BL0605-10L2500NAT/LF
    ACX(璟德)
    SMD
    单片式SMD,小型、低轮廓、轻量化设计,符合RoHS标准,适用于2.3~2.69GHz无线通信系统。
BL0605-10L2500NAT/LF 数据手册
ACX Advanced Ceramic X BL 0605 Series Multilayer Chip Baluns Features Monolithic SMD with small, low-profile and light-weight type. RoHS compliant  Automobile grade & AEC-Q200 compliant Applications  2.3 ~ 2.69 GHz wireless communication systems. Specifications Frequency Unbalanced Part Number BL060510L2500NA_ Balance Insertion Range Impedance Impedance Loss (MHz) (ohm) (ohm) (dB) 50 100 0.55 max. 2300 ~ 2690 VSWR @BW 2.0 max. Phase Amplitude Difference Difference (degree) (dB) 180  10 2.5 max. Q’ty/Reel (pcs) : 10,000 Operating Temperature Range : -40 ~ +85 oC Storage Temperature Range : -40 ~ +85 oC Storage Period : 12 months max.* *12 months in vacuum sealed bag and 1 week after opened. Please keep unused parts in vacuum sealed bags. Solder Paste : SAC 305 type is recommended. Power Capacity : 2W max. Part Number BL  0605  - 10  L  2500  NA    /LF   Type BL : Balun  Dimensions ( L × W ) 0.6 × 0.5 mm  Balanced Impedance 10 : 100 ohm  Material Code L  Central Frequency 2500 : 2500MHz  Specification Code NA  Packaging T: Tape & Reel B: Bulk  Soldering /LF=lead-free BL0605-10L2500NAT/LF REV:4 PAGE:1/7 ACX Advanced Ceramic X Terminal Configuration < Top View>    No. Terminal Name No. Terminal Name  GND  Balanced Port  Unbalanced Port  Balanced Port  * White area is directional marking Dimensions and Recommended PC Board Pattern Unit : mm W T < Top View> a b c d T W L L L W 0.65  0.5  0.05 0.05 Mark Dimensions T 0.45 max a b c d 0.225 0.2 0.15 0.2 +0.1/-0.05 +0.1/-0.05 +0.1/-0.05 +0.1/-0.05 0.2 * Solder Resist Land 0.18 0.18 * Through-hole ( 0.3) * 0.25 Line width should be designed to match 50characteristic impedance, depending on PCB material and thickness. * BL0605-10L2500NAT/LF REV:4 PAGE:2/7 ACX Advanced Ceramic X Measuring Diagram Network Analyzer** Port 3* Port 1:Unbalanced Port Port 1(50Ω) Ports 2 and 3: Balanced Port IL=Sds21 RL=Sss11 Port 2* Amp_balance = dB(S(2,1)/S(3,1)) Phase_balance = Phase(S(2,1)/S(3,1)) *Impedance for ports 2 and 3 = Balanced Impedance/2 GND **E5071B from Agilent Typical Electrical Characteristics (T=25oC) Insertion and Return Loss Amplitude and Phase Balance 6 RL IL -20 -40 200 150 4 100 2 50 0 0 -50 -2 -100 -4 -150 -6 -60 2.0 2.1 2.2 2.3 2.4 2.5 2.6 f req, GHz 2.7 2.8 2.9 3.0 phase_difference amplitude_difference 0 -200 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 3.0 f req, GHz Notes The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your order. BL0605-10L2500NAT/LF REV:4 PAGE:3/7 ACX Advanced Ceramic X Taping Specifications Tape Dimensions (Unit: mm) & Quantity Type A A’ B C D E F T 2.0± 4.0± 0.58± 0.78± 2.0± 3.5± 8.0± 0.45± 0.05 0.1 0.03 0.03 0.05 0.05 0.2 0.03 0605 Quantity/reel Tape material 10,000pcs Paper Reel Dimensions (Unit: mm) 1.4 ± 0.2 Label 178± 1 60±1 Label: Customer’s Name, ACX P/N, Q’ty, Date, ACX Corp. 13.5±0.5 B A Type A B 0605 2.3±0.5 9.0±0.3 Leader and Trailer Tape Trailer End Trailer (160 mm min.) Empty Compartments with Cover Tape (500 mm min.) BL0605-10L2500NAT/LF REV:4 PAGE:4/7 ACX Advanced Ceramic X Peel-off Force Top Cover Tape Peeling Direction
BL0605-10L2500NAT/LF 价格&库存
很抱歉,暂时无法提供与“BL0605-10L2500NAT/LF”相匹配的价格&库存,您可以联系我们找货
