P1
TAI-TECH
Power Inductor
DFP201610TF-SERIES
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
14/08/13
新 發 行
楊祥忠
詹偉特
林宜蕰
1.1
16/06/27
更新可靠度
楊祥忠
詹偉特
孔妍暄
備
註
www.tai-tech.com.tw
P2
TAI-TECH
Power Inductor
DFP201610TF-SERIES
1. Features
1. This specification applies Low Profile Power Inductors.
2. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Dimension
Halogen
Pb
Halogen-free
Pb-free
B
A
D
E
D
C
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
DFP201610TF
2.0 -0.1/+0.2
1.6 -0.1/+0.2
1.0Max
0.60 ref. 0.80 ref.
Units: mm
3. Part Numbering
DFP
201610 TF
A
B
C
R24
M
D
E
A: Series
B: Dimension
C: Lead Free
Material
D: Inductance
E: Inductance Tolerance
R24=0.24uH
M=±20%
4. Specification
TAI-TECH
Part Number
Test
Frequency
(uH)
(Hz)
DCR
(Ω) typ.
DCR
(Ω) Max.
I sat
(A) typ.
I sat
(A) Max.
I rms
(A) typ
I rms
(A) MAX
DFP201610TF-R24M
0.24
±20%
0.1V/1M
0.023
0.028
5.10
4.50
4.40
3.90
DFP201610TF-R33M
0.33
±20%
0.1V/1M
0.031
0.040
3.90
3.50
3.50
3.10
DFP201610TF-R47M
0.47
±20%
0.1V/1M
0.035
0.042
3.85
3.40
3.30
3.00
DFP201610TF-R68M
0.68
±20%
0.1V/1M
0.046
0.055
3.25
2.80
2.80
2.50
DFP201610TF-1R0M
1.0
±20%
0.1V/1M
0.059
0.072
2.90
2.50
2.40
2.20
DFP201610TF-1R5M
1.5
±20%
0.1V/1M
0.098
0.118
2.30
1.80
2.10
1.80
DFP201610TF-2R2M
2.2
±20%
0.1V/1M
0.141
0.170
2.10
1.70
1.70
1.55
DFP201610TF-4R7M
4.7
±20%
0.1V/1M
0.320
0.384
1.00
0.90
1.00
0.90
Note:
Isat:Based on inductance change (△L/L0:≦30%)@ ambient temp. 25℃
Irms:Based on temperature rise (△T:40℃.)Max
www.tai-tech.com.tw
P3
TAI-TECH
DFP201610TF-R33
0.6
0.3
0.45
Inductance(uH)
Inductance(uH)
DFP201610TF-R24
0.4
0.2
0.1
0.3
0.15
2
3
4
5
2
DCcurrent(A)
1.2
0.6
0.9
0.4
0.2
0.6
0.3
2
3
4
1
DCcurrent(A)
1.5
2
2.5
3
2
2.5
DCcurrent(A)
DFP201610TF-1R0
DFP201610TF-1R5
2
2.8
1.5
2.1
Inductance(uH)
Inductance(uH)
4
DFP201610TF-R68
0.8
Inductance(uH)
Inductance(uH)
DFP201610TF-R47
1
1.4
0.5
0.7
1
1.5
2
2.5
1
DCcurrent(A)
1.5
DCcurrent(A)
DFP201610TF-2R2
DFP201610TF-4R7
4
8
3
6
Inductance(uH)
Inductance(uH)
3
DCcurrent(A)
2
1
4
2
1
1.5
2
2.5
DCcurrent(A)
0.6
DCcurrent(A)
www.tai-tech.com.tw
0.9
1.2
P4
TAI-TECH
5. Material List
No.
Description
Specification
a.
Core
Ferrite Core
b.
Glue
Epoxy with magnetic powder
c
Termination
Tin Pb Free
d
Wire
Enameled Copper Wire
Appearance of exposed wire tolerance limit :
1. Width direction(dimension a):Acceptable when a≦w/2
Nonconforming when a>w/2
2. Length direction(dimension b):Dimension b is not specified.
3. The total area of exposed wire occurring to each sides is
not greater than 50% of coating resin area, and is acceptable.
www.tai-tech.com.tw
P5
TAI-TECH
6. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
HP4284A,CH11025,CH3302,CH1320,CH1320S
Inductance
Refer to standard electrical characteristics list.
DCR
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
Saturation DC Current (Isat) will cause L0
Saturation Current (Isat)
△L≦30% typical.
to drop △L(%)(keep quickly).
Heat Rated Current (Irms) will cause the coil temperature rise
△T(℃) without core loss.
Approximately △T≦40℃
1.Applied the allowed DC current(keep 1 min.).
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature: 125±2℃
Life Test
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Humidity:85±2﹪R.H,
Load Humidity
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Moisture Resistance
Appearance:No damage.
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Thermal
shock
Step2:25±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Vibration
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
www.tai-tech.com.tw
P6
TAI-TECH
Item
Performance
Test Condition
Type
Peak value
(g's)
Normal
duration
(D) (ms)
Wave form
Velocity
change
(Vi)ft/sec
SMD
50
11
Half-sine
11.3
Lead
50
11
Half-sine
11.3
Shock
Bending
Soderability
More than 95% of the terminal electrode should
be covered with solder。
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805:40x100x1.2mm
=0805:1.2mm
0805:1kg ,
很抱歉,暂时无法提供与“DFP201610TF-4R7M”相匹配的价格&库存,您可以联系我们找货
