FTR0603-004
FTR0603-004
    FTR(乔光电子)
FTR0603-004 数据手册
FTR0603 Series Positive Temperature Coefficient (PTC) Data Sheet Description The 0603 series provides miniature surface mount resettable overcurrent protection withholding current from 40mA to 500mA. This series is suitable for ultra portable applications where space is at a premium and the device current is low. Features ■ ROHS compliant and lead-free ■ Fast response to fault current ■ Low profile ■ Low resistance ■ Compatible with high temperature solders ■ Compact design saves board space Applications ■ USB peripherals and Type C ■ Disk drives ■ General electronics ■ PDAs/digital cameras ■ Game console port protection ■ HDMI and Set-top-box Electrical Characteristics Part Number Marking Ihold (A) Itrip (A) Vmax (V) Imax (A) Pd typ. (W) FTR0603-004 - 0.04 0.12 24 20 FTR0603-010 1 0.10 0.30 15 FTR0603-020 2 0.20 0.50 FTR0603-025 2 0.25 FTR0603-035 3 FTR0603-050 5 Maximum time to trip Resistace Time(s) Current(A) Rmin(Ω ) R1max(Ω ) 0.5 1.00 0.20 4.00 40.0 40 0.5 1.00 0.50 0.90 6.0 9 40 0.5 0.60 1.00 0.55 3.5 0.55 9 40 0.5 0.08 8.00 0.50 3.0 0.35 0.75 6 40 0.5 0.10 8.00 0.20 1.0 0.50 1.00 6 40 0.5 0.10 8.00 0.10 0.68 ·Ihold= Hold current: maximum current device will pass without tripping in 23℃ still air. ·Pd typ.= Typical power dissipated from device when in the tripped state at 23℃still air. ·Rmin= Minimum resistance of device in initial (un-soldered) state. ·Itrip= Trip current: minimum current at which the device will trip in 23℃ still air. ·R1max= Maximum resistance of device at 23℃measured one hour after tripping or ·Vmax= Maximum voltage device can withstand without damage at rated current (Imax) ·Imax= Maximum fault current device can withstand without damage at rated voltage reflow soldering of 260℃for 20 sec. (Vmax) ■Caution: Operation beyond the specified rating may result in damage and possible arcing and flame. Thermal Derating Chart Part Number Ambient Operation Temperature -40℃ -20℃ 0℃ 23℃ 40℃ 50℃ 60℃ 70℃ 85℃ FTR0603-004 0.052 0.048 0.044 0.040 0.032 0.028 0.024 0.020 0.012 FTR0603-010 0.130 0.120 0.110 0.100 0.080 0.070 0.060 0.050 0.030 FTR0603-020 0.270 0.250 0.230 0.200 0.170 0.140 0.120 0.100 0.070 FTR0603-025 0.320 0.290 0.270 0.250 0.210 0.180 0.160 0.140 0.100 FTR0603-035 0.470 0.410 0.380 0.350 0.290 0.260 0.240 0.200 0.140 FTR0603-050 0.670 0.590 0.540 0.500 0.410 0.370 0.340 0.290 0.200 Revision:10-May-18 1/5 www.ftrqg.com FTR0603 Series Dimensions and PAD Size Dimensins(mm) Part Number A B C D E Min. Max. Min. Max. Min. Max. Min. Max. Min. Max. FTR0603-004 1.40 1.80 0.60 1.00 0.40 1.00 0.15 0.50 - 0.40 FTR0603-010 1.40 1.80 0.60 1.00 0.40 1.00 0.15 0.50 - 0.40 FTR0603-020 1.40 1.80 0.60 1.00 0.40 1.00 0.15 0.50 - 0.40 FTR0603-025 1.40 1.80 0.60 1.00 0.40 1.00 0.15 0.50 - 0.40 FTR0603-035 1.40 1.80 0.60 1.00 0.55 1.55 0.15 0.50 - 0.40 FTR0603-050 1.40 1.80 0.60 1.00 0.55 1.55 0.15 0.50 - 0.40 Partnumber code F T R Special Voltage Rating FTR Logo Revision:10-May-18 Device Demension Holding Current Rating 2/5 www.ftrqg.com FTR0603 Series Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25 to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TLto TP) 3℃/second max. Preheat -Temperature Min (TS min) 150℃ -Temperature Max (TS max) 200℃ -Time (min to max)( tS) 60-180 seconds TS maxto TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) 217℃ -Time (tL) 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual PeakTemperature (tP) 20-40 seconds Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. 0℃~35℃, ≤70%RH Storage Condition ·Recommended reflow methods: IR, vapor phase oven, hot air oven, N 2 environment for lead-free ·Recommended maximum paste thickness is 0.25mm (0.010 inch) ·Device can be cleaned using standard industry methods and solvents. Note 1: All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. Revision:10-May-18 3/5 www.ftrqg.com FTR0603 Series Environmental Specifications Operating / Storage temperature -40℃ to +85℃ Maximum Device Surface Temperature in Tripped State 125℃ Passive Aging +85℃, 1000 hours ±50% typical resistance change Humidity Aging +85℃, 85%RH, 1000 hours ±50% typical resistance change Thermal Shock MIL-STD-202, Method 107G +85℃/-40℃ 20 times -50% typical resistance change Solvent Resistance MIL-STD-202, Method 215 No change Vibration MIL-STD-883C, Method 2007.1, Condition A No change Moisture Level Sensitivity Level 1, J-STD-020C Physical Specifications Terminal Material Solder-Plated Copper (Solder Material: Matte Tin (Sn)) Terminal Solderability Meets EIA Specification RS186-9E, ANSI/J-STD-002 Category 3. Revision:10-May-18 4/5 www.ftrqg.com FTR0603 Series Packaging Part Number Quantity Part Number Quantity FTR0603-004 4000 FTR0603-025 4000 FTR0603-010 4000 FTR0603-035 4000 FTR0603-020 4000 FTR0603-050 4000 Tape Dimension (mm) Symbol P0 P1 P2 D0 B T E F W 004,010, 035, 020,025 050 W 8.00±0.30 8.00±0.30 P0 4.00±0.10 4.00±0.10 P1 4.00±0.10 4.00±0.10 P2 2.00±0.10 2.00±0.10 D0 Φ1.55±0.10 Φ1.55±0.10 D1 0.50±0.10 0.50±0.10 E 1.75±0.10 1.75±0.10 F 3.50±0.05 3.50±0.05 A0 1.10±0.1 1.10±0.1 B0 1.92±0.1 1.92±0.1 K0 0.75±0.1 0.95±0.1 T 0.20±0.1 0.20±0.1 B0 D1 A A B K0 SECTION B-B A0 SECTION A-A Reel Revision:10-May-18 5/5 C Φ178.0±1.0 D Φ60.2±0.5 H 11.0±0.5 W 9.0±1.5 www.ftrqg.com
FTR0603-004 价格&库存
很抱歉,暂时无法提供与“FTR0603-004”相匹配的价格&库存,您可以联系我们找货
FTR0603-004
库存:10775
