2SA733
PNP Silicon Epitaxial Planar Transistor
for switching and AF amplifier applications.
The transistor is subdivided into five groups, R, O,
Y, P and L, according to its DC current gain. As
complementary type the NPN transistor 2SC945 is
recommended.
On special request, these transistors can be
manufactured in different pin configurations.
1. Emitter 2. Collector 3. Base
TO-92 Plastic Package
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
Collector Base Voltage
-VCBO
60
V
Collector Emitter Voltage
-VCEO
50
V
Emitter Base Voltage
-VEBO
5
V
Collector Current
-IC
150
mA
Power Dissipation
Ptot
250
mW
Tj
150
O
Tstg
- 55 to + 150
O
Junction Temperature
Storage Temperature Range
Characteristics at Ta = 25 OC
Parameter
DC Current Gain
at -VCE = 6 V, -IC = 1 mA
Current Gain Group
C
C
Symbol
Min.
Typ.
Max.
Unit
hFE
hFE
hFE
hFE
hFE
40
70
120
200
350
80
140
240
400
700
-ICBO
100
nA
-IEBO
100
nA
Collector Base Breakdown Voltage
at -IC = 100 µA
-V(BR)CBO
60
V
Collector Emitter Breakdown Voltage
at -IC = 10 mA
-V(BR)CEO
50
V
Emitter Base Breakdown Voltage
at -IE = 10 µA
-V(BR)EBO
5
V
Collector Emitter Saturation Voltage
at -IC = 100 mA, -IB = 10 mA
-VCE(sat)
0.3
V
Base Emitter On Voltage
-VBE(on)
0.5
0.8
V
Gain Bandwidth Product
at -VCE = 6 V, -IC = 10 mA
fT
50
MHz
Cob
2.8
pF
Collector Base Cutoff Current
at -VCB = 60 V
Emitter Base Cutoff Current
at -VEB = 5 V
R
O
Y
P
L
Collector Output Capacitance
at -VCB = 10 V, f = 1 MHz
SEMTECH ELECTRONICS LTD.
Dated : 17/08/2016 Rev:01
2SA733
I C - VBE
Total power dissipation
vs. ambient temperature
-200
VCE=-6V
300
-100
Free air
Ta=75 C
IC - mA
P tot (mW)
250
200
150
50 C
-10
25 C
0 C
-25 C
-1
100
50
75
50
100
-0.1
-0.4 -0.5
150
125
Tamb ( C)
Collector current vs.
collector emitter voltage
-2.0 -1.8 -1.6
-1.4
-1.2
-1.0
-100
-80
-10
-45
-40
-8
-0.8
-35
-30
-0.6
-0.4
-40
-6
Ic - mA
-60
Ic - mA
-1
VBE , V
-25
-20
-4
-15
I B =-0.2mA
-10
-20
-2
-0.9
-0.8
-0.7
-0.6
-0.4 -0.6
-0.8
-1.0
IB=-5 A
-10
-20
VCE, V
-30
-40
-50
VCE, V
hFE - I C
hFE - I C
1000
1000
VCE=-6V
Ta=75 C
50 C
-1V
100
hFE
hFE
VCE=-6V
10
100
25 C
-25 C
0 C
10
-0.1
-10
-1
-100
-0.1
I C, mA
-10
-1
-100
I C, mA
2SA733
VCE(sat), VBE(sat) - I C
fT - I E
VBE(sat)
500
VCE= -6V
fT - MHz
-1V
-0.1
VCE(sat)
IC/IB=10
-0.01
-1
100
IC/IB=10
10
1
-100
-10
I E, mA
Normalized h-parameters
vs. emitter current
vs. collector emitter voltage
100
100
VCE=-6V, IE=1mA, f=1kHz
-4
hie=5.5k , hre=7.5x10
Normalized h parameters
100
10
I C, mA
hfe=20s, hoe=28 s
10
hoe
hre
hfe
hie
1
0.1
-0.1
hfe
hre
hoe
hie
-1
-10
-100
-4
hfe=20s, hoe=28 s
hoe
10
hie
hre
1
hfe
hfe
hoe
0.1
0.1
hre
hie
1
10
100
IE, mA
VCE, V
Cob - VCB
100
f=1MHz
Cob - pF
VCE(sat), VBE(sat) - V
-1
10
1
-1
-10
-100
VCB, V
很抱歉,暂时无法提供与“2SA733P”相匹配的价格&库存,您可以联系我们找货
