SFHG89GA002
SFHG89GA002
    WISOL(威盛)
    适用于GPS、GLONASS和COMPASS接收器的声表面波滤波器,具有高可靠性和小尺寸封装。
SFHG89GA002 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. WISOL PART No. SFHG89GA002 DOC. No. SMS-51-L-SFT FX-14 DATE March 19, 2013 REVISION 000 WISOL Hong, Byung-Chul Jeon. Hyeon Cheol Hong, Seong-Su ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 373-7, GAJANG-DONG, OSAN-SI, GYUNGGI-DO, KOREA, 447-210 http://www.wisol.co.kr Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz ▶ SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 A TABLE OF CONTENTS 1. REVISION HISTORY ..................................................................................................................................... 3 2. DEFINITION .................................................................................................................................................. 4 3. PRECAUTIONS ............................................................................................................................................. 4 4. OUTLINE DRAWING & DIMENSIONS.......................................................................................................... 5 5. MARKING ...................................................................................................................................................... 6 6. PERFORMANCE ........................................................................................................................................... 7 6-1. MAXIMUM RATINGS .......................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ................................................................................................... 8 7. RELIABILITY ............................................................................................................................................... 10 7-1. ENGINEERING SAMPLE FLOW CHART ......................................................................................... 10 7-2. TEST ITEM & CONDITION ................................................................................................................ 11 9. RECOMMENDED PCB DIMENSIONS ....................................................................................................... 12 10. CAUTION ................................................................................................................................................... 13 11. PACKING ................................................................................................................................................... 14 11-1. DIMENSIONS.................................................................................................................................. 14 11-2. REELING QUANTITY ..................................................................................................................... 15 11-3. TAPING STRUCTURE .................................................................................................................... 15 11-4. INNER BOX(Reel Packing) STRUCTURE ...................................................................................... 16 11-5. OUTER BOX STRUCTURE ............................................................................................................ 17 12. TAPE SPECIFICATIONS .......................................................................................................................... 18 13. RoHS DATA ............................................................................................................................................... 19 http://www.wisol.co.kr Page 2/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 1. REVISION HISTORY 000 March 19, 2013 http://www.wisol.co.kr All page Make specification Page 3/20 March 19, 2013 Surface Acoustic Wave Filter SFHG89GA002 COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 2. DEFINITION 2-1. PART No. SF H G89 G A0 02 (1) (2) (3) (4) No. (5) (6) EXPLANATION (1) SAW Filter (2) Design Type (3) Center Frequency: (4) Input:50ohm,Output:50ohm (5) Package size: 1.1×0.9mm (6) Design Revision (02: Molding type) 1561.10MHz(1559.10 ~ 1563.10) 1575.42MHz(1574.42 ~ 1576.42) 1601.72MHz(1597.55 ~ 1605.89) 2-2. APPLICATION : Band-Pass Filter for COMPSS & GPS & GNSS Rx etc 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. http://www.wisol.co.kr Page 4/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] D V X O X http://www.wisol.co.kr Page 5/20 No. Function 2, 3, 5 Ground 1 Unbalanced Input 4 Unbalanced Output March 19, 2013 Surface Acoustic Wave Filter SFHG89GA002 COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 5. MARKING DVX ○ X 5-1. D V X X - The 1st, 2nd character 'DV' indicates the model name of SAW Filter “SFHG89GA002”. - The 3rd character 'X' indicates the year and the month of manufacture. Year Month 1 2 3 4 5 6 7 8 9 10 11 12 2013 P Q R S T U V W X Y Z a 2014 1 2 3 4 5 6 7 8 9 A B C 2015 D E F G H I J K L M N O 2016 P Q R S T U V W X Y Z a ※ This rotates by the 3 years. - The 4th character 'X' indicates day of manufacture. 5-2. ○ - This symbol indicates input pin 1. - This indicates the producing center ○: China 5-3. Marking: Laser Marking http://www.wisol.co.kr Page 6/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 15 dBm Operating Temperature Range -30 ~ +85 ℃ Storage Temperature Range -40 ~ +85 ℃ http://www.wisol.co.kr Page 7/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -30 ~ +85℃ SPECIFICATIONS Item FREQUENCY RANGE [MHz] UNIT Insertion Loss 1559.10 ~ 1563.10 Insertion Loss Min. Typ. (25℃) Max. dB - 1.3 1.6 1574.42 ~ 1576.42 dB - 1.0 1.3 Insertion Loss 1597.55 ~ 1605.89 dB - 1.4 1.7 VSWR(IN/OUT) 1559.10 ~ 1563.10 - - 1.2 1.7 VSWR(IN/OUT) 1574.42 ~ 1576.42 - - 1.2 1.6 VSWR(IN/OUT) 1597.55 ~ 1605.89 - - 1.3 1.8 DC ~ 960 dB 37 40 1427 ~ 1463 dB 40 44 1710 ~ 1785 dB 35 38 1850 ~ 1910 dB 35 38 1920 ~ 1980 dB 35 38 2400 ~ 2483 dB 42 45 2500 ~ 2570 dB 42 45 2570 ~ 3000 dB 38 43 4900 ~ 6000 dB 23 27 Absolute Attenuation Input: Unbalanced 50 ohm Output: Unbalanced 50 ohm Terminating impedance 6-2-2. TEST FIXTURE [X-Ray Top View] 50Ω 50Ω http://www.wisol.co.kr DVX O X Page 8/20 March 19, 2013 Surface Acoustic Wave Filter SFHG89GA002 COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6-2-3. GRAPH Nearband 0 -20 -40 -60 -80 1.43 1.48 1.53 1.58 Frequency (GHz) 1.63 1.68 1.73 Passband 0 -2 -4 -6 -8 -10 1.53 1.56 1.59 Frequency (GHz) 1.62 1.65 Wideband 0 -10 -20 -30 -40 -50 -60 0 http://www.wisol.co.kr 1 2 3 Frequency (GHz) Page 9/20 4 5 6 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (JESD22-A113F) Temp. Drift (n=5) Thermal Shock (n=23) Board Adhesion (n=11) Low Temp. Storage (n=23) PCT (n=23) Bending Test (n=11) High Temp. Storage (n=23) Vib ration (n=23) ESD Test (n=11) Humidity Test (n=23) Drop (n=23) ESD Limit Test (n=11) Final Electrical Data (n=74) Final Electrical Data (n=92) Final Electrical Data (n=44) http://www.wisol.co.kr Page 10/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning Environment Test JESD22A113F -30℃ → +25℃→ +85℃ High Temp. Storage +85℃ 240hr JESD22-A103C Low Temp. Storage -40℃ 240hr JESD22-A119 description High Temp. High Humidity Storage +85℃ 85%RH 240hr JESD22-A106B Thermal Shock -40℃/30min ⇔ +85℃/30min , 100cycle JESD22-A106A +121℃ 100%RH 96hr JESD22-A102C Vibration Test (Random) 20 ㎐~2000 ㎐,0.053G²/Hz or 8g's RMS,15min/plane IEC 68-2-36 Fdb Drop Test 152 ㎝ 12times Steel floor JIG(110g~150g) IEC 1178-1.4.8.9 0.5 ㎜/sec 1point push IEC 68-2-21 Ue3 0.5 ㎜/sec 3times -PCB : FR4 , PCB SIZE : 100*40 ㎜ IEC 68-2-21 Ue3 Solder Heat Resistance ±250V,C=100pF,R=1.5 ㏀,1times IEC 68-2-21 Ue3 static marginal test C=100pF,R=1.5 ㏀,1times(demand of customer) JESD22-A114F Board Adhesion Bending Test Physical Test +125℃ 24hr Baking → +60℃ 60%RH 120hr → Reflow Test(3times) REMARK Temp. Drift High Temp. Operating Mechanical Test TEST CONDITION http://www.wisol.co.kr Page 11/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [unit:mm] http://www.wisol.co.kr Page 12/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidith(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is requied, refer to IPC/JEDEC J-STD-033 for bake proceddure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack & Lavel (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH http://www.wisol.co.kr Page 13/20 March 19, 2013 Surface Acoustic Wave Filter SFHG89GA002 COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.1 1.35 Ø 1.50 Ø 0.50 1.75 3.5 4 4 2 0.25 0.7 8 0.05 0.10 0.10 0.05 0.02 +0.10 0.05 0.05 -0.00 +0.30 0.05 0.10 0.07 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø 258.0 Ø 81.0 Ø 13.0 50.0 2.2 7.0 30.0 35.0 1.8 1.5 9.0 1.0 0.5 0.8 0.3 0.5 0.8 1.0 0.5 0.5 +1.0 +1.0 -0.5 -0.5 - The product shall be packed properly not to damaged during transportation and storage. http://www.wisol.co.kr Page 14/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-2. REELING QUANTITY 10 inch reel: 10,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. D V X O X D V X O X 11-3-2. BAR CODE LABEL (1) MODEL NAME BARCODE (2) SFH836AQ101 Model Name (3) RLYC12563 (4) 8000 / qAFYU http://www.wisol.co.kr Page 15/20 Reel number Quantity / Marking March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Plastic Reel Material: Antistatic Vinyl Bag Size: Material: Size: http://www.wisol.co.kr 2 310×340mm Paper(SW1D(E)) 3 260×37×265mm Page 16/20 March 19, 2013 Surface Acoustic Wave Filter SFHG89GA002 COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-5. OUTER BOX STRUCTURE Material: TYPE A Paper(SW3B(A)) SIZE(mm) a b c 270 240 275 Inner Box # 6 boxes SIDE ① SIDE ② - SIDE is the same as front side. http://www.wisol.co.kr Page 17/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g http://www.wisol.co.kr Page 18/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 13. RoHS DATA http://www.wisol.co.kr Page 19/20 March 19, 2013 Surface Acoustic Wave Filter COMPASS Rx 1561.10MHz GPS Rx 1575.42MHz GLONASS Rx 1601.72MHz http://www.wisol.co.kr SFHG89GA002 3 1.1×0.9×0.5mm 5pin lay-out Page 20/20 Version : 000 March 19, 2013
SFHG89GA002 价格&库存
很抱歉,暂时无法提供与“SFHG89GA002”相匹配的价格&库存,您可以联系我们找货
