GPD5353L100-36V2800-J
    INGHAI(赢海)
GPD5353L100-36V2800-J 数据手册
規 格 承 認 書 PECIFICATION FOR APPROVAL 客 戶 CUSTOMER 項 目 ITEM 型 號 : 通用型规格书 电压范围 12-36V : 压电有源报警器(内含驱动电路) TYPE : GPD5353L100-12-36V2800-J 报警声 描述 DESCRIPTION : Φ53.4 x H53.0 mm 2800Hz DC12-36V >=120DB at 30cm 客戶料號 CUSTOMER NO. : 規 格 書 號 L=100 mm SPECIFICATION NO.: 版 本 EDITION NO. 日 期 DATE : V1.1 : 20 客戶承認 CUSTOMER CONFIRM AND SIGN 檢查 審核 承認 TESTED BY CHECKED BY APPROVED BY 東莞市赢海電子有限公司 DONGUAN INGHAI ELECTRONICS CO.,LTD 製作 審查 確認 ISSUED BY CHECKED BY APPROVED BY 周明 李林 地址:廣東省東莞市長安鎮上沙管理區北橫路 8 號 電話 / TEL:0769-83060958 傳真 / FAX: 0769-81608993 網址:HTTP://WWW.INGHAI.COM DONGGUAN INGHAI ELECTRONICS CO.,LTD 1/3 Model NO: GPD5353L100-12-36V2800-J 报警声 A: DIMEMSIONS Unit:mm Tolerance:±0.5 黑 红 B: SPECIFICATIONS Model NO GPD5353L110 Rated Voltage 12-36VDC Operating Voltage 9-38VDC Max.Rated Current Max.180mA Sound Pressure level(dB/min) at 30cm Min.120dB Resonant Frequency 2800±200Hz Operating Temperature -20 ℃~+60 ℃ Storage Temperature -30 ℃~+70 ℃ Case material and color ABS / Black Measuring condition Part shall be measured under a condition (Temperature: 5~ 35℃, Humidity: 45% ~ 85%R.H., Atmospheric pressure: 860 ~ 1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure. C: Reliability Test 2/3 After any following tests the part shall meet specifications without any degradation in appearance and performance except SPL. SPL shall not deviate more than -10 dB from the initial value 1. Ordinary Temperature Life Test The part shall be subjected to 96 hours at 25±10℃. Input rated voltage 2. 3. 4. 5. 6. 7. Resonant frequency, 1/2 duty Square wave. High Temperature Test The part shall be capable of with standing a storage temperature of +70℃ for 96 hours. Low Temperature Test The part shall be capable of with standing a storage temperature of -30℃ for 96 hours. Humidity Test Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours and expose to room temperature for 6 hours Temperature Shock Test Temperature:60℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle) Total cycle: 10 cycles Drop Test Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick, three sides, six plain.) Vibration Test Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes Note: As this product is not protected from foreign material entering, please make sure that any foreign materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it. 3/3
GPD5353L100-36V2800-J 价格&库存
很抱歉,暂时无法提供与“GPD5353L100-36V2800-J”相匹配的价格&库存,您可以联系我们找货
    • 1+32.40000
    • 200+12.53880
    • 500+12.10680
    • 1000+11.88000
