MT5811
MT5811
    MAXIC(美芯晟科技)
    MT5811
MT5811 数据手册
MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 1 KEY FEATURES  Wide input voltage range from 3.5V to 12V  Less than 15W of power transfer  Compliant with latest WPC Qi specification  power sleeping mode  Embedded 32-bit ARM M0® processor with  QC2.0/QC3.0, FCP/SCP support  Integrated three pairs of N-MOSFET drivers  Supports 8~24MHz XTAL  Integrated 440~660MHz programmable PLL for high performance PWM generation (support for single coil applications only)  Integrated high voltage Buck converter to  Build-in 10bit ADC for voltage, current and temperature measurement reduce transmitter’s power consumption in  Integrated 60MHz programmable oscillator for system and PWM generation 16KB eFlash and 4 KB SRAM  Integrated Watchdog for sleeping power monitor and wake-up v1.2.4 with proprietary protocol support  Integrated 32KHz oscillator for ultra-low high voltage input cases  Build-in 10bit DAC with output buffer Integrated 3.3V LDO for internal and I/O  Low operating current and extremely low standby current in deep sleeping mode power supplies  Integrated 1.5V LDO for core power supply  Supports SWD debug mode  Precise low-side current sensing function for  Supports I2C, UART and SPI Interface with plenty of GPIO’s FOD and current mode demodulation   4 channels demodulation AFE for voltage  Dual VDD_IO pins for flexible I/O levels and current mode demodulation  Over-voltage/current/temperature protection 16 channels dedicated DSP for robust ASK  Input under voltage detection and lockout demodulation  function Dedicate FSK modulation hardware with  Available in 6mm x 6mm QFN48 package programmable modulation depth  2 high performance PWM generation modules with 6 channels PWM output for each module, both with programmable dead time control 2 APPLICATIONS  WPC compliant wireless power transmitters for smart phones and wearable devices  Other wireless power applications Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 1 MT5811 Maximizing IC Performance Highly Integrated, High Performance Wireless Power Transmitter 3 DESCRIPTION The MT5811 is a highly integrated, high performance System on Chip (SoC) for magnetic induction based wireless power transmitter solutions. It is fully compliant with the latest Wireless Power Consortium (WPC) Qi v1.2.4 specification, with both Baseline Power Profile (BPP) and Extended Power Profile (EPP) support. The integrated large size e-FLASH enables flexible customer function support. The MT5811 integrates high voltage Buck, two LDO’s, three pairs of N-MOSFET’s drivers, four channels of ASK demodulation Analog Front End (AFE), 16 channels of ASK demodulation DSP. The embedded precise low-side current sensing, generic 10 bit ADC and DAC enable high performance FOD and Q factor detection. It supports over voltage, over current, under voltage protection and over temperature protection (OVP, OCP, UVP, OTP) for safe operation. The MT5811 integrates separated high frequency and low frequency oscillators for low power and low cost application. The internal high frequency PLL with support of external crystal is designed for high accuracy clock and PWM signal generation. The high flexible I/O configuration enables multi-coil application with optimized standalone MOSFET driver (MT5603). The MT5811 is able to provide flexible dead time control and phase shift generation to improve EMI performance. The MT5811 supports multi-protocol power adaptor interface detection and control with support of QC 2.0/3.0, SCP, FCP, etc. The MT5811 integrates an ARM Cortex M0 processor with 16KB eFlash memory and various serial interfaces (I2C, UART, GPIO’s, etc.), offering powerful processing capabilities and code space. The reference application is available with standard firmware. With the support of library (released separately), customers can easily develop the customized features. Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 2 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 4 TYPICAL APPLICATION CIRCUIT Single Coil Application VIN+ VIN- SW_B ISH ISL VIN Optional VIN_SNS BST1 VDD5V DRV1H SW1 VIN5V DRV1L LDO1P5 BST2 LDO3P3 DRV2H MT5811 SW2 DRV2L GND BST3 GPIO DRV3H SW3 GND Functional Modules (including Indicator LED, Buzzer, Sensing, Protections, etc.) Coil GND Fast Charging Adapter Interface (including QC2.0/3.0, FCP, SCP, etc.) DRV3L GPIO XIN XOUT ISNS_O DEMOD1 DEMOD0 Optional Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 3 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 5 PIN CONFIGURATIONS AND FUNCTION 5.1 Pin Configurations ISH ISL ISNS_O DEMOD1 DEMOD0 NC2 LDO3P3 VDD5V VIN_SNS NC1 VIN SW_B 48 47 46 45 44 43 42 41 40 39 38 37 Top View VIN5V 1 36 GND NC0 2 35 BST1 GPIOA1 3 34 DRV1H GPIOA3 4 33 SW1 GPIOA4 5 32 DRV1L GPIOA6 6 MT5811 31 BST3 LDO1P5 7 YYWWXX XXXX 30 DRV3H GND 8 29 SW3 XIN 9 28 DRV3L XOUT 10 27 BST2 GPIOA7 11 26 DRV2H VDDIOA 12 25 SW2 Email: sales@maxictech.com Tel: 86-10-62662828 GND www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 4 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 5.2 Pin Functions Pin Name Pin No. Type Description VIN5V 1 PWR +5V input voltage pin, connect 4.7uF capacitor. VDD5V 41 PWR BUCK converter’s output, 100mA souring capability, connect 10uF and 0.1uF capacitor to GND. LDO1P5 7 PWR VDDIOA 12 PWR Internal 1.5V LDO’s output, connect 1uF capacitor to GND. Power supply for GPIO group A, connect 1.8V/3.3V/5V power, and connect 1uF capacitor to GND. Power supply for GPIO group B, connect 1.8V/3.3V/5V power, and connect VDDIOB 13 PWR 1uF capacitor to GND. VIN 38 PWR Power Supply Input. LDO3P3 42 PWR Internal 3.3V LDO’s output, connect 1uF capacitor to GND. GPIOA1 3 I/O Can be configured as GPIO/SWCK/SDA/TXD/DM/FCP/DAC/ADC2 GPIOA3 4 I/O Can be configured as GPIO/SWDIO/SCL/TRXD/DP/DAC/ADC4 GPIOA4 5 I/O Can be configured as GPIO/SCL2/TRXD2/ADC5 GPIOA6 6 I/O Can be configured as GPIO/SDA2/TXD2/ADC7 GPIOA7 11 I/O Can be configured as GPIO/SDA2/TXD2/ADC9 GPIOB0 14 I/O Can be configured as GPIO/SCL3/TRXD3/PWM/ADC12 GPIOB1 15 I/O Can be configured as GPIO/SDA3/TXD3/PWM/ADC13 GPIOB2 16 I/O Can be configured as GPIO/SCS/PWM/ADC14 GPIOB3 17 I/O Can be configured as GPIO/MOSI/SCL3/ADC15 GPIOB4 18 I/O Can be configured as GPIO/SCP/PWM/ADC16 GPIOB5 19 I/O Can be configured as GPIO/MISO/SDA3/ADC17 GPIOB8 20 I/O Can be configured as GPIO/PWM GPIOB6 21 I/O Can be configured as GPIO/LED/SCS/PWM GPIOB7 22 I/O Can be configured as GPIO/LED/SCP/PWM GPIOC0 23 I/O GPIO XIN 9 I/O Clock input pin, can be configured as external XTAL OSC(8~24MHz) /GPIO XOUT 10 I/O Clock output pin, can be configured as external XTAL OSC(8~24MHz) /GPIO DRV2L 24 PWM Output-Drive pin for low side power MOSFET in the 2nd switch pair. SW2 25 PWM Switching node in the 2nd switch pair. DRV2H 26 PWM Output-Drive pin for high side power MOSFET in the 2nd switch pair. BST2 27 ANA Bootstrap cap in the 2nd switch pair, connect 10nF capacitor to SW2. DRV3L 28 PWM Output-Drive pin for low side power MOSFET in the 3rd switch pair. SW3 29 PWM Switching node in the 3rd switch pair. DRV3H 30 PWM Output-Drive pin for high side power MOSFET in the 3rd switch pair. Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 5 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance Pin Name Pin No. Type BST3 31 ANA Bootstrap cap in the 3rd switch pair, connect 10nF capacitor to SW3. DRV1L 32 PWM Output-Drive pin for low side power MOSFET in the 1st switch pair. SW1 33 PWM Switching node in the 1st switch pair. DRV1H 34 PWM Output-Drive pin for high side power MOSFET in the 1st switch pair. BST1 35 ANA Bootstrap cap in the 1st switch pair, connect 10nF capacitor to SW1. SW_B 37 ANA Switching node of internal BUCK converter. VIN_SNS 40 ANA Input Voltage Sense. DEMOD0 44 ANA Demodulation channel 0 input pin. DEMOD1 45 ANA Demodulation channel 1 input pin. ISNS_O 46 ANA Input current sense voltage output. ISL 47 ANA Negative input of current sense ISH 48 ANA Positive input of current sense NC0 2 NC No connection. Must keep floating. NC1 39 NC No connection. Must keep floating. NC2 43 NC No connection. Must keep floating. GND 8, 36, GND GND Email: sales@maxictech.com Tel: 86-10-62662828 Description Power Ground. www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 6 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 5.3 I/O Pin Configuration Pin Name Bit[3:0] VALUE 0~3 4 5 GPIOA1 GPIO swclk GPIOA2 GPIO GPIOA3 GPIO swdio GPIOA4 GPIO i2c_scl uart_trxd GPIOA5 GPIO GPIOA6 GPIO i2c_sda uart_txd GPIOA7 GPIO i2c_sda uart_txd GPIOA8 GPIO i2c_scl uart_trxd GPIOA9 GPIO GPIOA10 GPIO 6 7 I2C GPIOA4 GPIOA6 GPIOA7 GPIOA8 scl_o output from I2C0 scl_i input to I2C0 sda_o output from I2C0 sda_i input to I2C0 sda_o output from I2C0 sda_i input to I2C0 scl_o output from I2C0 scl_i input to I2C0 (address = 0x4000_2030 bit[1:0] = 2’b00, default) uart_txd output from UART0 (address = 0x4000_2030 bit[3:2] = 2’b00, default) (address = 0x4000_2030 bit[1:0] = 2’b00, default) (address = 0x4000_2030 bit[1:0] = 2’b00, default) (address = 0x4000_2030 bit[1:0] = 2’b00, default) UART GPIOA4 //need set(address = 0x4000_1800 bit[5] //= 1’b1) GPIOA6 uart_rxd input to UART0 uart_txd output from UART0 (address = 0x4000_2030 bit[3:2] = 2’b00, default) //need set(address = 0x4000_1800 bit[5] //= 1’b0) default GPIOA7 uart_txd output from UART0 (address = 0x4000_2030 bit[3:2] = 2’b00, default) //need set(address = 0x4000_1800 bit[5] //= 1’b0) default GPIOA8 uart_txd output from UART0 (address = 0x4000_2030 bit[3:2] = 2’b00, default) //need set(address = 0x4000_1800 bit[5] uart_rxd Email: sales@maxictech.com Tel: 86-10-62662828 //= 1’b1) input to UART0 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 7 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance Pin Name Bit[3:0] VALUE 0~3 4 5 8 9 A B GPIOB0 GPIO GPIO i2c_scl uart_trxd PWM1_1P PWM1_1N ATIM1_P GPIOB1 GPIO GPIO i2c_sda uart_txd PWM1_1P PWM1_1N ATIM1_P GPIOB2 GPIO GPIO spi_cs LED1 PWM1_3P PWM1_3N ATIM3_P GPIOB3 GPIO GPIO spi_sda i2c_scl PWM1_2P PWM1_2N ATIM2_P GPIOB4 GPIO GPIO spi_sck LED2 PWM1_3P PWM1_3N ATIM3_P GPIOB5 GPIO GPIO spi_sda i2c_sda PWM1_2P PWM1_2N ATIM2_P GPIOB6 GPIO GPIO spi_cs LED1 PWM1_2P PWM1_2N ATIM2_P GPIOB7 GPIO GPIO spi_sck LED2 PWM1_2P PWM1_2N ATIM2_P GPIOB8 GPIO GPIO PWM1_3P PWM1_3N ATIM3_P GPIOB9 GPIO GPIO PWM1_2P PWM1_2N ATIM2_P I2C GPIOB0 GPIOB1 GPIOB3 GPIOB5 scl_o output from I2C1 scl_i input to I2C1 sda_o output from I2C1 sda_i input to I2C1 scl_o output from I2C1 scl_i input to I2C1 sda_o output from I2C1 sda_i input to I2C1 uart_txd output from UART1 uart_rxd input to UART1 (address = 0x4000_2030 bit[1:0] = 2’b01) (address = 0x4000_2030 bit[1:0] = 2’b01) (address = 0x4000_2030 bit[1:0] = 2’b01) (address = 0x4000_2030 bit[1:0] = 2’b01) UART GPIOB0 (address = 0x4000_2030 bit[3:2] = 2’b01) //need set address = 0x4000_1A00 bit[2] = 1 GPIOB1 uart_txd output from UART1 (address = 0x4000_2030 bit[3:2] = 2’b01) //need set address = 0x4000_1A00 bit[2] = 0 default Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 8 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance Pin Bit[3:0] VALUE Name 0~3 4 5 6 7 PWM1_3P PWM2_3P ATIM3_P 8 9 A B C D GPIOC0 GPIO GPIOC1 GPIO PWM1_1P PWM1_1N PWM2_1P PWM2_1N ATIM1_P ATIM1_N GPIOC2 GPIO PWM1_1P PWM1_1N PWM1_2P PWM1_2N PWM2_1P PWM2_1N GPIOC3 GPIO PWM2_2N PWM1_2N PWM1_1P PWM1_1N PWM1_2P PWM1_2N PWM2_1P PWM2_1N ATIM1_P ATIM1_N GPIOC4 GPIO PWM1_2P PWM1_2N PWM1_3P PWM1_3N PWM2_2P PWM2_2N PWM2_3N PWM_2_3P ATIM2_N ATIM2_P GPIOC5 GPIO PWM1_2P PWM1_2N PWM1_3P PWM1_3N PWM2_2P PWM2_2N ATIM2_P ATIM2_N GPIOC6 GPIO PWM1_2P PWM1_2N PWM1_3P PWM1_3N PWM2_2P PWM2_2N ATIM2_P ATIM2_N GPIOC7 GPIO PWM1_1P PWM1_1N PWM1_3P PWM1_3N PWM2_1P PWM2_1N ATIM3_P ATIM3_N GPIOC8 GPIO PWM1_1P PWM1_1N PWM1_3P PWM1_3N PWM2_3P PWM2_3N ATIM3_P ATIM3_N GPIOC9 GPIO PWM1_1P PWM1_1N PWM1_3P PWM1_3N PWM2_1P PWM2_1N ATIM3_P ATIM3_N GPIOC10 GPIO PWM1_3P PWM1_3N PWM2_1P PWM2_1N PWM2_3P PWM2_3N ATIM2_P ATIM2_N GPIOC11 GPIO PWM1_2P PWM1_2N PWM1_3P PWM1_3N PWM2_2P PWM2_2N ATIM2_P ATIM2_N PWM1_1P PWM1_1N Bit[3:0] VALUE Pin Name GPIO Email: sales@maxictech.com Tel: 86-10-62662828 0 1 2 3 Hiz input output inout www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 9 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 6 SPECIFICATIONS 6.1 Absolute Maximum Ratings VIN_SNS, VIN 30V SW_B, SW1, SW2, SW3 24V BST1, DRV1H SW1+6V BST2, DRV2H SW2+6V BST3, DRV3H SW3+6V VDD5V, VIN5V, VDDIOA, VDDIOB, GPIO_groupA, GPIO_groupB, GPIOC0, XIN, XOUT, DRV1L, DRV2L, DRV3L, DEMOD0, 6V DEMOD1, ISNS_O LDO3P3 3.9V LDO1P5 1.8V ISL, ISH, GND ±0.3V Storage Temperature -55°C to 150°C Operating Junction Temperature Range, TJ -40°C to 125°C Maximum Soldering Temperature (Reflow, Pb-Free, soldering, 10s) 260°C 6.2 ESD Ratings Test Model Pins Ratings HBM All pins ±1500V CDM All pins ±500V 6.3 Recommended Operating Conditions Operating Voltage (Vin) 3.5V ~ 12V Operating Current (Iin) 0 ~ 2A Operating Temperature (Environment) -40°C ~ 85°C 6.4 Thermal Information (Package Thermal Data) Junction to ambient (RθJA) 36°C/W Notes: (1) Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “Recommended Operating Conditions” is not implied. Exposure to absolute– maximum–rated conditions for extended periods may affect device reliability. (2) All voltage values are with respect to network ground terminal. (3) ESD testing is performed according to the respective JESD22 JEDEC standard. 6.1 Absolute Maximum Ratings. Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 10 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 6.5 Electrical Characteristics (Test conditions: VIN=5.5V, TA=25°C unless otherwise stated.) Symbol Parameter Conditions Min Typ Max Unit Power Supply Vin UVLO UVLO_HYS Input operating voltage range Under voltage lockout Ramp from 0~5V. Under Voltage Lockout Hysteresis Idc DC operation input current Iq Quiescent input current Isleep Sleep mode input current 3.5~12 V 2.5 V 0.3 V TBD mA 1 mA TBD uA LDO LDO3P3_Vout Output voltage LDO3P3_Iout Load current LDO1P5 1.5V LDO Regulator Cout=1uF; VIN=5V Cout=1uF; VIN=5V 3.0 3.3 3.6 50 V mA 1.35 1.5 1.65 V 4.5 5 5.5 V BUCK Converter Vout Output voltage Iout Load current Cout=10uF; L=4.7uH 100 mA Current Sense Programming Ability Vsns_offset Gain Current sense output offset ISL=ISH, 1.6/1.2/ programming step Measure ISNS_O PIN 0.9/0.6 Current sense gain 20/30/40/ programming step 50 V DEMOD Demodulation input Vdem_cm common mode voltage programming step Programmable. Default=0.6V 0.6/0.9 /1.2 V ADC Vin_adc ADC input range 0~2.4 V N_adc Number of bits of ADC 10 bit N_ch Number of input channels 16 N DNL Differential Nonlinearity ±1 LSB S_adc ADC sampling rate 100 KSPS Vdac DAC output range 0~2.4 V N_dac Number of bits of DAC 10 bit S_dac DAC code update speed 2 M Low speed oscillator 32 KHz DAC CLOCK F_osc32k Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 11 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance Symbol Parameter F_osc60M 60M oscillator Conditions Min Typ Max Unit 60 MHz 50 ns 50 ns MOSFET Drivers Tl_on_off Th_on_off Low-side Gate Driver Rise CLOAD= 3nF; 10% to and Fall Times 90%, 90% to 10% High-side Gate Driver Rise CLOAD= 3nF; 10% to and Fall Times 90%, 90% to 10% GPIO VIH Input high voltage 0.7* V VDDIO VIL Input low voltage 0.3* VDDIO VOH Output high voltage I=8mA 0.8* V VDDIO VOL Output low voltage I=8mA 0.2* VDDIO I_lkg V leakage current V 1 uA DP and DM VDPsrc Voltage source on DP 0.6 V VDP3p3 3.3V source on DP 3.3 V IDPsrc DP current source 10 uA IDPsink DP sink current 100 uA IDMsink DM sink current 100 uA RDMdown DM pull down resistor 20 KΩ IDPlkg DP leakage current DP/DM open 1 uA IDMlkg DM leakage current DP/DM open 1 uA 140 °C 120 °C Thermal Shut Down T_thermal_r Thermal shut down rising threshold T_thermal_f Thermal shut down falling threshold Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 12 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 6.6 Typical Operating Characteristics The following performance characteristics were taken using MT5811 wireless power transmitter and MT5715 wireless power receiver at TA=25°C, unless otherwise noted. Efficiency vs. Output Load Test Condition: Vin=5.5V, Vout=5V Efficiency(%) 95 90 85 80 75 70 65 60 55 50 45 40 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.3 1.4 1.5 Output Current(A) Efficiency(%) Efficiency vs. Output Load Test Condition: Vin=9V, Vout=9V 95 90 85 80 75 70 65 60 55 50 45 40 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.3 1.4 1.5 Output Current(A) Efficiency(%) Efficiency vs. Output Load Test Condition: Vin=9V, Vout=12V 95 90 85 80 75 70 65 60 55 50 45 40 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.3 1.4 1.5 Output Current(A) Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 13 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 7 DETAILED DESCRIPTIONS 7.1 Overview MT5811 is an SoC for wireless power transmitter solutions. It integrates all major functional blocks to ensure high flexibility, high performance and high reliability. With the abundant hardware functional blocks and the powerful M0 and the spacious eFlash memory, we allow our customers to implement differentiated functions and features on their own, based on the basic building blocks and libraries provided by us. MT5811 represents the state of art wireless power transmitter SoC solution and sets an industry bench mark for high integration, rich feature set, extraordinary performance, extreme flexibility and low cost. Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 14 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 7.2 Functional Block Diagram LDO1P5 VIN5V VDD5V SW_B VIN VIN_SNS ISH ISL ISNS_O MT5811 GND Biasing LDO 1.5V HV BUCK OVP Low Side Current Sense BST1 1.5V LDO3P3 DRV1H 3.3V LDO 3.3V SW1 FOD & Q Factor Detection DEMOD0 Demodulation DRV1L PWM Generator and FSK Modulator MOS Driver BST3 QC 2.0/3.0 Sensing DEMOD1 DRV3H SW3 10bit DAC GPIO(ADC) 10bit ADC DRV3L 32K OSC GPIO(DAC) BST2 XIN 60M OSC Core PLL DRV2H SW2 XOUT DRV2L GND I/O Interface VDDIOA VDDIOB Email: sales@maxictech.com Tel: 86-10-62662828 GPIO (FCP, SCP, QC2.0/3.0) GPIO (LED, Buzzer, etc.) www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 15 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 7.3 Theory of Operation The wireless power system uses magnetic induction to transfer power from a power transmitter (Tx) to a power receiver (Rx). Before power transfer begins, the Rx and Tx communicate with each other to establish that the Rx is indeed capable of power receiving, whether it needs power transfer, how much power is required, etc. In short, the communication ensures an appropriate power transfer from the power transmitter to the power receiver. When power transfer begins, the power transmitter runs an alternating electrical current through its coil(s), which generates an alternating magnetic field in accordance with Faraday's law. Varying electric field generates varying magnetic field; varying magnetic field generates varying electric field. Therefore, the power transfer is achieved. Transmitter (Tx) Input Power MT5811 Receiver (Rx) MT5715 Load Communication Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 16 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 8 DETAILED PACKAGING INFORMATIONS QFN48 Package Outline and Dimensions SYMBOL A A1 b c D D2 e Ne Nd E E2 L b1 h Email: sales@maxictech.com Tel: 86-10-62662828 MILLIMETER MIN 0.70 0.15 0.18 5.90 4.10 5.90 4.10 0.35 0.69 0.30 NOM 0.75 0.02 0.20 0.20 6.00 4.20 0.40BSC 4.40BSC 4.40BSC 6.00 4.20 0.40 0.35 MAX 0.80 0.05 0.25 0.23 6.10 4.30 6.102.7 4.30 0.45 0.79 0.40 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 17 MT5811 Highly Integrated, High Performance Wireless Power Transmitter Maximizing IC Performance 9 ORDERING INFORMATION Part No. MT5811 Package Package Package Ambient Type Information Quantity Temperature QFN48 6 x 6 mm QFN48 3000 -40°C~+85°C Chip Mark MT5811 YYWWXX XXXX 10 REVISION HISTORY Revision Date 1.0 2019-05-27 Description Initial release. Important Notice  Maxic Technology Corporation (Maxic) reserves the right to make correction, modifications, enhancements, improvements and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All products are sold subject to Maxic’s terms and conditions of sale supplied at the time of order acknowledgement.  Reproduction, copying, transferring, reprinting this paper without Maxic’s written permission is prohibited.  Maxic assumes no liability for applications assistance or the design of customers’ products. Maxic warrants the performance of its products to the specifications applicable at the time of sale. Customers are responsible for their products and applications using Maxic components. To minimize the risks associated with customers’ products and applications, customers should provide adequate design and operating safeguards. Email: sales@maxictech.com Tel: 86-10-62662828 www.maxictech.com Copyright © 2019 Maxic Technology Corporation Rev 1.0 Page 18
MT5811 价格&库存
很抱歉,暂时无法提供与“MT5811”相匹配的价格&库存,您可以联系我们找货
