HP6513T3B-33
HP6513T3B-33
    HYPWR(瀚昕微)
    SOT89-3
HP6513T3B-33 数据手册
HP6513 40V, Low Quiescent Current, High Reliability LDO GENERAL DESCRIPTION FEATURES The HP6513 series is a high accuracy, high input voltage low quiescent current, high speed, and low dropout liner regulator with high ripple rejection. The input voltage is up to 40V and load current is up to 300mA at VOUT = 5V & VIN = 7V. The device is manufactured with BCD process. The HP6513 offers over-current limit, soft start and over temperature protection to ensure the device working in well conditions. ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ Input voltage: 4.75V~40V Output voltage: 1.8V~5.7V Output accuracy: < ±2% Output current: 150mA (Typ.) Up to 300mA @ VIN = 7V, VOUT = 5V, HP6513T3A package PSRR: 60dB @ 100Hz Dropout voltage: 600mV @ IOUT = 100mA Quiescent current: 4.2μA @ VIN = 12V(Typ.) ESD HBM: 8KV The HP6513 regulators is available in standard SOT893L, SOT23-5L and SOT23-3L packages. Standard products are Pb-free and Halogen-free. ⚫ Recommend capacitor: 10μF APPLICATIONS ⚫ ⚫ Smart electric meter In-car entertainment ⚫ Electric bicycle TYPICAL APPLICATION CIRCUIT VIN VOUT VOUT HP6513 C1 10uF C2 10uF GND In plugging application, CIN is recommended to use 10uF electrolytic capacitor or 10uF MLCC with 2 ohm series resistors to prevent chip burning due to the large input voltage spike when plugging. See APPLICATION INFORMATION for more information. PIN ASSIGNMENT 2 1 2 VOUT GND 3 VIN SOT89-3L(Top View) HP6513T3A HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. SOT89-3L Page 1 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO 2 1 2 3 GND VIN VOUT SOT89-3L(Top View) HP6513T3B SOT89-3L VOUT NC 5 4 1 2 3 VIN GND NC SOT23-5L(Top View) HP6513S5A SOT23-5L NC NC 5 4 1 2 3 GND VIN VOUT SOT23-5L(Top View) HP6513S5B SOT23-5L VIN 3 1 2 GND VOUT SOT23-3L(Top View) HP6513S3 SOT23-3L PIN DESCRIPTION PIN NO SYMBOL I/O DESCRIPTTION 1 VOUT O Output 2 GND Ground Ground 3 VIN Power Input HP6513T3A HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. Page 2 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO PIN NO SYMBOL I/O DESCRIPTTION 1 GND Ground Ground 2 VIN Power Input 3 VOUT O Output SYMBOL I/O DESCRIPTTION 1 VIN Power Input 2 GND Ground Ground 3 NC - Not connect 4 NC - Not connect 5 VOUT O Output SYMBOL I/O DESCRIPTTION 1 GND Ground Ground 2 VIN Power Input 3 VOUT O Output 4 NC - Not connect 5 NC - Not connect SYMBOL I/O DESCRIPTTION 1 GND Ground Ground 2 VOUT O Output 3 VIN Power Input HP6513T3B PIN NO HP6513S5A PIN NO HP6513S5B PIN NO HP6513S3 ORDERING INFORMATION PART NO PACAKGE TEMPERATURE TAPE & REEL HP6513T3A-XX HP6513T3B-XX HP6513S5A-XX HP6513S5B-XX HP6513S3-XX SOT89-3L SOT89-3L SOT23-5L SOT23-5L SOT23-3L -40 ~ +105℃ -40 ~ +105℃ -40 ~ +105℃ -40 ~ +105℃ -40 ~ +105℃ 2500/REEL 2500/REEL 3000/REEL 3000/REEL 3000/REEL “XX”: several fixed output voltages ranging from 1.8V to 5.7V. E.g. HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. “33”: VOUT = 3.3V Page 3 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO PART NUMBER RULES MARKING DESCRIPTION HP6513□ 1 -□ 2 Code Description 1 □ Package: 5 4 NXYWV 1 S3: SOT23-3L 2 NXYWV 3 SOT23-5L S5A/S5B: SOT23-5L SOT23-3L T3A/T3B: SOT89-3L 2 □ “N”: Product Code. Here “O” stands for “HP6513S3”, “Q” Voltage version: XX: several fixed output voltages stands for ranging from 1.8V to 5.7V “HP6513S5B”. “HP6513S5A”, “P” stands for “X”: Internal Control Code “Y”: Internal Control Code Example: 33: 3.3V “W”: The week of manufacturing. “A” stands for week 1, “Z” stands for week 26, “ A ” stands for week 27, “ Z ” stands for week. “V” : Output voltage code. SOT89-3L: 2 XXXX X YM XX V XX 1 2 3 Part Number Internal Control Code V:Output Voltage Code XX:Serial Number GND VIN VOUT Y: Year M: Month X: Internal Control Code TYPICAL OUTPUT VOLTAGE CODE TABLE VOUT CODE VOUT CODE 3.0V G 3.3V H 3.6V I 5.0V K ABSOLUTE MAXIMUM RATINGS (Note) SYMBOL ITEMS VALUE UNIT VIN Input Voltage -0.3~45 V VOUT Output Voltage -0.3~6.5 V PDMAX Power Dissipation OTP limited W TJ Junction Temperature -40~150 ℃ Tstg Storage Temperature -55 to 150 ℃ Tsolder Package Lead Soldering Temperature (10s) 260 ℃ ESD MM Machine Mode 200 V ESD HBM Human Body Mode 8000 V Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability . HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. Page 4 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO RECOMMANDED OPERATING RANGE SYMBOL ITEMS VIN VIN Supply Voltage RθJA Thermal Resistance on PCB TOPT Operating Temperature VALUE UNIT 4.75 to 40 V 45 ℃/W -40 to +105 ℃ SIMPLIFIED BLOCK DIAGRAM VIN VOUT Current Limit OTP VREF HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. - + Page 5 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO ELECTRICAL CHARACTERISTICS o The following specifications apply for VIN = 12V, TA = 25 C, CIN = COUT = 10μF, unless specified otherwise. SYMBOL VIN VOUT △VOUT IQ ITEMS CONDITIONS MIN Input Range IOUT = 10mA 4.75 Output Range IOUT = 10mA VOUTx0.98 Output Voltage Quiescent Current IOUT_PK Maximum Output Current VDROP Dropout Voltage △VLINE Line Regulation △VLOAD Load Regulation ISHORT PSRR eNO TSD ΔVO/ΔT Short Current Power Supply Rejection Rate Output Noise Voltage MAX UNIT 40 V VOUT VOUTx1.02 V 4.9 5 5.1 3.234 3.3 3.366 2.94 3.0 3.06 VIN = 7V, IOUT = 0 4 6 VIN = 24V, IOUT = 0 4.6 6.7 VIN = 40V, IOUT = 0 5.4 8.2 VIN - VOUT = 4V, RL=1Ω 500 550 IOUT = 10mA 60 90 IOUT = 100mA 600 900 VIN =7 ~ 24V, VOUT = 5V, IOUT = 1mA 0.02 0.03 VIN = 7 ~ 45V, VOUT = 5V, IOUT = 1mA 0.08 0.1 19 37 VIN = 12V, IOUT = 10mA VIN = 7V, IOUT = 1 ~ 100mA VOUT Short to GND with 1Ω (1ms pulse), VIN = 12V Temperature Coefficient HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. 180 VIN = 10V, F = 100Hz 60 VPP = 0.5V, F = 1kHz 50 IOUT = 1mA F = 10kHz 40 10Hz to 100kHz, COUT = 10μF, IOUT=10mA Thermal Shutdown Protection TYP VIN = 12V, IOUT = 1mA V µA mA mV %/V mV mA dB ±100 μVRMS 165 ℃ ±0.5 mV/℃ Page 6 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO TYPICAL PERFORMANCE CHARACTERISTICS CIN = 10μF, COUT = 10μF, TOPT = 25C, unless specified otherwise. (HP6513T3A Package) IQ vs. Input Voltage 7 8 6 7 5 6 4 IQ (uA) IQ (uA) IQ vs. Input Voltage 3 2 5 4 3 2 1 VOUT=3.3V VOUT=5V 1 0 0 0 5 10 15 20 25 30 35 40 0 45 5 10 Output Voltage vs. Temperature 25 30 35 40 45 Output Voltage vs. Temperature 3.4 5.5 3.2 Output Voltage (V) Output Voltage (V) 20 Input Voltage (V) Input Voltage (V) 3 2.8 Io=1mA 2.6 2.4 VOUT=3.3V 2.2 5 4.5 Io=1mA 4 VOUT=5V 3.5 3 2 -40 -20 0 -40 -20 0 20 40 60 80 100 120 140 160 20 40 60 80 100 120 140 160 Temperature (℃) Temperature (℃) Output Voltage vs. Input Voltage Output Voltage vs. Input Voltage 4 6 3.5 5 3 Io=1mA 2.5 Io=10mA 2 Io=100mA 1.5 1 VOUT=3.3V Output Voltage (V) Output Voltage (V) 15 4 Io=1mA 3 Io=10mA Io=100mA 2 VOUT=5V 1 0.5 0 0 0 5 10 15 20 25 30 Input Voltage (V) HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. 35 40 45 0 5 10 15 20 25 30 35 40 45 Input Voltage (V) Page 7 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO Output Voltage vs. Output Current Output Voltage vs. Output Current 6 3 5 Output Voltage (V) Output Voltage(V) 3.5 VOUT=3.3V 2.5 HP6513T3A 2 Vin=6V 1.5 Vin=12V 1 Vin=24V 0.5 VOUT=5V HP6513T3A 4 3 Vin=6V Vin=12V Vin=24V Vin=30V 2 1 Vin=30V 0 0 0 100 200 300 0 50 Output Current(mA) 3 5 Output Voltage(V) Output Voltage(V) 6 VOUT=3.3V HP65132T3B Vin=6V 1.5 Vin=12V 1 Vin=24V 0.5 Vin=30V 4 250 300 VOUT=5V HP6513T3B 3 Vin=6V 2 Vin=12V Vin=24V 1 Vin=30V 0 0 0 100 200 300 0 Output Current (mA) 3 5 Output Voltage(V) 6 VOUT=3.3V HP6513S5A 2 Vin=6V 1.5 Vin=12V 1 Vin=24V 0.5 Vin=30V 100 150 200 250 300 Output Voltage vs. Output Current 3.5 2.5 50 Output Current (mA) Output Voltage vs. Output Current Output Voltage(V) 200 Output Voltage vs. Output Current 3.5 2 150 Output Current (mA) Output Voltage vs. Output Current 2.5 100 VOUT=5V HP6513S5A 4 3 Vin=6V Vin=12V 2 Vin=24V 1 0 Vin=30V 0 0 100 200 Output Current (mA) HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. 300 0 100 200 300 Output Current (mA) Page 8 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO Output Voltage vs. Output Current 3.5 3.5 3 3 Output Voltage(V) Output Voltage(V) Output Voltage vs. Output Current VOUT=3.3V HP6513S5B 2.5 2 Vin=6V Vin=12V Vin=24V Vin=30V 1.5 1 0.5 2.5 VOUT=3.3V HP6513S3 2 Vin=6V Vin=12V Vin=24V Vin=30V 1.5 1 0.5 0 0 0 100 200 300 0 100 Output Current (mA) Dropout Voltage vs. Output Current 80.00 Dropout Voltage(V) 70.00 PSRR (dB) 60.00 50.00 40.00 30.00 20.00 Io=10mA 0.00 0.01 0.1 1 10 100 900 800 700 600 500 400 300 200 100 0 1000 10 30 50 Frequency (kHz) 70 90 110 130 150 Output Current (mA) IQ vs. Temperature IQ vs. Output current 9 9 8 8 7 IQ(uA) 7 IQ (uA) 300 Output Current (mA) PSRR vs. Frequency 10.00 200 6 5 Vin=6V 6 5 4 3 Vin=12V 2 4 1 0 3 0 50 100 150 Output current (mA) HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. 200 -40 10 60 110 160 Temperature (℃) Page 9 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO IQ vs. IOUT 25 Vin=5V Vin=10V Vin=20V Vin=30V IQ (uA) 20 15 10 5 0 1 10 100 1000 10000 100000 IOUT (uA) Power ON/OFF CH1:VIN VIN=40V Line Transient CH1:VIN VIN=6V-12V CH2:VOUT IOUT=1mA VOUT=5V CH2:VOUT IOUT=1mA HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. VOUT=5V VIN=6V-12V IOUT=10mA VOUT=5V Page 10 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO APPLICATION INFORMATION INPUT CAPACITOR An input capacitor of 10μF is required between the VIN and GND pin. The capacitor shall be placed as close as possible to VIN pin, and the use of electrolytic capacitors is recommended. The tolerance and temperature coefficient must be considered in order to ensure the capacitor work within the operation range over the full range of temperature and operating conditions. OUTPUT CAPACITOR In applications, it is important to select the output capacitor for stable operation. The minimum capacitance for stable and correct operation is 1μF. The capacitance tolerance should be ±30% or better over the operation temperature range. The recommended capacitor type is MLCC. NO-LOAD STABILITY The HP6513 will remain stable and in regulation with no external load. This is especially important in CMOS RAM keep-alive applications. HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. TYPICAL CIRCUIT The following figure shows a typical application circuit for the HP6513 devices. The value of external components shall be chosen carefully, depending on the application. In plugging application, because the overshoot caused by the insertion and withdrawal of power on the chip may damage the chip, it is recommended that VIN be less than 30V and the input voltage spike should not exceed 45V. VIN VIN R C1 + HP6513 GND VOUT VOUT C2 In plugging application, it is suggested that R, C1 are selected as following: 1. C1=10μF ~ 100μF electrolytic capacitor with maximum voltage greater than 50V, R=0 2. C1=1μF ~ 10μF MLCC with maximum voltage greater than 50V and R=2Ω in the type of 1206 - the resistor shall be carefully chosen to make sure enough margin to sustain the surge current during plugging. Page 11 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO PACKAGE OUTLINE Package SOT89-3L Devices per reel 1000Pcs Unit mm Package Dimension: D A L b1 e E E1 D1 b c e1 Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.400 1.600 0.055 0.063 b 0.320 0.520 0.013 0.020 b1 0.400 0.580 0.016 0.023 c 0.350 0.440 0.014 0.017 D 4.400 4.600 0.173 0.181 D1 1.45 1.65 0.057 0.065 E 2.300 2.600 0.091 0.102 E1 3.940 4.250 0.155 0.167 e 1.500 TYP 0.060 TYP e1 3.000 TYP 0.118 TYP L 0.900 HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. 1.200 0.035 0.047 Page 12 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO PACKAGE OUTLINE Package SOT23-5L Devices per reel 3000Pcs Unit mm Package Dimension: Ɵ D 0.2 E E1 L b e c Symbol Dimensions In Millimeters A2 A A1 e1 Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0℃ 8℃ 0℃ 8℃ HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. Page 13 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO PACKAGE OUTLINE Package SOT23-3L Devices per reel 3000Pcs Unit mm Package Dimension: Ɵ D 0.2 E1 E L b c e A1 A2 A e1 Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0℃ 8℃ 0℃ 8℃ HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. Page 14 sales@hypwr.com HP6513 40V, Low Quiescent Current, High Reliability LDO Revision History Version No. Date Description Preliminary 2017-06-06 -Initial preliminary release Version 1.0 2017-11-23 -Update features -Update electrical characteristics -Update typical performance characteristics Version 1.1 2017-12-25 -Update package Version 1.2 2018-02-12 -Update marking description Version 1.3 2018-03-02 -Add HP6513T3B & HP6513S5 Version 1.4 2018-03-07 -Add HP6513S3 Version 1.5 2018-03-27 -Change HP6513S5 to HP6513S5A -Add HP6513S5B -Update marking description Version 1.6 2018-03-28 -Update temperature range Version 1.7 2018-05-04 -Update electrical characteristics -Update typical performance characteristics Version 1.8 2018-06-04 -Add application information Version 1.9 2018-07-20 -Update HP6513T3B T&R quantity Version 2.0 2019-12-02 -Update marking description Version 2.1 2020-03-02 -Add marking description on output voltage code -Update package information HP6513 Datasheet, 2020 Version 2.1 Hypower Microelectronics(Shanghai)Co., Ltd. Page 15 sales@hypwr.com
HP6513T3B-33 价格&库存
很抱歉,暂时无法提供与“HP6513T3B-33”相匹配的价格&库存,您可以联系我们找货
