasons other than the products or
infringement of third-party intellectual property rights and any other rights due to the use of the information described
herein.
3.
SII Semiconductor Corporation is not responsible for damages caused by the incorrect information described herein.
4.
Take care to use the products described herein within their specified ranges. Pay special attention to the absolute
maximum ratings, operation voltage range and electrical characteristics, etc.
SII Semiconductor Corporation is not responsible for damages caused by failures and/or accidents, etc. that occur
due to the use of products outside their specified ranges.
5.
When using the products described herein, confirm their applications, and the laws and regulations of the region or
country where they are used and verify suitability, safety and other factors for the intended use.
6.
When exporting the products described herein, comply with the Foreign Exchange and Foreign Trade Act and all
other export-related laws, and follow the required procedures.
7.
The products described herein must not be used or provided (exported) for the purposes of the development of
weapons of mass destruction or military use. SII Semiconductor Corporation is not responsible for any provision
(export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons,
missiles, or other military use.
8.
The products described herein are not designed to be used as part of any device or equipment that may affect the
human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems,
combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment,
aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle
use or other uses. Do not use those products without the prior written permission of SII Semiconductor Corporation.
Especially, the products described herein cannot be used for life support devices, devices implanted in the human
body and devices that directly affect human life, etc.
Prior consultation with our sales office is required when considering the above uses.
SII Semiconductor Corporation is not responsible for damages caused by unauthorized or unspecified use of our
products.
9.
Semiconductor products may fail or malfunction with some probability.
The user of these products should therefore take responsibility to give thorough consideration to safety design
including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing
injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction.
The entire system must be sufficiently evaluated and applied on customer's own responsibility.
10. The products described herein are not designed to be radiation-proof. The necessary radiation measures should be
taken in the product design by the customer depending on the intended use.
11. The products described herein do not affect human health under normal use. However, they contain chemical
substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips
may be sharp. Take care when handling these with the bare hands to prevent injuries, etc.
12. When disposing of the products described herein, comply with the laws and ordinances of the country or region where
they are used.
13. The information described herein contains copyright information and know-how of SII Semiconductor Corporation.
The information described herein does not convey any license under any intellectual property rights or any other
rights belonging to SII Semiconductor Corporation or a third party. Reproduction or copying of the information
described herein for the purpose of disclosing it to a third-party without the express permission of SII Semiconductor
Corporation is strictly prohibited.
14. For more details on the information described herein, contact our sales office.
1.0-2016.01
www.sii-ic.com
