SS24F
SS24F
    MDD(辰达半导体)
    SMAF(DO-214AD)
    电压:40V 电流:2A
SS24F 数据手册
SS22F THRU SS2200F Reverse Voltage - 20 to 200 Volts Forward Current - 2.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features SMAF  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency 0.106(2.70) 0.094(2.40) 0.063 (1.60) 0.051 (1.30) 0.146(3.70) 0.130(3.30)  Built-in strain relief,ideal for automated placement  High forward surge current capability  High temperature soldering guaranteed: 260 °C/10 seconds at terminals 0.047(1.20) 0.035(0.90) 0.008(0.20) 0.005(0.12) 0.047(1.20) 0.031(0.80) 0.193(4.90) 0.173(4.40) Mechanical Data Case: JEDEC SMAF molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight : 0.00095 ounce, 0.027grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code SYMBOLS Maximum repetitive peak reverse voltage VRRM Maximum RMS voltage Maximum DC blocking voltage VRMS Maximum average forward rectified current Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25℃ at rated DCblocking voltage TA=100℃ Typical junction capacitance (NOTE 1) VDC MDD SS23F MDD SS24F MDD SS25F MDD SS26F MDD SS28F MDD SS210F 20 14 20 30 21 30 40 28 40 50 35 50 60 42 60 80 56 80 100 70 100 MDD MDD SS2150F SS2200F 150 105 150 200 140 200 V V V 2.0 A IFSM 50 A VF 0.55 IR CJ RJA Operating junction temperature range TJ TSTG 0.5 5.0 0.70 0.85 0.95 0.3 3.0 160 -55to+125 V mA pF 80 80.0 ℃/W ℃ -55to+150 ℃ -55to+150 Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas http://www.microdiode.com UNITS I(AV) Typical thermal resistance (NOTE 2) Storage temperature range MDD SS22F Rev:2024A2 Page :1 SS22F THRU SS2200F Reverse Voltage - 20 to 200 Volts Forward Current - 2.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics Fig.1 Forward Current Derating Curve Instaneous Reverse Current ( μA) 2.0 Average Forward Current (A) 1.6 Single Phase Half Wave 60Hz Resistive or inductive Load 1.2 0.8 SS22F-SS24F SS26F-SS2200F 0.4 0 0 25 50 75 100 125 150 10 4 10 3 10 2 TJ=100°C TJ=75°C SS22F/SS26F SS28F-SS220F 1 10 10 TJ=25°C 0 0 175 20 40 60 80 100 Percent of Rated Peak Reverse Voltage(%) Case Temperature (°C) Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 500 20 TJ=25°C 200 1.0 Junction Capacitance (pF) Instaneous Forward Current (A) 10 SS22F/SS24F SS26F SS28F/SS212F SS215F/SS220F 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 100 50 SS22F/SS24F 20 SS26F-SS220F 10 1.8 0.1 Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 100 50 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 Number of Cycles at 60Hz 100 Transient Thermal Impedance(°C/W) Peak Forward Surage Current (A) 100 10 Fig.6- Typical Transient Thermal Impedance 60 00 1 Reverse Voltage (V) Instaneous Forward Voltage (V) 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 SS22F THRU SS2200F Reverse Voltage - 20 to 200 Volts Forward Current - 2.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 SMAF E F B A Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width W P D2 T D1 C W1 D 2.80 4.75 1.42 1.50 178.00 54.40 13.00 1.75 5.05 4.00 4.00 2.00 0.30 8.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMAF REEL SIZE 7" REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) 3,000 4.0 6,000 210*208*203 178 400*265*400 120,000 10.0 Suggested Pad Layout Symbol http://www.microdiode.com Unit (mm) Unit (inch) A 1.8 0.071 B C 1.6 3.8 0.150 D 2.2 0.087 E 5.4 0.213 0.063 Rev:2024A2 Page :3
SS24F 价格&库存
很抱歉,暂时无法提供与“SS24F”相匹配的价格&库存,您可以联系我们找货
SS24F
  • 1+0.47150
  • 200+0.15755
  • 1500+0.09810
  • 3000+0.07786
库存:5831
SS24F
  • 1000+0.11187
  • 3000+0.09695
库存:2250
SS24F
  • 1+0.07460
  • 50+0.07020
  • 200+0.06480
库存:33
SS24F
  • 5+0.08430
  • 50+0.07890
  • 150+0.07560
库存:409
