A7105
A7105
    AMICCOM(笙科)
    QFN20_4X4MM_EP
    A7105
A7105 数据手册
A7105 2.4GHz Transceiver Preliminary Document Title Preliminary Chinese Version Data sheet - A7105 Revision History Rev. No. History Issue Date 0.1 Initial issue Jan 18 , 2008 0.2 電性規格修正、章節調整、暫存器建議值修正、功能描述修正、 修改 state machine 示意圖、增加正印資訊、Reflow 溫度曲 Aug 30 , 2008 線、捲帶規格 0.3 修改產品資訊及正印資訊 Remark Oct. 20 , 2008 Important Notice: AMICCOM reserves the right to make changes to its products or to discontinue any integrated circuit product or service without notice. AMICCOM integrated circuit products are not designed, intended, authorized, or warranted to be suitable for use in life-support applications, devices or systems or other critical applications. Use of AMICCOM products in such applications is understood to be fully at the risk of the customer. Oct. 2008. Version 0.3(Preliminary) 1 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 目錄 應用 .............................................................................................................................................................................. 4 一般描述....................................................................................................................................................................... 4 特性 .............................................................................................................................................................................. 4 接腳配置....................................................................................................................................................................... 5 接腳說明 (I: input, O: output, I/O: input or output, OD: open drain output)................................................................... 5 系統方塊圖 ................................................................................................................................................................... 6 絕對最大範圍................................................................................................................................................................ 7 電氣特性....................................................................................................................................................................... 7 控制暫存器 ................................................................................................................................................................... 9 9.1 控制暫存器列表 ................................................................................................................................................... 9 9.2 控制暫存器說明 ................................................................................................................................................. 11 10.串列介面(3 or 4-wire serial interface)控制 .................................................................................................................. 26 10.1 SPI 格式 .......................................................................................................................................................... 26 10.2 3 or 4-wire 線串列介面讀/寫時序圖(3 or 4-Wire Serial Interface Timing Chart) ................................................ 26 10.3 控制暫存器存取型態........................................................................................................................................ 27 10.4 SPI 時序特性 ................................................................................................................................................... 28 10.5 Strobe Command ............................................................................................................................................. 28 10.6 RF chip Reset Command................................................................................................................................. 30 10.7 ID Read/Write Command ................................................................................................................................. 31 10.8 TX FIFO write /RX FIFO Read Command........................................................................................................ 31 11. 系統狀態機制 (State machine) ................................................................................................................................. 33 12. 工作模式 (Mode of operation).................................................................................................................................. 35 12.1 Direct mode...................................................................................................................................................... 35 12.2 FIFO mode....................................................................................................................................................... 37 13. FIFO (First In First Out)功能...................................................................................................................................... 39 13.1 傳送封包格式 ................................................................................................................................................... 39 13.2 封包處理 (Packet Handling)............................................................................................................................ 40 13.3 資料傳送時間 ................................................................................................................................................... 40 13.4 TX/RX FIFO ..................................................................................................................................................... 41 13.5 FIFO Extension ................................................................................................................................................ 42 14. 系統時脈 (System Clock)......................................................................................................................................... 44 14.1 clock chain 機制 .............................................................................................................................................. 45 14.2 一些除頻器的設定 ........................................................................................................................................... 45 15. 工作頻率設定............................................................................................................................................................ 48 15.1 RF 頻率的設定 ................................................................................................................................................ 48 15.2 AIF 的做法 ....................................................................................................................................................... 49 15.3 up / low side band 的做法 ................................................................................................................................ 49 15.4 自動頻率補償(AFC) ......................................................................................................................................... 50 16. CAL state 校準 .......................................................................................................................................................... 51 16.1 IF 校準(Calibration Process) ........................................................................................................................... 51 16.2. VCO band 校準(Calibration Process)............................................................................................................. 51 16.3. VCO current 校準(Calibration Process).......................................................................................................... 52 17. ADC (Analog Digital Converter)................................................................................................................................. 53 17.1 溫度量測.......................................................................................................................................................... 53 17.2 RSSI 量測 ........................................................................................................................................................ 53 17.3 載波(Carrier)偵測 ............................................................................................................................................. 54 17.4 外部信號源量測................................................................................................................................................ 55 18. TWOR(Wake up on Radio using Timer) 及 WOR(Wake up on Radio)..................................................................... 56 18.1 TWOR .............................................................................................................................................................. 56 18.2 WOR ................................................................................................................................................................ 56 19. Battery Detector ........................................................................................................................................................ 57 1. 2. 3. 4. 5. 6. 7. 8. 9. Oct. 2008. Version 0.3(Preliminary) 2 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 20. Firmware Procedure.................................................................................................................................................. 58 20.1 A7105 的韌體程序 ............................................................................................................................................ 58 20.2 A7105 的偵錯 ................................................................................................................................................... 58 20.3 A7105 的範例說明 : 定頻及跳頻...................................................................................................................... 59 21 振盪電路.................................................................................................................................................................... 63 21.1 使用內部振盪電路 ............................................................................................................................................ 63 21.2 使用外部振盪信號 ............................................................................................................................................ 63 22. TX power 設置.......................................................................................................................................................... 64 23. 應用線路(Application Circuit)....................................................................................................................................65 24. 產品資訊(Ordering Information)................................................................................................................................ 65 25. 封裝資訊................................................................................................................................................................... 66 26. 正印資訊................................................................................................................................................................... 67 27. Reflow 溫度曲線 ....................................................................................................................................................... 68 28. 捲帶規格................................................................................................................................................................... 69 Oct. 2008. Version 0.3(Preliminary) 3 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 1. 應用    無線資料傳輸 無線遙控 無線鍵盤、滑鼠 ■ ■ ■ 家庭自動化系統 無線玩具、遊戲搖桿 2.4GHz ISM 頻段通信系統 2. 一般描述 A7105 是一低成本且適用於 2.4GHz ISM 頻段的無線應用的射頻晶片。7105 內含高靈敏度的接收器(250Kbps@ -99dbm) 以及高效率的功率放大器, 很適合 30 米以內的應用。 A7105 的工作頻率是可以程式化設置, 最高為 500Kbps。 在數位介面部份,有支援 4pin(SPI)或 3pin 控制, 另外在 RF data 的處理有 2 種模式可供選擇 : FIFO(利用 RF 內部的 memory 先儲存要發射/接收的 data), Direct(直接發射/接收)。 在 FIFO 模式下, 也支援 CRC(CRC16), FEC(約可增加靈敏度 1~2dbm), data whitening(可視為 data 加密), Manchester code 的編/解碼。 A7105 內建, RSSI, 溫度的 sensor, 來偵測環境對 RF IC 的影響, 而且也內建 1ch ADC 可偵測使用電壓。 內建無線喚醒 機制, 可延長電池壽命。 封裝 QFN4X4 20 pin。 3. 特性                      Frequency bands: 2400 – 2483MHz ISM band. FSK and GFSK 調變 Low current consumption: RX:16 mA Low current consumption: TX:19 mA (output power 0dBm) Programmable RF output power: up to 0 dBm. On chip regulator, supply voltage 1.9 ~ 3.6V. On chip low power RC oscillator. Low current (< 1uA) in sleep mode and need only one crystal while working together with MCU. High sensitivity (-99dBm@250Kbps, -96dBm@500Kbps, ) Programmable data rate up to 500Kbps Support 4- wire(SPI) or 3- wire interface to access FIFO data, command and register setting Package handling hardware includes preamble, sync word, FEC, CRC data whitening and manchester coding. Separate 64 – byte RX and TX FIFOs Support FIFO extension function and up to 256 bytes. Easy to use with an low cost MCU Fast settling time synthesizer for frequency hopping system. Digital RSSI output for clear channel indication Digital temperature output Build in 1 channel ADC for detect external analog element. Build in WWS(wireless wakeup system) for reduce power consumption of battery. Support Frequency compensation scheme to make use the low cost (low accuracy) crystal. Important Notice: AMICCOM reserves the right to make changes to its products or to discontinue any integrated circuit product or service without notice. AMICCOM integrated circuit products are not designed, intended, authorized, or warranted to be suitable for use in life-support applications, devices or systems or other critical applications. Use of AMICCOM products in such applications is understood to be fully at the risk of the customer. Oct. 2008. Version 0.3(Preliminary) 4 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary REGI CKO GIO2 GIO1 18 17 16 BPBG 19 1 VDA1 RSSI 20 4. 接腳配置 4 12 SCK VDA2 5 11 SCS 10 RFO VDA3 DVDD 9 13 XO 3 8 RFI XI SDIO 7 14 GND 2 6 GND VT 15 Fig 4.1 A7105 QFN Package Top View 5. 接腳說明 (I: input, O: output, I/O: input or output, OD: open drain output) Symbol I/O Function Description Pin No. External pin connected to bypass capacitor for RSSI reading or input pin for ADC. 1 RSSI AO Regulator bias point 2 BPBG AO Low noise amplifier input. 3 RFI AI Power amplifier output. 4 RFO AO 5 VDA2 I Voltage supply for RX & TX analog part VCO VT(tuning voltage)輸入. 6 VT AI 接地. 7 GND I 振盪電路輸入接點. 8 XI AI 振盪電路輸出接點. 9 X0 AO 10 VDA3 I Voltage supply for PLL part 串列介面信號致能 11 SCS DI 串列介面時脈訊號 12 SCK DI 數位電源提供輸入. 13 DVDD I 串列介面資料信號. 14 SDIO DI/O 接地. 15 GND I 多工信號輸入/輸出 1 / 串列介面資料信號. 16 GIO1 DI/O 多工信號輸入/輸出 2 / 串列介面資料信號. 17 GIO2 DI/O 時脈訊號輸出. 18 CKO DO Regulator input 19 REGI AI Regulator output and voltage supply of IF part 20 VDA1 PO Note : A:類比(Analog)、D:數位(Digital) 、I:輸入(Input) 、O:輸出(Output) 、P:電源(Power) Oct. 2008. Version 0.3(Preliminary) 5 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary REGI CKO GIO2 GIO1 20 19 18 17 16 regulator & temp sensor 2 3 RFO 4 PA fractional-N RFI IFAMP &RSSI BPF LNA VCO TX modulator data packet handle BPBG Crystal & RC OSC. VCO_CAL 9 10 VDA3 8 XO 7 XI 6 GND 5 VT VDA2 15 GND 14 SDIO 13 DVDD 12 SCK 11 SCS FIFO ADC BPF_CAL FIFO SPI & Signal Control RX demodulator data packet handle 1 PLL RSSI VDA1 6. 系統方塊圖 Fig 6.1 系統方塊圖 Oct. 2008. Version 0.3(Preliminary) 6 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 7. 絕對最大範圍 Parameter With respect to Rating Unit Supply voltage range (VDD) GND -0.3 ~ 3.6 Vdc Other I/O pins range GND -0.3 ~ VDD+0.3 Vdc 0 dBm -55 ~ 125 °C Maximum input RF level Storage Temperature range *Stresses above those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only; functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 8. 電氣特性 (Internal regulator voltage set to 2.1V) Parameter Description Min. Type Max. Unit 125 °C °C V General Storage Temperature -55 Operating Temperature -40 85 Supply Voltage 1.9 3.6 Sleep mode(RC OSC on) Standby mode (Crystal OSC, Regulator on) PLL mode(Crystal OSC, Regulator, Synthesizer on) Active RX Mode Active TX mode(output power 0dBm) Synthesizer block (includes crystal oscillator, PLL and VCO.) Crystal start up time Crystal frequency VCO Operation Frequency PLL phase noise Offset 10k Offset 100K Offset 1M PLL settling time (Without auto calibration) Transmitter µA µA 9 mA 16 19 mA mA 0.6 mS MHz MHz dBc 24 2400 –2500 80 85 90 Output power Frequency deviation -20 25K Data rate TX settling time 1K Loop bandwidth 500K 1 1800 1 80 µs 3 500K dBm Hz 500K Bps 20 µS -99 dBm -96 dBm Receiver Receiver sensitivity @ BER = 0.1% Data rate 250K Data rate 500K Oct. 2008. Version 0.3(Preliminary) 7 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary IF frequency bandwidth 250/500 KHz IF center frequency 250/500 KHz Image rejection RSSI range 20 @RF input -110 LO leakage at RF port Digital IO DC characteristics High Level Input Voltage(VIH) Low Level Input Voltage(VIL) High Level Output Voltage(VOH) Low Level Output Voltage(VOL) 0.8*VDD 0 VDD-0.4 0 @lOH=-0.5mA @lOL=0.5mA Oct. 2008. Version 0.3(Preliminary) 8 25 dB -55 dBm -50 dBm VDD 0.2*VDD VDD 0.4 V V V V AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 9. 控制暫存器 A7105 chip 有 51x8-bit 的控制暫存器,可透過簡單的 3 線或 4 線串列相容的介面操作讀出或寫入資料。 9.1 控制暫存器列表 Address / Name 00h Mode 01h Mode control 02h Calc 03h FIFO I 04h FIFO II 05h FIFO Data 06h ID Data 07h RC OSC I 08h RC OSC II 09h RC OSC III 0Ah CKO Pin 0Bh GIO1 Pin 0Ch GIO2 Pin 0Dh Clock 0Eh Data rate 0Fh PLL I 10h PLL II 11h PLL III 12h PLL IV 13h PLL V 14h TX I 15h TX II 16h Delay I 17h Delay II R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 W R W R RESETN DDPC DDPC FECF ARSSI ARSSI CRCF AIF AIF CER DFCD CD XER WOR_EN WOR_EN PLLER FMT FMT TRSR FMS FMS TRER ADCM ADCM R/W - - - - - VCC VBC FBC W FEP7 FEP6 FEP5 FEP4 FEP3 FEP2 FEP1 FEP0 W FPM1 FPM0 PSA5 PSA4 PSA3 PSA2 PSA1 PSA0 R/W FIFO7 FIFO6 FIFO5 FIFO4 FIFO3 FIFO2 FIFO1 FIFO0 R/W ID7 ID6 ID5 ID4 ID3 ID2 ID1 ID0 W R WWS_SL7 WWS _SL6 WWS _SL5 WWS _SL4 WWS _SL3 WWS _SL2 WWS _SL1 WWS _SL0 RCOC5 RCOC4 RCOC3 RCOC2 RCOC1 RCOC0 W WWS _SL9 WWS _SL8 WWS _AC5 WWS _AC4 WWS _AC3 WWS _AC2 WWS _AC1 WWS _AC0 W BBCKS1 BBCKS0 - - - RCOSC_E TSEL TWOR_OE W ECKOE CKO3 CKO2 CKO1 CKO0 CKOI CKOE SCKI W - - GIO1S3 GIOS2 GIO1S1 GIO1S0 GIO1I GIO1OE W - - GIO2S3 GIO2S2 GIO2S1 GIO2S0 GIO2I GIO2OE R/W GRC3 GRC2 GRC1 GRC0 CSC1 CSC0 CGS XS R/W SDR7 SDR6 SDR5 SDR4 SDR3 SDR2 SDR1 SDR0 R/W CHN7 CHN6 CHN5 CHN4 CHN3 CHN2 CHN1 CHN0 R/W DBL RRC1 RRC0 CHR3 CHR2 CHR1 CHR0 IP8 W R W R W R BIP7 IP7 BFP15 -FP15 BFP7 AC7-FP7 BIP1 IP1 BFP9 AC9-FP9 BFP1 AC1-FP1 BIP0 IP0 BFP8 AC8-FP8 BFP0 AC0-FP0 W TXSM1 TXSM0 TXDI TME FS FDP2 FDP1 FDP0 W - PDV1 PDV0 FD4 FD3 FD2 FD1 FD0 W DPR2 DPR1 DPR0 TDL1 TDL0 PDL2 PDL1 PDL0 W WSEL2 WSEL1 WSEL0 AGC_D1 AGC_D0 RS_DLY2 RS_DLY1 RS_DLY0 Oct. 2008. Version 0.3(Preliminary) BIP6 BIP5 BIP4 BIP3 BIP2 IP6 IP5 IP4 IP3 IP2 BFP14 BFP13 BFP12 BFP11 BFP10 AC14-FP14 AC13-FP13 AC12-FP12 AC11-FP11 AC10-FP10 BFP6 BFP5 BFP4 BFP3 BFP2 AC6-FP6 AC5-FP5 AC4-FP4 AC3-FP3 AC2-FP2 9 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 18h W RX 19h R/W RX Gain I 1Ah W RX Gain II 1Bh W RX Gain III 1Ch W RX Gain IV W 1Dh RSSI Threshold R 1Eh W ADC 1Fh W Code I 20h W Code II 21h W Code III W 22h R IF Calibration I 23h R IF Calibration II 24h W VCO current R Calibration 25h W VCO Single band R Calibration I 26h VCO Single band W Calibration II W 27h Battery detect R - RXSM1 RXSM0 AFC RXDI DMG BWS ULS MVGS - IGS MGS1 MGS0 LGS2 LGS1 LGS0 RH7 RH6 RH5 RH4 RH3 RH2 RH1 RH0 RL7 RL6 RL5 RL4 RL3 RL2 RL1 RL0 ENGC - - - MHC LHC1 LHC0 VGCE RTH7 ADC7 RTH6 ADC6 RTH5 ADC5 RTH4 ADC4 RTH3 ADC3 RTH2 ADC2 RTH1 ADC1 RTH0 ADC0 RSM1 RSM0 ERSS FSARS - XADS RSS CDM - MCS WHTS FECS CRCS IDL PML1 PML0 - DCL2 DCL1 DCL0 ETH1 ETH0 PMD1 PMD0 - WS6 WS5 WS4 WS3 WS2 WS1 WS0 - - - MFBS FBCF MFB3 FB3 MFB2 FB2 MFB1 FB1 MFB0 FB0 - - FCD4 FCD3 FCD2 FCD1 FCD0 - - VCCS MVCS VCOC3 VCOC2 VCOC1 VCOC0 - - - FVCC VCB3 VCB2 VCB1 VCB0 - - - - MVBS MVB2 MVB1 MVB0 - - DVT1 DVT0 VBCF VB2 VB1 VB0 - - VTH2 VTH1 VTH0 VTL2 VTL1 VTL0 RGS RGV1 RGV0 - BVT2 BVT1 BVT0 BD_E RGS RGV1 RGV0 BDF BVT2 BVT1 BVT0 BD_E - TXCS PAC1 PAC0 TBG2 TBG1 TBG0 DCM1 DCM0 MLP1 MLP0 SLF2 SLF1 SLF0 DCV6 DCV5 DCV4 DCV3 DCV2 DCV1 DCV0 - - - - - CPC1 CPC0 - - - DBD XCC XCP1 XCP0 PMPE PRIC1 PRIC0 PRRC1 PRRC0 SDPW NSDO - - TLB TLB RLB RLB VCBS - - - RFT3 RFT2 RFT1 RFT0 IGFI1 IGFI0 IGFQ2 IGFQ1 IGFQ0 IFBS LIMS RSC6 RSC5 RSC4 RSC3 RSC2 RSC1 RSC0 FT6 FT5 FT4 FT3 FT2 FT1 FT0 28h W TX test 29h W DMT Rx DEM test I 2Ah W DCV7 Rx DEM test II 2Bh W CPC 2Ch W Crystal test 2Dh W PLL test 2Eh W VCO test I 2Fh W VCO test II 30h W IGFI2 IFAT 31h R/W RSC7 RScale 32h W FT7 Filter test Legend: - = unimplemented Oct. 2008. Version 0.3(Preliminary) 10 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 9.2 控制暫存器說明 9.2.1 Mode Register (Address: 00h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W -RESETN FECF RESETN CRCF RESETN CER RESETN XER RESETN PLLER RESETN TRSR RESETN TRER RESETN -- -- -- -- -- -- -- -- Reset RESETN : 只要這個 register 做寫入時 。 寫入時, 就是做 RF IC reset。 FECF : FEC 檢查旗標, 檢查旗標 如讀出為: 如讀出為 [0]: 表示 FEC 檢查正確。 [1]: 表示 FEC 檢查錯誤。 CRCF : CRC 檢查旗標, 檢查旗標 如讀出為: 如讀出為 [0]: 表示 CRC 檢查正確。 [1]: 表示 CRC 檢查錯誤。 CER : RF chip 致能狀態 致能狀態, 如讀出為 狀態 如讀出為: [0]: 表示 chip 關閉。 [1]: 表示 chip 開啟。 XER : 石英振盪器致能狀態 石英振盪器致能狀態, 狀態 如讀出為: 如讀出為 [0]: 表示振盪器關閉。 [1]: 表示振盪器開啟。 PLLE : PLL 開啟狀態 開啟狀態, 狀態 如讀出為: 如讀出為 [0]: 表示 PLL 關閉。 [1]: 表示 PLL 開啟。 TRSR : TRX state 狀態, 狀態 如讀出為: 如讀出為 [0]: *表示 RX state。 [1]: *表示 TX state。 * 當讀出 TRER=1 時。 TRER : TRX state 致能狀態 致能狀態, 狀態 如讀出為: 如讀出為 [1]: 表示 RF 正在 TX or RX。 9.2.2 Mode Control Register (Address: 01h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W -DDPC -ARSSI -AIF CD DFCD -WOR_EN -FMT -FMS -ADCM 0 1 0 0 0 0 0 0 Reset DDPC(Direct mode data pin control) : Direct mode 時 SPI 的 SDIO 當作 data 的 IO。 。 [0]: 關閉。 [1]: 致能。 ARSSI : 進 RX mode 時自動量測 RSSI。 。 [0]: 關閉。 [1]: 致能。 AIF(Auto IF) : 進 RX mode 時系統自動加減 系統自動加減一 加減一個 IF 頻率。 頻率。 [0]: 關閉。 [1]: 致能。 LO 頻率(RX) = LO 頻率(TX) - IF 頻率.(bit ULS=0;upper side band) LO 頻率(RX) = LO 頻率(TX) + IF 頻率.(bit ULS=1;lower side band) CD / DFCD : CD(Read) : Carrier detector 訊號。 DFCD(Data Filter by CD) : 經由 Carrier Detector 訊號過濾資料封包。 [0]: 關閉。 [1]: 致能。 WOR_EN : WOR mode 致能。 致能。 [0]: 關閉。 [1]: 致能。當對 MCU 送出 wake up 信號後, 會自動清除為 0。 Oct. 2008. Version 0.3(Preliminary) 11 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary FMT : FIFO mode test。 。 [0]: Normal。 [1]: FIFO mode test。僅在 FIFO mode 工作模式有效。當完成封包(packet)測試後,會自動清除為 0。 FMS : Direct/FIFO 模式選擇。 模式選擇。 [0]: Direct 模式。 [1]: FIFO 模式。 ADCM : ADC 量測致能。 量測致能。 [0]: 關閉 ADC 量測或已量測完成。 [1]: 量測致能。當量測完成後,此位元會自動清除為 0。 ADCM None Rx state RX state [0] None None [1] 溫度量測 RSSI 量測、載波偵測、對外部信號作 ADC 量測轉換 9.2.3 Calibration Control Register (Address: 02h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W --- --- --- --- --- VCC 0 VBC 0 FBC 0 VCC : VCO Current Calibration 校準選項致能。 校準選項致能。 [0]: 關閉 VCO Current Calibration 或已校準完成。 [1]: 校準致能。當校準完成後,此位元會自動清除為 0。 VBC : VCO Bank Calibration 校準選項致能。 校準選項致能。 [0]: 關閉 VCO Bank Calibration 或已校準完成。 [1]: 校準致能。當校準完成後,此位元會自動清除為 0。 FBC : IF Filter Bank 校準選項致能。 校準選項致能。 [0]: 關閉 IF Filter Bank 或已校準完成。 [1]: 校準致能。當校準完成後,此位元會自動清除為 0。 9.2.4 FIFO Register I (Address: 03h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W FEP7 0 FEP6 0 FEP5 1 FEP4 1 FEP3 1 FEP2 1 FEP1 1 FEP0 1 FEP[7:0] : TX/RX FIFO byte 結束位址設定。 。 結束位址設定。FIFO 結束位址 = FEP[7:0]+1。 9.2.5 FIFO Register II (Address: 04h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W FPM1 0 FPM0 1 PSA5 0 PSA4 0 PSA3 0 PSA2 0 PSA1 0 PSA0 0 FPM[1:0] : TX/RX FIFO 臨界值設定。 臨界值設定。 設定值 Bytes in TX FIFO Bytes in RX FIFO [00] 4 60 [01] 8 56 [10] 12 52 [11] 16 48 PSA[5:0] : TX FIFO packet 傳送起始位址設定。 傳送起始位址設定。 9.2.6 FIFO DATA Register (Address: 05h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W FIFO7 0 FIFO6 0 FIFO5 0 FIFO4 0 FIFO3 0 FIFO2 0 FIFO1 0 FIFO0 0 FIFO[7:0] : TX/RX FIFO data。 。讀寫資料均在同一個暫存器。 讀寫資料均在同一個暫存器。 Oct. 2008. Version 0.3(Preliminary) 12 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 9.2.7 ID DATA Register (Address: 06h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W ID7 0 ID6 0 ID5 0 ID4 0 ID3 0 ID2 0 ID1 0 ID0 0 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ID[7:0] : ID data。 。讀寫資料均在同一個暫存器。 讀寫資料均在同一個暫存器。 9.2.8 RC OSC Register I (Address: 07h) Bit R/W Name R W Reset Bit 7 Bit 6 RCOC5 RCOC4 RCOC3 RCOC2 RCOC1 RCOC0 WWS_SL7 WWS _SL6 WWS _SL5 WWS _SL4 WWS _SL3 WWS _SL2 WWS _SL1 WWS _SL0 0 0 0 0 0 0 0 0 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 WWS_SL[7:0] : WWS Sleep Time delay 設定。 設定。(7.8ms ~ 7.99s)  1  Sleep time = (WWS _ SL[9 : 0] + 1) × 32 ×  s  4092  RCOC[5:0] : RC oscillator calibration counter value。 。 9.2.9 RC OSC Register II (Address: 08h) Bit R/W Name Reset W Bit 7 Bit 6 Bit 5 WWS _SL9 WWS _SL8 WWS _AC5 WWS _AC4 WWS _AC3 WWS _AC2 WWS _AC1 WWS _AC0 0 0 0 0 0 0 0 0 WWS_AC[4:0] : WWS ACtion delay 設定。 設定。(244us ~ 15.6ms)  1  ACtion time = (WWS _ AC[5 : 0] + 1) × 1 ×  s 。  4092  9.2.10 RC OSC Register III (Address: 09h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W BBCKS1 0 BBCKS0 0 --- --- --- RCOSC_E TSEL 0 TWOR_OE 1 1 BBCKS[1:0] : Clock select for digital block。 。 [00]: System clock / 2。 [01]: System clock / 4。 [10]: System clock / 6。 [11]: System clock / 8。 RCOSC_E : RC oscillator 致能選擇。 致能選擇。 [0]: 關閉。 [1]: 致能(預設)。 TSEL : 計時器喚醒時間。 計時器喚醒時間。 [0]: 使用 WOR_AC。 [1]: 使用 WOR_SL。 TWOR_OE : Use Timer to wake up MCU without RF。 。 [0]: 關閉。 [1]: 致能(預設)。 9.2.11 CKO Pin Control Register (Address: 0Ah) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W ECKOE 1 CKOS3 0 CKOS2 1 CKOS1 1 CKOS0 1 CKOI 0 CKOE 1 SCKI 0 ECKOE : 外部時脈輸出致能。 外部時脈輸出致能。 這 bit 會控制 CKO[3:0]選項內[0101],[0110],[0111]這三個選項的時脈輸出。 Oct. 2008. Version 0.3(Preliminary) 13 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary CKOS[3:0] : CKO pin 信號輸出選擇。 信號輸出選擇。 [0000]: BCK(bit clock)。 [0001]: MRCK(modulation rate)。 [0010]: FPF(FIFO pointer flag)。 [0011]: EOP,EOVBC,EOFBC,EOADC,EOVCC,OKADC。 [0100]: 外部時脈輸出。系統時脈/1。 [0101]: 外部時脈輸出。系統時脈/2,由 bit ECKOE 決定輸出開啟或關閉。 [0110]: 外部時脈輸出。系統時脈/4,由 bit ECKOE 決定輸出開啟或關閉。 [0111]: 外部時脈輸出。系統時脈/8,由 bit ECKOE 決定輸出開啟或關閉。 [1xxx]: 保留。 CKOI : CKO pin 信號反向輸出。 信號反向輸出。 [0]: 非反向輸出。 [1]: 反向輸出。 CKOE : CKO pin 信號輸出開啟。 信號輸出開啟。 [0]: High Z。 [1]: 開啟。 SCKI : SPI 時脈反向輸入。 時脈反向輸入。 [0]: 非反向輸入。 [1]: 反向輸入。 9.2.12 GIO1 Pin Control Register (Address: 0Bh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- --- GIO1S3 0 GIO1S2 0 GIO1S1 0 GIO1S0 0 GIO1I 0 GIO1OE 1 GIO1S[3:0] : GIO1 pin 信號輸出選擇。 信號輸出選擇。 設定值 TX state RX state [0000] WTR(non-standby state) output [0001] EOAC(end of access code) FSYNC(frame sync) [0010] TMEO(TX modulation enable) CD(carrier detect) [0011] Preamble OK output [0100] TWOR/WOR(wakeup MCU) [0101] In phase demodulator output(DMII) [0110] P_SDO(4 wire SPI data out) [0111] TRXD In/Out [1000] RXD [1001] TXD [1010] In phase demodulator external input(EXDI0) [1011] External FSYNC input in RX direct mode [11xx] 保留 GIO1I : GPIO1 pin 信號反向輸出。 信號反向輸出。 [0]: 非反向輸出。 [1]: 反向輸出。 GIO1OE : GPIO1 pin 信號輸出開啟。 信號輸出開啟。 [0]: High Z。 [1]: 開啟。 9.2.13 GIO2 Pin Control Register (Address: 0Ch) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- --- GIO2S3 0 GIO2S2 1 GIO2S1 0 GIO2S0 0 GIO2I 0 GIO2OE 1 GIO2S [3:0] : GIO2 pin 信號輸出選擇。 信號輸出選擇。 設定值 TX state RX state [0000] WTR(non-standby state) output Oct. 2008. Version 0.3(Preliminary) 14 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary [0001] [0010] [0011] [0100] [0101] [0110] [0111] [1000] [1001] [1010] [1011] [11xx] EOAC(end of access code) FSYNC(frame sync) TMEO(TX modulation enable) CD(carrier detect) Preamble OK output TWOR/WOR(wakeup MCU) In phase demodulator output(DMIQ) P_SDO(4wire SPI data out) TRXD In/Out RXD TXD In phase demodulator external input(EXDI0) External FSYNC input in RX direct mode 保留 GIO2I : GIO2 pin 信號反向輸出。 信號反向輸出。 [0]: 非反向輸出。 [1]: 反向輸出。 GIO2OE : GIO2 pin 信號輸出開啟。 信號輸出開啟。 [0]: High Z。 [1]: 開啟。 9.2.14 Clock Register (Address: 0Dh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W GRC3 1 GRC2 1 GRC1 1 GRC0 1 CSC1 0 CSC0 1 CGS 0 XS 1 GRC[3:0] : Clock Chain reference frequency 除頻設定。 除頻設定。 Clock Chain reference = f xtal =2MHz (GRC[3:0]+1) CSC[1:0] : Clock source 除頻設定。 除頻設定。 [00]: / 1。[01]: / 2。[10]: / 2。[11]: / 4。 CGS : Clock source 選擇。 選擇。 [0]: X’stal clock。 [1]: Clock Chain。 XS : 石英振盪器選擇。 石英振盪器選擇。 [0]: RFIC 的 clock 由外部提供。[1]: clock 由內部線路產生。 9.2.15 Data Rate Register (Address: 0Eh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W SDR7 0 SDR6 0 SDR5 0 SDR4 0 SDR3 0 SDR2 0 SDR1 0 SDR0 0 SDR[7:0] : Data rate 除頻設定。 除頻設定。 Data rate = SystemCloc k 。 32*(SDR[7:0]+1) 9.2.16 PLL Register I (Address: 0Fh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W CHN7 0 CHN6 0 CHN5 0 CHN4 0 CHN3 0 CHN2 0 CHN1 0 CHN0 0 CHN[7:0] : RF 頻道選擇。 頻道選擇。 Oct. 2008. Version 0.3(Preliminary) 15 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 9.2.17 PLL Register II (Address: 10h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W DBL 1 RRC1 0 RRC0 0 CHR3 1 CHR2 1 CHR1 1 CHR0 1 IP8 0 DBL : Crystal oscillator 倍頻選擇. 倍頻選擇 [0]: Xtal source = Crystal oscillator. [1]: Xtal source =2 * Crystal oscillator. RRC[1:0] : RF PLL reference counter. The divider range is from 1 to 4. CHR[3:0] : Channel frequency step 設定。 設定。 CHR[3 : 0] + 1 = PFD 2MHz PFD : PLL 參考比較頻率(PLL comparison frequency) 9.2.18 PLL Register III (Address: 11h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W IP7 BIP7 0 IP6 BIP6 1 IP5 BIP5 0 IP4 BIP4 0 IP3 BIP3 1 IP2 BIP2 0 IP1 BIP1 1 IP0 BIP0 1 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 AC9-FP9 BFP9 AC8-FP8 BFP8 Reset BIP[8:0] : RF 基本頻率整數部份 基本頻率整數部份( 頻率整數部份 Integer Part) 設定. 設定 IP [8:0]: RF PLL 整數部份讀出數值. 9.2.19 PLL Register IV (Address: 12h) Bit R/W Bit 7 Name R W FP15 BFP15 Reset Bit 6 AC14-FP14 AC13-FP13 AC12-FP12 AC11-FP11 AC10-FP10 BFP14 BFP13 BFP12 BFP11 BFP10 0 0 0 0 0 0 0 0 9.2.20 PLL Register V (Address: 13h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W AC7-FP7 BFP7 0 AC6-FP6 BFP6 0 AC5-FP5 BFP5 0 AC4-FP4 BFP4 0 AC3-FP3 BFP3 0 AC2-FP2 BFP2 0 AC1-FP1 BFP1 1 AC0-FP0 BFP0 1 Reset BFP[15:0] : RF 基本頻率分數部份 設定. 基本頻率分數部份( 頻率分數部份 Fractional Part)設定 設定 RF 頻率公式: 頻率公式: BFP[15 : 0] ) 216 + (CHN[7 : 0] ⋅ Channel Step ) fRF _ Base = PFD ⋅ (BIP[8 : 0] + fRF = fRF _ Base 註: f RF 為 RF 的工作頻率 Channel Step 為頻道距離, Channel Step = PFD ,目前 4 * (CHR[3 : 0] + 1) A7105 Channel Step 是設 500KHz AC[14:0](Read) :頻率補償 頻率補償 SPI 讀出數值(RX Reg. bit AFC=1)。 。 讀出數值 FP[15:0](Read) : PLL 頻率分數部份 SPI 讀出數值(RX Reg. bit AFC=0)。 Oct. 2008. Version 0.3(Preliminary) 16 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 當開啟 AIF 功能(Mode control Reg. bit AIF=1 時) RF 頻率(RX mode)=RF 頻率 – IF 頻率(RX Reg. ULS=0)。 RF 頻率(RX mode)=RF 頻率 + IF 頻率(RX Reg. ULS=1)。 9.2.21 TX Register I (Address: 14h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W TXSM1 0 TXSM0 0 TXDI 0 TME 1 FS 0 FDP2 1 FDP1 1 FDP0 0 TXSM[1:0] : Moving average for non filter select. [00]: non moving average。[01]: 2 moving average。[10]: 4 moving average。[11]: 8 moving average。 TXDI : TX data 反向輸出。 反向輸出。 [0]: 非反向輸出。 [1]: 反向輸出。 TME : TX 調變致能。 調變致能。 [0]: 調變關閉。 [1]: 調變開啟。 FS : filter 選擇. 32h)設置 設置.預設值為 選擇 Filter shape 可從 Filter test 暫存器(address: 暫存器 設置 預設值為 gaussian filter(BT=0.7). [0]: 關閉。 [1]: 開啟。 FDP[2:0] : Frequency deviation power 設定. 設定 頻率偏移量(frequency deviation): f dev = 127 ⋅ PFD ⋅ (FD[4 : 0] + 1) ⋅ 2 FDP[ 2:0] 2 24 註: PFD 為參考比較頻率 9.2.22 TX Register II (Address: 15h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- PDV1 0 PDV0 0 FD4 0 FD3 1 FD2 0 FD1 1 FD0 1 PDV[1:0] : division select for TX data rate while TX filter is on TX data rate = PFD 32 * PDV[1 : 0] * (SDR[7 : 0] + 1) FD[4:0] : Frequency deviation 設定. 設定 9.2.23 Delay Register I (Address: 16h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W DPR2 0 DPR1 0 DPR0 0 TDL1 1 TDL0 0 PDL2 0 PDL1 1 PDL0 0 DPR[2:0] : 延遲時間倍數設定。 延遲時間倍數設定。 TDL[1:0] : TX settling 延遲時間設定。 延遲時間設定。 Tx Settling Delay = 20 * (TDL[1 : 0] + 1) * (DPR[2 : 0] + 1) us PDL[2:0] : PLL settling 延遲時間設定。 延遲時間設定。 PLL Settling Delay = 20 * (PDL[2 : 0] + 1) * (DPR[2 : 0] + 1) us Oct. 2008. Version 0.3(Preliminary) 17 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 9.2.24 Delay Register II (Address: 17h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Name Reset W WSEL2 0 WSEL1 1 WSEL0 0 AGC_D1 0 Bit 3 Bit 2 Bit 1 Bit 0 AGC_D0 RS_DLY2 RS_DLY1 RS_DLY0 1 0 1 0 WSEL[2:0] : Xtal 起振 settling 延遲時間設定。 延遲時間設定。(2000us ~ 2.5ms 2.5ms) ms) [000]: 200us。[001]: 400us。[010]: 600us。[011]: 800us。 [100]: 1ms。 [101]: 1.5ms。 [110]: 2ms。 [111]: 2.5ms。 AGC_D[1:0] : AGC 轉換時 RSSI settling 時間設定。(10~40us) [000]: 10us。[001]: 20us。[010]: 30us。[011]: 40us。 RS_DLY[2:0] : 進 RX state RSSI 量測 settling 時間設定。(10~80us) [000]: 10us。[001]: 20 us。[010]: 30us。 [011]: 40 us。 [100]: 50us。[101]: 60 us。[110]: 70us。[111]: 80 us。 9.2.25 RX Register (Address: 18h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- RXSM1 0 RXSM0 0 AFC 0 RXDI 0 DMG 0 BWS 1 ULS 0 RXSM[1:0] : RX demodulator smooth filter 選擇 RXSM[0]: [1]: demodulation filter bandwidth = 1MHz。[0]: demodulation filter bandwidth = 2MHz。 RXSM[1]: [1]: 8 bit moving average of data filter。 [0]: 4 bit moving average of data filter。 AFC : 頻率補償(frequency compensation)校準選擇 校準選擇。 頻率補償 校準選擇。 [0]: 手動校準。 [1]: 自動校準。 RXDI : RX data 反向輸出。 反向輸出。 [0]: 非反向輸出。 [1]: 反向輸出。 DMG : Demodulator 增益選擇。 增益選擇。 [0]: ×1 [1]: ×3 BWS : BPF 頻帶寬選擇。 帶寬選擇。 [0]: 250KHz。 [1]: 500KHz。 ULS : 接收端 Up/Low side band 選擇。 選擇。 [0]: up side band。 [1]: low side band。 9.2.26 RX Gain Register I (Address: 19h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W MVGS 0 --- IGS 1 MGS1 0 MGS0 0 LGS2 0 LGS1 0 LGS0 0 MVGS : 手動 VGA 校正。 校正。 [0]: 自動。 [1]: 手動。 IGS : PGA gain select. [0]: 12dB。 [1]: 6dB。 MGS[1:0] : Mixer gain select. [00]: 24dB。[01]: 18dB。[10]: 12dB。[11]: 6dB。 LGS[2:0] : LNA gain select. [000]: 24dB。[001]: 18dB。[010]: 12dB。[011]: 6dB。[1XX]: 0dB。 Oct. 2008. Version 0.3(Preliminary) 18 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 9.2.27 RX Gain Register II (Address: 1Ah) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W RH7 0 RH 6 0 RH5 0 RH4 0 RH3 1 RH2 0 RH1 1 RH0 0 RH[7:0] : VGA 校正目標上限 校正目標上限。 上限。 9.2.28 RX Gain Register III (Address: 1Bh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W RL7 1 RL6 0 RL5 1 RL4 1 RL3 0 RL2 1 RL1 0 RL0 0 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 MHC 1 LLC1 1 LLC0 1 VGCE 0 RH[7:0] : VGA 校正目標下限 校正目標下限。 下限。 9.2.29 RX Gain Register IV (Address: 1Ch) Bit R/W Bit 7 Name Reset W ENGC 1 Bit 6 ENGC : End of AGC tuning [0]:在設定目標內仍然持續量測調整,直到接收到 ID code 才停止。 [1]: 調整至目標範圍內則停止量測與調整。 MHC : Mixer high current 選擇。 選擇。 [0]: 0.6mA。 [1]: 1.2mA。 LLC : LNA low current 選擇。 選擇。 [00]: 0.5mA。[01]: 1.0mA。[10]: 1.5mA。[11]: 2.0mA。 VGCE: VGA calibration 致能. 當校準完成後,此位元會自動清除為 0(Combine with FSYNCO). VGA calibration will be done when VGCE or FSYNCO active high. 9.2.30 RSSI Threshold Register (Address: 1Dh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W ADC7 RTH7 1 ADC6 RTH6 0 ADC5 RTH5 0 ADC4 RTH4 1 ADC3 RTH3 0 ADC2 RTH2 0 ADC1 RTH1 0 ADC0 RTH0 1 Reset RTH[7:0] : 載波偵測(carrier detect)臨界值設定 臨界值設定。 載波偵測 臨界值設定。 CD=1 for RSSI(ADC value) ≦ RTH。 CD=0 for RSSI(ADC value) ≧ RTH。 ADC[7:0] : 溫度、 、或外部信號量測的 ADC 值輸出。 溫度、RSSI、 值輸出。 RX state: Digital RSSI output. PWRRSSI = -110dbm + 40*RSSI[7:0] / 8 Non-RX state: Digital thermometer output. The relative temperature is around + 2 ℃ * ADC[7:0]. External voltage measurement: the voltage is around 4.69 mV * ADC[7:0]. 9.2.31 ADC Control Register (Address: 1Eh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W RSM1 0 RSM0 1 ERSS 0 FSARS 1 --- XADS 0 RSS 1 CDM 1 RSM[1:0] : RSSI hysteresis select. [00]: 5。 [01]: 10。 [10]: 15。 [11]: 20。 Oct. 2008. Version 0.3(Preliminary) 19 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary ERSS : Sync 時結束 RSSI 的量測。 的量測。 [0]: 關閉。 [1]: 致能。 FSARS : ADC 時脈選擇。 時脈選擇。 [0]: system clock / 4。 [1]: system clock / 2。 XADS : ADC 輸入信號的選擇。 輸入信號的選擇。 [0]: 對內部溫度或 RSSI 信號作 ADC 量測轉換。 [1]: 對外部信號作 ADC 量測轉換。 RSS : 溫度 / RSSI 量測選擇。 量測選擇。 [0]: Temperature 量測。 [1]: RSSI 或 Carrier 量測。 CDM : 載波(Carrier)偵測模式 偵測模式。 載波 偵測模式。 [0]: 單次量測。 [1]: 連續偵測(for Carrier)。 9.2.32 Code Register I (Address: 1Fh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- MCS 0 WHTS 0 FECS 0 CRCS 0 IDL 1 PML1 1 PML0 1 MCS : Manchester code 選擇。 選擇。 [0]: 關閉。 [1]: 開啟。 WHTS : Data whitening (Data Encryption)選擇 選擇。 選擇。 [0]: 關閉。 [1]: 開啟。 FECS : FEC 選擇。 選擇。 [0]: 關閉。 [1]: 開啟。 註: FEC 是使用(7, 4) Hamming code. CRCS : CRC 選擇。 選擇。 [0]: 關閉。 [1]: 開啟。 IDL : ID code 長度選擇。 長度選擇。 [0]: 2 bytes。 [1]: 4 bytes。 PML[1:0] : Preamble 長度選擇。 長度選擇。 [00]: 1 byte。 [01]: 2 bytes。 [10]: 3 bytes。 [11]: 4 bytes。 9.2.33 Code Register II (Address: 20h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- DCL2 1 DCL1 1 DCL0 1 ETH1 0 ETH0 1 PMD1 1 PMD0 1 DCL[2:0] : DC 平均值收到 Data 長度設定。 長度設定。 DCL0: [0]: DC value hold at 8 bit after preamble detect。[1]: DC value hold at 16 bit after preamble detect。 DCL1: [0]: 32 bits before ID code word detected。[1]: 64 bits before ID code word detected。 DCL2: [0]: 128 bits after ID code word detected。[1]: 256 bits after ID code word detected。 ETH[1:0] : ID code 容許錯誤 bit 數。 [00]: 0 bit。 [01]: 1 bit(建議值)。 [10]: 2 bit。 [11]: 3 bit。 PMD[1:0] : Preamble 長度偵測設定。 長度偵測設定。 [00]: 0bit。 [01]: 4bits。 [10]: 8bits。 [11]: 16bits。 注意:偵測長度設定需小於 PML[1:0]的設定值。 Oct. 2008. Version 0.3(Preliminary) 20 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary 9.2.34 Code Register III (Address: 21h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- WS6 0 WS5 1 WS4 0 WS3 1 WS2 0 WS1 1 WS0 0 WS[6:0] : Data Whitening 初始 seed 設定(data encryption key)。 。 設定 9.2.35 IF Calibration Register I (Address: 22h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W ---- ---- ---- FBCF MFBS 0 FB3 MFB3 0 FB2 MFB2 1 FB1 MFB1 1 FB0 MFB0 0 Reset MFBS : IF filter 自動(Auto)/手動 手動(Manual)校準選擇 校準選擇。 自動 手動 校準選擇。 [0]: 自動校準。 [1]: 手動校準。 MFB[3:0] : IF filter 手動(Manual)調校值設定 調校值設定。 手動 調校值設定。 FBCF : IF filter calibration 成功/錯誤指示 成功 錯誤指示。 錯誤指示。 [0]: 校準成功。 [1]: 校準失敗。 FB[3:0] : IF filter 調校值設定. 調校值設定 9.2.36 IF Calibration Register II (Address: 23h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R --- --- FCD4 -- FCD3 -- FCD2 -- FCD1 -- FCD0 -- FCD4 -- FCD[4:0] : IF filter calibration deviation from goal. 9.2.37 VCO current Calibration Register (Address: 24h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W ---- ---- -VCCS 0 FVCC MVCS 0 VCB3 VCOC3 1 VCB2 VCOC2 0 VCB1 VCOC1 0 VCB0 VCOC0 0 Reset VCCS : VCO 調校電流設定 調校電流設定。 設定。 [0]:1mA。 [1]:1.5mA。 MVCS : 手動 VCO 電流選擇。 電流選擇。 [0]:VCB。 [1]:VCOC。 VCOC[3:0] : VCO 手動電流設定 手動電流設定。 電流設定。 FVCC : VCO current calibration 成功/錯誤指示 成功 錯誤指示。 錯誤指示。 [0]: 成功。 [1]: 失敗。 VCB[3:0] : VCO 電流自動校準值 9.2.38 VCO Single band Calibration Register I (Address: 25h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W ---- ---- DVT1 --- DVT0 --- VBCF MVBS 0 VB2 MVB2 1 VB1 MVB1 0 VB0 MVB0 0 Reset Oct. 2008. Version 0.3(Preliminary) 21 AMIC Communication Corporation A7105 2.4GHz Transceiver Preliminary MVBS : VCO bank 自動(Auto)/手動 自動 手動(Manual)校準選擇 校準選擇。 手動 校準選擇。 [0]: 自動校準。 [1]: 手動校準。 MVB[2:0] : VCO band 手動調校值設定。 手動調校值設定。 DVT[1:0] : DVT 值輸出。 值輸出。 [00]: VT
A7105 价格&库存
很抱歉,暂时无法提供与“A7105”相匹配的价格&库存,您可以联系我们找货
