規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
型 號
通用型规格书 电压范围 3-24V
压电有源蜂鸣器(内含驱动电路)
TYPE
: GPD5330L100-3-24V3000
DESCRIPTION : Φ53.0 x H30.5 mm 焊线 L100mm
客戶料號
CUSTOMER NO. :
規 格 書 號
DC3-24V
3000Hz
≥100dB
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.0
2015-8-28
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
審核
承認
TESTED BY
CHECKED BY
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
審查
確認
ISSUED BY
CHECKED BY
APPROVED BY
周明
李林
地址:廣東省東莞市長安鎮上沙第五工业区新春路 1 号新春科技园
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
1/4
DONGGUAN INGHAI ELECTRONICS CO.,LTD
Model NO: GPD5330L100-3-24V3000
A: DIMEMSIONS
Unit: mm
Tolerance:±0.5
B: SPECIFICATIONS
Model NO
GPD5330L120
Rated Voltage
3-24VDC
Operating Voltage
3-25VDC
Max.Rated Current
Max.80mA
Sound Pressure level(dB/min) at 10cm
Min.≥100dB
Resonant Frequency
3000±500Hz
Operating Temperature
-70 ℃~+60 ℃
Storage Temperature
-30 ℃~+70 ℃
Case material and color
ABS / Black
Measuring condition
Part shall be measured under a condition (Temperature: 5~35℃, Humidity: 45%~85%R.H., Atmospheric pressure:
860 ~1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure:
860 ~1060hPa) is regulated to measure.
2/4
C: Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are measured by the
measuring instruments shown below
In the measuring test, buzzer is placed as follows:
D: Typical Frequency Response Curve:
dB
mA
100
80
90
70
dB
80
mA
60
70
50
60
40
3
6
9
12 15 18 21
VDC
3/4
E: Reliability Test
After any following tests the part shall meet specifications without any degradation in
appearance and performance except SPL. SPL shall not deviate more than -10 dB
from the initial value
1.
Ordinary Temperature Life Test
The part shall be subjected to 96 hours at 25±10℃. Input rated voltage
2.
3.
4.
5.
6.
7.
Resonant frequency, 1/2 duty Square wave.
High Temperature Test
The part shall be capable of with standing a storage temperature of +70℃ for 96 hours.
Low Temperature Test
The part shall be capable of with standing a storage temperature of -70℃ for 96 hours.
Humidity Test
Temperature:+40℃±3℃
Relative Humidity:90%~95% Duration: 48 hours
and expose to room temperature for 6 hours
Temperature Shock Test
Temperature:60℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle)
Total cycle: 10 cycles
Drop Test
Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick,
three sides, six plain.)
Vibration Test
Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes
Note:
As this product is not protected from foreign material entering, please make sure that any foreign materials
(e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production
processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it.
4/4
GPD5330L100-24V3000 价格&库存
很抱歉,暂时无法提供与“GPD5330L100-24V3000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+30.78000
- 200+11.91240
- 500+11.50200
- 1000+11.28600
