HSBA3056
N-Ch 30V Fast Switching MOSFETs
Applications
Product Summary
Power Management in Desktop Computer or
DC/DC Converters
Isolated DC/DC Converters in Telecom and
Industrial.
VDS
30
V
RDS(ON),typ
3.2
mΩ
ID
73
A
Features
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
PRPAK5*6 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1
73
A
ID@TC=100℃
46
A
IDM
Pulsed Drain Current2
120
A
EAS
Single Pulse Avalanche Energy3
80
mJ
IAS
Avalanche Current
40
A
PD@TC=25℃
Total Power Dissipation4
38
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient 1
RθJC
Thermal Resistance Junction-Case1
www.hs-semi.cn
Ver 2.0
Typ.
Max.
Unit
55
℃/W
3.3
℃/W
1
HSBA3056
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.021
V/℃
VGS=10V , ID=20A
3.2
3.9
VGS=4.5V , ID=15A
4.9
6.1
1.0
1.7
2.2
V
-5.73
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=20A
75
S
Rg
Gate Resistance
VDS=10V , VGS=0V , f=1MHz
0.7
1.65
2.6
Qg
Total Gate Charge (4.5V)
14.6
Qgs
Gate-Source Charge
5.8
Qgd
Gate-Drain Charge
3.5
Td(on)
VDS=15V , VGS=4.5V , ID=20A
7.5
Rise Time
VDD=15V , VGS=10V , RG=3
20.1
Turn-Off Delay Time
ID=20A
21.6
Fall Time
4.4
Ciss
Input Capacitance
1476
Coss
Output Capacitance
556
Crss
Reverse Transfer Capacitance
70
Min.
Typ.
Max.
Unit
Tr
Td(off)
Tf
Turn-On Delay Time
nC
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Conditions
Continuous Source Current1,5
VG=VD=0V , Force Current
30
A
Diode Forward Voltage2
VGS=0V , IS=1A , TJ=25℃
1
V
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.1mH,IAS=40A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSBA3056
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-charge Characteristics
diode
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSBA3056
Fig.7 Capacitance
Fig.8 Safe Operating Area
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
BVDSS
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
Fig.11 Unclamped Inductive Switching
Waveform waveform
www.hs-semi.cn
Ver 2.0
4
HSBA3056
Ordering Information
Part Number
HSBA3056
www.hs-semi.cn
Package code
PRPAK5*6
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSBA3056”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.47632
- 50+0.42188
- 150+0.39856
- 500+0.36943
- 3000+0.30975
- 6000+0.30197
