UMW
R
UMW FDN338P
SOT-23 Plastic-Encapsulate MOSFETS
FDN338 P-Channel 20-V(D-S) MOSFET
SOT–23
ID
RDS(on)MAX
V(BR)DSS
112mΩ@-4.5V
-20 V
-2.8 A
142mΩ@-2.5V
1. GATE
2. SOURCE
3. DRAIN
FEATURE
z TrenchFET Power MOSFET
APPLICATION
z
z
MARKING
Load Switch for Portable Devices
DC/DC Converter
Equivalent Circuit
338
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
±8
Continuous Drain Current
ID
-2.8
Pulsed Drain Current
IDM
-10
Continuous Source-Drain Diode Current
IS
-0.72
Maximum Power Dissipation
PD
0.4
W
℃/W
Thermal Resistance from Junction to Ambient(t ≤5s)
R θJA
312.5
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~+150
www.umw-ic.com
1
Unit
V
A
友台半导体有限公司
UMW
R
UMW FDN338P
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Units
Static
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID =-250µA
-20
Gate-source threshold voltage
VGS(th)
VDS =VGS, ID =-250µA
-0.4
-1
V
Gate-source leakage
IGSS
VDS =0V, VGS =±8V
±100
nA
Zero gate voltage drain current
IDSS
VDS =-20V, VGS =0V
-1
µA
Drain-source on-state resistance a
Forward transconductance
RDS(on)
a
gfs
VGS =-4.5V, ID =-2.8A
0.090
0.112
VGS =-2.5V, ID =-2.0A
0.110
0.142
VDS =-5V, ID =-2.8A
6.5
Ω
S
b
Dynamic
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
Crss
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
Gate resistance
Rg
Turn-on delay time
td(on)
Rise time
tr
Turn-off delay time
td(off)
Fall time
tf
405
VDS =-10V,VGS =0V,f =1MHz
pF
75
55
VDS =-10V,VGS =-4.5V,ID =-3A
VDS =-10V,VGS =-2.5V,ID =-3A
5.5
10
3.3
6
0.7
nC
1.3
f =1MHz
VDD=-10V,
RL=10Ω, ID =-1A,
VGEN=-4.5V,Rg=1Ω
6.0
Ω
11
60
30
50
10
ns
Drain-source body diode characteristics
Continuous source-drain diode current
Pulse diode forward current
Body diode voltage
a
IS
-1.3
TC=25℃
-10
ISM
VSD
A
IS=-0.7A
-0.8
-1.2
V
Notes :
a.Pulse Test : Pulse Width < 300µs, Duty Cycle ≤2%.
b.Guaranteed by design, not subject to production testing.
www.umw-ic.com
2
友台半导体有限公司
很抱歉,暂时无法提供与“FDN338P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.63140
- 200+0.21010
- 1500+0.13200
- 3000+0.10439
