FP6166S5CTR
FP6166S5CTR
    FITIPOWER(天鈺科技)
    SOT23-5
    1V~5.5V 600MA 5.5V
FP6166S5CTR 数据手册
FP6166 600mA Low Noise High PSRR 85T LDO with Shutdown Description Features The FP6166 is a low dropout, low noise, high PSRR and very low quiescent current positive linear regulator. The FP6166 can supply 600mA output current with low dropout voltage at about 890mV that optimized for battery-powered systems or portable wireless devices such as mobile phones. The shutdown function can provide remote control for the external signal to decide the on/off state of FP6166 that consumes less than 0.1µA during shutdown mode.     The FP6166 regulator is able to operate with output capacitors as small as 1µF for stability. Other than the current limit protection, FP6166 also offers the on chip thermal shutdown feature providing protection against overload or any condition when the ambient temperature exceeds the maximum junction temperature. The FP6166 offers high precision output voltage of 2%. It is housed in low-profile, space-saving SOT-23-5 and SOP-8 packages.         Low Dropout Voltage of 890mV at 600mA Low 30μVrms Output Noise Guaranteed 600mA Output Current Adjustable Mode Output Voltage Range is from 1V to 5.5V-Vdrop Very Low Quiescent Current at 45µA Max. 2% Output Voltage Accuracy Fast Response in Line/Load Transient Thermal Shutdown Protection Current Limit Protection Low-ESR Ceramic Capacitor for Output Stability Miniature Packages: SOT-23-5 and SOP-8 RoHS Compliant Applications      Mobile Phone Notebook, Sub-Notebook and Tablet Computer DSC Portable Information Appliance Battery Power System Pin Assignments Ordering Information S5 Package (SOT-23-5) FP6166□□□ VOUT ADJ 5 4 1 2 TR: Tape/Reel C: Green Package Type S5: SOT-23-5 SO: SOP-8 3 VIN GND SHDN SO Package (SOP-8) SOT-23-5 Marking SHDN VIN 1 2 8 GND 7 GND VOUT 3 6 GND ADJ 4 5 GND Part Number Product Code FP6166S5CTR C7G Figure 1. Pin Assignment of FP6166 FP6166-0.5-DEC-2015 1 FP6166 85T Typical Application Circuit VIN VIN VOUT VOUT CIN R1 2.2µF FP6166 COUT 1µF ADJ R2 VSHDN SHDN GND Figure 2. Typical Application Circuit of FP6166 Note 1:To prevent oscillation, it is recommended to use minimum 2.2µF/1µF X7R or X5R dielectric capacitors if ceramics are used as input/output capacitors. Functional Pin Description Pin Name VIN VOUT Pin Function Power is supplied to this device from this pin which is required an input filter capacitor. capacitor in the range of 2.2µ F to 10µ F is sufficient. In general, the input The output supplies power to loads. The output capacitor is required to prevent output voltage from oscillation. The FP6166 is stable with a 1µ F or greater output capacitor. The larger output capacitor will be required for application with larger load transients. The large output capacitor could reduce output noise, improve stability and PSRR. ADJ Voltage Feedback Input Pin. GND Common Ground Pin Connect ADJ and VOUT with a resistive voltage divider. Pull this pin high to enable IC, and pull this pin low to shutdown IC. the built-in pull-low resistor. FP6166-0.5-DEC-2015 Keeping this pin floating will shut down IC due to 2 FP6166 85T Block Diagram RSEN VIN PMOS VOUT Current Limit Power Shutdown SHDN _ Error Amp + 5MΩ ADJ Thermal Shutdown R1 _ Vref + Output Mode Comparator + _ 0.166V R2 GND Figure 3. Block Diagram of FP6166 Absolute Maximum Ratings ● VIN, , ADJ to GND --------------------------------------------------------------------------------------- +6V ● Package Thermal Resistance (θJA) SOT-23-5 ------------------------------------------------------------------------------------------------- +250ºC/W SOP-8 ----------------------------------------------------------------------------------------------------- +110ºC/W ● Maximum Junction Temperature (TJ) ------------------------------------------------------------------------ +150ºC ● Storage Temperature Range (TSTG) -------------------------------------------------------------------------- -65ºC to +150ºC ● Lead Temperature (Soldering, 10 sec.) (TLEAD) ------------------------------------------------------------ +260ºC Note 2:Stresses beyond those listed under “Absolute Maximum Ratings" may cause permanent damage to the device. Recommended Operating Conditions ● Input Voltage (VIN) ------------------------------------------------------------------------------------------------ +2.0V to +5.5V ● Operating Temperature Range (TOPR) ----------------------------------------------------------------------- -40ºC to +85ºC FP6166-0.5-DEC-2015 3 FP6166 85T Electrical Characteristics (VIN=VOUT+1V, pin connected to VIN, CIN=2.2µF, COUT=1µF, TA=25ºC, unless otherwise specified) Parameter Current Limit Short Circuit Current Quiescent Current Symbol ILIMIT Conditions RLoad=1 Typ 600 800 mA 500 mA ISHORT IQ IOUT= 0mA Standby Current ISTBY Reference Voltage VREF IOUT= 1mA Reference Voltage Accuracy VREF IOUT= 1mA pin connected to GND IOUT=150mA Dropout Voltage (Note3) Min VDROP IOUT=300mA IOUT=600mA Max Unit 45 70 µA 0.1 1 µA 1 -2 V +2 VOUT=1.2V 1050 1260 VOUT=1.8V 750 900 VOUT=2.5V 500 600 VOUT=3.0V 270 330 VOUT=3.3V 230 270 VOUT=1.2V 1730 2075 VOUT=1.8V 1450 1750 VOUT=2.5V 980 1170 VOUT=3.0V 510 610 VOUT=3.3V 400 480 VOUT=1.2V 1995 2395 VOUT=1.8V 1600 1920 VOUT=2.5V 1350 1620 VOUT=3.0V 1150 1380 VOUT=3.3V 890 1070 % mV Line Regulation VLINE IOUT=1mA, VIN=VOUT +1V to 5V 1 8 mV Load Regulation (Note4) VLOAD IOUT=0mA to 150mA 6 30 mV Ripple Rejection (Note5) PSRR VIN=VOUT+1V, fRIPPLE = 10kHz 70 dB Output Noise Voltage (Note5) VNOISE COUT=1μF, IOUT=0mA 30 μVRMS TC IOUT = 1mA, VIN = 5V 100 ppm/ºC 150 ºC 25 ºC Temperature Coefficient (Note5) Thermal Shutdown Threshold (Note5) FP6166-0.5-DEC-2015 TSD TSD Hysteresis 4 FP6166 85T Electrical Characteristics (Continued) (VIN=VOUT+1V, pin connected to VIN, CIN=2.2µF, COUT=1µF, TA=25ºC, unless otherwise specified) Parameter Symbol Min R Pull-Low Resistance Pin Threshold Conditions Typ Max 5 V ( Start-up V ( FF Shutdown Unit MΩ 1.0 V 0.4 V Note 3:The dropout voltage is defined as VIN-VOUT, which is measured when VOUT drops 2% of its normal value with the specified output current. Note 4:Load regulation and dropout voltage are measured at a constant junction temperature by using a 40ms low duty cycle c urrent pulse. Note 5:Guarantee by design. FP6166-0.5-DEC-2015 5 FP6166 85T Typical Performance Curves 85 65 VOUT=1.2V Quiescent Current (μA) Quiescent Current (μA) VOUT=3.3V 80 60 55 50 45 40 75 70 65 60 55 35 50 30 2.1 2.6 3.1 3.6 4.1 4.6 Input Voltage (V) 5.1 3.3 5.6 4.3 5.3 5.8 Figure 5. Quiescent Current vs. Input Voltage 1000 700 VIN=5V VOUT=1.5V VIN=5V VOUT=1.5V 650 Short Circuit Current (mA) 950 900 850 800 750 700 650 600 550 600 550 500 450 400 350 300 250 200 500 -40 -20 0 20 40 60 -40 80 -20 0 Temperature (ºC) 20 40 60 80 Temperature (ºC) Figure 6. Current Limit vs. Temperature Figure 7. Short Circuit Current vs. Temperature 3.6 1.6 VIN=3.6V VOUT=1.2V 1.5 VIN=4.3V VOUT=3.3V 3.5 Output Voltage (V) 1.4 Output Voltage (V) 4.8 Input Voltage (V) Figure 4. Quiescent Current vs. Input Voltage Current Limit (mA) 3.8 1.3 1.2 1.1 1 3.4 3.3 3.2 3.1 0.9 3 0.8 -40 -20 0 20 40 60 Temperature (ºC) Figure 8. Output Voltage vs. Temperature FP6166-0.5-DEC-2015 80 -40 -20 0 20 40 60 80 Temperature (ºC) Figure 9. Output Voltage vs. Temperature 6 FP6166 85T Typical Performance Curves (Continued) 80 65 VIN=3.6V VOUT=1.2V VIN=4.3V VOUT=3.3V 75 Quiescent Current (μA) Quiescent Current (μA) 60 55 50 45 40 35 70 65 60 55 50 30 45 -40 -20 0 20 40 60 80 -40 -20 0 Temperature (ºC) Figure 10. Quiescent Current vs. Temperature 40 60 80 Figure 11. Quiescent Current vs. Temperature 1200 2500 VOUT=1.2V CIN=2.2μF COUT=1μF 2000 TJ=-40ºC 1500 TJ=85ºC 1000 VOUT=3.3V CIN=2.2μF COUT=1μF 1000 Dropout Voltage (mV) Dropout Voltage (mV) 20 Temperature (ºC) TJ=25ºC 500 TJ=25ºC TJ=85ºC 800 600 TJ=-40ºC 400 200 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.1 0.2 Loading Current (A) Figure 12. Dropout Voltage vs. Loading Current 0.3 0.4 0.5 Loading Current (A) Figure 13. Dropout Voltage vs. Loading Current VIN=3.6V, VOUT=1.2V, IOUT=0mA to 600mA VIN=3.6V, VOUT=1.2V, IOUT=10mA to 600mA VOUT 50mV/div. VOUT 50mV/div. IOUT 500mA/div. IOUT 500mA/div. 400μs/div. 400μs/div. Figure 14. Load Transition Response Figure 15. Load Transition Response FP6166-0.5-DEC-2015 0.6 7 FP6166 85T Typical Performance Curves (Continued) VIN=5V, VOUT=3.3V, IOUT=10mA to 600mA VIN=5V, VOUT=3.3V, IOUT=0mA to 600mA VOUT 100mV/div. VOUT 100mV/div. IOUT 500mA/div. IOUT 500mA/div. 200μs/div. 200μs/div. Figure 16. Load Transition Response Figure 17. Load Transition Response VIN=5V, VOUT=3.3V, IOUT=600mA VIN=5V, VOUT=3.3V, IOUT=600mA 2V/div. 2V/div. VOUT VOUT 1V/div. 1V/div. 40μs/div. 40μs/div. Figure 18. Enable Test Figure 19. Shutdown Test VIN=3.5V4.5V, VOUT=3.3V, IOUT=10mA VIN VOUT 1V/div. 20mV/div. VIN 1V/div. VOUT 20mV/div. VIN=2.2V3.2V, VOUT=1.2V, IOUT=10mA 1ms/div. 1ms/div. Figure 20. Line Transition Response Figure 21. Line Transition Response FP6166-0.5-DEC-2015 8 Power Supply Rejection Ratio (dB) Typical Performance Curves (Continued) FP6166 85T 0 VIN=4.3V, VOUT=3.3V, COUT =2.2uF, IOUT=0A -20 -40 -60 -80 0.01 0.1 1 10 100 1000 Frequency (kHz) Figure 22. Power Supply Rejection Ratio vs. Frequency FP6166-0.5-DEC-2015 9 FP6166 85T Application Information The FP6166 is a low dropout linear regulator which provides 600mA output current at dropout voltage about 890mV. Current limit and on chip thermal shutdown features provide protection against any combination of overload or ambient temperature which exceeds maximum junction temperature. Output Voltage Setting The output can be set to fixed or adjustable mode. The internal output mode comparator compares the ADJ pin voltage with 166mV reference. If the ADJ pin voltage is higher than 166mV, the FP6166 will be set into adjustable output mode and the non-inverting input of the error amplifier will be connected to the external voltage divider. If the ADJ pin voltage is lower than 166mV, the FP6166 will be set into fixed output mode and the non-inverting input of the error amplifier will be connected to the internal voltage divider. The output voltage VOUT is set by using a resistive divider R1 and R2. Thus the output voltage is: V T =1V 1 R1 R Protection Features In order to prevent overloading or thermal condition damaging the device, FP6166 contains internal thermal and current limit functions which are designed to protect the device. It will rapidly shut off PMOS pass element during over-temperature condition. Thermal Consideration The power handling capability of the device will be limited by allowable operation junction temperature (125ºC). The power dissipated by the device will be estimated by PD = IOUT  (VIN-VOUT). The power dissipation should be lower than the maximum power dissipation listed in “Absolute Maximum Ratings” section. Shutdown Operation The FP6166 will be shut down by pulling the input low and turned on by driving the high. If pin is floating, the FP6166 will shut down because pin has built-in a pull low resistor (refer to Block Diagram). Output and Input Capacitor The FP6166 regulator is designed to stabilize with a wide range of output capacitors. The ESR of the output capacitor affects stability. Larger value of the output capacitor decreases the peak deviations and improves transient response for larger current changes. The capacitor types (aluminum, ceramic and tantalum) have different characterizations such as temperature and voltage coefficients. All ceramic capacitors are manufactured with a variety of dielectrics, each with different behavior across temperature and applications. Common dielectrics used are X5R, X7R and Y5V. It is recommended to use 1µF to 10µF X5R or X7R dielectric ceramic capacitors with 30mΩ to 50mΩ ESR range between device outputs and ground for stability. The FP6166 is designed to stabilize with low ESR ceramic capacitors, and higher values of capacitors and ESR could improve output stability. The ESR of output capacitor is very important because it generates a zero to provide phase lead for loop stability. There is no requirement for the ESR on the input capacitor, but its voltage and temperature coefficient have to be considered for device application environment. FP6166-0.5-DEC-2015 10 FP6166 85T Outline Information SOT-23-5 Package (Unit: mm) SYMBOLS UNIT DIMENSION IN MILLIMETER MIN MAX A 0.90 1.45 A1 0.00 0.15 A2 0.90 1.30 B 0.30 0.50 D 2.80 3.00 E 2.60 3.00 E1 1.50 1.70 e 0.90 1.00 e1 1.80 2.00 L 0.30 0.60 Note:Followed From JEDEC MO-178-C. Carrier Dimensions FP6166-0.5-DEC-2015 11 FP6166 85T Outline Information (Continued) SOP-8 Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 1.35 1.75 A1 0.10 0.25 A2 1.25 1.50 B 0.31 0.51 D 4.80 5.00 E 3.80 4.00 e 1.20 1.34 H 5.80 6.20 L 0.40 1.27 Note:Followed from JEDEC MO-012-E Carrier Dimensions Life Support Policy Fitipower’s products are not authorized for use as critical components in life support devices or other medical systems. FP6166-0.5-DEC-2015 12
