BM24-10DP/2-0.35V(51) 数据手册
0.35mm Pitch 0.8mm Height Hybrid Power/Signal Connectors for Board-to-Board and FPC-to-Board
BM24 Series
(Supports USB3.0 signal)
Conventional
type
(P= 0.35 mm,
20 contacts)
Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
L]Zcjh^c\V*
6edlZghjeean
BM24 with 10
contact positions
(Plus two power
contacts)
7nXdchda^YVi^c\i]ZedlZgidildYZY^XViZYedlZge^ch!
i]Z7B')Åh]nWg^YedlZg$h^\cVaYZh^\chVkZhkVajVWaZE87heVXZdkZg
XdckZci^dcVah^\cVaXdciVXidcanhinaZXdccZXidgh#
Fig.1
■Features
1. Rated current : 5A
Area for vacuum pick up
%#,bb
%#,bb
The compact BM24 Series features a space-saving
design with the power contacts rated at 5A, and
the signal contact rated at 0.25A. (Fig.1)
2. High contact reliability
A 2-point contact structure for both power and
signal contacts provides high contact reliability.
(Fig.3)
3. Enhanced mating process
A guide rib ensures self-alignment during mating,
with an alignment range of 0.3mm. In addition, a
tactile click is generated upon mating completion,
preventing incomplete mating and enhancing mating
operability.
Fig.2
Cross-sectional view of mated contacts
Signal contact
Two-point
contact
4. Supports USB3.0/3.1 transmission
The signal contact supports USB3.0/3.1 signals.
Power contact
Two-point
contact
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2016.3②
1
BM24 Series●0.35mm Pitch 0.8mm Height Hybrid Power/Signal Connectors for Board-to-Board and FPC-to-Board
■Product Specifications
Rated
Power contact : 5A
Operating
Storage
-40 to 85°C (Note 2)
-10 to 60ç (Note 3)
current Signal contact : 0.25A(Note 1) temperature range
temperature range
Storage
Operating
Rated
40 to 70% (Note 3)
20 to 80%
30V AC/DC
humidity range
humidity range
voltage
Ratings
Items
Specifications
1. Insulation resistance
Conditions
100Mø min.
Measured at 100V DC
2. Withstanding voltage No flashover or dielectric breakdown
150V AC for one minute
3. Contact resistance
Signal contact : 100mø max.
Power contact : 15mø max.
Measured at 20mV AC, 1kHz, and 1mA
4. Vibration
No electrical discontinuity for more than 1µs.
Frequency : 10 to 55 Hz ; half amplitude : 0.75mm,
in 3 axis directions for 2 hours
5. Humidity
Contact resistance : Signal contact : 100mø max.
Insulation resistance : 50Mø min.
96 hours at a temperature of 40 ±2ç and
a humidity range from 90 to 95%
6. Temperature cycle
Insulation resistance : 100Mø min.
(-55ç for 30 minutes ➝ 5 to 35°C for 10 minutes ➝
85°C for 30 minutes ➝ 5 to 35°C for 10 minutes)
in 5 cycles
7. Durability
10 mating cycles
8. Solder heat
resistance
No dissolution or melting of the resin that will
affect the performance.
Reflow : with recommended temperature profile ; Hand
soldering at soldering iron temperature of 350ç for
3 seconds max.
Note 1 : The total current capacity for connectors with 40 or more signal contacts is 10A for all contacts.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : Storage refers to long-term-storage of unused items before they are mounted on the PCB.
Operating temperature / humidity range applies to the state of temporary storage such as non-powered after mounting on the
PCB, and during transportation, etc.
■Materials / Finish
Product
Receptacle
Header
Part
Materials
Finish
UL Regulation
Insulator
LCP
Black
UL94V-0
Signal contact
Phosphor bronze
Gold plated
Power contact
Copper alloy
Gold plated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacle / Header
BM 24 − * DS / 2 − 0.35 V (51)
❶
2
❷
❸
❹
❺
❻
❼
❽
❶ Series Name : BM
❺ Number of Power Contacts : 2
❷ Series No. : 24
❻ Contact Pitch : 0.35mm
❸ Number of Signal Contacts : 10, 20, 24, 30, 40
❼ Termination type
V : Straight SMT
❹ Connector type
DS : Receptacle
DP : Header
❽ Gold plated specification and packaging status
(51) : Gold plate thickness 0.05µm
Embossed tape packaging (10,000 pcs/reel)
■Receptacle
6
7
E2 %#(*
Recommended PCB layout
7¤%#%'
E2%#(*¤%#%&
8¤%#%'
E2%#(*¤%#%'
>chjaViZYVgZV
(eViiZgcegd]^W^iZYVgZV)
Unit : mm
Part No.
BM24-10DS/2-0.35V(51)
BM24-20DS/2-0.35V(51)
BM24-24DS/2-0.35V(51)
BM24-30DS/2-0.35V(51)
BM24-40DS/2-0.35V(51)
HRS No.
677-2002-1 51
677-2004-7 51
677-2006-2 51
677-2008-8 51
677-2010-0 51
No. of Contacts
10
30
40
A
5.25
7
7.7
8.75
10.5
B
1.4
3.15
3.85
4.9
6.65
C
5.55
7.3
8
9.05
10.8
Note 1 : Please place orders in full reel quantities.
Note 2 : This connector has no polarity.
D
E
■Header
F
2.02
1.92
P= 0.35
0.12
0.66
0.43
P=0.35±0.01
0.18±0.01
0.18±0.02
Part No.
BM24-20DP/2-0.35V(51)
BM24-24DP/2-0.35V(51)
BM24-30DP/2-0.35V(51)
BM24-40DP/2-0.35V(51)
2.44±0.01
F±0.02
2.44+0.05
P=0.35±0.02
1.46 ‒0.05
F±0.02
1.48±0.01
G±0.01
H±0.01
H±0.02
2.34±0.01
Recommended metal mask dimensions (mask thickness : 100 µm)
G±0.02
1.66±0.01
1.06 ‒0.05
7¤%#%'
%#&)B6M
8¤%#%'
Unit : mm
HRS No.
677-2001-9 51
677-2003-4 51
677-2005-0 51
677-2007-5 51
677-2009-0 51
No. of Contacts
10
30
40
D
4.32
6.07
6.77
7.82
9.57
E
3
4.75
5.45
6.5
8.25
F
1.4
3.15
3.85
4.9
6.65
G
3.73
5.48
6.18
7.23
8.98
H
2.27
4.02
4.72
5.77
7.52
3
Embossed Tape Dimensions (complies with JIS C 0806)
●Receptacle
J-J
J
Ø1
3±
0.2
Ø1.5 feed hole
diameter
Ø80±1
0˚
12
Ø380±2
1.75±0.1
Un-reeling direction
0˚
K
J
2±0.5
0.25±0.1
N±0.5
1.02±0.15
P±1
Unit : mm
Part No.
No. of Contacts
10
24
30
40
L
M
N
P
7.5
16
17.5
21.5
11.5
24
25.5
29.5
2±0.5
Ø1
0˚
12
T±0.3
0˚
Q-Q
Q
12
S±0.1
0.8
0.25±0.1
R
Q
U±0.5
0.87±0.15
Ø1.5 feed hole
diameter
Ø80±1
R-R
Ø380±2
R
0.2
.1
Product label
3±
4±0.1 2±0.1 4±0.1
1±
Ø1.5 +0
●Reel dimensions
1.75±0.1
●Header
Ø2
Product label
K-K
12
L±0.1
K
M±0.3
.1
0.8
1±
Ø2
4±0.1 2±0.1 4±0.1
Ø1.5 +0
●Reel dimensions
V±1
Unit : mm
Part No.
No. of Contacts
10
24
30
40
S
T
U
V
7.5
16
17.5
21.5
11.5
24
25.5
29.5
4
Precautions
1.Recommended solder
temperature profile
MAX 250ç
250
Temperature
(ç)
220
200
Within 60 seconds
180
150
90 to 120 sec
100
50
Room
temperature
100
[Conditions]
1. Peak temperature
2. Heat section
3. Preheat section
4. Number of reflow cycles
150
200
250
300
Heating time (sec)
: Maximum of 250ç
: 220ç min., within 60 seconds
: 150 to 180ç, 90 to 120 seconds
: Maximum of 2 cycles
Note 1 : The temperature refers to the surface temperature of the PCB in the
area of the connector lead.
Note 2 : When you use nitrogen reflow, please mount the product with the
oxygen concentration at a minimum of 1,000 ppm.
Please contact us if the concentration is below 1,000 ppm.
2. Recommended manual
soldering conditions
Soldering iron temperature: 340 ± 10°C ;
Soldering time: within 3 seconds
3. Recommended stencil
thickness and open area
ratio to PCB pattern area
Thickness: 0.1mm
Aperture ratio : 80% on the DS side ; 70% on the DP side
4. Board warpage
A maximum of 0.02mm at the center of the connector relative to each end of
the connector.
5. Cleaning conditions
6. Precautions
Cleaning is not recommended. If you clean this product, please evaluate its
performance before using it.
(Cleaning may impair the mating/unmating properties and lower resistance to
environmental factors)
●Care should be taken when mating/unmating the connector when it is not
mounted on the PCB. This could cause damage or deformation of the contacts.
●Avoid supporting the PCB only with the connectors.
Support it by other means such as bolts, screws, posts, etc.
●Care should be taken that excessive prying mating/unmating could cause
damage.
●In the case of hand soldering, please do not apply any flux, which could
cause flux wicking.
●This product may have slight color differences due to production lot
variability, but this does not the performance.
●Please refer to the next page for precautions regarding mating/unmating.
●Because the product can disengage if dropped (or other impact), and by
FPC routing, it is advised to secure the mated connectors to the board with
housings and cushioning materials.
●Caution! Do not use the connector in non-recommended conditions (i.e.,
rated current, rated voltage, PCB design and operating environment, etc.).
Such usage could lead to material outgassing, ignition, or short-circuit, etc.
Refer to the specifications and the guidelines for board pattern dimensions,
board cautions, and connector treatment.
Pleasae contact Hirose if using the connector under conditions other than
those described in the specifications and the guidelines is being considered.
5
●Handling Precautions when Mating Connectors
BM24−*DS−0.35V
BM24−*DP−0.35V
Do not apply excessive force while positioning the connector for mating.
Too much force will cause damage/shaving of the housing material, and
may lead to a failure in contact resistance and other issues.
Once the positioning for correct mating is obtained, mating height drops
down one stage. There is no movement in the horizontal direction.
Mating should occur at this stage, while taking care that there is no
horizontal movement.
●Handling Precautions when Un-mating Connectors
BM24−*DS−0.35V
BM24−*DP−0.35V
Be sure to unmate the connectors in a straight line direction.
If you are unable to unmate a cnnector in straight line direction due
to a handling issue, pull it out in an oblique direction as shown in the
figure on the left. However, the connector could be broken if there is not
enough support on the FPC. Please account for this during prototyping.
Pitch orientation Correct
Unmating a connector by a corner, as shown in the figure to the
left, could damage the connector and contacts. Never disconnect
connectors using a corner.
Corner orientation Incorrect
Make sure that the FPC has a stiffener of sufficient strength. If the
stiffener is not strong enough, the connector could be broken, as shown
in the figure on the left. It is advised to test the FPCs strength by repeated
mating/unmating cycles.
We recommend the use of a glass epoxy material with a minimum thickness
of 0.3mm, or a stainless steel material with a minimum thickness of 0.2mm.
6
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 03/2016. Contents are subject to change without notice for the purpose of improvements.
